  3. Fighting off a relay module
3 Posts 3 Posters 1.3k Views 3 Watching
    moskovskiy82
    wrote on last edited by moskovskiy82
    Need a node with a button input (doesn't do anything to relay state) and a single relay. As this is connected to Home Assistant have to provide feedback and present the relay.
    The problem is with the code below it just starts sending the relay state in a loop without stopping.
    mys-out/67/1/1/0/2 1
    Tried everything and seems got stuck somewhere
    #define SN "MYS Vannaya Gidro"
    #define SV "2.1.1"
    //System settings
    #define MY_NODE_ID 67
    #include <Bounce2.h>
    #include <math.h>
    #include <Wire.h>
    //SETUP PINS
    #define BUTTON_PIN1 7
    const int MQ_Pin = A3;
    #define RELAY_1  5
    //Define CHILD_IDS
    #define CHILD_ID_RELAY 1
    #define CHILD_ID_BUT1 2
    #define CHILD_ID_MQ 3
    //Relay VARS
    #define RELAY_ON 1
    #define RELAY_OFF 0
    //SENSORS
    long SENSOR_Millis = 0;
    long SENSOR_interval = 60000;
    //Buttons
    Bounce debouncer1 = Bounce();
    int oldValue1=-1;
    bool state;
    //Messages
    MyMessage msgRelay(CHILD_ID_RELAY, V_STATUS);
    MyMessage msgMQ(CHILD_ID_MQ, V_LEVEL);
    MyMessage msgBut1(CHILD_ID_BUT1,V_TRIPPED);
    //Initial for HA
    bool initialValueSent = false;
    void before()
      pinMode(BUTTON_PIN1, INPUT_PULLUP);
      debouncer1.attach(BUTTON_PIN1);
      debouncer1.interval(5);
      pinMode(RELAY_1, OUTPUT);
      digitalWrite(RELAY_1, loadState(1)?RELAY_ON:RELAY_OFF);
    {  Serial.begin(115200); }
      sendSketchInfo(SN, SV);
      wait(50);
      present(CHILD_ID_RELAY, S_BINARY);
      wait(50);
      present(CHILD_ID_MQ, S_AIR_QUALITY);
      wait(50);
      present(CHILD_ID_BUT1, S_WATER_LEAK);
    if (!initialValueSent)
        send(msgRelay.set(loadState(1)?RELAY_OFF:RELAY_ON));
      unsigned long SENSOR_Current_Millis = millis();
      if((unsigned long)(SENSOR_Current_Millis - SENSOR_Millis) >= SENSOR_interval)
        SENSOR_Millis = SENSOR_Current_Millis;
        float mq_reading = analogRead(MQ_Pin);
        send(msgMQ.set(mq_reading, 1));
        debouncer1.update();
          int value = debouncer1.read();
          if (value != oldValue1)
            // Send in the new value
            send(msgBut1.set(value==HIGH ? 1 : 0));
            oldValue1 = value;
      if (message.type==V_STATUS)
          initialValueSent = true;
         // Update relay state to HA
      state = message.getBool();
      digitalWrite(RELAY_1, state?RELAY_ON:RELAY_OFF);
      saveState(CHILD_ID_RELAY, state);
      send(msgRelay.set(state?RELAY_ON:RELAY_OFF));
    Boots33B martinhjelmareM 2 Replies Last reply
    • M moskovskiy82
      #define SV "2.1.1"
      //System settings
      #include <math.h>
      #include <Wire.h>
      //SETUP PINS
      #define RELAY_1  5
      //Define CHILD_IDS
      //Relay VARS
      #define RELAY_ON 1
      #define RELAY_OFF 0
      //SENSORS
      //Buttons
      int oldValue1=-1;
      bool state;
      //Messages
      //Initial for HA
      void before()
        wait(50);
        wait(50);
        wait(50);
              oldValue1 = value;
      Boots33B
      Boots33B
      Boots33
      @moskovskiy82
      you could try
      or perhaps
          send(msgRelay.set(loadState(1)?RELAY_OFF:RELAY_ON), true);
      • M moskovskiy82
        #define SV "2.1.1"
        //System settings
        #include <math.h>
        #include <Wire.h>
        //SETUP PINS
        #define RELAY_1  5
        //Define CHILD_IDS
        //Relay VARS
        #define RELAY_ON 1
        #define RELAY_OFF 0
        //SENSORS
        //Buttons
        int oldValue1=-1;
        bool state;
        //Messages
        //Initial for HA
        void before()
          wait(50);
          wait(50);
          wait(50);
                oldValue1 = value;
        martinhjelmareM
        martinhjelmareM
        martinhjelmare
        @moskovskiy82
        Add a wait call after sending the initial value. I don't understand why you want to invert the saved state before sending it to the controller.
