  3. Connenct a RS485 Network to a NodeMCU Gateway?
6 Posts 3 Posters 4.6k Views 4 Watching
  • ThomasDrT Offline
    ThomasDrT Offline
    ThomasDr
    where connect the Pins DI, DE, RE, RO on the NodeMCU?
    And how do I define the pins in the sketch?
    regards
    ThomasD
    • rejoe2R Offline
      rejoe2R Offline
      rejoe2
      Just some guesses:
      The PIN assignment for arduino nano is due to the use of altsoftserial lib.
      Most likely you may rather use hardware serial on ESP8266. See http://esp8266.github.io/Arduino/versions/2.3.0/doc/reference.html for the relevant PINs on the ESP (most likely serial0 is the better choice).
      Connect DE-RE (linked together) to any interrupt-capable PIN and adopt sketch accordingly.
      Btw: What is your motivation to build a wired network and then connect the whole thing wirelessly to your controller? (I personally try to get rid of all RF transmissions, so this is why I use RS485 as preferred transport layer and connect the whole thing via USB...)
      ThomasDrT 1 Reply Last reply
        it's a similar setup of what I am planning to do: I'd prefer the rs485 for the security sensors as it can't be jammed and since I'm going to have powered sensors it is not a big issue to have an additional cable.
        • rejoe2R rejoe2
          Just some guesses:
          ThomasDrT Offline
          ThomasDrT Offline
          ThomasDr
          @rejoe2 said in Connenct a RS485 Network to a NodeMCU Gateway?:
          Just some guesses:
          i will build a few Sensors in the yard and i thing the best way to connect these Sensor Array to the Controller is WIFI.
          regards
          ThomasD
          rejoe2R 1 Reply Last reply
          • ThomasDrT ThomasDr
            Just some guesses:
            regards
            ThomasD
            rejoe2R Offline
            rejoe2R Offline
            rejoe2
            @ThomasDr Thx for info.
            So using wires to connect also teh GW seems not to be an option. And why do you not plan a entirely wireless infrastructure and - if really needed - a repeater node instead of the NodeMCU for the wireless bridge in the house? Especially: RFM69@868MHz should have better range than wifi. To address security related troubles also signing etc. could be used.
            • rejoe2R rejoe2
              ThomasDrT Offline
              ThomasDrT Offline
              ThomasDr
              @rejoe2
              I'm assuming the Wifi is the best solution, but if RF868 would be better I'll look at it again.
              I also have a couple Xbee module Series 1, could you start something else?
              Perhaps also an idea add Xbee to the Mysensor API.
              regards
              ThomasD
