  3. [SOLVED] Node Sensor affecting local sensors on GW.
7 Posts 3 Posters 2.5k Views 4 Watching
  • korttomaK
    korttomaK
    korttoma
    MySensors Lib version 2.1.1
    I have a RFM69 Ethernet GW to witch I have also connected 4 relays with buttons. Like this:
     * Version 1.0 - Henrik EKblad
     * Contribution by Tomas Hozza <thozza@gmail.com>
     * LED purposes:
    //#define MY_DEBUG
    #define SN "EthGW/RFM69 Rele Button"
    #define SV "1.1"
    //#define MY_RADIO_NRF24
    #define MY_RADIO_RFM69
    #define MY_IS_RFM69HW
    #define MY_RF69_SPI_CS 4
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 10
    // radio on the same spi bus.
    // Enable to UDP
    //#define MY_USE_UDP
    #define MY_IP_ADDRESS 192,168,1,100   // If this is disabled, DHCP is used to retrieve address
    #define MY_PORT 5003
    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
    #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xED, 0xED
    // Flash leds on rx/tx/err
    //#define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // Enable inclusion mode
    //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
    #if defined(MY_USE_UDP)
      #include <EthernetUdp.h>
    #include <Ethernet.h>
    #include <Bounce2.h>
    #define RELAY_ON 0                      // switch around for ACTIVE LOW / ACTIVE HIGH relay
    #define RELAY_OFF 1
    #define noRelays 4                     //2-4
    const int relayPin[] = {14, 15, 16, 17};       //  switch around pins to your desire
    const int buttonPin[] = {7, 8, 5, 6};   //  switch around pins to your desire
    class Relay             // relay class, store all relevant data (equivalent to struct)
      public:
        int buttonPin;                   // physical pin number of button
        int relayPin;             // physical pin number of relay
        boolean relayState;               // relay status (also stored in EEPROM)
    Relay Relays[noRelays];
    Bounce debouncer[noRelays];
    MyMessage msg[noRelays];
      wait(100);
      // Initialize Relays with corresponding buttons
      for (int i = 0; i < noRelays; i++) {
        Relays[i].buttonPin = buttonPin[i];              // assign physical pins
        Relays[i].relayPin = relayPin[i];
        msg[i].sensor = i;                                   // initialize messages
        msg[i].type = V_LIGHT;
        pinMode(Relays[i].buttonPin, INPUT_PULLUP);
        wait(100);
        Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
        digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
        send(msg[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
        wait(50);
        debouncer[i] = Bounce();                        // initialize debouncer
        debouncer[i].attach(buttonPin[i]);
        debouncer[i].interval(30);
        wait(50);
      sendSketchInfo(SN, SV);
      wait(100);
        present(i, S_LIGHT);                               // present sensor to gateway
      wait(100);
      for (byte i = 0; i < noRelays; i++) {
        if (debouncer[i].update()) {
          int value = debouncer[i].read();
          if ( value == LOW) {
            // save sensor state in EEPROM (location == sensor number)
            saveState( i, Relays[i].relayState );
      //wait(20);
        if (message.sensor < noRelays) {          // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
          digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
          saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
      wait(20);
    Now I added a node (Node 103) to the network with a similar setup:
       The MySensors Arduino library handles the wireless radio link and protocol
       between your home built sensors/actuators and HA controller of choice.
       The sensors forms a self healing radio network with optional repeaters. Each
       repeater and gateway builds a routing tables in EEPROM which keeps track of the
       network topology allowing messages to be routed to nodes.
       Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
       Copyright (C) 2013-2015 Sensnology AB
       Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
       Documentation: http://www.mysensors.org
       Support Forum: http://forum.mysensors.org
       This program is free software; you can redistribute it and/or
       modify it under the terms of the GNU General Public License
       version 2 as published by the Free Software Foundation.
       REVISION HISTORY
       Version 1.0 - Henrik Ekblad
       DESCRIPTION
       Example sketch showing how to control physical relays.
       This example will remember relay state after power failure.
       http://www.mysensors.org/build/relay
    //#define MY_DEBUG
    // Define a static node address, remove if you want auto address assignment
    #define MY_NODE_ID 103
    #define SN "HAButtDoorLock"
    #define SV "1.0"
    #define RELAY_ON 1                      // switch around for ACTIVE LOW / ACTIVE HIGH relay
    #define RELAY_OFF 0
    #define CHILD_ID_DOOR 4   // Id of the sensor child
    #define CHILD_ID_LOCK 5   // Id of the sensor child
    const int relayPin[] = {14, 16, 15, 17};       //  switch around pins to your desire
    const int buttonPin[] = {7, 5, 6, 4};   //  switch around pins to your desire
    #define DIGITAL_INPUT_DOOR 3   // The digital input you attached your motion sensor.
    #define DIGITAL_INPUT_LOCK 8   // The digital input you attached your motion sensor.
    //define what is on and off for the reed switches
    #define DOOR_CLOSED 0
    #define DOOR_OPEN 1
    #define DOOR_LOCKED 1
    #define DOOR_UNLOCKED 0
      public:
    MyMessage msgDoor(CHILD_ID_DOOR, V_TRIPPED);
    MyMessage msgLock(CHILD_ID_LOCK, V_LOCK_STATUS);
    // Storage of old status
    int oldDoorValue=-1;
    int oldLockValue=-1;
     * Setup code
      wait(100);
        wait(100);
        wait(50);
        wait(50);
      // Setup the door sensor
      pinMode(DIGITAL_INPUT_DOOR,INPUT);
        // Setup the interupt pin
      pinMode(DIGITAL_INPUT_LOCK,INPUT);
      //pinMode(DIGITAL_INPUT_INT,INPUT);
      // Activate internal pull-up
      digitalWrite(DIGITAL_INPUT_DOOR,HIGH);
      digitalWrite(DIGITAL_INPUT_LOCK,HIGH);
      //digitalWrite(DIGITAL_INPUT_INT,LOW);
      wait(100);
      wait(100);
      present(CHILD_ID_DOOR, S_DOOR);
      present(CHILD_ID_LOCK, S_LOCK);
     *  Main loop function
      int DoorValue = digitalRead(DIGITAL_INPUT_DOOR);
      if (DoorValue != oldDoorValue) {
         // Send in the new value
         wait(300);
         send(msgDoor.set(DoorValue ? DOOR_OPEN : DOOR_CLOSED));
         oldDoorValue = DoorValue;
      wait(20);
      int LockValue = digitalRead(DIGITAL_INPUT_LOCK);
      if (LockValue != oldLockValue) {
         wait(300);
         send(msgLock.set(LockValue ? DOOR_UNLOCKED : DOOR_LOCKED));
         oldLockValue = LockValue;
      wait(20);
      //wait(20);
      wait(30);
    The problem now is that when I push a button on the Node and the Node sends the new state to the GW the relays on the GW change state. So how do I need to change the "Receive" function on the GW to prevent this from happening?
    Sorry that I don't have any communication logs from this since I did not expect any issues with it so I did not test it on the bench before installing it where is should be and now it is not so simple to get communication logs.
    • Tomas
    • rejoe2R
      rejoe2R
      rejoe2
      Not tested, but kind of a bet:
      there seems to be also a "message.destination". So you could change the GW-code within the receive function to also ask whether the sensor is on the node ( && message.destination == 0) or anywhere else.
      But that's just a workaround and may also be nevessary for repeater nodes...
      korttomaK 1 Reply Last reply
      • rejoe2R rejoe2
        korttomaK
        korttomaK
        korttoma
        @rejoe2 I saw the "message.destination" but is not the destination of the message sent by Node 103 always = 0 when it sends the new status to the controller? Is there any way to filter the received messages by the source?
        • Tomas
        • korttomaK korttoma
          @korttoma try message.sensor or message.sender
          I am not sure how they differ
            korttomaK
            korttomaK
            korttoma
            I guess that message.sensor is for the child sensors on the node and as you can see this is already used in the receive function on the GW.
            The problem is that I'm using the same sensor IDs on both the remote Node and the GW.
            One solution would be to change the sensor IDs on the GW and use message.sensor but I was trying to find another solution first and the message.sender looks like it might be what I'm looking for.
            Thanks @mfalkvidd , I knew I could count on you to know something I have missed from the protocol API.
            I will try the following on the GW (seems to compile fine):
              if (message.sender == 0) {
              wait(20);
            • Tomas
            • korttomaK
              korttomaK
              korttoma
              I'm glad to confirm that using the filtering in my previous post solved my issue.
              Now the relays on the GW only operate from controller commands an not from status updates from Node 103. Thanks again @mfalkvidd !
              • Tomas
                Great work @korttoma
                Thanks for reporting back!
