  3. Problem Gateway and Node
6 Posts 3 Posters 2.0k Views 3 Watching
  • P Offline
    P Offline
    Philippe 57
    Hello everyone
    I come back to you because I can no longer operate my gateway, I explain:
    here is the log of starting my gateway:
    0 MCO:BGN:INIT GW,CP=RNNGA---,VER=2.2.0-beta
    3 TSM:INIT
    4 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSM:INIT:GW MODE
    15 TSM:READY:ID=0,PAR=0,DIS=0
    17 MCO:REG:NOT NEEDED
    IP: 192.168.20.210
    1320 MCO:BGN:STP
    1323 MCO:BGN:INIT OK,TSP=1```
    Insert Code Here
    until all is well (finally I think)
    but the gateway stays as it does not communicate it sends nothing to the node
    here is the code:
     * Version 1.0 - Henrik EKblad
     * Contribution by Tomas Hozza <thozza@gmail.com>
     * LED purposes:
     * - To use the feature, uncomment MY_DEFAULT_xxx_LED_PIN in the sketch below
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
    #define MY_IP_ADDRESS 192,168,20,210
    #define MY_IP_GATEWAY_ADDRESS 192,168,20,254
    #define MY_PORT 5003
    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    but I do not see why because my node sends a lot of info, I even put capacitor for the 3.3V but the same
    I changed several times RF module and the same
    a yes from time to time I have this:
    900005 TSF:SAN:OK
    Thank you for your help
    • scalzS Offline
      scalzS Offline
      wrote on last edited by scalz
      @Philippe-57
      Hello.
      Could you provide some more infos, please, so it's easier for people to help you (i quickly saw your other post on jeedom which has a bit more infos than here ;) )
      • hardware for gw and node. How it's wired. A photo can sometimes help too.
      • sketch used for both, and the version of MySensors used.
      • logs for both
      • could you do a cleareeprom for gw and node before retrying
      Then we can try to replicate your setup and check if it's hardware or software related
      • M Offline
        M Offline
        manutremo
        There doesn't seem to be anything wrong on the limited piece of log you post.
        Regarding "the gateway stays as it does not communicate it sends nothing to the node" - what do you mean exactly? Usually communication is the other way around, that is, the node sends something to the gateway, then the gateway responds. If the gw doesn't receive anything from a node, it will communicate nothing (except from periodical heartbeats to the controller, the sanity check results and maybe something else).
        • M Offline
          M Offline
          manutremo
          By the way - I also had many issues getting two modules to talk at the beginning, and after checking countless things what I finally found is that they were just too close to each other (I was building and testing them on the same table). Once I separated them by 2-3m they started to talk. Setting them to high power while they are too close together causes them to "shout" too much so they can't talk.
          You may want to try reducing the tx power by using the define MY_RF24_PA_LEVEL. This is setup to RF24_PA_MAX as default, you can try to reduce it to one of the lower power options RF24_PA_MIN, RF24_PA_LOW, RF24_PA_HIGH. The MIN option should be enough when modules are some meters appart.
          During testing, it might also be useful to reduce the communication speed by using the MY_RF24_DATARATE define. Once they work together in test conditions, you may then increase the distance, power and speed. There is a very useful sketch around which continuously shows the number of lost packets as a measure of link quality which can be helpful on setting the right power settings for your home size.
          • P Offline
            P Offline
            Philippe 57
            @manutremo said in Problem Gateway and Node:
            hello and thanks again for your help
            after the modifications of the LEVEL, I still have the same problem
            here is the debug of the node:
             __  __       ____
                    |___/                      2.2.0-beta
            17 MCO:BGN:INIT REPEATER,CP=RNNRA---,VER=2.2.0-beta
            26 MCO:BGN:BFR
            28 TSM:INIT
            29 TSF:WUR:MS=0
            36 TSM:INIT:TSP OK
            37 TSM:FPAR
            40 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            2048 !TSM:FPAR:NO REPLY
            2050 TSM:FPAR
            2052 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            4060 !TSM:FPAR:NO REPLY
            4062 TSM:FPAR
            4064 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            6072 !TSM:FPAR:NO REPLY
            6074 TSM:FPAR
            6076 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            8084 !TSM:FPAR:FAIL
            8085 TSM:FAIL:CNT=1
            8087 TSM:FAIL:DIS
            8089 TSF:TDI:TSL
            and here is the debug of the gateway:
            3 TSM:INIT
            4 TSF:WUR:MS=0
            11 TSM:INIT:TSP OK
            13 TSM:INIT:GW MODE
            IP: 192.168.20.210
            1320 MCO:BGN:STP
            the code of the node:
             * Version 1.0 - Henrik Ekblad
            #define MY_RF24_PA_LEVEL RF24_PA_MIN
            #define MY_REPEATER_FEATURE
            void before()
            		pinMode(pin, OUTPUT);
            		present(sensor, S_BINARY);
            	if (message.type==V_STATUS) {
            		// Change relay state
            		// Store state in eeprom
            		// Write some debug info
            		Serial.print(message.sensor);
            the code of the gateway:
             * LED purposes:
            #define MY_SOFTSPI
            • M Offline
              M Offline
              manutremo
              Hi, the node log shows that it is unable to find a parent (the gw). This could be caused by several causes. It is difficult to troubleshoot at this point, assuming all the power and stability requirements from the radios are met, I would propose go back to the initial step, check everything and start from 0, even loading another nrf24l01 library and run a ping pong test or a similar simple sketch that allows you to discard sw problems and can confirm If all the hw is working correctly, including the wiring. Sorry to not be of more help.
              11.9k
              113.3k
