  3. No controller, no gateway | passive node
11 Posts 2 Posters 4.2k Views 2 Watching
  • berkseoB
    berkseoB
    berkseo
    wrote on last edited by berkseo
    bool state = true;
    #define MY_NODE_ID 101
    #define MY_PASSIVE_NODE
    #define BUTTON 1
    MyMessage msg(BUTTON,V_STATUS);
      present(BUTTON,  S_BINARY);
      sendSketchInfo("TEST BUTTON", "1.1");
      Serial.begin(115200);
    Serial.println(" SEND HELLO ");
    send(msg.setDestination(100).setSensor(1).set(state));
      delay(5000);
      Serial.println("Hello is delivered");
    bool state = true;
    #define MY_NODE_ID 100
    #define RELAY 1
    MyMessage msg(RELAY,V_STATUS);
      present(RELAY, S_BINARY);
      sendSketchInfo("TEST RELAY", "1.1");
    send(msg.setDestination(101).setSensor(1).set(state));
      delay(5000);
      So are you basically sending a message from one node to the other without gateway, right?
      • berkseoB
        berkseoB
        berkseo
        Yes, You are right. This is a simple example of sending and receiving messages between two nodes without the participation of the gateway.
          It is one way communication only? Like a garage door/gate 433mhz remote
          berkseoB 1 Reply Last reply
            berkseoB
            berkseoB
            berkseo
            @gohan You can send and receive messages in both directions. It all depends on how it will be implemented in the sketch. You can use more than two nodes. I would use it in case of a gateway failure. This will preserve the basic functionality of the device. For example, a light switch that is physically divided into two nodes. On one node, the touch panel on the other relay node controls the light. There can be a lot of use cases.
              Could you please post the code for everyone?
                berkseoB
                berkseoB
                berkseo
                @gohan Of course, everything is simple there, uses one public function.
                  I know it is just to keep a reference here on the forum and for others less expert in programming that would like to see the actual code :wink:
                    berkseoB
                    berkseoB
                    berkseo
                    @gohan said in no controller, no gateway:
                    ready, in the first post
                      you didn't put the "MY_PARENT_NO_ID 100" that I saw in the video: is it ok?
                        berkseoB
                        berkseoB
                        berkseo
                        yes this is normal, this def is not needed. just forgot to delete when recording a video
                        two-way sending is done in the above application, this is also not in the video. you just asked about it earlier.
