  3. What settings for ESP8266 Node?
2 Posts 2 Posters 1.3k Views 3 Watching
  • siodS
    siodS
    siod
    I would like to convert the below sketch to a ESP8266 /WeMos D1 Mini compatible sketch. Do I have to change MY RADIO NRF24 to ESP8266 or sth like that? PS I am using MQTT and Openhab 2...
     * IRremote: IRsendDemo - demonstrates sending IR codes with IRsend
     * An IR LED must be connected to Arduino PWM pin 3.
     * Version 0.1 July, 2009
     * Copyright 2009 Ken Shirriff
     * http://arcfn.com
    // Define Node ID
    #define MY_NODE_ID 5
    //#define MY_PARENT_NODE_ID 50 //Repeater Node 1!
    //#define MY_PARENT_NODE_IS_STATIC
    #include <IRremote.h>
    IRsend irsend;
    // Initialize message
    MyMessage msg(CHILD_ID, V_IR_SEND);
      Serial.begin(9600);
        sendSketchInfo("LED Licht TV Steuerung", "1.0");
        present(CHILD_ID, S_IR);
       Serial.println(F("Incoming Message:"));
       Serial.println(message.getString());
      if (message.type == V_IR_RECEIVE) {
        // Send command to Turn LEDs On
        if (message.getString("anaus")) {
        for (int i = 0; i < 3; i++) {
            irsend.sendNEC(0xFF02FD, 32);
            Serial.println("Message sent");
            delay(40);
            // Send command to Turn LEDs Red
        else if (message.getString("rot")) {
            irsend.sendNEC(0xFF1AE5, 32);
            delay(40);
            // Send command to Turn LEDs green
        else if (message.getString("gruen")) {
            irsend.sendNEC(0xFF9A65, 32);
            delay(40);
                // Send command to Turn LEDs blue
        else if (message.getString("blau")) {
            irsend.sendNEC(0xFFA25D, 32);
            delay(40);
                    // Send command to Turn LEDs white
        else if (message.getString("weiss")) {
            irsend.sendNEC(0xFF22DD, 32);
            delay(40);
                        // Send command to Turn LEDs faster
        else if (message.getString("schneller")) {
            irsend.sendNEC(0xFFE817, 32);
            delay(40);
                            // Send command to Turn LEDs slower
        else if (message.getString("langsamer")) {
            irsend.sendNEC(0xFFC837, 32);
            delay(40);
                   // Send command to Turn LEDs brighter
        else if (message.getString("heller")) {
            irsend.sendNEC(0xFF3AC5, 32);
            delay(40);
            // Send command to Turn LEDs darker
        else if (message.getString("dunkler")) {
            irsend.sendNEC(0xFFBA45, 32);
            delay(40);
                // Send command to Turn LEDs Fade7
        else if (message.getString("fade7")) {
            irsend.sendNEC(0xFFE01F, 32);
            delay(40);
                    // Send command to Turn LEDs flash
        else if (message.getString("flash")) {
            irsend.sendNEC(0xFFD02F, 32);
            delay(40);
        // Send command to Turn LEDs Jump7
        else if (message.getString("jump")) {
            irsend.sendNEC(0xFFA05F, 32);
            delay(40);
        else{
          // if nothing else matches, do the default
          // default is optional
          Serial.println("Nicht belegt");
    still learning...
      It depends if you want it connected via wifi or via nrf24, if the second just leave the nrf24 define
