  3. [SOLVED] ESP8266 Inclusion Issue
4 Posts 2 Posters 1.4k Views 2 Watching
  • R
    R
    RWoerz
    I was running a UNO and a 5100 Ethernet shield as a GW but some of my sensors were to far away to work so I'm trying to use a ESP8266 as a GW. After bringing it up inclusion didn't work but I was getting an update from a temp sensor on the Vera. I then removed the MySensors plugin and load all the latest files in the Vera. I'm running MySensors 2.1.1 I downloaded yesterday. On the Vera neither of the Start or Stop buttons are lite. The Start or Stop buttons light only as long a I hover over them and pressing the start button I get a wait symbol for 2 or 3 seconds but that's it. When I press the inclusion button on the GW I don't see any changes. This is the startup log of the GW, sensor 25 is already running and I pressed the inclusion button on the GW and started sensor 6. I can't tell why inclusion isn't working. The Vera is IP is 192.168.0.48. The GW Sketch is included at the end.
    scandone
    f 0, scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 9
    cnt
    connected with RWCL, channel 1
    ip:192.168.0.137,mask:255.255.255.0,gw:192.168.0.1
    .IP: 192.168.0.137
    0;255;3;0;9;MCO:BGN:STP
    0;255;3;0;9;TSF:MSG:READ,25-25-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSF:MSG:BC
    0;255;3;0;9;TSF:MSG:FPAR REQ,ID=25
    0;255;3;0;9;TSF:CKU:OK,FCTRL
    0;255;3;0;9;TSF:MSG:GWL OK
    0;255;3;0;9;TSF:MSG:SEND,0-0-25-25,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    0;255;3;0;9;TSF:MSG:READ,25-25-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    0;255;3;0;9;TSF:MSG:PINGED,ID=25,HP=1
    0;255;3;0;9;TSF:MSG:SEND,0-0-25-25,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
    0;255;3;0;9;TSF:MSG:READ,25-25-0,s=32,c=1,t=45,pt=7,l=5,sg=0:79.9
    0;255;3;0;9;TSF:MSG:READ,25-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0:79.7
    0;255;3;0;9;TSF:MSG:READ,25-25-0,s=4,c=1,t=0,pt=7,l=5,sg=0:68.9
    0;255;3;0;9;TSF:MSG:READ,25-25-0,s=1,c=1,t=0,pt=7,l=5,sg=0:72.5
    0;255;3;0;9;TSF:MSG:READ,25-25-0,s=2,c=1,t=0,pt=7,l=5,sg=0:64.4
    0;255;3;0;9;TSF:MSG:READ,25-25-0,s=12,c=1,t=34,pt=7,l=5,sg=0:2.0
    0;255;3;0;9;TSF:MSG:READ,25-25-0,s=11,c=1,t=4,pt=7,l=5,sg=0:80.7
    0;255;3;0;9;TSF:MSG:READ,25-25-0,s=3,c=1,t=0,pt=7,l=5,sg=0:83.3
    0;255;3;0;9;TSF:MSG:READ,25-25-0,s=13,c=1,t=2,pt=2,l=2,sg=0:1
    pm open,type:2 0
    0;255;3;0;9;TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSF:MSG:FPAR REQ,ID=1
    0;255;3;0;9;TSF:PNG:SEND,TO=0
    0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    0;255;3;0;9;TSF:MSG:PINGED,ID=1,HP=1
    0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=0,t=17,pt=0,l=10,sg=0:2.0.1-beta
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
    0;255;3;0;9;TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSF:MSG:FPAR REQ,ID=6
    0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    0;255;3;0;9;TSF:MSG:PINGED,ID=6,HP=1
    0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
    0;255;3;0;9;TSF:MSG:READ,25-25-0,s=11,c=1,t=4,pt=7,l=5,sg=0:68.3
    0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
    0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
    0;255;3;0;9;!TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=11,pt=0,l=22,sg=0:TemperatureAndHumidity
    0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
    0;255;3;0;9;TSF:MSG:READ,6-6-0,s=0,c=0,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
    0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
    0;255;3;0;9;TSF:MSG:READ,6-6-0,s=1,c=1,t=0,pt=7,l=5,sg=0:79.0
    0;255;3;0;9;TSF:MSG:READ,6-6-0,s=0,c=1,t=1,pt=7,l=5,sg=0:29.2
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=11,pt=0,l=18,sg=0:Temperature Sensor
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
    0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:72.5
    0;255;3;0;9;TSF:MSG:READ,25-25-0,s=11,c=1,t=4,pt=7,l=5,sg=0:66.3
     * Version 1.0 - Henrik EKblad
     * Contribution by Ivo Pullens (ESP8266 support)
     * The EthernetGateway sends data received from sensors to the WiFi link.
     * VERA CONFIGURATION:
     * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
     * E.g. If you want to use the defualt values in this sketch enter: 192.168.178.66:5003
     * LED purposes:
     * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
     * GND        GND
      * Inclusion mode button:
    #define LED_BUILTIN D4
    #define D0 16  // GPIO16
    #define D1 5   // GPIO5 I2C Bus SCL (clock)
    #define D2 4   // GPIO4 I2C Bus SDA (data)
    #define D3 0   // GPIO0
    #define D4 2   // GPIO2 Same as "LED_BUILTIN", but inverted logic
    #define D5 14  // GPIO14 SPI Bus SCK (clock)
    #define D6 12  // GPIO12 SPI Bus MISO
    #define D7 13  // GPIO13 SPI Bus MOSI
    #define D8 15  // GPIO15 SPI Bus SS (CS)
    #define D9 3   // GPIO3 RX0 (Serial console)
    #define D10 1  // GPIO1 TX0 (Serial console)
    #define MY_BAUD_RATE 115200
    #define MY_GATEWAY_ESP8266
    #define MY_ESP8266_SSID "RWCL"
    #define MY_ESP8266_PASSWORD "xxxxxxxxx"
    // Enable UDP communication
    #define MY_USE_UDP
    #define MY_ESP8266_HOSTNAME "sensor-gateway"
    #define MY_IP_ADDRESS 192,168,0,137
    #define MY_IP_GATEWAY_ADDRESS 192,168,0,1
    #define MY_PORT 5003
    #define MY_CONTROLLER_IP_ADDRESS 192,168,0,48
    // Enable inclusion mode
    #define MY_INCLUSION_MODE_DURATION 120
    // Digital pin usef for inclusion LED
    // Set blinking period
    #define MY_WITH_LEDS_BLINKING_INVERSE
    // Flash leds on rx/tx/err
    // Led pins used if blinking feature is enabled above
    #define MY_DEFAULT_ERR_LED_PIN D0  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  D4  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  D1  // the PCB, on board LED
    #if defined(MY_USE_UDP)
    #include <WiFiUdp.h>
    #include <ESP8266WiFi.h>
    • R
      R
      RWoerz
      Problem resolved.
      YveauxY 1 Reply Last reply
      • R RWoerz
        Problem resolved.
        YveauxY
        YveauxY
        @RWoerz Great to hear you solved it!
        What did you do/fix? Please share, so others can learn from it!
        • R
          R
          RWoerz
          Let me start by saying I made some incorrect assumptions. If you look I assigned an IP address to the device and to the MY_CONTROLLER_IP_ADDRESS which I thought was necessary so it could find my Vera. It talks about the fact that by assigning an IP address to it it changed it from Server to Client mode which I couldn't find much info on. You have to know I'm a hardware guy. I know just enough software to be dangerous. I think it was this change that kept it from working.
          The way I had it configured wireshark showed the ESP8266 only sent out one packet after being powered up, after that nothing. I was able to telnet to it on port 5003 but basically got nothing. After commenting out the MY_CONTOLLER_IP_ADDRESS when I telneted to it I saw a stream of sensor data. It seems a bit counterintuitive but in this mode it looks like my Vera was connecting to the GW and watching the data stream. That's a WAG on my part but it seems logical at this point.
          Now I hope someone can give me some help on my Senesebender Micro issue.
