  3. Node-RED
  4. Extract sensor values in Node-red
Scheduled Pinned Locked Moved Node-RED
23 Posts 5 Posters 13.7k Views 8 Watching
  • tbowmoT tbowmo
    @scottdube
    Sorry I don't have more documentation at hand, than what is in the mysensors npm module already. But basically I use the switch node to route messages, on subtype, then on nodeId, and last on childId.
    I'm currently remodeling my node-red setup.. Moving everything to MQTT for internal message distribution between all parts (both within node-red and to external systems).
    scottdube
    @tbowmo Thank you, would it be possible to get that flow? I have not been successful building it myself.
    Thanks for your work on this!
    • tbowmoT
      tbowmoT
      tbowmo
      @scottdube
      I have put my nodered flows on github as a project, where you can clone from, find it at https://github.com/tbowmo/nodered-mysensors-flow
      Please note that this is taylored specifically to my usage, but could be used as an inspiration..
      (In nodered 0.18.x they have added possibility to have multiple projects, including git and github integration)
      S 1 Reply Last reply
      • tbowmoT tbowmo
        @scottdube
        scottdube
        @tbowmo Thank you! I am needing the inspiration! :)
