  3. Node-RED
  4. Extract sensor values in Node-red
Scheduled Pinned Locked Moved Node-RED
23 Posts 5 Posters 13.9k Views 8 Watching
  • lozzer65L
    lozzer65L
    lozzer65
    Hi All
    I am having a go with Node-red. I have several temp sensors which I know are working as they are on home assistant. I know I am getting the values into Node-red using the debug.
    This is an example of the info coming in.
    msg.payload : string[15]
    "2;0;1;0;0;19.1↵"
    29/10/2017, 09:51:23node: 4764cb04.8ff4a4
    "2;1;1;0;0;16.9↵"
    msg.payload : string[16]
    "67;0;1;0;0;63.0↵"
    msg.payload : string[18]
    "0;255;3;0;2;2.1.1↵"
    29/10/2017, 09:51:26node: 4764cb04.8ff4a4
    "67;0;1;0;0;62.5↵"
    29/10/2017, 09:51:33node: 4764cb04.8ff4a4
    29/10/2017, 09:51:41node: 4764cb04.8ff4a4
    "2;0;1;0;0;19.0↵"
    29/10/2017, 09:51:43node: 4764cb04.8ff4a4
    29/10/2017, 09:51:53node: 4764cb04.8ff4a4
    29/10/2017, 09:51:54node: 4764cb04.8ff4a4
    "2;1;1;0;0;16.8↵"
    29/10/2017, 09:52:03node: 4764cb04.8ff4a4
    29/10/2017, 09:52:13node: 4764cb04.8ff4a4
    29/10/2017, 09:52:23node: 4764cb04.8ff4a4
    29/10/2017, 09:52:31node: 4764cb04.8ff4a4
    "2;0;1;0;0;19.1↵"
    29/10/2017, 09:52:34node: 4764cb04.8ff4a4
    29/10/2017, 09:52:39node: 4764cb04.8ff4a4
    "67;5;1;0;0;27.0↵"
    29/10/2017, 09:52:41node: 4764cb04.8ff4a4
    "67;5;1;0;0;27.5↵"
    So I want to separate the information so that I can show a gauge and graph and use in a thermostat. so nodeId 67 childSensorId 0 is a sensor I want the value for, and also nodeId 67 childSensorId 5. I have tried with this script in a function, but it does not output anything.
    if (msg.payload.nodeId == 67 && msg.payload.childSensorId === 0) {
    var msg;
    msg.payload = msg.payload.value;
    msg.topic = "Temperature";
    return msg;
    Could someone point me in the right direction to what i am doing wrong.
    gohanG 1 Reply Last reply
    • lozzer65L lozzer65
      Hi All
      "2;0;1;0;0;19.1↵"
      "2;1;1;0;0;16.9↵"
      "67;0;1;0;0;63.0↵"
      "67;0;1;0;0;62.5↵"
      "2;0;1;0;0;19.0↵"
      "2;1;1;0;0;16.8↵"
      "2;0;1;0;0;19.1↵"
      "67;5;1;0;0;27.0↵"
      "67;5;1;0;0;27.5↵"
      var msg;
      return msg;
      @lozzer65 have you tried the mysensors nodes?
      • lozzer65L
        lozzer65L
        lozzer65
        Hi
        Yes I have. They just seem to to reformat the whole data. I just want to extract the temp value from each sensor to display in a gauge and a graph.
          Are you using mqtt gateway or ethernet?
          lozzer65L 1 Reply Last reply
            lozzer65L
            lozzer65L
            lozzer65
            @gohan Ethernet gateway. As you can see above I have data. Just can't seem to extract the temp value for each sensor to make it usable for a gauge and graph
              If you switch to mqtt gateway, you could just link the gauge to the topic of the sensor and you are done
                lozzer65L
                lozzer65L
                lozzer65
                @gohan Hi, Can you give me some pointers on what I need to do to change to MQQT Gateway. I am not overly sure on the difference.
                  https://www.mysensors.org/build/mqtt_gateway
                  it is pretty much the same as the ethernet, it just needs a few extra parameters and an mqtt broker running somewhere (if you already have a RPI, just install mosquitto)
                    lozzer65L
                    lozzer65L
                    lozzer65
                    @gohan Ok, thanks for the advise. Strange that I can't use what I have, especially seeing as I can see the data coming from the sensors in node-red.
                      I don't remember how to use the mysensors nodes, but knowing how mqtt works, just take advantage of it: the sensor is publishing a value to a topic, so just read that.
                        lozzer65L
                        lozzer65L
                        lozzer65
                        @gohan I am just thinking about the implications of moving to mqqt. This will break my home assistant setup. I also have over 30 sensors I would have to change the setup of.
                        If you see this as an example, "67;0;1;0;0;62.5↵" which is my data from a sensor showing in node-red debug. The 67 is the nodeId, the next 0 is the childSensor Id and the 62.5 is the temperature.
                        This the code I am using in a function of node-red to try and extract the temp value.
                        var msg;
                        return msg;
                        Can anyone spot any reason why this may not work ?
                          You don't need to change the sensors. Did you check if HA doesn't support mqtt gateway?
                          • lozzer65L
                            lozzer65L
                            lozzer65
                            I have built an Mqtt gateway as you suggested. from the arduino serial monitor I can see it working, as below.
                            0;255;3;0;9;Sending message on topic: mygateway1-out/67/3/1/0/0
                            0;255;3;0;9;TSF:MSG:READ,67-67-0,s=3,c=1,t=0,pt=7,l=5,sg=0:11.5
                            0;255;3;0;9;TSF:MSG:READ,67-67-0,s=3,c=1,t=0,pt=7,l=5,sg=0:11.0
                            0;255;3;0;9;TSF:MSG:READ,67-67-0,s=5,c=1,t=0,ptto=7,l=5,sg=0:16.5
                            0;255;3;0;9;Sending message on topic: mygateway1-out/67/5/1/0/0
                            I have mosquitto broker running on my pi 3. Node-red shows connected to the mqqt broker, yet no data is shown passing.
                            any ideas how best to fault find this issue
                              If you use a mqtt client and subscribe to the topic mygateway1-out/67/5/1/0/0 do you actually see messages? Or subscribe to mygateway1-out/# and see all mqtt messages. If you see correct messages your setup is correct
                              • lozzer65L
                                lozzer65L
                                lozzer65
                                Gohan
                                Thanks very much for that pointer. You have been very helpful. All working now.
                                  Do you think it is easier with mqtt or with serial?
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    If you use the node-red-contrib-mysensors nodes, then you can split the sensor string into the different parts.
                                    Then you are able to use for example the switch node, to filter the data..
                                    S 1 Reply Last reply
                                      var msg;
                                      return msg;
                                      G
                                      G
                                      Geoff
                                      @lozzer65 I'm playing with node red and a mock TCP gateway at the moment and looking at your code I think the problem is that rather than msg.payload.nodeId it should be msg.nodeId and msg.payload.childSensorId should be msg.childSensorId. I realise you've moved on to MQTT but thought I'd mention it in case others come looking.
                                      • tbowmoT tbowmo
                                        scottdube
                                        @tbowmo Hi there I have your nodes installed but having a little trouble getting started. Is there any documentation I could follow? I want to build a flow just like the one you have in this post. Thank for your help and your work on this!
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @scottdube
                                          Sorry I don't have more documentation at hand, than what is in the mysensors npm module already. But basically I use the switch node to route messages, on subtype, then on nodeId, and last on childId.
                                          I'm currently remodeling my node-red setup.. Moving everything to MQTT for internal message distribution between all parts (both within node-red and to external systems).
