  3. Dallas18B20 begin causes reset [solved]
4 Posts 3 Posters 1.5k Views 4 Watching
    I have connected a single DS18B20 as described on https://www.mysensors.org/build/temp (including the 4.7kohm pullup)
    When I call sensor.begin, the Pro Mini resets.
    With a before function looking like this I get "proof" that the node dies on begin:
    void before()
      Serial.println("Calling begin");
      Serial.flush();
      sensors.begin();
      Serial.println("Begin was OK");
      Serial.println("request returned");
      Serial.println(sensors.getTempCByIndex(0));
    Debug:
    4 MCO:BGN:BFR
    Calling begin
    4 MCO:BGN:BFR
    Calling begin
    4 MCO:BGN:BFR
    Calling begin
    4 MCO:BGN:BFR
    Calling begin
    4 MCO:BGN:BFR
    Calling begin
    • I have tried two different DS18B20 sensors. No difference.
    • If I disconnect the data pin, begin returns and all temperature readings return -127.00C, as expected.
    • If I disconnect the GND pin (and re-connect the data pin), begin returns and all temperature readings return -127.00C, as expected.
    • I have tried using the bare DS18B20 library (without MySensors) and get the same result.
    Any idea what could be wrong or what I could do to troubleshoot this?
    • R
      R
      robosensor
      Try to call Serial.flush(); after each print line, this ensures that all data sent to serial port before next line executed.
      Can you post image with connection wires to DS18B20 sensor? Could the problem be that this chip is a fake?
      • R robosensor
        Thanks @robosensor
        I decided to re-do all wiring to make a clear photo. When I did that I realized that I had connected GND on the DS18B20 to the reset pin on the Pro Mini.
        No wonder the mcu was reset when communication occurred on the onewire bus.
        • rejoe2R
          rejoe2R
          rejoe2
          This post is deleted!
