  3. "in-wall" switch and "in-ceiling" relay... advice please :)
6 Posts 4 Posters 2.2k Views 4 Watching
  • ben999B
    ben999B
    ben999
    wrote on last edited by ben999
    Hi Folks
    I am designing an in-wall switch to suit my needs :
    • a touch-switch with relay (to control lighting) from a single location
    • a touch-switch without relay (sending ON/OFF command to the gateway) so i can expand the previous design to a 2-way, 3-way, x-way system :)
    My house has been built in the late 70's... meaning the wall boxes are fairly shallow.
    So far, the second design fits in the wall boxes.
    But adding a SSR looks very difficult from where is stand (with my tools and knowledge)
    Idea of the moment is : how about adding a node (with relay) in the ceiling, where the lighting is suspended ?
    Any pros and cons ?
    Thanks for reading !
    dbemowskD 1 Reply Last reply
      If you have room in the ceiling, it's a good solution, the only problem I see is that it is not very easy to reach in case you need to do any maintenance (ota updates are quite a must in this case)
        @ben999 - I suggest you search the forum. There are alot about this.
        Also openhardware.io has alof of ready project you can take inspiration from.
        ben999B 1 Reply Last reply
        • sundberg84S sundberg84
          ben999B
          ben999B
          ben999
          @gohan and @sundberg84 thanks a lot for your replies
          @sundberg84 sorry i didn't explain enough. It was more like "would it be safe to do so"...
          My current project is highly inspired by Aproxx's work
          https://www.openhardware.io/view/77/AC-DC-double-solid-state-relay-module
          So i use a varistor, fuse and thermal cutoff, but would it be enough ?
          I just don't fancy burning the house down...
          • ben999B ben999
            @ben999 - same there, this has been discussed alot!
            Have a look here about safety:
            • http://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers
            • http://forum.mysensors.org/topic/1540/110v-230v-ac-to-mysensors-pcb-board
            • http://lygte-info.dk/review/Power Mains to 5V 0.6A Hi-Link HLK-PM01 UK.html
            • https://skippy.org.uk/quick-look-at-the-hlk-pm01/
            • https://www.ieee.li/pdf/essay/safety_considerations_in_power_supply_design.pdf
            • https://forum.mysensors.org/topic/4175/clearance-creepage-and-other-safety-aspects-in-mysensors-pcbs
            A recent one: https://forum.mysensors.org/topic/7919/which-are-trustworthy-brands-for-a-simple-usb-wall-charger/
            The issue will always be that a DIY AC/DC powered node will not be covered with any insurances or so. Its possible to do the safe but without any CE/FEE markings you are not covered... and even a safe product can fail.
            • ben999B ben999
              Hi Folks
              Any pros and cons ?
              dbemowskD
              dbemowskD
              @ben999 I have a number of switches around my house that I designed myself. They don't have relay control. They just talk to the automation controller and act as basically a scene switch. If you are in the US, this may be an option for you. Here is the thread that talks about it.
              https://forum.mysensors.org/topic/4317/us-decora-style-wall-switch/34
              The way I have mine set up, the switch talks to my Vera controller, and my Vera uses scenes to talk to another relay controller on the light/fan/device that I want to control. Many of the relay controllers that I have are Sonoffs. The response from switch to Vera to Sonoff is near instantaneous.
              The switches that I designed consist of 3 boards. The power supply board, the controller boardf (arduino pro mini + nRF24 radio) and the switch board. The switch boards that I designed is universal and can be made as a 4 button, 2 button or single button switch. I also have 3D designs for the switch plates that I made. These can be found on my thingiverse page. https://www.thingiverse.com/dbemowsk/designs.
