  3. [SOLVED] ESP8266 WiFi Gateway trouble - pm open, type:2 0
11 Posts 3 Posters 6.5k Views 4 Watching
  • S
    Strixx
    Help needed. I am trying to build a WiFi gateway using NodeMCU. Actually I built it a year ago and it was working fine. But then this hole projekt was suspended, and brought to life again now. But I am not able to get the GW wroking.
    I am using Arduino IDE 1.8.5 and have tried with both MySensors library 2.0.0 and 2.1.1. Without any differens.
    This is my code:
    #define MY_BAUD_RATE 9600
    #define MY_GATEWAY_ESP8266
    #define MY_ESP8266_SSID "wifi_n2@home"
    #define MY_ESP8266_PASSWORD "XXXXXXX"
    // Enable UDP communication
    //#define MY_USE_UDP
    #define MY_ESP8266_HOSTNAME "MySensor_GW"
    //#define MY_IP_ADDRESS 192,168,2,50
    //#define MY_IP_GATEWAY_ADDRESS 192,168,2,1
    #define MY_PORT 5003
    // Set blinking period
    //#define MY_DEFAULT_LED_BLINK_PERIOD 10
    // Flash leds on rx/tx/err
    // Led pins used if blinking feature is enabled above
    // Internal LED is PIN 16
    //#define MY_DEFAULT_TX_LED_PIN  16  // the PCB, on board LED = 16
    #if defined(MY_USE_UDP)
    #include <WiFiUdp.h>
    #include <ESP8266WiFi.h>
    And here is the serial output:
    0;255;3;0;9;Starting gateway (RNNGE-, 2.0.0)
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 4
    cnt
    connected with wifi_n2@home, channel 6
    dhcp client start...
    chg_B1:-40
    0;255;3;0;9;TSM:READY
    f r-40, scandone
    ...................pm open,type:2 0
    No matter what I tries in the code (static/non static IP) it is the same output.
    Any ideas about what is wrong?
    • S Strixx
      This is my code:
      scandone
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      aid 4
      cnt
      chg_B1:-40
      f r-40, scandone
      @Strixx I can't see anything wrong. The serial output looks fine.
      Could you describe what you expected to see?
      • S
        Strixx
        I don't know what I except to see. Don't remember how it looked a year ago. But at least an assigned IP (I have seen this output in the forum searching this)
        I can't ping it. I can't telnet. I can't see it in my router. And my controller can't find it.
        Tried as I wrote with both static and dynamic IP.
        • S Strixx
          @Strixx yes, you are right. After DHCP the output should say something like this:
          connected with Mr-IoT.com, channel 5
          .....ip:192.168.1.204,mask:255.255.255.0,gw:192.168.1.1
          .IP: 192.168.1.204
          Could you comment out #define MY_RADIO_NRF24 and disconnect the nrf to see if the problem is related to radio?
          S 1 Reply Last reply
            .IP: 192.168.1.204
            Strixx
            @mfalkvidd I've tried disconnected the radio and comment out the radio. Still the same.
            I googled the phrase "pm open,type:2 0" and all hits seemed to refer to problems. So I assumed it was some kind of error message. Since I can't find any documentation of the initial output in the serial interface, and I haven't got the time to go through all the source code.
            I started building the gw a year a go, and then it worked. Then I put it on a shelf waiting to get the time to build some sensors. Two weeks ago I started with this project again. And the only thing changed is I now have a new computer. Same router (but uodated firmware), same server, same gateway (Domoticz).
            So I thought it was the usb port not being able to power the Node MCU. To day I plugged in a powered usb hub, but that made no difference. Then tried recompiling with the latest MySensors library, then "down grading". Still the same.
            • S Strixx
              @Strixx said in ESP8266 WiFi Gateway trouble - pm open, type:2 0:
              I doubt the search results mean that "pm open,type:2 0" indicates a problem. People don't usually post detailed logs when their projects are successful, they post them when they have trouble.
              This is the output of my esp8266 when commenting the nrf define. I also changed the wifi ssid and password, but everything else is exactly like your post above (I copied the code you posted). Result:
              0;255;3;0;9;MCO:BGN:INIT GW,CP=R-NGE--,VER=2.1.1
              scandone
              f 0, scandone
              state: 0 -> 2 (b0)
              state: 2 -> 3 (0)
              state: 3 -> 5 (10)
              add 0
              aid 1
              cnt
              .IP: 192.168.1.204
              0;255;3;0;9;MCO:BGN:STP
              0;255;3;0;9;MCO:BGN:INIT OK,TSP=NA
              pm open,type:2 0
              it responds to ping:
              $ ping 192.168.1.204
              Pinging 192.168.1.204 with 32 bytes of data:
              Reply from 192.168.1.204: bytes=32 time=75ms TTL=128
              Reply from 192.168.1.204: bytes=32 time=95ms TTL=128
              Reply from 192.168.1.204: bytes=32 time=16ms TTL=128
              and netcat:
              $ nc 192.168.1.204 5003
              0;255;0;0;17;2.1.1
              The connection is also verified in the Arduino IDE Serial Monitor:
              0;255;3;0;9;Client 0 connected
              Could you post the full output when doing the same on your gateway?
              • S
                Strixx
                Well off course you are right about not posting output when it works. But then again Google wont find many answers on that phrase.
                Any way. Last night I updated uupdated to MySensors library 2.1.1, and tried again, without any luck. I did notice that I got some errors about invalid library in the IDE after switching to 2.1.1. But there was no luck, still no assigned IP. Tried to change to a different AP. Nothing
                So this morning I gave it a new go and change the code back to static IP, and now it is working.
                connected with wifi_2@home, channel 11
                ip:192.168.2.50,mask:255.255.255.0,gw:192.168.2.1
                .IP: 192.168.2.50
                pm open,type:2 0
                0;255;3;0;9;Client 0: 0;0;3;0;2
                So I cant find any pattern in this. I will do some more testing during the day to see if I can find what went wrong before..
                  Why don't you give a try to mysensors library 2.2?
                  • S
                    Strixx
                    Ok... Sorry for bothering you... I have been testing several things now for an hour. And I found what was causing the errors, and it was my Asus router. A year ago when started this project apparently set up an dhcp rule for the gateway binding it to a certain ip when connecting. Some how this is the cause for not getting any IP at all.
                    Because now, when removing this rule, I am able to connect and receive IP adress in dynamic mode on.
                    It is strange because I have allot of other things that is getting manually assigned IP from the DHCP in the router, and they all works. But I guess this is to hard for me to find why the gateway is not working with this settings in the router..
                    Now I will get back to testing inclusion mode and traffic leds on the NodeMCU wifi gateway.
                      That's odd as I use dhcp reservations too without issues
                      • S
                        Strixx
                        It for shore is. And what is even more strange is that adding a new manually assigned IP now is working.
                        Can't explain it. The router is a Asus RT-AC66U.
