  3. Waterproof Temp Sensor with dht humidty/temp sensor
8 Posts 4 Posters 5.1k Views 1 Watching
  • C Offline
    C Offline
    cleight
    wrote on last edited by cleight
    I am new to mysensors and am trying to work on a waterproof temperature sensor now with an additional DHTII for outdoor temp/humidity for around my Hot tub. I got the DHTII example working and am now trying to add in the code for the Dallas Temperature waterproof sensor and getting lots of errors. hoping someone can look at my code and point out my mistakes so I can learn.
    sketch_HotTubTemp.ino
    • D Offline
      daulagari
      Hi @cleight
      To help you further it would be good if you can post the errors you are getting and add a link to the Dallas temperature sensor you are trying to use.
      C 1 Reply Last reply
      • E Offline
        E Offline
        ericvdb
        How are yu powering the Dallas temperature sensor an ddid you add the pull-up resistor of 4k7 ?
        B 1 Reply Last reply
        • E ericvdb
          B Offline
          B Offline
          BulldogLowell
          wrote on last edited by BulldogLowell
          @ericvdb
          how many dallas sensors on the 1 Wire bus?
          it looks like you are presenting device number 0 (and possibly 1) twice...
            // Startup OneWire
            sensors.begin();
            gw.begin();
            gw.sendSketchInfo("Humidity", "1.0");
            gw.sendSketchInfo("Temperature Sensor", "1.0");
              gw.present(i, S_TEMP); // <<<<<<<<<<<<< First Here, device O and 1 will be create
            gw.present(CHILD_ID_HUM, S_HUM);  //<<<<<<<<<<< Then you create device 0 again...
            gw.present(CHILD_ID_TEMP, S_TEMP); //<<<<<<<<<<< Then you create device 1 again...
          • D daulagari
            Hi @cleight
            C Offline
            C Offline
            cleight
            @daulagari said:
            Hi @cleight
            I am using this temperature sensor, I should also note that when I compiled it compiled fine. waterproof temp sensor Found it on the Mysensors Store Page.
            I am powering the Dallas Temp Sensor from the Nano with 5.5V and have a 4k7 resistor between the VCC and Signal wire.
            @BulldogLowell said:
            @ericvdb
              // Startup OneWire
              sensors.begin();
              gw.begin();
            I have one sensor on the One Wire bus, the other temp/humidity sensor you see listed is a DHTII Humidity/Temp Sensor which I believe does not use the OneWire bus.
            The code compiled fine and appears to be working, I am not sure it is 100% correct though.
            Latest copy of the sketch: sketch_HotTubTemp2.ino
            • C Offline
              C Offline
              cleight
              I finally got my iBoard Gateway working and Vera can see the temperature sensor node. However the 2 temperature probes are showing up but the humidity sensor is not. Can someone please look at my sketch to see what I missed?
              • C Offline
                C Offline
                cleight
                Ok so I finally got it working and showing all 3 devices in the Vera Controller. I am not sure if the code is the cleanest, but it is working. The only outstanding issue I am having at this point is my temperatures are showing up in Celsius and I would like them to show in Fahrenheit? I did some research on the forums and have tried changed the Vera controller from Imperial to Metric and vise-versa with no luck.
                Here is the latest sketch for reference: sketch_HotTubTemp2.ino
                • C cleight
                  B Offline
                  B Offline
                  BulldogLowell
                  @cleight
                  try this...
                  start here:
                  boolean metric = true;
                  with
                  boolean metric = false;
                  and comment out this line:
