  3. Home Assistant
  4. MySensor on Hass.io - can't get it work
28 Posts 6 Posters 12.8k Views 6 Watching
    @maty
    You should send feedback of state changes to home assistant from your device. This is done from the receive function. The switch in home assistant will switch as soon as the feedback comes in.
    Also set optimistic to false in your mysensors config section.
    MaTyM
    MaTyM
    MaTy
    wrote on last edited by MaTy
    #21
    @martinhjelmare
    You mean in my sketch, something like this?
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
    I had optimistic set false.
    BTW: Strange thing, baud rate in my sketch is 38400, but when I set it up in Hass.io, lights won't work, when I changed to 115200 in .yaml (in sketch is still 38400), all works fine, except the states update.
    • MaTyM MaTy
      @martinhjelmare
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      @maty
      In your example above you never send the feedback from receive. Use the send method
      from within receive to do that.
      In what sketch have you set baud rate to 38400? For the light device or for the gateway? It's only the gateway baud rate that is relevant for home assistant config, since it's the gateway that interfaces via the serial connection to home assistant.
      MaTyM 1 Reply Last reply
        @maty
        MaTyM
        MaTyM
        MaTy
        #23
        @martinhjelmare
        Should it be something like this added to my sketch?
        send(msg.set(RELAY_1;V_LIGHT)
        send(msg.set(RELAY_2;V_LIGHT)
        I ment BAUD_RATE defined in this sketch
        #if F_CPU == 8000000L
        #define MY_BAUD_RATE 38400
        Once again, sorry for tons of noob questions. But I didn't write that sketch by myself, and my knowledge about programming is below basic.
        • martinhjelmareM
          martinhjelmareM
          martinhjelmare
          Something like this:
          send(msg.set(state));
          The arduino mega runs at 16 MHz so that if block won't be entered, and the define of baud rate won't change.
            MaTyM
            MaTyM
            MaTy
            @martinhjelmare
            I checked my sketch once again, and confronted it with MySensors documentation, and I actually found the send message command in it. Should I change something to make it work properly with Hass.io
              if (debouncer.update()) {
                // Get the update value.
                int value = debouncer.read();
                // Send in the new value.
                if(value == LOW){
                     saveState(1, !loadState(1));
                     digitalWrite(RELAY_1, loadState(1)?RELAY_ON:RELAY_OFF);
                     send(msg.set(loadState(1)));
            • MaTyM MaTy
              @martinhjelmare
                  if(value == LOW){
              martinhjelmareM
              martinhjelmareM
              martinhjelmare
              #26
              @maty
              Yes. There are two ways of interacting with the device to make a state change. Either by pressing the button or by sending a message from home assistant to the device. The send command you showed above will only happen if the button is pressed when the loop is running.
              When you send a message from home assistant to the device, to change the state, the message will be received in your sketch by the receive function.
              So you need to add a send command to the receive function and send the new state back to home assistant after doing the digitalWrite call and saving the state.
              • MaTyM MaTy
                @tom-carpenter
                How did You make it? Is it via serial gateway?
                Tom CarpenterT
                Tom CarpenterT
                Tom Carpenter
                @maty Yes serial gateway hooked to the pi
                R 1 Reply Last reply
                • Tom CarpenterT Tom Carpenter
                  R
                  R
                  Rincewind
                  @tom-carpenter How did you configure the serial gateway in configuration.yaml? can you please post that section?
                  Also what arduino hardware did you use?
