  3. what is this?
what is this?
7 Posts 3 Posters 1.9k Views 3 Watching
  • BarnaB
    BarnaB
    Barna
    I have bought a AM2301 from ebay, it was ok, so I have ordered another 2pcs.
    But the new ones are not same, could you help me to identify what it is ?
    thanks
    Barna
    dbemowskD 1 Reply Last reply
    • BarnaB Barna
      thanks
      Barna
      dbemowskD
      dbemowskD
      @barna Looks like a DHT21 (AM2301) temp/humidity sensor module. What is that out of?
      • dbemowskD
        dbemowskD
        Looks like this without the cover
        • BarnaB
          BarnaB
          Barna
          yes, the covers are same, I have an another AM2301, which works, but it looks inside like this0_1513961409487_3.png
          • BarnaB
            BarnaB
            Barna
            the code that I use with this does not work with the "non identified" sensor
            • BarnaB Barna
              dbemowskD
              dbemowskD
              @barna Can you show a picture of your wiring and what code you are using?
              • D
                D
                DavidZH
                The surface of the sensor appears to be a light-sensitive semiconductor. Maybe you can unscrew the little PCB from the case and see on the bottom. There could be some information there.
