  3. help to pass version 2 mysensors
4 Posts 2 Posters 1.1k Views 3 Watching
  • Z Offline
    Z Offline
    zrom69
    Hello
    I am a beginner in programming and excuse me
    my english
    i tried to go to v 2 his function not these you can m help thank you in advance[0_1514023990085_sketch_dec23b.ino](Envoi en cours 100%)
    Z 1 Reply Last reply
    • Z zrom69
      Hello
      my english
      Z Offline
      Z Offline
      zrom69
      wrote on last edited by gohan
      @zrom69 said in help to pass version 2 mysensors:
      Hello
      my english
      // Example sketch för a "light switch" where you can control light or something
      // else from both vera and a local physical button (connected between digital
      // pin 3 and GND).
      // This node also works as a repeader for other nodes
      #include <DHT.h>
      //pin sensori
      #define PIR_PIN 2                   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
      #define HUMIDITY_TEMPERATURE_PIN 3  // sensore temperatura umidita
      #define RELAY_PIN  4                // relay pin
      int BATTERY_SENSE_PIN = A1;         // Pin carica batteria o pannello solare
      int FOTORESIST_SENSE_PIN = A2;      // Pin fotoresistenza
      //interupt per sleep arduino
      #define INTERRUPT PIR_PIN-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
      //id per vera
      #define CHILD_ID_RELE 1   // Id relay
      #define CHILD_ID_HUM 2    // id temperatura
      #define CHILD_ID_TEMP 3   // id umidita
      #define CHILD_ID_PIR 4    // Id pir
      #define CHILD_ID_LIGHT 5  // Id luminosita (fotoresistenza)
      //definizione per nodo vera
      #define NODE_ID 10
      #define SN "meteo station"
      #define SV "1.4"
      //variabili
      bool state_relay;                 //stato relay
      float batt_valore;                //dichiaro la variabile valore che memorizzerà il valore della batteria dal pin analogico
      float batt_volt;                  //volt batteria
      float batt_charged_percent;       //percentuale carica batteria
      float last_batt_charged_percent;  //percentuale carica batteria precedente
      float batt_min_voltage = 0.5;     //tensione minima batteria
      float batt_max_voltage = 5;       //tensione massima batteria
      float fotoresistenza_valore;      //dichiaro la variabile valore che memorizzerà il valore della fotoresistenza dal pin analogico
      float last_fotoresistenza_valore; //dichiaro la variabile valore precedente
      int lux_vera;                      //valore luminosita da inviare a vera
      DHT dht_int;
      float lastTemp_int = -1;
      float lastHum_int = -1;
      boolean metric = true;
      MyMessage msgRelay(CHILD_ID_RELE,V_LIGHT);
      MyMessage msgPir(CHILD_ID_PIR, V_TRIPPED);
      MyMessage msgLux(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
        gw.begin(incomingMessage, NODE_ID, false);
        gw.sendSketchInfo(SN, SV);
        //Sensore umidita temperatura
        dht_int.setup(HUMIDITY_TEMPERATURE_PIN);
        gw.present(CHILD_ID_RELE, S_LIGHT);       //light vera
        gw.present(CHILD_ID_HUM, S_HUM);          //umidity vera
        gw.present(CHILD_ID_TEMP, S_TEMP);           // temp vera
        gw.present(CHILD_ID_PIR, S_MOTION);          // motion vera
        gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);  //light level (fotoresistenza)
        pinMode(RELAY_PIN, OUTPUT);
        //PIR
        pinMode(PIR_PIN, INPUT);
        state_relay = 0;
        //GestisciRelay();
        digitalWrite(RELAY_PIN, LOW);
        gw.send(msgRelay.set(state_relay));
          gw.process();
          //sensore temperatura umidita
          delay(dht_int.getMinimumSamplingPeriod());
          float temperature_int = dht_int.getTemperature();
          if (isnan(temperature_int))
              lastTemp_int = -1;
          else if (temperature_int != lastTemp_int)
            lastTemp_int = temperature_int;
            if (!metric)
              temperature_int = dht_int.toFahrenheit(temperature_int);
            gw.send(msgTemp.set(temperature_int, 1));
            Serial.print("T int: ");
            Serial.println(temperature_int);
          float humidity_int = dht_int.getHumidity();
          if (isnan(humidity_int))
              lastHum_int = -1;
          else if (humidity_int != lastHum_int)
              lastHum_int = humidity_int;
              gw.send(msgHum.set(humidity_int, 1));
              Serial.print("H int: ");
              Serial.println(humidity_int);
          //fotoresistenza
          for(int i=0;i<150;i++)
            fotoresistenza_valore += analogRead(FOTORESIST_SENSE_PIN);  //read the input voltage from battery or solar panel
            delay(2);
          fotoresistenza_valore = fotoresistenza_valore / 150;
          Serial.print ("fotoresistenza: ");
          Serial.println(fotoresistenza_valore);
          if (fotoresistenza_valore != last_fotoresistenza_valore)
            lux_vera = (int) fotoresistenza_valore;
            gw.send(msgLux.set(lux_vera));
            last_fotoresistenza_valore = fotoresistenza_valore;
          //fotoresistenza
          //pir relay
          // Read digital motion value
          boolean tripped = digitalRead(PIR_PIN) == HIGH;
          Serial.println("pir:");
          Serial.println(tripped);
          gw.send(msgPir.set(tripped?"1":"0"));  // Send tripped value to gw
          //accende la luce con il buio
          if (fotoresistenza_valore < 200)  //poca luce
            if (tripped == 1)
               state_relay = 1;
            else
               state_relay = 0;
          GestisciRelay();
          //pir relay
          //battery
            batt_valore += analogRead(BATTERY_SENSE_PIN);  //read the input voltage from battery or solar panel
            delay(2);
          batt_valore = batt_valore / 150;
          Serial.print ("batt_valore: ");
          Serial.println(batt_valore);
          batt_volt = (batt_valore / 1024) * batt_max_voltage;
          Serial.print ("batt_volt: ");
          Serial.println(batt_volt);
         //The map() function uses integer math so will not generate fractions
         // so I multiply battery voltage with 10 to convert float into a intiger value
         // when battery voltage is 6.0volt it is totally discharged ( 6*10 =60)
         // when battery voltage is 7.2volt it is fully charged (7.2*10=72)
         // 6.0v =0% and 7.2v =100%
         //batt_charged_percent = batt_volt*10;
         //batt_charged_percent = map(batt_volt*10, 60 , 72, 0, 100);
          batt_charged_percent = batt_volt * 10;
          batt_charged_percent = map(batt_volt * 10, batt_min_voltage * 10 , batt_max_voltage * 10, 0, 100);
          //batt_charged_percent = (batt_volt / batt_max_voltage) * 100;
          Serial.print ("batt_charged_percent: ");
          Serial.println(batt_charged_percent);
          if (last_batt_charged_percent != batt_charged_percent)
              gw.sendBatteryLevel(batt_charged_percent);
              last_batt_charged_percent = batt_charged_percent;
          //battery
          delay(50);
          gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME);
        if (message.isAck()) {
           // Change relay state_relay
           state_relay = message.getBool();
           GestisciRelay();
           // Write some debug info
           Serial.print(message.sensor);
      void GestisciRelay()
          //Serial.print(" GestisciRelay state_relay:");
          //Serial.println(state_relay);
          if (state_relay == 0)
            //Serial.println("SPENTO RELAY");
          else
            digitalWrite(RELAY_PIN, HIGH);
            //Serial.println("ACCESO RELAY");
        Hi
        did you read this? https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x
          Hi
          Z Offline
          Z Offline
          zrom69
          @gohan
          you can check i add module rain
          // pin 3 and GND).
          #define MY_NODE_ID 2
          #define MY_PARENT_NODE_ID  0
          #include <DHT.h>
          //pin sensori
          #define PIR_PIN 6                   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
          #define DIGITAL_INPUT_RAIN_SENSOR 5
          #define INTERRUPT PIR_PIN-6 // Usually the interrupt = pin -2 (on uno/nano anyway)
          #define INTERRUPT DIGITAL_INPUT_RAIN_SENSOR-2
          //id per vera
          #define CHILD_ID_RAIN 6
          #define NODE_ID 10
          #define SV "1.4"
          //variabili
          int lastRainValue = -1;
          int nRainVal;
          boolean bIsRaining = false;
          String strRaining = "NO";
          DHT dht_int;
          MyMessage msgRain(CHILD_ID_RAIN, V_TRIPPED);
            pinMode(DIGITAL_INPUT_RAIN_SENSOR, INPUT);
            //PIR
            state_relay = 0;
            //GestisciRelay();
            present(CHILD_ID_RAIN, S_MOTION, "WS Rain");
                  lastTemp_int = -1;
                if (!metric)
                  lastHum_int = -1;
              //fotoresistenza
                delay(2);
              //fotoresistenza
              //pir relay
                if (tripped == 1)
                   state_relay = 1;
                else
                   state_relay = 0;
              GestisciRelay();
              //pir relay
              //battery
                delay(2);
              bIsRaining = !(digitalRead(DIGITAL_INPUT_RAIN_SENSOR));
                if(bIsRaining){
                    strRaining = "YES";
                else{
                    strRaining = "NO";
                //Serial.print("Raining?: ");
                //Serial.print(strRaining);
                //Serial.print("\t Moisture Level: ");
                //Serial.println(nRainVal);
                //http://henrysbench.capnfatz.com/henrys-bench/arduino-sensors-and-input/arduino-rain-sensor-module-guide-and-tutorial/
                send(msgRain.set(bIsRaining, 1));
              //battery
              delay(50);
               GestisciRelay();
              else
