  3. Controlling Turbovex TX 35A by Mysensors
4 Posts 2 Posters 1.1k Views 2 Watching
  • Knud RishøjK Offline
    Knud Rishøj
    Hi there,
    I am new to Mysensors, and wanna get started on a small project. What i had in mind was to regulate the speed of my "One Room Ventilation" system. (http://www.turbovex.dk/fileadmin/filer/BOLIG/Downloads/TX_35A_montage_og_vedlige_19.01.11_.pdf )
    From what i can read, the fan inside it needs from 4-9 volts to operate. so i was thinking that a LED Dimmer might do the trick. (the fan speed is regulated by voltage).
    I was wondering if anyone could point me in the right direction?
    N 1 Reply Last reply
    • Knud RishøjK Knud Rishøj
      Hi there,
      N Offline
      N Offline
      Hello @knud-rishøj and welcome toMySensors !
      From the document I believe you have 2 solutions :
      • set voltage to maximum or close to maximum and then use PWM + MOSFET + RC filter to regulate the voltage received by the motor
      • check the exact action of the screw that sets the voltage and replace it
        Knud Rishøj
        Hello @Nca78, and thank you for you answer.
        If i was to use option 1 (set voltage to maximum or close to maximum and then use PWM + MOSFET + RC filter to regulate the voltage received by the motor) is that the same approach as building af LED dimmer? and where do i get the 9v from?
        In option 2, do you suggest replacing the screw with at motor?
        Thank you in advance
          N Offline
          N Offline
          @knud-rishøj yes it's the same than led dimmer except you add a RC filter because the motor will be very noisy if you set on/off like it's done for the LEDs. Your circuit would be inserted between existing connection to motor and the motor.
          For the screw I don't know what it does, so you have to check the circuit to see how it influences the output voltage.
          Not such an easy project to start with IMHO ;)
