  3. Home Assistant
  4. Gateway Addon for Hass.io
19 Posts 6 Posters 9.7k Views 8 Watching
  • G
    G
    ghiglie
    Hi there,
    in these days I've been trying to get the Gateway working as an add-on for Hass.io, running on RaspberryPi3.
    You can find all my work (well, tons of hours for just some lines! :D) here on GitHub. Even it's the master branch, it's totally in development...
    So, now, I'm stuck.
    It looks like that if I start the Docker container as privileged, it works! But not when it start with the configuration you see, and neither I can give the privileged capability to the container.
    Any ideas on what on the host I should expose?
    atmega328p serial killer
    HomeAssistant / gateway: ESP8266 & NRF24L01+ gateway
    hautomateH 1 Reply Last reply
    • G ghiglie
      Hi there,
      So, now, I'm stuck.
      hautomateH
      hautomateH
      hautomate
      @ghiglie I presume you've seen this. Tried them all?
      Privilege for access to hardware/system. Available access: NET_ADMIN, SYS_ADMIN, SYS_RAWIO, SYS_TIME, SYS_NICE
      • hautomateH
        hautomateH
        hautomate
        Is this the error you're taking about?
        [services.d] starting services
        [services.d] done.
        ifelse: fatal: unable to exec /run.sh: Permission denied
        [cmd] /run.sh exited 111
        [cont-finish.d] executing container finish scripts...
        [cont-finish.d] 99-message.sh: executing...
                        Oops! Something went wrong.
         We are so sorry, but something went terribly wrong when
         starting or running this add-on.
         Be sure to check the log above, line by line, for hints.
        [cont-finish.d] 99-message.sh: exited 0.
        [cont-finish.d] done.
        • hautomateH
          hautomateH
          hautomate
          Try setting permissions on run.sh.
          RUN chmod a+x /run.sh
          CMD [ "/run.sh" ]
          • G
            G
            ghiglie
            wrote on last edited by ghiglie
            oops, sorry, I've fixed that locally after I pushed the code to git. I see just now I'm not exposing the 5003 port... :|
            I'll add the RUN command.
            I mean, mysgw hangs on activating the transport.
            @hautomate said in Gateway Addon for Hass.io:
            Yes, tried all, even with gpio set to true.
            • hautomateH
              hautomateH
              hautomate
              wrote on last edited by hautomate
              Add...
              "host_network": true,
              and for port 5003, what about this?
              "ports": {
              "5003/tcp": 5003
              Or put the port as an option so it could be configured by the user. I'm not sure what else would be needed for this to work.
              "options": {
              "port": 5003,
              G 1 Reply Last reply
              • hautomateH hautomate
                Add...
                "ports": {
                "5003/tcp": 5003
                "options": {
                "port": 5003,
                G
                G
                ghiglie
                Add...
                "ports": {
                "5003/tcp": 5003
                "options": {
                "port": 5003,
                I've added it locally, since it's primaly a MQTT image.
                I'm stopping here now:
                mysgw: Starting gateway...
                mysgw: Protocol version - 2.2.0-rc.2
                mysgw: MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0-rc.2
                mysgw: TSF:LRT:OK
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                so it's not starting the transport.
                Any idea on what I shoudl enable?
                • G ghiglie
                  Add...
                  "ports": {
                  "5003/tcp": 5003
                  "options": {
                  "port": 5003,
                  mysgw: TSF:LRT:OK
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  hautomateH
                  hautomateH
                  hautomate
                  @ghiglie hmm, not sure. Would you please update your repo with the latest and I'll try a reinstall and have a closer look?
                    G
                    G
                    ghiglie
                    sorry, I'm out for work :( I'll do ASAP tomorrow!
                    EDIT: Updated!
                    • G ghiglie
                      EDIT: Updated!
                      hautomateH
                      hautomateH
                      hautomate
                      @ghiglie It shows the last commit as 14 days ago...
                      • S
                        swcrawford
                        Will be watching with interest. I'd like to move to hass.io but this is the one thing stopping me.
                          G
                          G
                          ghiglie
                          git-noob mistake! updated!
                          • G ghiglie
                            hautomateH
                            hautomateH
                            hautomate
                            @ghiglie said in Gateway Addon for Hass.io:
                            Haha! I forgot to tell you that I have no idea what I'm doing :)
                            The 'run chmod' command is still missing in the dockerfile.
                            • R
                              R
                              rusg323
                              Wondering what the status of this is. Would love to try it out as I have migrated to hassio and would love to integrate mysensors gateway back on the same rpi.
                              • kwekK
                                kwekK
                                kwek
                                I'm also trying to make a hassio addon for the mysensors gateway which is connected on the same raspberry pi 2.
                                If I run the docker image with --privileged then it runs correctly: it manages to read from the nrf2401, it connects to the MQTT server and publishes incoming messages.
                                However, if I run the container without --privileged (like hassio does), the mysgw program does not output anything else after:
                                : TSF:LRT:OK
                                : TSM:INIT
                                : TSF:WUR:MS=0
                                I'm running the container like this:
                                docker run -it --rm --cap-add SYS_RAWIO --device /dev/mem --device /dev/gpiomem local/mysgw
                                If I run a strace on the mysgw binary, I see:
                                bash-4.4# strace mysgw -d 2>&1 | grep open
                                open("/sys/class/gpio", O_RDONLY|O_LARGEFILE|O_DIRECTORY|O_CLOEXEC) = 3
                                open("/sys/class/gpio/gpiochip0/base", O_RDONLY|O_LARGEFILE) = 4
                                open("/sys/class/gpio/gpiochip0/ngpio", O_RDONLY|O_LARGEFILE) = 4
                                open("/sys/class/gpio/gpiochip100/base", O_RDONLY|O_LARGEFILE) = 4
                                open("/sys/class/gpio/gpiochip100/ngpio", O_RDONLY|O_LARGEFILE) = 4
                                open("/etc/mysensors.dat", O_RDONLY|O_LARGEFILE) = 3
                                open("/dev/urandom", O_RDONLY|O_LARGEFILE) = 3
                                open("/dev/console", O_WRONLY|O_NOCTTY|O_LARGEFILE|O_CLOEXEC) = 5
                                open("/etc/mysensors.dat", O_RDONLY|O_LARGEFILE) = 5
                                open("/proc/cpuinfo", O_RDONLY|O_LARGEFILE) = 5
                                open("/proc/device-tree/soc/ranges", O_RDONLY|O_LARGEFILE) = -1 ENOENT (No such file or directory)
                                open("/dev/mem", O_RDWR|O_SYNC|O_LARGEFILE) = 5
                                It looks like it can't open a device which is also described in https://www.mysensors.org/apidocs/group__BCM2835grp.html
                                It seems to be a symlink to some device in /sys, but this directory is empty somehow.
                                bash-4.4# ls -al /proc/device-tree
                                lrwxrwxrwx    1 root     root            29 May  7 15:10 /proc/device-tree -> /sys/firmware/devicetree/base
                                bash-4.4# ls -al /sys/firmware
                                total 0
                                drwxrwxrwt    2 root     root            40 May  7 15:34 .
                                dr-xr-xr-x   12 root     root             0 May  7 15:34 ..
                                That's how far I got. Does anyone know how to make this device available within the container without having to use --privileged?
                                • kwekK kwek
                                  : TSF:LRT:OK
                                  : TSM:INIT
                                  : TSF:WUR:MS=0
                                  total 0
                                  G
                                  G
                                  ghiglie
                                  Hi @kwek, sorry for taking so much to reply. We've been taking the same path!
                                  @kwek said in Gateway Addon for Hass.io:
                                  Same here. I've been trying some time ago, if I get to start the container in privileged mode it runs without any problems!
                                  So, I've been looking to how enable the GPIO on the board to the container, using the ResinOS guide: https://docs.resin.io/learn/develop/hardware/gpio/
                                  ...but I got nothing of use. You see anyway that the GPIO definitions are under the /sys/class/gpio/ device tree...
                                  I hope to have some more spare time to test this.
                                  • G ghiglie
                                    hautomateH
                                    hautomateH
                                    hautomate
                                    @ghiglie Here's an add-on that uses a pi gpio pin. Maybe it will help.
                                    https://github.com/pantomax/hassio-addons/tree/master/rpi-rf-receiver
                                    It's discussed in this thread:
                                    https://community.home-assistant.io/t/rpi-rf-receiver-addon/32947
                                      G
                                      G
                                      ghiglie
                                      @hautomate Thanks! I didn't notice it at all.
                                      EDIT: A quick look:
                                      @pantomax in config.json "only" has:
                                          "devices": ["/dev/mem:/dev/mem:rw"],
                                          "privileged": ["SYS_RAWIO"],
                                          "gpio": "true",
                                      ...while I put an overpowered:
                                        "devices": [ "/dev/mem:/dev/mem:rw" ],
                                        "privileged": [ "SYS_RAWIO", "SYS_ADMIN", "NET_ADMIN" ],
                                        "gpio": "true",
                                      so... it should work :(
                                      • B
                                        B
                                        BlackChart
                                        Did you get this up and running?
