  3. Home Assistant
  4. Gateway Addon for Hass.io
19 Posts 6 Posters 9.2k Views 8 Watching
  • G Offline
    G Offline
    ghiglie
    Hi there,
    in these days I've been trying to get the Gateway working as an add-on for Hass.io, running on RaspberryPi3.
    You can find all my work (well, tons of hours for just some lines! :D) here on GitHub. Even it's the master branch, it's totally in development...
    So, now, I'm stuck.
    It looks like that if I start the Docker container as privileged, it works! But not when it start with the configuration you see, and neither I can give the privileged capability to the container.
    Any ideas on what on the host I should expose?
    atmega328p serial killer
    HomeAssistant / gateway: ESP8266 & NRF24L01+ gateway
    hautomateH 1 Reply Last reply
    • G ghiglie
      Hi there,
      So, now, I'm stuck.
      hautomateH Offline
      hautomateH Offline
      hautomate
      @ghiglie I presume you've seen this. Tried them all?
      Privilege for access to hardware/system. Available access: NET_ADMIN, SYS_ADMIN, SYS_RAWIO, SYS_TIME, SYS_NICE
      • hautomateH Offline
        hautomateH Offline
        hautomate
        Is this the error you're taking about?
        [services.d] starting services
        [services.d] done.
        ifelse: fatal: unable to exec /run.sh: Permission denied
        [cmd] /run.sh exited 111
        [cont-finish.d] executing container finish scripts...
        [cont-finish.d] 99-message.sh: executing...
                        Oops! Something went wrong.
         We are so sorry, but something went terribly wrong when
         starting or running this add-on.
         Be sure to check the log above, line by line, for hints.
        [cont-finish.d] 99-message.sh: exited 0.
        [cont-finish.d] done.
          hautomateH Offline
          hautomate
          Try setting permissions on run.sh.
          RUN chmod a+x /run.sh
          CMD [ "/run.sh" ]
          • G Offline
            G Offline
            ghiglie
            wrote on last edited by ghiglie
            oops, sorry, I've fixed that locally after I pushed the code to git. I see just now I'm not exposing the 5003 port... :|
            I'll add the RUN command.
            I mean, mysgw hangs on activating the transport.
            @hautomate said in Gateway Addon for Hass.io:
            Yes, tried all, even with gpio set to true.
              hautomateH Offline
              hautomate
              wrote on last edited by hautomate
              Add...
              "host_network": true,
              and for port 5003, what about this?
              "ports": {
              "5003/tcp": 5003
              Or put the port as an option so it could be configured by the user. I'm not sure what else would be needed for this to work.
              "options": {
              "port": 5003,
              G 1 Reply Last reply
              • hautomateH hautomate
                Add...
                "ports": {
                "5003/tcp": 5003
                "options": {
                "port": 5003,
                G Offline
                G Offline
                ghiglie
                Add...
                "ports": {
                "5003/tcp": 5003
                "options": {
                "port": 5003,
                I've added it locally, since it's primaly a MQTT image.
                I'm stopping here now:
                mysgw: Starting gateway...
                mysgw: Protocol version - 2.2.0-rc.2
                mysgw: MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0-rc.2
                mysgw: TSF:LRT:OK
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                so it's not starting the transport.
                Any idea on what I shoudl enable?
                • G ghiglie
                  Add...
                  "ports": {
                  "5003/tcp": 5003
                  "options": {
                  "port": 5003,
                  mysgw: TSF:LRT:OK
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  hautomateH Offline
                  hautomateH Offline
                  hautomate
                  @ghiglie hmm, not sure. Would you please update your repo with the latest and I'll try a reinstall and have a closer look?
                    G Offline
                    G Offline
                    ghiglie
                    sorry, I'm out for work :( I'll do ASAP tomorrow!
                    EDIT: Updated!
                    • G ghiglie
                      EDIT: Updated!
                      hautomateH Offline
                      hautomateH Offline
                      hautomate
                      @ghiglie It shows the last commit as 14 days ago...
                      • S Offline
                        swcrawford
                        Will be watching with interest. I'd like to move to hass.io but this is the one thing stopping me.
                          G Offline
                          G Offline
                          ghiglie
                          git-noob mistake! updated!
                          • G ghiglie
                            hautomateH Offline
                            hautomateH Offline
                            hautomate
                            @ghiglie said in Gateway Addon for Hass.io:
                            Haha! I forgot to tell you that I have no idea what I'm doing :)
                            The 'run chmod' command is still missing in the dockerfile.
                            • R Offline
                              R Offline
                              rusg323
                              Wondering what the status of this is. Would love to try it out as I have migrated to hassio and would love to integrate mysensors gateway back on the same rpi.
                              • kwekK Offline
                                kwekK Offline
                                kwek
                                I'm also trying to make a hassio addon for the mysensors gateway which is connected on the same raspberry pi 2.
                                If I run the docker image with --privileged then it runs correctly: it manages to read from the nrf2401, it connects to the MQTT server and publishes incoming messages.
                                However, if I run the container without --privileged (like hassio does), the mysgw program does not output anything else after:
                                : TSF:LRT:OK
                                : TSM:INIT
                                : TSF:WUR:MS=0
                                I'm running the container like this:
                                docker run -it --rm --cap-add SYS_RAWIO --device /dev/mem --device /dev/gpiomem local/mysgw
                                If I run a strace on the mysgw binary, I see:
                                bash-4.4# strace mysgw -d 2>&1 | grep open
                                open("/sys/class/gpio", O_RDONLY|O_LARGEFILE|O_DIRECTORY|O_CLOEXEC) = 3
                                open("/sys/class/gpio/gpiochip0/base", O_RDONLY|O_LARGEFILE) = 4
                                open("/sys/class/gpio/gpiochip0/ngpio", O_RDONLY|O_LARGEFILE) = 4
                                open("/sys/class/gpio/gpiochip100/base", O_RDONLY|O_LARGEFILE) = 4
                                open("/sys/class/gpio/gpiochip100/ngpio", O_RDONLY|O_LARGEFILE) = 4
                                open("/etc/mysensors.dat", O_RDONLY|O_LARGEFILE) = 3
                                open("/dev/urandom", O_RDONLY|O_LARGEFILE) = 3
                                open("/dev/console", O_WRONLY|O_NOCTTY|O_LARGEFILE|O_CLOEXEC) = 5
                                open("/etc/mysensors.dat", O_RDONLY|O_LARGEFILE) = 5
                                open("/proc/cpuinfo", O_RDONLY|O_LARGEFILE) = 5
                                open("/proc/device-tree/soc/ranges", O_RDONLY|O_LARGEFILE) = -1 ENOENT (No such file or directory)
                                open("/dev/mem", O_RDWR|O_SYNC|O_LARGEFILE) = 5
                                It looks like it can't open a device which is also described in https://www.mysensors.org/apidocs/group__BCM2835grp.html
                                It seems to be a symlink to some device in /sys, but this directory is empty somehow.
                                bash-4.4# ls -al /proc/device-tree
                                lrwxrwxrwx    1 root     root            29 May  7 15:10 /proc/device-tree -> /sys/firmware/devicetree/base
                                bash-4.4# ls -al /sys/firmware
                                total 0
                                drwxrwxrwt    2 root     root            40 May  7 15:34 .
                                dr-xr-xr-x   12 root     root             0 May  7 15:34 ..
                                That's how far I got. Does anyone know how to make this device available within the container without having to use --privileged?
                                • kwekK kwek
                                  : TSF:LRT:OK
                                  : TSM:INIT
                                  : TSF:WUR:MS=0
                                  total 0
                                  G Offline
                                  G Offline
                                  ghiglie
                                  Hi @kwek, sorry for taking so much to reply. We've been taking the same path!
                                  @kwek said in Gateway Addon for Hass.io:
                                  Same here. I've been trying some time ago, if I get to start the container in privileged mode it runs without any problems!
                                  So, I've been looking to how enable the GPIO on the board to the container, using the ResinOS guide: https://docs.resin.io/learn/develop/hardware/gpio/
                                  ...but I got nothing of use. You see anyway that the GPIO definitions are under the /sys/class/gpio/ device tree...
                                  I hope to have some more spare time to test this.
                                  • G ghiglie
                                    hautomateH Offline
                                    hautomateH Offline
                                    hautomate
                                    @ghiglie Here's an add-on that uses a pi gpio pin. Maybe it will help.
                                    https://github.com/pantomax/hassio-addons/tree/master/rpi-rf-receiver
                                    It's discussed in this thread:
                                    https://community.home-assistant.io/t/rpi-rf-receiver-addon/32947
                                      G Offline
                                      G Offline
                                      ghiglie
                                      @hautomate Thanks! I didn't notice it at all.
                                      EDIT: A quick look:
                                      @pantomax in config.json "only" has:
                                          "devices": ["/dev/mem:/dev/mem:rw"],
                                          "privileged": ["SYS_RAWIO"],
                                          "gpio": "true",
                                      ...while I put an overpowered:
                                        "devices": [ "/dev/mem:/dev/mem:rw" ],
                                        "privileged": [ "SYS_RAWIO", "SYS_ADMIN", "NET_ADMIN" ],
                                        "gpio": "true",
                                      so... it should work :(
                                      • B Offline
                                        B Offline
                                        BlackChart
                                        Did you get this up and running?
                                        12.1k
