  3. gateway on hass.io - not getting the sensors
6 Posts 3 Posters 2.5k Views 3 Watching
  • Giorgio GilestroG Offline
    Giorgio Gilestro
    I am relocating my network from veralite to home assistant and encountering some problems.
    The HASS server runs on a raspberry Pi 3 through hass.io
    The serial gateway appears to be properly running but there is no sign of life in home assistant beside a configuration file being created with json values about only one of the many nodes I have. No device is being created in the the webUI.
    The /config/mysensors.json file looks like this:
       "0":{
          "sensor_id":0,
          "children":{
          "type":18,
          "sketch_name":null,
          "sketch_version":null,
          "battery_level":0,
          "protocol_version":"2.1.1"
       "7":{
          "sensor_id":7,
          "children":{
             "0":{
                "id":0,
                "type":1,
                "description":"",
                "values":{
             "1":{
                "id":1,
                "type":4,
                "description":"",
                "values":{
             "2":{
                "id":2,
                "type":3,
                "description":"",
                "values":{
             "3":{
                "id":3,
                "type":25,
                "description":"",
                "values":{
          "type":17,
          "sketch_name":"mySensors Picture Frame",
          "sketch_version":"1.5",
          "battery_level":0,
          "protocol_version":"2.0.0"
    To check whether the gateway can receive any input, I have changed the code on one of my sensor and updated - among the rest - the version number from 1.5 to 1.6. As you may see in the file above, this was not picked up by home assistant in any way.
    In general, I am having a hard time troubleshooting what is wrong because I get not debug information regarding mysensors despite the fact this is properly (I think) configured in the configuration.yaml file. Here's the relevant portion.
    Any idea of what could be going wrong? Does anyone have a hello_world sketch that is known to be working with homeassistant that I could try? Thanks?
    logger:
      default: info
      logs:
        requests.packages.urllib3.connectionpool: critical
        requests.packages.urllib3: critical
        homeassistant.components.cameras: fatal
        homeassistant.components.mysensors: debug
    mysensors:
      gateways:
         - device: '/dev/ttyUSB0'
           persistence_file: '/config/mysensors.json'
           baud_rate: 115200
      optimistic: false
      persistence: true
      version: 2.0
    hautomateH martinhjelmareM 2 Replies Last reply
    • Giorgio GilestroG Giorgio Gilestro
         "0":{
            "sensor_id":0,
            "children":{
            "type":18,
            "sketch_name":null,
            "battery_level":0,
         "7":{
            "sensor_id":7,
            "children":{
               "0":{
                  "id":0,
                  "type":1,
                  "description":"",
                  "values":{
               "1":{
                  "id":1,
                  "type":4,
                  "description":"",
                  "values":{
               "2":{
                  "id":2,
                  "type":3,
                  "description":"",
                  "values":{
               "3":{
                  "id":3,
                  "type":25,
                  "description":"",
                  "values":{
            "type":17,
            "battery_level":0,
      logger:
        default: info
        logs:
      mysensors:
        gateways:
             baud_rate: 115200
        optimistic: false
        persistence: true
        version: 2.0
      hautomateH Offline
      hautomateH Offline
      hautomate
      @giorgio-gilestro
      Have a look at this thread. Maybe the latest release will show some logging for you?
      https://community.home-assistant.io/t/mysensors-mqtt-gateway-integration/39743/3
      Giorgio GilestroG 1 Reply Last reply
           "0":{
              "sensor_id":0,
              "children":{
              "type":18,
              "sketch_name":null,
              "battery_level":0,
           "7":{
              "sensor_id":7,
              "children":{
                 "0":{
                    "id":0,
                    "type":1,
                    "description":"",
                    "values":{
                 "1":{
                    "id":1,
                    "type":4,
                    "description":"",
                    "values":{
                 "2":{
                    "id":2,
                    "type":3,
                    "description":"",
                    "values":{
                 "3":{
                    "id":3,
                    "type":25,
                    "description":"",
                    "values":{
              "type":17,
              "battery_level":0,
        logger:
          default: info
          logs:
        mysensors:
          gateways:
               baud_rate: 115200
          optimistic: false
          persistence: true
          version: 2.0
        martinhjelmareM Offline
        martinhjelmare
        @giorgio-gilestro
        Serial logs from both a node and gateway can usually help pinpointing issues in the mysensors part of the comm link. This can also be used to rule out problems in that part.
        Is the mysensors serial gateway running on a standalone arduino connected via USB to the RPi3?
        • hautomateH hautomate
          @giorgio-gilestro
          Giorgio Gilestro
          @hautomate I am already running version 0.61.1
          @martinhjelmare Yes, it's the same serial gateway that used to be connected to my veralite. The Pi3 is powered by a 3A power supply so there's should be enough juice for everyone.
          Not sure how to intercept the serial log from the gateway, though. I've used socat for this purpose in the past but I doubt I can do from within a hassio instance.
          hautomateH 1 Reply Last reply
            Giorgio Gilestro
            Ok, so this miraculously started to work today after 48h. Obviously, I did not change anything myself. Go figure.
              hautomateH Offline
              hautomateH Offline
              hautomate
              @giorgio-gilestro said in gateway on hass.io - not getting the sensors:
              I think you can see that if you SSH to the host.
              https://home-assistant.io/developers/hassio/debugging/
