  3. Protecting a lock switch securely with MySensors and Domoticz
22 Posts 6 Posters 7.3k Views 5 Watching
  • SushukkaS Sushukka
    @monte True but one need to draw a line to some level. Thing is that in this case the hacker would need to stay close proximity of the house and that would be recorded to security cameras I have around the property. In some crowded apartment building the situation would be a whole lot different. In that case I probably wouldn't have permission to mess with the lock or at least I wouldn't allow any remote functionality with it. But just speculating...remote lock functionality on highly crowded area...MySensors+arduino signing but not cryptography -> maye nah, ESP8266 with WPA2 maybe good enough, RaspBerry or some miniLinux would give lots of options, but not realtime systems, maybe not that reliable stepper etc. handling anymore. HW level should be anyway easy to make secure enough, but controller like Domoticz could be the weak link. Maybe just force authentication to Domo everytime. It seems to prevent also direct REST calls as it should.
    monteM
    monteM
    monte
    @sushukka i agree with your point. I just wanted to bring light to some aspects that might be out of your view. Before you make any choice about security you better know what the choices are :) Last advice, google info about your wifi router, if it has any known vulnerabilities that would allow to hack it from outside without much effort.
      @monte Hmm, not a bad hack and easy one too. However, when using mobile devices and the maximum of ten choices in the dummy selector you need to use drop-down menu. Not very user friendly for pin input... Going to have this as a backup idea anyway. :)
      @jkandasa What I understand reverse proxy is a good solution when you don't have dozens of ESP8266 nodes already directly connected to Domoticz as Mysensors LAN gateways or...they use port 5003 and I should reverse proxy only the web gui port, right? In that case wouldn't that mean that every time I open Domoticz from any intranet device (mobile, laptop, pc), it would require authentication unless...I would define static IPs to all of them and whitelist them...?
      monteM
      monteM
      monte
      @sushukka I wrote my solution for this problem as I also have a lock-node to secure :)
      Look, maybe you will find it useful. https://forum.mysensors.org/topic/9204/secure-node-encrypted-communication-aes-128
