  3. No communication with NRF24L01 on RPi3 64bit [SOLVED]
3 Posts 2 Posters 1.3k Views 2 Watching
  • G
    G
    Gunther
    wrote on last edited by Gunther
    Hi!
    Just recently discovered MySensors and this is what I was looking for!
    Unfortunately I can't get communications my RPI3 to communicate with a NRF24L01.
    My setup: RPi3 with a custom kernel 4.13.16 using 64bit, with loaded kernel module spi_bcm2835.
    $ uname -r
    4.13.16-v8+
    $ cat /boot/config.txt
    dtparam=spi=on
    $ lsmod
    spi_bcm2835            20480  0
    $ ls /dev/spidev0.*
    /dev/spidev0.0  /dev/spidev0.1
    I use the dev-branch (also tried stable, same behavior):
    $ ./configure --prefix=/data/home/gunther/mysensors --my-transport=nrf24 --my-gateway=ethernet --my-port=5003
    [SECTION] Detecting target machine.
      [OK] machine detected: SoC=unknown, Type=unknown, CPU=aarch64.
    [SECTION] Checking GPIO Sysfs.
      [OK] /sys/class/gpio/export found
    [SECTION] Detecting SPI driver.
      [OK] SPI driver detected:SPIDEV.
    [SECTION] Detecting init system.
      [FAILED] unknown init system.
    [SECTION] Saving configuration.
    [SECTION] Cleaning previous builds.
    [OK] Finished.
    The unknown init system should be fine, as I do not want to create any startup scripts or move files somewhere.
    Running the gateway as root gives:
    $ ./bin/mysgw -d
    mysgw: Starting gateway...
    mysgw: Protocol version - 2.2.1-alpha
    mysgw: MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.1-alpha
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: !TSM:INIT:TSP FAIL
    mysgw: TSM:FAIL:CNT=1
    mysgw: TSM:FAIL:DIS
    mysgw: TSF:TDI:TSL
    This tells me that the communication between radio and RPI fails.
    I (more than) triple-checked the wiring.
    I use a voltage regulator from 5V to 3.3V and have a 47µF capacitor between GND and 3.3V. I also tried a different voltage regulator and NRF24L01.
    I assume the radio itself should be fine because attached to a Arduino Nano (with voltage regulator, without condensator) I see:
    16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.2.0
    25 TSM:INIT
    26 TSF:WUR:MS=0
    33 TSM:INIT:TSP OK
    35 TSM:FPAR
    37 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2046 !TSM:FPAR:NO REPLY
    Which I expect to the missing gateway.
    -) Is the SPIDEV driver ok? BCM does not compile for 64bit.
    -) Do I need to activate any GPIO ports with
    echo "$i" > /sys/class/gpio/export or anything alike?
    -) Is it ok, that I use other GPIO ports directly for other things?
    -) Is there a way to test that SPI is working properly?
    Thanks!
    G 1 Reply Last reply
    • G Gunther
      Hi!
      $ uname -r
      4.13.16-v8+
      dtparam=spi=on
      $ lsmod
      spi_bcm2835            20480  0
      $ ls /dev/spidev0.*
      [OK] Finished.
      $ ./bin/mysgw -d
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: TSM:FAIL:DIS
      mysgw: TSF:TDI:TSL
      25 TSM:INIT
      26 TSF:WUR:MS=0
      33 TSM:INIT:TSP OK
      35 TSM:FPAR
      Thanks!
      G
      G
      Gunther
      @gunther After fighting with this problem for some days, I now got it working. The solution was to use the BCM driver instead of SPIDEV.
      I achieved that by commenting out the 32 bit gcc flags in ./configure
      function gcc_cpu_flags {
          local soc=$1
          case $soc in
          BCM2835)
              flags="-march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard"
          BCM2836)
              flags="-march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard"
          BCM2837)
              flags=""
              #flags="-march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard"
      and running configure with this options:
      $ ./configure --my-transport=nrf24 --my-gateway=ethernet --my-port=5003 --soc=BCM2837
      Hope this shortens the learning curve for 64bit Rasperry Pi users!
      • G Gunther
            local soc=$1
            case $soc in
            BCM2835)
            BCM2836)
            BCM2837)
                flags=""
        @gunther great work, thanks for sharing! And welcome to the MySensors community :)
