  3. Error when communicating with EasyIot
4 Posts 4 Posters 2.3k Views 2 Watching
    A Former User
    Hello ,
    I have trouble to get the correct communication when communicating with EasyIoT.
    This is what ise on my Arduino (Mini pro) when debug is on.
    I need some help to understand protocol it does not match what is described in MySensors serial 1.4.
    sensor started, id 5
    send: 5-5-0-0 s=255,c=0,t=17,pt=0,l=5,st=fail:1.4.1
    send: 5-5-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
    send: 5-5-0-0 s=255,c=3,t=11,pt=0,l=13,st=fail:Temp,Door,Bat
    send: 5-5-0-0 s=255,c=3,t=12,pt=0,l=3,st=fail:1.0
    send: 5-5-0-0 s=0,c=0,t=6,pt=0,l=5,st=fail:1.4.1
    send: 5-5-0-0 s=1,c=0,t=0,pt=0,l=5,st=fail:1.4.1
    Door = 0
    send: 5-5-0-0 s=1,c=1,t=16,pt=2,l=2,st=fail:0
    send: 5-5-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
    batLevel = 100
    send: 5-5-0-0 s=255,c=3,t=0,pt=1,l=1,st=fail:100
    Temp = 21.10
    send: 5-5-0-0 s=0,c=1,t=0,pt=7,l=5,st=fail:21.1
    LOOP = 1
    Door = 0
    Regards sigolhi
    pvojP 1 Reply Last reply
    • skywatchS
      skywatchS
      skywatch
      I had a similar issue, but now EasyIoT is working with a test sensor well.
      Have you set both the pi gateway and the arduino to the same radio channel?
      That one got me scratching my head for a while! :)
      Skywatch.
      • ? A Former User
        Hello ,
        Door = 0
        batLevel = 100
        Temp = 21.10
        LOOP = 1
        Door = 0
        Regards sigolhi
        pvojP
        pvojP
        pvoj
        @sigolhi Almost the same problem here.
        See the forum topic: http://iot-playground.com/forum/mysensors-driver/43-configuring-mysensor-nodes
        Unfortunately no solution yet..
        EasyIoTE 1 Reply Last reply
        • pvojP pvoj
          EasyIoTE
          EasyIoTE
          EasyIoT
          wrote on last edited by EasyIoT
          @pvoj It shoud work. It works for me and other users also reports it works.
          EasyIoT framework http://iot-playground.com
