  3. Can't get encryption and signing to work
14 Posts 2 Posters 3.0k Views 2 Watching
  • vigonotionV
    vigonotionV
    vigonotion
    Hey guys,
    so encryption and signing seems to be exasperating. I've tried it over and over, read the documentation and some forum posts and tried to make it work.
    My goal is to have all my nodes to communicate encrypted and signed, so that nothing else but my nodes can read the sensor data and send sensor data to the Gateway.
    I do not have an ATSHA so I want to go with soft signing. What I've done so far:
    • Running the personalizer with Soft Signing for the GW and Soft Signing Serial for my sensors
    • Tried many different combinations of the Signing and Encryption definitions.
      Currently, I've got these definitions:
    /** SIGNING AND ENCRYPTION **/
    // Setup Soft Signing
    #define MY_SIGNING_SOFT
    #define MY_SIGNING_SOFT_RANDOMSEED_PIN 7
    #define MY_SECURITY_SIMPLE_PASSWD "XXXXXXXXXXXXXXXX"
    //#define MY_RF24_ENABLE_ENCRYPTION
    /** END SIGNING AND ENCRYPTION **/
    I've tried this out with and without Simple Password enabled, but as I understand it correctly, using the Personalizer is more secure so I want to go with the personalizer.
    What I get:
    1. The gateway accepts everything. A normal node (no signing, no personalization whatsoever) can send data to the gateway
    2. The gateway accepts nothing. Neither the node run with the same personalizer sketch/simple passwd nor any other node without security settings.
    I can't get behind this security and signing thing as I can't get it running. Can you guys help me?
    Thanks in advance
    Tom
    PS: Hard- and Software:
    • Arduino Pro Mini 3V3 and 5V for Sensor Nodes
    • ESP8266 for MQTT Gateway
    • PlatformIO with MySensors 2.2.0
    • NRF24 Antennas (the normal ones)
    AnticimexA 1 Reply Last reply
    • vigonotionV vigonotion
      Hey guys,
      What I get:
      Thanks in advance
      Tom
      AnticimexA
      AnticimexA
      Anticimex
      @b1ackra1n hi,
      First of all, the simple password flag is mutually exclusive with all other security settings.
      Secondly, make sure you set any sketch specific defines prior to including mysensors.h.
      Thirdly, there are debugging flags to enable so you get more detailed logs. Right now you provide nothing, so it is impossible to determine what the problem is.
      • vigonotionV
        vigonotionV
        vigonotion
        1. It doesn't work with SIMPLE_PASSWD disabled either
        currently I'm trying it with these settings:
        1. Yeah, defines are all above the include
        2. I can't get #define MY_DEBUG_VERBOSE_SIGNING to work, the output is just gibberish, but here are my normal debug prints from the sensor node:
         __  __       ____
                |___/                      2.2.0
        32 MCO:BGN:INIT NODE,CP=RNNNAS-X,VER=2.2.0
        124 TSM:INIT
        126 TSF:WUR:MS=0
        137 TSM:INIT:TSP OK
        141 TSM:INIT:STATID=42
        145 TSF:SID:OK,ID=42
        149 TSM:FPAR
        231 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        376 TSF:MSG:READ,0-0-42,s=255,c=3,t=8,pt=1,l=1,sg=1:0
        387 TSF:MSG:FPAR OK,ID=0,D=1
        2246 TSM:FPAR:OK
        2248 TSM:ID
        2250 TSM:ID:OK
        2254 TSM:UPL
        2260 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
        2312 TSF:MSG:READ,0-0-42,s=255,c=3,t=25,pt=1,l=1,sg=1:1
        2322 TSF:MSG:PONG RECV,HP=1
        2328 TSM:UPL:OK
        2330 TSM:READY:ID=42,PAR=0,DIS=1
        2347 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
        2369 TSF:MSG:READ,0-0-42,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
        2392 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
        2404 !TSF:MSG:SIGN FAIL
        2414 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=1,st=OK:
        2426 !TSF:MSG:SIGN FAIL
        2435 TSF:MSG:READ,0-0-42,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
        2609 TSF:MSG:READ,0-0-42,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
        4431 !TSF:MSG:SIGN FAIL
        4435 !TSF:MSG:SIGN FAIL
        4440 !TSF:MSG:SIGN FAIL
        4544 !TSF:MSG:SIGN FAIL
        4648 !TSF:MSG:SIGN FAIL
        4753 !TSF:MSG:SIGN FAIL
        4757 MCO:REG:REQ
        4765 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=7,st=OK:2
        4804 TSF:MSG:READ,0-0-42,s=255,c=3,t=16,pt=0,l=0,sg=1:
        4851 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
        4886 TSF:MSG:READ,0-0-42,s=255,c=3,t=27,pt=1,l=1,sg=1:1
        4896 !TSF:MSG:SIGN VERIFY FAIL
        4900 MCO:BGN:STP
        XXX - STARTING NODE - XXX
        4904 MCO:BGN:INIT OK,TSP=1
        4915 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
        4923 TSF:TDI:TSL
        4927 MCO:SLP:WUP=-1
        4931 TSF:TRI:TSB
        4933 !TSF:MSG:SIGN FAIL
        4937 !TSF:MSG:SIGN FAIL
        4943 !TSF:MSG:SIGN FAIL
        4947 !TSF:MSG:SIGN FAIL
        4952 MCO:SLP:MS=1000,SMS=0,I1=255,M1=255,I2=255,M2=255
        4962 TSF:TDI:TSL
        4966 MCO:SLP:WUP=-1
        4968 TSF:TRI:TSB
        4972 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
        4982 TSF:TDI:TSL
        4984 MCO:SLP:WUP=-1
        4988 TSF:TRI:TSB
        4993 MCO:SLP:MS=1000,SMS=0,I1=255,M1=255,I2=255,M2=255
        5003 TSF:TDI:TSL
        5005 MCO:SLP:WUP=-1
        5009 TSF:TRI:TSB
        5013 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
        5023 TSF:TDI:TSL
        5025 MCO:SLP:WUP=-1
        5029 TSF:TRI:TSB
        5033 MCO:SLP:MS=1000,SMS=0,I1=255,M1=255,I2=255,M2=255
        5042 TSF:TDI:TSL
        5046 MCO:SLP:WUP=-1
        5050 TSF:TRI:TSB
        5054 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
        5062 TSF:TDI:TSL
        5066 MCO:SLP:WUP=-1
        5070 TSF:TRI:TSB
        and from the gateway:
        1093 GWT:TPC:CONNECTING...
        1098 GWT:TPC:IP=192.168.1.70
        1103 MCO:BGN:STP
        1106 MCO:BGN:INIT OK,TSP=1
        1111 GWT:TPC:IP=192.168.1.70
        1116 GWT:RMQ:MQTT RECONNECT
        1138 GWT:RMQ:MQTT CONNECTED
        1143 GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
        1154 GWT:TPS:TOPIC=mygateway1-out/0/255/3/0/11,MSG SENT
        1164 GWT:TPS:TOPIC=mygateway1-out/0/255/3/0/12,MSG SENT
        pm open,type:2 0
        13651 TSF:MSG:READ,42-42-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        13661 TSF:MSG:BC
        13664 TSF:MSG:FPAR REQ,ID=42
        13669 TSF:PNG:SEND,TO=0
        13674 TSF:CKU:OK
        13677 TSF:MSG:GWL OK
        14051 TSF:MSG:SEND,0-0-42-42,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        14704 TSF:MSG:READ,42-42-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
        14714 TSF:MSG:PINGED,ID=42,HP=1
        14727 TSF:MSG:SEND,0-0-42-42,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
        14742 TSF:MSG:READ,42-42-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
        14755 TSF:MSG:SEND,0-0-42-42,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
        15940 TSF:MSG:READ,42-42-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
        15957 TSF:MSG:SEND,0-0-42-42,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
        15981 TSF:MSG:READ,42-42-0,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
        15997 TSF:MSG:SEND,0-0-42-42,s=255,c=3,t=27,pt=1,l=1,sg=1,ft=0,st=OK:1
        33057 TSF:MSG:READ,42-42-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        33068 TSF:MSG:BC
        33071 TSF:MSG:FPAR REQ,ID=42
        33076 TSF:PNG:SEND,TO=0
        33080 TSF:CKU:OK
        33083 TSF:MSG:GWL OK
        33409 TSF:MSG:SEND,0-0-42-42,s=255,c=3,t=8,pt=1,l=1,sg=1,ft=0,st=OK:0
        34109 TSF:MSG:READ,42-42-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
        34120 TSF:MSG:PINGED,ID=42,HP=1
        34137 TSF:MSG:SEND,0-0-42-42,s=255,c=3,t=25,pt=1,l=1,sg=1,ft=0,st=OK:1
        Still trying to get those signing debug logs to work, but I hope these logs already help
        vigonotionV AnticimexA 2 Replies Last reply
           __  __       ____
                  |___/                      2.2.0
          124 TSM:INIT
          126 TSF:WUR:MS=0
          137 TSM:INIT:TSP OK
          149 TSM:FPAR
          2246 TSM:FPAR:OK
          2248 TSM:ID
          2250 TSM:ID:OK
          2254 TSM:UPL
          2328 TSM:UPL:OK
          4757 MCO:REG:REQ
          4900 MCO:BGN:STP
          4923 TSF:TDI:TSL
          4927 MCO:SLP:WUP=-1
          4931 TSF:TRI:TSB
          4962 TSF:TDI:TSL
          4966 MCO:SLP:WUP=-1
          4968 TSF:TRI:TSB
          4982 TSF:TDI:TSL
          4984 MCO:SLP:WUP=-1
          4988 TSF:TRI:TSB
          5003 TSF:TDI:TSL
          5005 MCO:SLP:WUP=-1
          5009 TSF:TRI:TSB
          5023 TSF:TDI:TSL
          5025 MCO:SLP:WUP=-1
          5029 TSF:TRI:TSB
          5042 TSF:TDI:TSL
          5046 MCO:SLP:WUP=-1
          5050 TSF:TRI:TSB
          5062 TSF:TDI:TSL
          5066 MCO:SLP:WUP=-1
          5070 TSF:TRI:TSB
          1103 MCO:BGN:STP
          pm open,type:2 0
          13661 TSF:MSG:BC
          13674 TSF:CKU:OK
          33068 TSF:MSG:BC
          33080 TSF:CKU:OK
          vigonotionV
          vigonotionV
          vigonotion
          @b1ackra1n
          Okay got the signing debug prints (sensor node)
          79 SGN:PER:OK
          112 SGN:INI:BND OK
          122 SGN:SKP:MSG CMD=3,TYPE=7
          1449 SGN:SKP:MSG CMD=3,TYPE=8
          2209 SGN:SKP:MSG CMD=3,TYPE=24
          2271 SGN:SKP:MSG CMD=3,TYPE=25
          2277 SGN:PRE:SGN REQ
          2279 SGN:PRE:WHI NREQ
          2283 SGN:SKP:MSG CMD=3,TYPE=15
          2293 SGN:PRE:XMT,TO=0
          2297 SGN:PRE:WAIT GW
          2322 SGN:SKP:MSG CMD=3,TYPE=15
          2326 SGN:PRE:SGN REQ,FROM=0
          2332 SGN:SKP:MSG CMD=3,TYPE=16
          2342 SGN:SGN:NCE REQ,TO=0
          2377 SGN:SKP:MSG CMD=3,TYPE=17
          2383 SGN:NCE:FROM=0
          2387 SGN:BND:NONCE=X
          2562 SGN:BND:HMAC=X
          2576 SGN:SGN:SGN
          2586 SGN:SKP:MSG CMD=3,TYPE=16
          2598 SGN:SGN:NCE REQ,TO=0
          2672 SGN:SKP:MSG CMD=3,TYPE=17
          2678 SGN:NCE:FROM=0
          2682 SGN:BND:NONCE=X
          2856 SGN:BND:HMAC=X
          2871 SGN:SGN:SGN
          4888 SGN:SKP:MSG CMD=3,TYPE=16
          4900 SGN:SGN:NCE REQ,TO=0
          4904 !SGN:SGN:SGN FAIL
          4909 SGN:SKP:MSG CMD=3,TYPE=16
          4921 SGN:SGN:NCE REQ,TO=0
          4927 !SGN:SGN:SGN FAIL
          4931 SGN:SKP:MSG CMD=3,TYPE=16
          4943 SGN:SGN:NCE REQ,TO=0
          4947 !SGN:SGN:SGN FAIL
          5052 SGN:SKP:MSG CMD=3,TYPE=16
          5154 !SGN:SGN:NCE REQ,TO=0 FAIL
          5261 SGN:SKP:MSG CMD=3,TYPE=16
          5365 !SGN:SGN:NCE REQ,TO=0 FAIL
          5470 SGN:SKP:MSG CMD=3,TYPE=16
          5574 !SGN:SGN:NCE REQ,TO=0 FAIL
          5580 SGN:SKP:MSG CMD=3,TYPE=26
          5683 SGN:SKP:MSG CMD=3,TYPE=7
          5789 SGN:SKP:MSG CMD=3,TYPE=17
          5795 SGN:NCE:FROM=0
          5799 SGN:BND:NONCE=X
          5974 SGN:BND:HMAC=X
          5992 SGN:SKP:MSG CMD=3,TYPE=17
          5998 SGN:NCE:FROM=0
          6000 SGN:BND:NONCE=X
          6176 SGN:BND:HMAC=X
          6195 SGN:SKP:MSG CMD=3,TYPE=17
          6199 SGN:NCE:FROM=0
          6203 SGN:BND:NONCE=X
          6377 SGN:BND:HMAC=X
          6633 SGN:SKP:MSG CMD=3,TYPE=8
          7786 SGN:SGN:NREQ=0
          7845 SGN:SKP:MSG CMD=3,TYPE=25
          PS: if anybody else has problems setting those up, you can only use MY_DEBUG or MY_DEBUG_VERBOSE_SIGNING. I had both enabled.
             __  __       ____
                    |___/                      2.2.0
            124 TSM:INIT
            126 TSF:WUR:MS=0
            137 TSM:INIT:TSP OK
            149 TSM:FPAR
            2246 TSM:FPAR:OK
            2248 TSM:ID
            2250 TSM:ID:OK
            2254 TSM:UPL
            2328 TSM:UPL:OK
            4757 MCO:REG:REQ
            4900 MCO:BGN:STP
            4923 TSF:TDI:TSL
            4927 MCO:SLP:WUP=-1
            4931 TSF:TRI:TSB
            4962 TSF:TDI:TSL
            4966 MCO:SLP:WUP=-1
            4968 TSF:TRI:TSB
            4982 TSF:TDI:TSL
            4984 MCO:SLP:WUP=-1
            4988 TSF:TRI:TSB
            5003 TSF:TDI:TSL
            5005 MCO:SLP:WUP=-1
            5009 TSF:TRI:TSB
            5023 TSF:TDI:TSL
            5025 MCO:SLP:WUP=-1
            5029 TSF:TRI:TSB
            5042 TSF:TDI:TSL
            5046 MCO:SLP:WUP=-1
            5050 TSF:TRI:TSB
            5062 TSF:TDI:TSL
            5066 MCO:SLP:WUP=-1
            5070 TSF:TRI:TSB
            1103 MCO:BGN:STP
            pm open,type:2 0
            13661 TSF:MSG:BC
            13674 TSF:CKU:OK
            33068 TSF:MSG:BC
            33080 TSF:CKU:OK
            AnticimexA
            AnticimexA
            Anticimex
            @b1ackra1n not really. If you run with personalizer (which by the way without an atsha is not much more secure than the simple password flag). I'd suggest you start with the simple flag first. If personalization has not been executed properly, signing won't work.
            vigonotionV 1 Reply Last reply
              @b1ackra1n
              79 SGN:PER:OK
              112 SGN:INI:BND OK
              2383 SGN:NCE:FROM=0
              2562 SGN:BND:HMAC=X
              2576 SGN:SGN:SGN
              2678 SGN:NCE:FROM=0
              2856 SGN:BND:HMAC=X
              2871 SGN:SGN:SGN
              5795 SGN:NCE:FROM=0
              5974 SGN:BND:HMAC=X
              5998 SGN:NCE:FROM=0
              6176 SGN:BND:HMAC=X
              6199 SGN:NCE:FROM=0
              6377 SGN:BND:HMAC=X
              7786 SGN:SGN:NREQ=0
              AnticimexA
              AnticimexA
              Anticimex
              @b1ackra1n said in Can't get encryption and signing to work:
              This is also in the documentation: https://www.mysensors.org/apidocs/group__MySigningTroubleshootinggrp.html
              Also, you don't need to obfuscate nonce and hmac signatures. They are not secret. Confirming that node and gw agree on these is a good place to start troubleshooting.
              • AnticimexA Anticimex
                vigonotionV
                vigonotionV
                vigonotion
                @anticimex what I've now done is I'm just using the MY_SECURITY_SIMPLE_PASSWD flag.
                This is my sensor nodes output:
                2154 SGN:PRE:SGN NREQ
                2158 SGN:PRE:WHI NREQ
                2166 SGN:PRE:XMT,TO=0
                2170 SGN:PRE:WAIT GW
                2205 SGN:PRE:NSUP
                The sensor node can send messages to the GW, but the GW also accepts messages from nodes without signing, which is not yet what I wanted.
                I'm now checking if GW and Sensor agree on Nonce and HMAC
                  2205 SGN:PRE:NSUP
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @b1ackra1n SGN:PRE:NSUP indicate that one of your nodes does not support signing, so your definitions are not correctly set on either the node or the GW.
                    vigonotionV
                    vigonotionV
                    vigonotion
                    @anticimex I think it's the GW:
                    11607 SGN:PRE:NSUP,TO=42
                    11613 SGN:PRE:XMT,TO=42
                    But I can't find what I've done wrong:
                    // #define MY_SIGNING_SOFT
                    // #define MY_SIGNING_SOFT_RANDOMSEED_PIN 7
                    // #define MY_SIGNING_REQUEST_SIGNATURES
                    // #define MY_RF24_ENABLE_ENCRYPTION
                    #define MY_GATEWAY_ESP8266
                    // Set MQTT client id
                    #define MY_MQTT_CLIENT_ID "mysensors-gw"
                    #define MY_NODE_ID 1
                    #define MY_MQTT_USER "XXX"
                    #define MY_MQTT_PASSWORD "XXX"
                    // Set WIFI SSID and password
                    #define MY_ESP8266_SSID "XXX"
                    #define MY_ESP8266_PASSWORD "XXX"
                    #define MY_ESP8266_HOSTNAME "mqtt-sensor-gateway"
                    // MQTT broker ip address.
                    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, X
                    #define MY_PORT X
                    #define SN "MySensors MQTT Gateway"
                    #define SV "1.0"
                    #include <Arduino.h>
                    #include <ESP8266WiFi.h>
                      // Send the Sketch Info
                      sendSketchInfo(SN, SV);
                      #define MY_PORT X
                      #define SV "1.0"
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @b1ackra1n I can't either to be honest. It seems like your gw at some point disable the feature. You could dig down the code to see what the simple password flag actually enables, and add #error statements at the bottom of your gw sketch to validate that the expected flags remain set.
                      Unfortunately I am knocked out in bed by some influenza so I cannot do effective code digging for the moment.
                        vigonotionV
                        vigonotionV
                        vigonotion
                        @anticimex I think I got it working. The problem was that i used #define MY_SECURITY_SIMPLE_PASSWD instead of #define MY_SIGNING_SIMPLE_PASSWD (did I read the wrong docs? https://www.mysensors.org/apidocs-beta/group__SigningSettingGrpPub.html#gaedf8ec407fbde609a520ea0d95da2aac)
                        With that, only nodes with that password are able to communicate. Still needs some testing, but seems to work.
                        That's for the SIMPLE_PASSWD part. Next step would be getting Soft Signing to work, I will try that now and then send the debug logs.
                        Thanks already, if everything else fails, I'm now able to use at least the SIMPLE_PASSWD.
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @b1ackra1n the link points to the beta release. So it is aligned with the development branch, not the master branch, and it looks like you use the official 2.2.0 release, so strip the -beta part of the url. My troubleshooting link also points to the release documentation.
                          • vigonotionV
                            vigonotionV
                            vigonotion
                            Now I got Soft Signing to work, although I'm not yet sure why it works now:
                            /** SOFT SIGNING **/
                            /** END SOFT SIGNING **/
                            I think the problem was that "the simple password flag is mutually exclusive" (thanks @Anticimex).
                            Now everything works as expected!
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @b1ackra1n good news 👍
