  3. Can't get encryption and signing to work
14 Posts 2 Posters 3.0k Views 2 Watching
  • vigonotionV vigonotion
    1. It doesn't work with SIMPLE_PASSWD disabled either
    currently I'm trying it with these settings:
    #define MY_SIGNING_SOFT
    1. Yeah, defines are all above the include
    2. I can't get #define MY_DEBUG_VERBOSE_SIGNING to work, the output is just gibberish, but here are my normal debug prints from the sensor node:
     __  __       ____
            |___/                      2.2.0
    32 MCO:BGN:INIT NODE,CP=RNNNAS-X,VER=2.2.0
    124 TSM:INIT
    126 TSF:WUR:MS=0
    137 TSM:INIT:TSP OK
    141 TSM:INIT:STATID=42
    145 TSF:SID:OK,ID=42
    149 TSM:FPAR
    231 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    376 TSF:MSG:READ,0-0-42,s=255,c=3,t=8,pt=1,l=1,sg=1:0
    387 TSF:MSG:FPAR OK,ID=0,D=1
    2246 TSM:FPAR:OK
    2248 TSM:ID
    2250 TSM:ID:OK
    2254 TSM:UPL
    2260 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2312 TSF:MSG:READ,0-0-42,s=255,c=3,t=25,pt=1,l=1,sg=1:1
    2322 TSF:MSG:PONG RECV,HP=1
    2328 TSM:UPL:OK
    2330 TSM:READY:ID=42,PAR=0,DIS=1
    2347 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
    2369 TSF:MSG:READ,0-0-42,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
    2392 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
    2404 !TSF:MSG:SIGN FAIL
    2414 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=1,st=OK:
    2426 !TSF:MSG:SIGN FAIL
    2435 TSF:MSG:READ,0-0-42,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
    2609 TSF:MSG:READ,0-0-42,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
    4431 !TSF:MSG:SIGN FAIL
    4435 !TSF:MSG:SIGN FAIL
    4440 !TSF:MSG:SIGN FAIL
    4544 !TSF:MSG:SIGN FAIL
    4648 !TSF:MSG:SIGN FAIL
    4753 !TSF:MSG:SIGN FAIL
    4757 MCO:REG:REQ
    4765 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=7,st=OK:2
    4804 TSF:MSG:READ,0-0-42,s=255,c=3,t=16,pt=0,l=0,sg=1:
    4851 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
    4886 TSF:MSG:READ,0-0-42,s=255,c=3,t=27,pt=1,l=1,sg=1:1
    4896 !TSF:MSG:SIGN VERIFY FAIL
    4900 MCO:BGN:STP
    XXX - STARTING NODE - XXX
    4904 MCO:BGN:INIT OK,TSP=1
    4915 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
    4923 TSF:TDI:TSL
    4927 MCO:SLP:WUP=-1
    4931 TSF:TRI:TSB
    4933 !TSF:MSG:SIGN FAIL
    4937 !TSF:MSG:SIGN FAIL
    4943 !TSF:MSG:SIGN FAIL
    4947 !TSF:MSG:SIGN FAIL
    4952 MCO:SLP:MS=1000,SMS=0,I1=255,M1=255,I2=255,M2=255
    4962 TSF:TDI:TSL
    4966 MCO:SLP:WUP=-1
    4968 TSF:TRI:TSB
    4972 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
    4982 TSF:TDI:TSL
    4984 MCO:SLP:WUP=-1
    4988 TSF:TRI:TSB
    4993 MCO:SLP:MS=1000,SMS=0,I1=255,M1=255,I2=255,M2=255
    5003 TSF:TDI:TSL
    5005 MCO:SLP:WUP=-1
    5009 TSF:TRI:TSB
    5013 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
    5023 TSF:TDI:TSL
    5025 MCO:SLP:WUP=-1
    5029 TSF:TRI:TSB
    5033 MCO:SLP:MS=1000,SMS=0,I1=255,M1=255,I2=255,M2=255
    5042 TSF:TDI:TSL
    5046 MCO:SLP:WUP=-1
    5050 TSF:TRI:TSB
    5054 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
    5062 TSF:TDI:TSL
    5066 MCO:SLP:WUP=-1
    5070 TSF:TRI:TSB
    and from the gateway:
    1093 GWT:TPC:CONNECTING...
    1098 GWT:TPC:IP=192.168.1.70
    1103 MCO:BGN:STP
    1106 MCO:BGN:INIT OK,TSP=1
    1111 GWT:TPC:IP=192.168.1.70
    1116 GWT:RMQ:MQTT RECONNECT
    1138 GWT:RMQ:MQTT CONNECTED
    1143 GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
    1154 GWT:TPS:TOPIC=mygateway1-out/0/255/3/0/11,MSG SENT
    1164 GWT:TPS:TOPIC=mygateway1-out/0/255/3/0/12,MSG SENT
    pm open,type:2 0
    13651 TSF:MSG:READ,42-42-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    13661 TSF:MSG:BC
    13664 TSF:MSG:FPAR REQ,ID=42
    13669 TSF:PNG:SEND,TO=0
    13674 TSF:CKU:OK
    13677 TSF:MSG:GWL OK
    14051 TSF:MSG:SEND,0-0-42-42,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    14704 TSF:MSG:READ,42-42-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    14714 TSF:MSG:PINGED,ID=42,HP=1
    14727 TSF:MSG:SEND,0-0-42-42,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
    14742 TSF:MSG:READ,42-42-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
    14755 TSF:MSG:SEND,0-0-42-42,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
    15940 TSF:MSG:READ,42-42-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
    15957 TSF:MSG:SEND,0-0-42-42,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
    15981 TSF:MSG:READ,42-42-0,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
    15997 TSF:MSG:SEND,0-0-42-42,s=255,c=3,t=27,pt=1,l=1,sg=1,ft=0,st=OK:1
    33057 TSF:MSG:READ,42-42-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    33068 TSF:MSG:BC
    33071 TSF:MSG:FPAR REQ,ID=42
    33076 TSF:PNG:SEND,TO=0
    33080 TSF:CKU:OK
    33083 TSF:MSG:GWL OK
    33409 TSF:MSG:SEND,0-0-42-42,s=255,c=3,t=8,pt=1,l=1,sg=1,ft=0,st=OK:0
    34109 TSF:MSG:READ,42-42-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    34120 TSF:MSG:PINGED,ID=42,HP=1
    34137 TSF:MSG:SEND,0-0-42-42,s=255,c=3,t=25,pt=1,l=1,sg=1,ft=0,st=OK:1
    Still trying to get those signing debug logs to work, but I hope these logs already help
    vigonotionV
    vigonotionV
    vigonotion
    @b1ackra1n
    Okay got the signing debug prints (sensor node)
    79 SGN:PER:OK
    112 SGN:INI:BND OK
    122 SGN:SKP:MSG CMD=3,TYPE=7
    1449 SGN:SKP:MSG CMD=3,TYPE=8
    2209 SGN:SKP:MSG CMD=3,TYPE=24
    2271 SGN:SKP:MSG CMD=3,TYPE=25
    2277 SGN:PRE:SGN REQ
    2279 SGN:PRE:WHI NREQ
    2283 SGN:SKP:MSG CMD=3,TYPE=15
    2293 SGN:PRE:XMT,TO=0
    2297 SGN:PRE:WAIT GW
    2322 SGN:SKP:MSG CMD=3,TYPE=15
    2326 SGN:PRE:SGN REQ,FROM=0
    2332 SGN:SKP:MSG CMD=3,TYPE=16
    2342 SGN:SGN:NCE REQ,TO=0
    2377 SGN:SKP:MSG CMD=3,TYPE=17
    2383 SGN:NCE:FROM=0
    2387 SGN:BND:NONCE=X
    2562 SGN:BND:HMAC=X
    2576 SGN:SGN:SGN
    2586 SGN:SKP:MSG CMD=3,TYPE=16
    2598 SGN:SGN:NCE REQ,TO=0
    2672 SGN:SKP:MSG CMD=3,TYPE=17
    2678 SGN:NCE:FROM=0
    2682 SGN:BND:NONCE=X
    2856 SGN:BND:HMAC=X
    2871 SGN:SGN:SGN
    4888 SGN:SKP:MSG CMD=3,TYPE=16
    4900 SGN:SGN:NCE REQ,TO=0
    4904 !SGN:SGN:SGN FAIL
    4909 SGN:SKP:MSG CMD=3,TYPE=16
    4921 SGN:SGN:NCE REQ,TO=0
    4927 !SGN:SGN:SGN FAIL
    4931 SGN:SKP:MSG CMD=3,TYPE=16
    4943 SGN:SGN:NCE REQ,TO=0
    4947 !SGN:SGN:SGN FAIL
    5052 SGN:SKP:MSG CMD=3,TYPE=16
    5154 !SGN:SGN:NCE REQ,TO=0 FAIL
    5261 SGN:SKP:MSG CMD=3,TYPE=16
    5365 !SGN:SGN:NCE REQ,TO=0 FAIL
    5470 SGN:SKP:MSG CMD=3,TYPE=16
    5574 !SGN:SGN:NCE REQ,TO=0 FAIL
    5580 SGN:SKP:MSG CMD=3,TYPE=26
    5683 SGN:SKP:MSG CMD=3,TYPE=7
    5789 SGN:SKP:MSG CMD=3,TYPE=17
    5795 SGN:NCE:FROM=0
    5799 SGN:BND:NONCE=X
    5974 SGN:BND:HMAC=X
    5992 SGN:SKP:MSG CMD=3,TYPE=17
    5998 SGN:NCE:FROM=0
    6000 SGN:BND:NONCE=X
    6176 SGN:BND:HMAC=X
    6195 SGN:SKP:MSG CMD=3,TYPE=17
    6199 SGN:NCE:FROM=0
    6203 SGN:BND:NONCE=X
    6377 SGN:BND:HMAC=X
    6633 SGN:SKP:MSG CMD=3,TYPE=8
    7786 SGN:SGN:NREQ=0
    7845 SGN:SKP:MSG CMD=3,TYPE=25
    PS: if anybody else has problems setting those up, you can only use MY_DEBUG or MY_DEBUG_VERBOSE_SIGNING. I had both enabled.
    AnticimexA 1 Reply Last reply
       __  __       ____
              |___/                      2.2.0
      124 TSM:INIT
      126 TSF:WUR:MS=0
      137 TSM:INIT:TSP OK
      149 TSM:FPAR
      2246 TSM:FPAR:OK
      2248 TSM:ID
      2250 TSM:ID:OK
      2254 TSM:UPL
      2328 TSM:UPL:OK
      4757 MCO:REG:REQ
      4900 MCO:BGN:STP
      4923 TSF:TDI:TSL
      4927 MCO:SLP:WUP=-1
      4931 TSF:TRI:TSB
      4962 TSF:TDI:TSL
      4966 MCO:SLP:WUP=-1
      4968 TSF:TRI:TSB
      4982 TSF:TDI:TSL
      4984 MCO:SLP:WUP=-1
      4988 TSF:TRI:TSB
      5003 TSF:TDI:TSL
      5005 MCO:SLP:WUP=-1
      5009 TSF:TRI:TSB
      5023 TSF:TDI:TSL
      5025 MCO:SLP:WUP=-1
      5029 TSF:TRI:TSB
      5042 TSF:TDI:TSL
      5046 MCO:SLP:WUP=-1
      5050 TSF:TRI:TSB
      5062 TSF:TDI:TSL
      5066 MCO:SLP:WUP=-1
      5070 TSF:TRI:TSB
      1103 MCO:BGN:STP
      pm open,type:2 0
      13661 TSF:MSG:BC
      13674 TSF:CKU:OK
      33068 TSF:MSG:BC
      33080 TSF:CKU:OK
      AnticimexA
      AnticimexA
      Anticimex
      @b1ackra1n not really. If you run with personalizer (which by the way without an atsha is not much more secure than the simple password flag). I'd suggest you start with the simple flag first. If personalization has not been executed properly, signing won't work.
      vigonotionV 1 Reply Last reply
        @b1ackra1n
        79 SGN:PER:OK
        112 SGN:INI:BND OK
        2383 SGN:NCE:FROM=0
        2562 SGN:BND:HMAC=X
        2576 SGN:SGN:SGN
        2678 SGN:NCE:FROM=0
        2856 SGN:BND:HMAC=X
        2871 SGN:SGN:SGN
        5795 SGN:NCE:FROM=0
        5974 SGN:BND:HMAC=X
        5998 SGN:NCE:FROM=0
        6176 SGN:BND:HMAC=X
        6199 SGN:NCE:FROM=0
        6377 SGN:BND:HMAC=X
        7786 SGN:SGN:NREQ=0
        AnticimexA
        AnticimexA
        Anticimex
        @b1ackra1n said in Can't get encryption and signing to work:
        This is also in the documentation: https://www.mysensors.org/apidocs/group__MySigningTroubleshootinggrp.html
        Also, you don't need to obfuscate nonce and hmac signatures. They are not secret. Confirming that node and gw agree on these is a good place to start troubleshooting.
        • AnticimexA Anticimex
          vigonotionV
          vigonotionV
          vigonotion
          @anticimex what I've now done is I'm just using the MY_SECURITY_SIMPLE_PASSWD flag.
          This is my sensor nodes output:
          2154 SGN:PRE:SGN NREQ
          2158 SGN:PRE:WHI NREQ
          2166 SGN:PRE:XMT,TO=0
          2170 SGN:PRE:WAIT GW
          2205 SGN:PRE:NSUP
          The sensor node can send messages to the GW, but the GW also accepts messages from nodes without signing, which is not yet what I wanted.
          I'm now checking if GW and Sensor agree on Nonce and HMAC
            2205 SGN:PRE:NSUP
            AnticimexA
            AnticimexA
            Anticimex
            @b1ackra1n SGN:PRE:NSUP indicate that one of your nodes does not support signing, so your definitions are not correctly set on either the node or the GW.
              vigonotionV
              vigonotionV
              vigonotion
              @anticimex I think it's the GW:
              11607 SGN:PRE:NSUP,TO=42
              11613 SGN:PRE:XMT,TO=42
              But I can't find what I've done wrong:
              /** SIGNING AND ENCRYPTION **/
              // Setup Soft Signing
              // #define MY_SIGNING_SOFT
              // #define MY_SIGNING_SOFT_RANDOMSEED_PIN 7
              // #define MY_SIGNING_REQUEST_SIGNATURES
              #define MY_SECURITY_SIMPLE_PASSWD "XXXXXXXXXXXXXXXX"
              // #define MY_RF24_ENABLE_ENCRYPTION
              /** END SIGNING AND ENCRYPTION **/
              #define MY_GATEWAY_ESP8266
              // Set MQTT client id
              #define MY_MQTT_CLIENT_ID "mysensors-gw"
              #define MY_NODE_ID 1
              #define MY_MQTT_USER "XXX"
              #define MY_MQTT_PASSWORD "XXX"
              // Set WIFI SSID and password
              #define MY_ESP8266_SSID "XXX"
              #define MY_ESP8266_PASSWORD "XXX"
              #define MY_ESP8266_HOSTNAME "mqtt-sensor-gateway"
              // MQTT broker ip address.
              #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, X
              #define MY_PORT X
              #define SN "MySensors MQTT Gateway"
              #define SV "1.0"
              #include <Arduino.h>
              #include <ESP8266WiFi.h>
                // Send the Sketch Info
                sendSketchInfo(SN, SV);
                #define MY_PORT X
                #define SV "1.0"
                AnticimexA
                AnticimexA
                Anticimex
                @b1ackra1n I can't either to be honest. It seems like your gw at some point disable the feature. You could dig down the code to see what the simple password flag actually enables, and add #error statements at the bottom of your gw sketch to validate that the expected flags remain set.
                Unfortunately I am knocked out in bed by some influenza so I cannot do effective code digging for the moment.
                  vigonotionV
                  vigonotionV
                  vigonotion
                  @anticimex I think I got it working. The problem was that i used #define MY_SECURITY_SIMPLE_PASSWD instead of #define MY_SIGNING_SIMPLE_PASSWD (did I read the wrong docs? https://www.mysensors.org/apidocs-beta/group__SigningSettingGrpPub.html#gaedf8ec407fbde609a520ea0d95da2aac)
                  With that, only nodes with that password are able to communicate. Still needs some testing, but seems to work.
                  That's for the SIMPLE_PASSWD part. Next step would be getting Soft Signing to work, I will try that now and then send the debug logs.
                  Thanks already, if everything else fails, I'm now able to use at least the SIMPLE_PASSWD.
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @b1ackra1n the link points to the beta release. So it is aligned with the development branch, not the master branch, and it looks like you use the official 2.2.0 release, so strip the -beta part of the url. My troubleshooting link also points to the release documentation.
                    • vigonotionV
                      vigonotionV
                      vigonotion
                      Now I got Soft Signing to work, although I'm not yet sure why it works now:
                      /** SOFT SIGNING **/
                      /** END SOFT SIGNING **/
                      I think the problem was that "the simple password flag is mutually exclusive" (thanks @Anticimex).
                      Now everything works as expected!
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @b1ackra1n good news 👍
                        12.5k
