  3. Finding USB port name for serial gateway running homeassistant on an Intel Nuc
10 Posts 2 Posters 2.9k Views 2 Watching
  • C
    C
    chorob
    I recently switched from a raspi to an intel nuc. My serial gateway worked well with the raspi. I am struggling to figure out the config parameters for my nuc. After a lot of google searching, I can't find it but am probably missing something easy.
    Below is the default. I cannot find the right terminal command for the nuc to show the connected devices. Any ideas? Thanks!
    device: '/dev/ttyUSB0'
    • C chorob
      @chorob the following commands can be useful:
      lsusb
      ls /dev/
      Disconnect the serial gateway and run the commands. Then connect the serial gateway and run the commands again. Compare the output. The difference should be the serial gateway.
      You can also run
      dmesg
      after connecting the serial gateway. The last few lines should show a message about what name the gateway got.
      C 1 Reply Last reply
        lsusb
        ls /dev/
        You can also run
        dmesg
        C
        C
        chorob
        @mfalkvidd Thanks for the tips. Still trying to figure it out.
        This was the output of your first suggestion:
        Unplugged
        ➜ ~ lsusb
        Bus 001 Device 003: ID 8087:0a2a
        Bus 001 Device 001: ID 1d6b:0002
        Bus 001 Device 002: ID 05e3:0610
        Bus 002 Device 001: ID 1d6b:0003
        Plugged in
        ➜ ~ lsusb
        Bus 001 Device 006: ID 1a86:7523
        Output of our last suggestion.
        [631437.779324] usb 1-3: new full-speed USB device number 6 using xhci_hcd
        I have tried different combinations using device 6 and it still is not validating my config file. Any ideas?
        Tried
        device: '/dev/ttyUSB6'
        device: '/dev/ttyACM6'
        device: '/dev/tty1a86:7523'
        Thanks!
        • C chorob
          Unplugged
          ➜ ~ lsusb
          Plugged in
          ➜ ~ lsusb
          Tried
          Thanks!
          @chorob try ls /dev/ as well
            C
            C
            chorob
            @mfalkvidd
            unplugged
            core fd full init kmsg mqueue null ptmx pts random shm stderr stdin stdout tty urandom zero
            plugged in
            Thanks!
            mfalkviddM 2 Replies Last reply
            • C chorob
              @mfalkvidd
              unplugged
              plugged in
              Thanks!
              @chorob strange. This is my output before plugging in:
              ls /dev
              autofs           full       loop3             mqueue              ram12  random     tty0   tty2   tty30  tty41  tty52  tty63                vcio    vcsa3
              block            fuse       loop4             net                 ram13  raw        tty1   tty20  tty31  tty42  tty53  tty7                 vc-mem  vcsa4
              btrfs-control    gpiochip0  loop5             network_latency     ram14  rfkill     tty10  tty21  tty32  tty43  tty54  tty8                 vcs     vcsa5
              bus              gpiomem    loop6             network_throughput  ram15  serial0    tty11  tty22  tty33  tty44  tty55  tty9                 vcs1    vcsa6
              cachefiles       hwrng      loop7             null                ram2   shm        tty12  tty23  tty34  tty45  tty56  ttyAMA0              vcs2    vhci
              char             initctl    loop-control      ppp                 ram3   snd        tty13  tty24  tty35  tty46  tty57  ttyMySensorsGateway  vcs3    watchdog
              console          input      mapper            ptmx                ram4   spidev0.0  tty14  tty25  tty36  tty47  tty58  ttyprintk            vcs4    watchdog0
              cpu_dma_latency  kmsg       mem               pts                 ram5   spidev0.1  tty15  tty26  tty37  tty48  tty59  ttyUSB20             vcs5    zero
              cuse             log        memory_bandwidth  ram0                ram6   stderr     tty16  tty27  tty38  tty49  tty6   uhid                 vcs6
              disk             loop0      mmcblk0           ram1                ram7   stdin      tty17  tty28  tty39  tty5   tty60  uinput               vcsa
              fb0              loop1      mmcblk0p1         ram10               ram8   stdout     tty18  tty29  tty4   tty50  tty61  urandom              vcsa1
              fd               loop2      mmcblk0p2         ram11               ram9   tty        tty19  tty3   tty40  tty51  tty62  vchiq                vcsa2
              and after:
              ls /dev
              autofs           full       loop3             mqueue              ram12  random     tty    tty19  tty3   tty40  tty51  tty62                urandom  vcsa1
              block            fuse       loop4             net                 ram13  raw        tty0   tty2   tty30  tty41  tty52  tty63                vchiq    vcsa2
              btrfs-control    gpiochip0  loop5             network_latency     ram14  rfkill     tty1   tty20  tty31  tty42  tty53  tty7                 vcio     vcsa3
              bus              gpiomem    loop6             network_throughput  ram15  serial     tty10  tty21  tty32  tty43  tty54  tty8                 vc-mem   vcsa4
              cachefiles       hwrng      loop7             null                ram2   serial0    tty11  tty22  tty33  tty44  tty55  tty9                 vcs      vcsa5
              char             initctl    loop-control      ppp                 ram3   shm        tty12  tty23  tty34  tty45  tty56  ttyAMA0              vcs1     vcsa6
              console          input      mapper            ptmx                ram4   snd        tty13  tty24  tty35  tty46  tty57  ttyMySensorsGateway  vcs2     vhci
              cpu_dma_latency  kmsg       mem               pts                 ram5   spidev0.0  tty14  tty25  tty36  tty47  tty58  ttyprintk            vcs3     watchdog
              cuse             log        memory_bandwidth  ram0                ram6   spidev0.1  tty15  tty26  tty37  tty48  tty59  ttyUSB0              vcs4     watchdog0
              disk             loop0      mmcblk0           ram1                ram7   stderr     tty16  tty27  tty38  tty49  tty6   ttyUSB20             vcs5     zero
              fb0              loop1      mmcblk0p1         ram10               ram8   stdin      tty17  tty28  tty39  tty5   tty60  uhid                 vcs6
              fd               loop2      mmcblk0p2         ram11               ram9   stdout     tty18  tty29  tty4   tty50  tty61  uinput               vcsa
              the difference being serial.
              So it seems your device does not create any serial port. Strange.
              • C chorob
                @mfalkvidd
                unplugged
                plugged in
                Thanks!
                @chorob see if the suggestion in https://unix.stackexchange.com/questions/189896/testing-qinheng-electronics-hl-340-usb-serial-adapter works on your Nuc. (sudo modprobe ch341)
                  C
                  C
                  chorob
                  @mfalkvidd
                  sudo modprobe ch341
                  modprobe: FATAL: Module ch341 not found in directory /lib/modules/4.8.17-yocto-standard
                  Must be a package I need to install? I just used the standard hass.io image for the NUC.
                  Thanks for your help on this!
                  • C chorob
                    @mfalkvidd
                    sudo modprobe ch341
                    @chorob what linux distro is the hass image based on?
                    Modules are installed differently depending on which linux distro, and I have no experience with Hass so I don't know.
                    Maybe it is easier to switch Arduino to one with a ftdi232 chip.
                      C
                      C
                      chorob
                      @mfalkvidd the image is based on resin.io. I will do some more digging but your advice might be the best option. I really appreciate your help on this. I will report back what I find. Thanks!
