  3. Motion Sensors
Motion Sensors
11 Posts 3 Posters 2.3k Views 3 Watching
  • mntlvrM
    mntlvrM
    mntlvr
    I updated my my sensors library to version 2.2 and now can not compile any of my motion sensors
    I get this error message which I never had before
    Arduino: 1.8.3 (Windows 10), Board: "Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
    C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Admin\Documents\Arduino\libraries -fqbn=arduino:avr:pro:cpu=16MHzatmega328 -ide-version=10803 -build-path C:\Users\Admin\AppData\Local\Temp\arduino_build_276754 -warnings=default -build-cache C:\Users\Admin\AppData\Local\Temp\arduino_cache_286133 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Admin\Desktop_0516-MotionSensorv2.choose_node_ID_0516-MotionSensorv2.choose_node_ID.ino
    C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Admin\Documents\Arduino\libraries -fqbn=arduino:avr:pro:cpu=16MHzatmega328 -ide-version=10803 -build-path C:\Users\Admin\AppData\Local\Temp\arduino_build_276754 -warnings=default -build-cache C:\Users\Admin\AppData\Local\Temp\arduino_cache_286133 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Admin\Desktop_0516-MotionSensorv2.choose_node_ID_0516-MotionSensorv2.choose_node_ID.ino
    Using board 'pro' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
    Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
    WARNING: Category '' in library Audio is not valid. Setting to 'Uncategorized'
    WARNING: Spurious .ci folder in 'MySensors' library
    WARNING: Spurious .mystools folder in 'MySensors' library
    WARNING: Category '' in library Scheduler is not valid. Setting to 'Uncategorized'
    WARNING: Category '' in library USBHost is not valid. Setting to 'Uncategorized'
    Detecting libraries used...
    "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\Admin\AppData\Local\Temp\arduino_build_276754\sketch_0516-MotionSensorv2.choose_node_ID.ino.cpp" -o "nul"
    "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\Admin\Documents\Arduino\libraries\MySensors" "C:\Users\Admin\AppData\Local\Temp\arduino_build_276754\sketch_0516-MotionSensorv2.choose_node_ID.ino.cpp" -o "nul"
    "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\Admin\Documents\Arduino\libraries\MySensors" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\Admin\AppData\Local\Temp\arduino_build_276754\sketch_0516-MotionSensorv2.choose_node_ID.ino.cpp" -o "nul"
    "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\Admin\Documents\Arduino\libraries\MySensors" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Admin\Documents\Arduino\libraries\MySensors\utility" "C:\Users\Admin\Documents\Arduino\libraries\MySensors\MySensor.cpp" -o "nul"
    "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\Admin\Documents\Arduino\libraries\MySensors" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Admin\Documents\Arduino\libraries\MySensors\utility" "C:\Users\Admin\Documents\Arduino\libraries\MySensors\utility\LowPower.cpp" -o "nul"
    "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\Admin\Documents\Arduino\libraries\MySensors" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Admin\Documents\Arduino\libraries\MySensors\utility" "C:\Users\Admin\Documents\Arduino\libraries\MySensors\utility\MsTimer2.cpp" -o "nul"
    "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\Admin\Documents\Arduino\libraries\MySensors" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Admin\Documents\Arduino\libraries\MySensors\utility" "C:\Users\Admin\Documents\Arduino\libraries\MySensors\utility\RF24.cpp" -o "nul"
    "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\Admin\Documents\Arduino\libraries\MySensors" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src\SPI.cpp" -o "nul"
    Generating function prototypes...
    "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\Admin\Documents\Arduino\libraries\MySensors" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\Admin\AppData\Local\Temp\arduino_build_276754\sketch_0516-MotionSensorv2.choose_node_ID.ino.cpp" -o "C:\Users\Admin\AppData\Local\Temp\arduino_build_276754\preproc\ctags_target_for_gcc_minus_e.cpp"
    In file included from C:\Users\Admin\Desktop_0516-MotionSensorv2.choose_node_ID_0516-MotionSensorv2.choose_node_ID.ino:17:0:
    C:\Users\Admin\Documents\Arduino\libraries\MySensors/MySensors.h:389:2: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
    Multiple libraries were found for "MySensors.h"
    Used: C:\Users\Admin\Documents\Arduino\libraries\MySensors
    Not used: C:\Program Files (x86)\Arduino\libraries\MySensors
    Multiple libraries were found for "SPI.h"
    Used: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
    Not used: C:\Program Files (x86)\Arduino\libraries\SPI
    Using library MySensors at version 2.2.0 in folder: C:\Users\Admin\Documents\Arduino\libraries\MySensors
    Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
    exit status 1
    Error compiling for board Arduino Pro or Pro Mini.
    Error downloading http://arduino.esp8266.com/package_esp8266com_index.json
    Can anyone help
    Bob
    • mntlvrM mntlvr
      exit status 1
      Can anyone help
      Bob
      @mntlvr you have 3 installations of MySensors. Not good. You also have 2 installations of the SPI library. Delete the ones you don't want to use.
      And you seem to have a broken setting for esp8266. Perhaps a bad URL in the preferences dialog?
      None of these are MySensors-related.
      However, this message is from MySensors:
      My guess is that you're upgrading from MySensors 1.5? If so, follow the guide at https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x
      • mntlvrM
        mntlvrM
        mntlvr
        Thanks ,mfalkvidd
        I just re-created the gateway in Vera and it show all okay now , guess I have to update all of my sensors that I have created with older version.
        By the way which librarys should I keep , the one where Arudino IDE is launched from or the one that was created automatically when I unzipped latest mysensors file?
        • mntlvrM mntlvr
          Thanks ,mfalkvidd
          @mntlvr in this case I recommend deleting all of them and install MySensors using the Arduino IDE Library Manager. That way you will only have one install, and it will be placed in the proper folder.
          • mntlvrM
            mntlvrM
            mntlvr
            Okay, mfalkvidd
            That took care of all of those errors.
            In the Ethernet gateway do you have to put anything in the void setup, or void loop or presentation areas?
            Bob
            • mntlvrM mntlvr
              Okay, mfalkvidd
              Bob
              @mntlvr no, they can be left empty.
              • mntlvrM
                mntlvrM
                mntlvr
                mfakvidd
                I have built two different gw's one Ethernet and one esp8266 WiFi.Both see and respond to my sensors. I am using the latest library and IDE 1.84. The issues I am having is neither gw will configure in either one of my Vera's the Vera3 model or the VeraPlus model.It seems no one on this forum has a Vera connected to their vera that have any idea as to why it will not configure. Now when I ran the Ethernet build for 3 years it worked just fine with Library 1.42 but since I have used the 2.2 library I have not successfully made any gw work . Now I uninstalled Arduino and all libraries and re-installed Arduino IDE and then installed MySensors Library 1.42 and then loaded the very same sketch I had used 3 years ago and loaded the Vera files from 3 years ago and it worked like a charm. Is there any idea you have that can help me I wish to use the latest Libraries with the latest Vera plugin but the just do not work together.
                All of my home automation is down right now until I can get MYSensors up and running with the latest gw.
                Thanks and hope you have some insight as to whether the Vera plugin is not compatible with the latest MySensors library or if there is another issue.But I know the hardware works when everything is older versions of library and Vera plugin
                • mntlvrM mntlvr
                  mfakvidd
                  @mntlvr sorry, I have no experience with Vera
                  • mntlvrM
                    mntlvrM
                    mntlvr
                    but you do not need experience with a Vera if I am doing something wrong with the gw then I need to know but since you are a admin perhaps you can talk to the people who do have the knowledge of the plugin's and see if there is an issue with the latest plugin files and Vera or the gateways
                    dbemowskD 1 Reply Last reply
                    • mntlvrM mntlvr
                      dbemowskD
                      dbemowskD
                      @mntlvr you are working the same issue in 2 threads again. Did you see my latest posts in the other thread?
                      • mntlvrM
                        mntlvrM
                        mntlvr
                        wrote on last edited by mntlvr
                        I am asking for help and thee is no one in Vera that can help so I am going to ask admin or others to help solve this problem. And yes I read you last post but you have no experience with Ethernet or Wifi so I must ask behond Vera postings and you would do the same
