  2. Feature Requests
  3. ESP32 Support to enable the powerful ESP32 + RFM95/Lora + LiPo battery boards
42 Posts 7 Posters 17.8k Views 5 Watching
  • H Offline
    H Offline
    heinzv
    wrote on last edited by heinzv
    #41
    I have now tried to build an indoor sensor with Homematic protocol and an e-paper display using Pa-Pa's AsksinPP and GxEPD libs. Now I'm far beyond the Atmegas328p Flash and RAM and close to the limit of an STM32 maple. So I will go for the little ESP32 barebone boards and a RFM69 (LoRa or ESPNow). I'm very happy, that ESP32 and RFM95 are now supported thanks to tekka!
      To report weather data as you said, you can get away with a simple pro mini, without the need to use a powerful esp32. The problem with the esp32 boards you find around are development boards, so are not really optimized for low power operations
      H Offline
      H Offline
      heinzv
      @gohan I will use this barebone ESP32S module without LED, USW, Voltage Regulator etc.
      https://de.aliexpress.com/item/ESP32-ESP32S-WIFI-Bluetooth-Module-240MHz-Dual-Core-CPU-MCU-Wireless-Network-Board-ESP-WROOM-32/32817688406.html?spm=a2g0x.search0104.3.1.3bc34eb5tSg79z&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10151_10065_10344_10068_5722815_10342_10547_10343_10340_5722915_10548_10341_5722615_10696_10084_10083_10618_10304_10307_10820_10821_10302_5722715_10059_100031_10103_10624_10623_10622_5722515_10621_10620,searchweb201603_2,ppcSwitch_3&algo_expid=499485e8-6df0-40d6-8033-c5497748adb9-0&algo_pvid=499485e8-6df0-40d6-8033-c5497748adb9&transAbTest=ae803_1&priceBeautifyAB=0
      12.2k
