  2. Feature Requests
  3. ESP32 Support to enable the powerful ESP32 + RFM95/Lora + LiPo battery boards
42 Posts 7 Posters 18.3k Views 5 Watching
  • H
    H
    heinzv
    There are very convinient, cost effective powerfull ESP32 boards available available which have WiFi, BLE, RFM95/Lora RF plus LiPo battery/charger availble since more than a year.
    They are ideal for both: A mySensors Gateway (RF to MQTT) as well as ideal for battery powered mySensore nodes (Nodemanager). I was hoping that I find a comprehesive project - like mysensors to use this boards, but failed because the ideal/convinient ESP32 is not (yet?) supported.
    So with an ESP8266 I would need in addition a RFM95 and a LipO chnager modul to be soldered which is not convinient and thus I'm looking further for other solutions, although I would love to use this project.
    I have tried it, but I tought there are too many changes required to adapt for an ESP32 for somebody who does not know enough of the internals of the project.
    I hope ESP32 support it will make it on the roadmap and other support this request!
      Well... you have to understand that MySensors is acommunity driven project and all contributions are from people that do it in their free time. Also keep in mind that Lora modules are not used that often
      • H heinzv
        Welcome to the MySensors community @heinzv
        Have you tried https://github.com/mysensors/MySensors/pull/865 ? If so, could yo provide feedback? As already mentioned, interest in the esp32 has so far been too low to reach a sufficient testing level.
        H 3 Replies Last reply
        • H
          H
          heinzv
          I know that most of the github projects are community driven. I think and hope that the community is also interested in the ESP32 boards (successor of the ESP8266) which are cost effective and convinient to use as there are a couple of products available which have LoRa and battery handling on board. So Lora is just a convinient RF On-Board feature (basically a RFM95 or SX1276 board already on the ESP32 PCB) with a more reliable transmission. And it's available since quite a while with a lot of available libraries. The reason why I was not doing all by myself is, that I'm not the exptern in the core and don't know all the dependencies and side effects. I give it a try but got many compiler errors.
            H
            H
            heinzv
            @mfalkvidd hi, thanks for your reply and as far as I have understood, there have been two enhancements done, ESP32 and RFM95 support! That is all I need (RFM95 is the LoRa chip I mentioned). I'm new to the github test/review process and I'm willing to test this pull request 865, How can I download this build to do some testing? I'm sorry to hear, that people don't show enough interest in ESP32 boards with the RFM95 onboard. I like them very much.
              H
              H
              heinzv
              @mfalkvidd I think I have found the repository for testing: https://github.com/tekka007/MySensors/tree/ESP32HW. I'll do some testing with my Heltec boards which have an ESP32 + RFM95/SX1276. I'll try a ESP32Gateway and an ESP32 Sensor Node (Temp + Humidity). I'll give feedback. Thanks a lot.
              • H heinzv
                @heinzv yup, that’s the one. Looking forward to see the results. If you run into any problems, just post here and we’ll try to help out.
                I have a few esp32 myself, but have not seen enough benefit when used for MySensors compared to the pro minis and esp8266, especially considering the much higher price point. Same thing with my LoRa radios.
                H 1 Reply Last reply
                  H
                  H
                  heinzv
                  @mfalkvidd Today, I have tested the repository from tekka007: https://github.com/tekka007/MySensors/tree/ESP32HW and build a GatewayESP32MQTTClient with a dummy sensor node MockMySensors. For both I used a Heltec ESP32 board with a Lora RFM95 chip. I looks to me as it works perfect. I can connect to my remote MQTT Mosquitto broker and it receives dummy sensor data from the sensor node using 868MHz. See serial monitor log extract.
                  It would be great if this pull request would make it into the master branch in the next upcomming version.
                  Excellent work tekka007! I got ESP32 and the Lora RFM95 / SX1276.
                  598 GWT:TPC:IP=10.0.0.34
                  3602 MCO:BGN:STP
                  3604 MCO:BGN:INIT OK,TSP=1
                  3606 GWT:TPC:IP=10.0.0.34
                  3608 GWT:RMQ:MQTT RECONNECT
                  3639 GWT:RMQ:MQTT CONNECTED
                  3641 GWT:TPS:TOPIC=GWO1/0/255/0/0/18,MSG SENT
                  22668 TSF:MSG:READ,254-254-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  22673 TSF:MSG:BC
                  22675 TSF:MSG:FPAR REQ,ID=254
                  22678 TSF:PNG:SEND,TO=0
                  22680 TSF:CKU:OK
                  22681 TSF:MSG:GWL OK
                  22931 TSF:MSG:SEND,0-0-254-254,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                  24727 TSF:MSG:READ,254-254-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  24732 TSF:MSG:BC
                    H
                    H
                    heinzv
                    @mfalkvidd and tekka007:
                    I used this board
                    https://www.aliexpress.com/item/SX1276-ESP32-LoRa-868MHz-915MHz-0-96-Inch-Blue-OLED-Display-Bluetooth-WIFI-Lora-Kit/32838226825.html?spm=2114.search0104.3.1.6a9b1590hjCRnJ&ws_ab_test=searchweb0_0%2Csearchweb201602_5_10152_10151_10065_10344_10068_10547_10342_10343_10340_10548_10341_10696_10084_10083_10618_10304_10307_10302_5711215_10313_10059_10534_100031_10103_10624_10623_10622_10621_10620-10152_10151%2Csearchweb201603_6%2CppcSwitch_3&algo_expid=c4550361-2189-418e-a3f9-0aa963e5a76a-0&algo_pvid=c4550361-2189-418e-a3f9-0aa963e5a76a&priceBeautifyAB=0
                    there are cheaper ones without OLED display, only ESP32 + RFM95 + LiPo power/changer
                    https://www.aliexpress.com/item/SX1278-LoRa-ESP32-Bluetooth-WI-FI-Lora-Internet-Antena-Placa-de-Desenvolvimento-for-Arduino-TTGO/32827824992.html?spm=2114.search0104.3.160.4dcc3d63m7idho&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10151_10065_10344_10068_10547_10342_10343_10340_10548_10341_10696_10084_10083_10618_10304_10307_10302_5711213_10313_10059_10534_100031_10103_10624_10623_10622_10621_10620,searchweb201603_6,ppcSwitch_3&algo_expid=a4163100-0f10-4b08-bfe3-3d1a2e143f0f-22&algo_pvid=a4163100-0f10-4b08-bfe3-3d1a2e143f0f&priceBeautifyAB=0
                    • H heinzv
                      I used this board
                      @heinzv excellent! Thanks for the feedback.
                      @tekka In your opinion, are there more tests you'd like to see before the esp32 support is merged? Any important features not yet implemented?
                      H tekkaT 2 Replies Last reply
                        H
                        H
                        heinzv
                        wrote on last edited by heinzv
                        @mfalkvidd great guys, excellent work! I'll do more testing in the upcomming days with more features and will give you certainly feedback.
                        Here is what I want to build and what additional features might be nice, but I can try to implement also parts by myself:
                        I'm trying to build some temp/humitity/pressure sensor with e-paper display (I have a couple of 1.54 to 2.9" e-papers) in a small enclosure with a Litium battery. Each sensor with e-paper in each room connected to the MQTT Gateway to an OpenHAB based home automation. This will control some IR heating panels.
                        On my reseach, I found the SHT31 from Sensirion as very accurate temp/humidity (better than others like the DHT22) with an additional Bosch BME280 both are supported by MySensors (very nice).
                        I also have seen that there is a feature to get the system time from the Gateway/Controller so that the e-paper display of the sensor nodes can show the date/time/weekday (the ESP32 has a build in RTC even during deep sleep).
                        Battery sensor support is also there to show the battery state on the e-paper. So I hope I can that working with the build in ADC's.
                        So what might is probaly missing is a standard e-paper support. That would be nice (most brands are compatible, I use the ones from Waveshare) to build sensors with display where the battery last for a year+.
                        Another thing - not sure if it fit's to the MySensors scope would be to control remote smart power plugs with energy monitor (868MHz or WiFi). Would that be possible?
                        THere are nice ones available for 15-20€ WiFi which have an energy monitor built in. Such as Gosund SP1 or Homecube SP1 etc. which use an ESP8266EX (most use the same HW).
                        https://www.amazon.com/Monitoring-Compatible-Asistant-Required-Anywhere/dp/B076VMNNRZ/ref=sr_1_fkmr0_2?s=hi&ie=UTF8&qid=1522098551&sr=1-2-fkmr0&keywords=gosund+sp1 I use the EU plug version from Amazon.de.
                        To your comment what advantage the ESP board has: I have tried to explain: It has the ESP32, the RFM95 and the LiPo switch/Charger all on one board without any soldering required and thus very small for 3 required features, For the Gateway, also the on baord OLED can be used. In total, it's not more expensive than all three parts extra and need less space no soldering etc.
                        So that is all for today. I hope I get some positive feedback and thanks again for the good work.
                        Heinz
                        gohanG 1 Reply Last reply
                        • scalzS
                          scalzS
                          wrote on last edited by scalz
                          regarding esp8266 vs esp32, I think this is not comparable, esp32 is far more powerful, so it can do more better.
                          I use MySensors with esp32 as gw too, betatesting with tekka for months, still testing and having fun on my side.
                          Stay tuned and you might see some nice upcoming stuff ;)
                          @heinzv said in ESP32 Support to enable the powerful ESP32 + RFM95/Lora + LiPo battery boards:
                          I used this board
                          I understand people like cheap price, but you don't always get what you would expect. aliexpress boards doesn't always rhyme with quality..
                          Just take a look at their wifi antenna design, and you might laugh, I do!
                          The first link looks ok, the placement of the wifi antenna could be better for a devboard.
                          But the 2nd link is really funny to see! And I'm pretty sure that if espressif saw this, they laughed too :smile:
                          Finally what to think of these designers..and LORA designs or rf skills. not really fcc stuff for sure!
                          Regarding epaper, new sensors or things like that, it can already be used in MySensors, why not? but I don't think it is up to MySensors to handle this, it's up to the users to make sketch.
                          Types are already available in MySensors I think.
                          • scalzS scalz
                            I used this board
                            H
                            H
                            heinzv
                            @scalz I agree with your statements. I like both the ESP8266/8285 as you get super-tiny and very cheap boards (like the ESP12-F) if you need only WiFi.
                            For many cases, it is sufficient. What I like with the ESP32 boards is that you get battery support + charging and also RFM chips on board. So a single board with all I need for battery powered devices.
                            For Gateways it's also ideal because much more powerfull dual core CPU (if that is really required) and BLE + 868MHz all on a small single board.
                            I'm fine with the Aliexpress boards for home usage. Even the RF design might be not high quality it is more than sufficient within a flat/house even with 10mW. dis a couple of distance testing in my flat. And the RFM95 can be SW configured up to 100mW (I rather use 10 to max 20mW).
                            I also like the e-paper (1.54" with 200x200 resolution for 10€). Works fine and need almost no power. For the Gateway, The onboard OLED for control/diagnostic/config infos is also usable.
                            Looking forward to see more cool stuff.
                            • scalzS
                              scalzS
                              @heinzv that's what I said! I prefer esp32 too :) I have a some esp8266 that I'll never use because I didn't like it, it was limited imho..
                              nowadays, why using oled,epaper etc on a gw when you have a mobile! web/native mobile app are a lot more "waf" and interactive, display is less limited too ;)
                              • scalzS scalz
                                H
                                H
                                heinzv
                                @scalz Mobile comes of course on top, but having wall mounted sensors without any display is not really convinient. And for the gateway OLED could be used just showing the state, IP address etc. not more.
                                scalzS 1 Reply Last reply
                                • H heinzv
                                  Heinz
                                  @heinzv for smart wifi socket, look at Tasmota or other similar sw for those esp8266 based sockets, maybe they added support for them.
                                  • H heinzv
                                    scalzS
                                    scalzS
                                    on my side, I bet on voice control to retrieve infos, so no need of wall mounted sensor displays. for more detailed infos, mobile etc for example. Simple, like this I can have very discrete sensor without exhibiting them on walls, especially with "unpolished display enclosure", I mean it's easier to make a simple 3d printed discrete enclosure than having to polish it a lot because of the display to have a neat result if wall mounted.
                                    One of my goal is the house smart/simple/no maintenance(optimized battery lifetime) enough so i don't need any displays except for data visualization but that's not the purpose of these simple room displays..visualization can be done on TV, smart mirrors etc, only the basic we already use for home, without any addition.
                                    I understand your point, matter of taste I guess :)
                                      H
                                      H
                                      heinzv
                                      @gohan I have some Sonoff Smart Plugs (S20) with Tasmota SW and it works with OpenHAB, but has no energy monitor. They (Sonoff, ITEAD) have currently no EU version with Energy Monitor (only the S31 Plug = US version).
                                      The Gosund/Homecube/* SP1 has both and has en ESP8266X and I have dumped the Flash (soldering the RX/TX pins) but I have not found a custom firmware which can be used with the Energy Monitor chip. I have not even found out data for the Chip named (3 lines): HJL-01 J1749 CYH D797480E.
                                      I know that one of the experts has connected a logical analyzer to another comerical product and has sniffed/found out the protocol of that chip and write a driver. I was hoping that somebody has the motivation/skill/instruments to also hack one of that attractive plugs.
                                      • H
                                        H
                                        heinzv
                                        if somebody is interested how the small ESP8266EX smart plug (SP1) looks inside.
                                        The second picture shows the energy monitor chip. I think that is the challenge to find a driver for that and read the values (voltage, amps etc.). If somebody (with a logical analyzer?) wants to be a hero :-)
                                        I don't like the original firmware as it only works with Chinese Clouds. I need LAN and OpenHAB support.
                                        • NeverDieN
                                          NeverDieN
                                          I thought ESP32 was too power hungry to run for long off a battery. So, maybe for a gateway, but I suspect that's it. Right? I think this largely answers the OP.
