  3. Double channel lora Gateway (UP/DOWN)
6 Posts 3 Posters 2.6k Views 3 Watching
  • R
    R
    riro2
    Hello everybody,
    I m student and I am currently working on my final project. One issu that I encounter right now is that I have to make a two way radio communicaiton lora gateway (that does not have any relation with a LoraWAN platforms) it is just for private communication.
    My question is how to make SPI connections between one RPi 3 (Master) and two RFM95W Lora transceivers (one for uplink and one for downlink) ?
    Is it just making simple SPI connections with two slaves, or is there any other consideration to take into account ?
    Help please
    alexsh1A 1 Reply Last reply
    • R riro2
      Hello everybody,
      Help please
      alexsh1A
      alexsh1A
      alexsh1
      @riro2 Are you going to use MySensors library at all?
      I would find many sources on internet how to connect a RFM95 module to a RPI. In fact, I have made a few PCBs for my Raspberry Pi 3 but this is all for TTN, which is using LoraWAN.
      https://github.com/hallard/RPI-Lora-Gateway
      https://www.thethingsnetwork.org/forum/t/loraspi-raspberry-pi-simple-shield-gateway-node/2348
      Unfortunately, I do not have any experience with just Lora communication.
      • XanderX
        XanderX
        Xander
        I'm experementing with this Library / Project:
        http://cpham.perso.univ-pau.fr/LORA/RPIgateway.html
        https://github.com/CongducPham/LowCostLoRaGw
        based on the Libelium Libraries.
        It is LORA-only (no LARAWAN). Thanks to the used arduPi-Libs there are the same soures for Arduino and Raspi.
        Originally only sensors are supported. I have changed the sources a bit to support both directions but with ONE Lora module. It shouldn't be difficult to use two modules.
        • XanderX Xander
          alexsh1A
          alexsh1A
          alexsh1
          @xander I cannot help you with that. I have no knowledge of Liberium libs and never tinkered with Lora.
          XanderX 1 Reply Last reply
          • alexsh1A alexsh1
            XanderX
            XanderX
            Xander
            @alexsh1 Sorry you missunderstood. My post was only a hint to help riro2 with his LORA problem. The Libraries from the refered project are working fine for me. Thanks anyway!
            • XanderX Xander
              alexsh1A
              alexsh1A
              alexsh1
              @xander Yes, you are right - sorry about that. This is what happens when reading from the phone. :relaxed:
