  3. [SOLVED] NRF24 can not sleep
10 Posts 3 Posters 3.1k Views 3 Watching
  • P
    P
    Pavel Polititsky
    Hi
    Several days im trying to build radio button using example for binary switch
    But at final I got the trouble with power consumption by NRF24
    328P was sleeping well and take only ~0.2uA. But NRF24 module still powered up with current ~800uA (sometimes 15mA, by chance) This current was measured on the power pin of NRF
    So, how to force it to sleep?
    Thx
    My code:
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #include <avr/sleep.h>
    #define SKETCH_NAME "Binary Sensor"
    #define SKETCH_MAJOR_VER "1"
    #define SKETCH_MINOR_VER "0"
    #define PRIMARY_CHILD_ID 3
    #define SECONDARY_CHILD_ID 4
    #define PRIMARY_BUTTON_PIN 2   // Arduino Digital I/O pin for button/reed switch
    #define SECONDARY_BUTTON_PIN 3 // Arduino Digital I/O pin for button/reed switch
    #if (PRIMARY_BUTTON_PIN < 2 || PRIMARY_BUTTON_PIN > 3)
    #error PRIMARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
    #if (SECONDARY_BUTTON_PIN < 2 || SECONDARY_BUTTON_PIN > 3)
    #error SECONDARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
    #if (PRIMARY_BUTTON_PIN == SECONDARY_BUTTON_PIN)
    #error PRIMARY_BUTTON_PIN and BUTTON_PIN2 cannot be the same
    #if (PRIMARY_CHILD_ID == SECONDARY_CHILD_ID)
    #error PRIMARY_CHILD_ID and SECONDARY_CHILD_ID cannot be the same
    MyMessage msg(PRIMARY_CHILD_ID, V_TRIPPED);
    MyMessage msg2(SECONDARY_CHILD_ID, V_TRIPPED);
    	// Setup the buttons
    	pinMode(PRIMARY_BUTTON_PIN, INPUT);
    	pinMode(SECONDARY_BUTTON_PIN, INPUT_PULLUP);
    	sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER "." SKETCH_MINOR_VER);
    	present(PRIMARY_CHILD_ID, S_DOOR);
    	present(SECONDARY_CHILD_ID, S_DOOR);
    void wake ()
      // cancel sleep as a precaution
      sleep_disable();
      // precautionary while we do other stuff
      detachInterrupt (0);
    }  // end of wake
    	uint8_t value;
    	static uint8_t sentValue=2;
    	static uint8_t sentValue2=2;
    	sleep(5);
    	value = !digitalRead(PRIMARY_BUTTON_PIN);
    	if (value != sentValue) {
    		// Value has changed from last transmission, send the updated value
    		send(msg.set(value==LOW));
    		sentValue = value;
        sleepNow(); // sleep function called here
      sleepNow();
    void sleepNow() // here we put the arduino to sleep
       ADCSRA = 0;
      set_sleep_mode (SLEEP_MODE_PWR_DOWN);
      sleep_enable();
      noInterrupts ();
      attachInterrupt (0, wake, RISING);
      EIFR = bit (INTF0);  // clear flag for interrupt 0
      // BODS must be set to one and BODSE must be set to zero within four clock cycles
      MCUCR = bit (BODS) | bit (BODSE);
      // The BODS bit is automatically cleared after three clock cycles
      MCUCR = bit (BODS);
      interrupts ();  // one cycle
      sleep_cpu ();   // one cycle
      } // end of loop
    • P Pavel Polititsky
      Hi
      Thx
      My code:
      void wake ()
        sleep_disable();
      }  // end of wake
      	uint8_t value;
      	sleep(5);
      		sentValue = value;
        sleepNow();
         ADCSRA = 0;
        sleep_enable();
        noInterrupts ();
        MCUCR = bit (BODS);
        } // end of loop
      @pavel-polititsky Mysensors has a built-in sleep function, that will turn off the nrf24. Use that and throw away all the complicated code ;-)
      • P
        P
        Pavel Polititsky
        It is just result of my experiments, builtin mysensors sleep function works the same. Also 800uA to NRF
        I' ve cheked right now. NRF consuming ~800uA in all examples.
        Its not posible to use battaries power
          @pavel-polititsky there have been a few cases where people have purchased bad nrf24 clones that wouldn't go to sleep properly. Maybe you stumbled on that variant.
          P 1 Reply Last reply
            P
            P
            Pavel Polititsky
            wrote on last edited by Pavel Polititsky
            @mfalkvidd it's possible... :smirk:
            But in this case I want to know exactly how much consumes original module with any example... Then I will try to replace several modules.
              @pavel-polititsky 900nA (yes nA, not µA)
              P maghacM 2 Replies Last reply
                P
                P
                Pavel Polititsky
                @mfalkvidd :astonished: Another module just fu...g works. Great thx!
                  maghacM
                  maghacM
                  maghac
                  @mfalkvidd How do you measure such low currents? I have the problems with some nodes that are consuming way too much power and I'd like to check them.
                  mfalkviddM P 2 Replies Last reply
                  • maghacM maghac
                    @maghac I don't. But the most accurate way seems to be to get a uCurrent gold.
                    • maghacM maghac
                      P
                      P
                      Pavel Polititsky
                      @maghac Im using mastech MY65 and I can measure ~0.1uA minimal current with some error
