  3. Motion/actuator sensor
5 Posts 3 Posters 4.1k Views 1 Watching
  • H
    H
    Hausner
    Hi
    I need some help now. I have been staring at the below code for quiet some time now, but I just can find the error.
    The code should be sending a tripped signal to the controller, and the controller should return an ON/OFF to 1 of the 2 actuators. I can control the actuators just fine ON/OFF from the controller, but the motion sensor then start to flip HIGH/LOW at the interval assigned from the sensitivity potmeter.
    Here is the code
     #define RELAY_1 6  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
      // Motion sensor defs
      unsigned long SLEEP_TIME = 10000; // Sleep time between reports (in milliseconds)
    #define CHILD_ID 3   // Id of the sensor child
    volatile int state = LOW;
    boolean lockLow = true;
    boolean lastTripped = 0;
    MyMessage msgMotion(CHILD_ID, V_TRIPPED);
    //MyMessage msgRelay(CHILD_ID, V_LIGHT);
    MyMessage msg(CHILD_ID, V_LIGHT);
      gw.sendSketchInfo("Relay/Motion Sensor", "1.0");
      // Fetch relay status
    gw.present(sensor, S_LIGHT);
    pinMode(pin, OUTPUT);
    digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
    gw.present(CHILD_ID, S_MOTION);
    // attachInterrupt(DIGITAL_INPUT_SENSOR, ON, CHANGE);
    delay(30000);
    gw.process();
    boolean tripped = (digitalRead(DIGITAL_INPUT_SENSOR) == HIGH);
    if (lastTripped != tripped ) {
    gw.send(msgMotion.set(tripped?"1":"0")); // Send new state
    lastTripped=tripped;
     if (message.type==V_LIGHT) {
     // Change relay state
     // Store state in eeprom
     // Write some debug info
     Serial.print(message.sensor);
    With the above code I get this on the sensor serial:
    send: 30-30-0-0 s=3,c=1,t=16,pt=0,l=1,st=ok:0
    send: 30-30-0-0 s=3,c=1,t=16,pt=0,l=1,st=ok:1
    every ~4 second.. PLS help :)
    jendrushJ 1 Reply Last reply
    • H Hausner
      Hi
      Here is the code
      delay(30000);
      gw.process();
      jendrushJ
      jendrushJ
      jendrush
      @Hausner Have you considered sensor failure?
      H 1 Reply Last reply
      • BulldogLowellB
        BulldogLowellB
        BulldogLowell
        so you want to trigger on only one side of the motion sensor's output?
        • jendrushJ jendrush
          H
          H
          Hausner
          Yes, but I've tried to load the default actuator and motion sensor sketches from the library, and both works fine, so I don't think I have faulty sensors.
          • H
            H
            Hausner
            Turned out that the Nano was faulty.
            I rebuilded the setup with a new Nano, and it's now working as designed :)
