  3. 'MySensoring' a Kidde Smoke Detector. (Completed)
smoke detector
30 Posts 7 Posters 27.5k Views 4 Watching
  • DrJeffD DrJeff
    @ServiceXp Cool I just tested it and was ready build my first unit. I will post after I do it tonight! Have you tried to sniff the Jumpers for signals(like the CO2 or Smoke)? You said you are using the built in battery low detection are you talking about the warning that the batteries need to be replaced locally or remote? Oh Nevermind it will alarm so you will know remote and audible siren and voice local.
    The 3V3 off the board proves to be clean enough? I read somewhere that that might be a problem.
    RJ_MakeR
    RJ_MakeR
    RJ_Make
    @DrJeff
    1. The battery warning is local only, I didn't want to build in a battery circuit as that would reduce battery life.
    2. I have a 47uf cap on my radio and seems to work well.
    RJ_Make
    • DrJeffD DrJeff
      RJ_MakeR
      RJ_MakeR
      RJ_Make
      @DrJeff
      Oh and no, I don't have the skill set to sniff those signals.. :bowtie:
      RJ_Make
      DrJeffD 1 Reply Last reply
      • RJ_MakeR RJ_Make
        @DrJeff
        DrJeffD
        DrJeffD
        DrJeff
        @ServiceXp One last question I think, are you picking up the speaker on the center wire it is @ 4V7 and drops down to -3 or so. where did you find 3V3 speaker connection?
        Thanks Almost done!
        • DrJeffD
          DrJeffD
          DrJeff
          wrote on last edited by DrJeff
          #24
          Ok all is Good! I just used the octocoupler minus the perf board,also as a side note I changed the resistor you showed to a 4.7K to keep the current of the speaker from being drowned out, I also added a power header.
          Before Mod
          and here is the Modded One!
          Thanks again @ServiceXp for all the hard work you did to get us this mod. Now 9 more to go! But I will wait and test this one out for a couple of months or maybe I should just build 5 more for now. Any Ideas on how to make this run on external power until power is lost?
          RJ_MakeR 1 Reply Last reply
          • DrJeffD DrJeff
            Before Mod
            RJ_MakeR
            RJ_MakeR
            RJ_Make
            @DrJeff Sorry about the delay.. Looks like you figured it out... :-)
            You really don't need to build anymore if you are using those detectors through out the house (and they are setup interlocked), as once one goes off, they all go off and will signal to your controller that there is trouble.
            RJ_Make
            • RJ_MakeR RJ_Make
              DrJeffD
              DrJeffD
              DrJeff
              @ServiceXp You're so smart :relieved: I didn't even think about the alarms being interconnected, thanks for saving my extra radios, Arduinos, and wasted time much appreciated. The only thing I might do is change the radio to the hardwired alarm.
              • P
                P
                peterkins
                Building regs call for mains powered smoke alarms interconnected by wireless with battery backup. Has anyone figured how to intercept the signalling between them? Their being mains powered makes them scary to experiment on.
                This'll be my first mysensor project with domoticz. Hopefully not biting off more than I can chew.
                • P peterkins
                  Moshe LivneM
                  Moshe LivneM
                  Moshe Livne
                  @peterkins They are probably 5v inside so you just have to figure out (like ServiceXp did) where to tap in. or, if you want something completely non intrusive just use a sound detector....
                  • P
                    P
                    peterkins
                    Thanks for suggesting the microphone option. Thinking about it though, these devices are much less scary if i do my tests with them running off the backup batteries.
                    • macieiksM
                      macieiksM
                      macieiks
                      If I want to use this code on Arduino Mega2560 with support of 4 smoke sensors only thing I need to do is to create "arrays" ?
                      Regards,
                      Maciek
                      RPI2 + RFLink + PiFace D2 + Aeon Z-Wave Gen5 + Foscams FI9821P&R2 + MySensors + UPS APC Back-UPS 950VA
                      RPI2 + RFXtrx433e + Foscams FI9821P + MySensors + UPS APC Back-UPS 950VA
                      RPIB+ + TP-Link MR3420 + Huawei E173 GarageDomoticz :)
