  3. Mysensors orange Pi SPI gateway
8 Posts 2 Posters 2.1k Views 2 Watching
  • P
    P
    Pavel Polititsky
    wrote on last edited by Pavel Polititsky
    This post is deleted!
      Domoticz has mqtt support for MySensors, but id to make a proper mqtt mysensors gateway just to exclude something wrong in your chain. Do you have any spare esp8266 to use?
      P 1 Reply Last reply
        P
        P
        Pavel Polititsky
        @gohan Now Ive changed my hardware to SPI according with this guide
        I have connected my NRF24 module (already checked on arduino) through SPI0 iface but something goes wrong again
        root@orangepipcplus:/MySensors#  ./bin/mysgw -d
        mysgw: Starting gateway...
        mysgw: Protocol version - 2.2.0
        mysgw: Serial port /dev/ttyUSB020 (115200 baud) created
        mysgw: MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0
        mysgw: TSF:LRT:OK
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: TSM:INIT:TSP OK
        mysgw: TSM:INIT:GW MODE
        mysgw: MCO:REG:NOT NEEDED
        mysgw: MCO:BGN:STP
        mysgw: MCO:BGN:INIT OK,TSP=1
        mysgw: TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
        mysgw: !TSF:MSG:LEN,0!=7
        mysgw: TSF:MSG:READ,14-14-0,s=0,c=0,t=14,pt=0,l=1,sg=1:
        mysgw: !TSF:MSG:LEN,14!=32
        mysgw: !TSF:MSG:LEN,0!=32
        NRF24 link looks like working properly but next I see
        infinite messages LEN,0! that going very fast
        root@orangepipcplus:/MySensors# ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=6
        --my-rf24-cs-pin=10 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020 --my-rf24-irq-pin=5
        [SECTION] Detecting target machine.
          [OK] machine detected: SoC=unknown, Type=unknown, CPU=armv7l.
        [SECTION] Checking GPIO Sysfs.
          [OK] /sys/class/gpio/export found
        [SECTION] Detecting SPI driver.
          [OK] SPI driver detected:SPIDEV.
        [SECTION] Detecting init system.
          [OK] init system detected: systemd.
        [SECTION] Saving configuration.
        [SECTION] Cleaning previous builds.
        [OK] Finished.
        Sure I know that GPIO H2 and H3 are different
        When I connecting IRQ wire - log has been ended at mysgw: MCO:BGN:INIT OK,TSP=1 and nothing more
        I have tried to change CE/CS pins numbers to wrong but log still the same. As if gpio not working
          Did you put a capacitor on nrf24 radio? Try the gw without -my-rf24-irq-pin=5
          I have no experience on the OrangePi platform, so I can't help much, that is why I was asking for ESP8266
            P
            P
            Pavel Polititsky
            @gohan of course I have capacitor connected 100uF (even 1000uF)
            I will try aftermorrow because my esp shield in my office
            Anyway its not a solution, only for testing...
            Without IRQ I have
              100uF is quite big, I bought a bag of 10uF ceramics and they work perfectly.
                P
                P
                Pavel Polititsky
                @gohan 10uF ceramic does not help
                  I dont' know if it may apply to you but take a look
                  https://forum.mysensors.org/topic/5174/solved-non-healing-tsm-msg-len-error-hours-into-run
