  3. DimmableLED+Relay problem
4 Posts 2 Posters 1.4k Views 2 Watching
    mysz0n
    Please help me verify the source of the problem. I use mysensors + domoticz.
    When I turn on one of the three dimmable led pins, the corresponding screen (first, second or third) is also activated
    Probably the problem lies in the code, but despite many attempts I did not manage to come to what is the reason for the error
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    //relay
    #define RELAY_PIN 26  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    //#define NUMBER_OF_RELAYS 16 // Total number of attached relays
    #define NUMBER_OF_RELAYS 20
    #define RELAY_ON 0  // GPIO value to write to turn on attached relay
    #define RELAY_OFF 1 // GPIO value to write to turn off attached relay
    int lastLightLevel;
    //dimmable led
    #define noLEDs 3
    const int LED_Pin[] = {4, 5, 6};
    #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
    static int currentLevel1 = 0;  // Current dim level...
    static int currentLevel2 = 0;  // Current dim level...
    static int currentLevel3 = 0;  // Current dim level...
    MyMessage dimmer1Msg(1, V_DIMMER);
    MyMessage light1Msg(1, V_LIGHT);
    MyMessage dimmer2Msg(2, V_DIMMER);
    MyMessage light2Msg(2, V_LIGHT);
    MyMessage dimmer3Msg(3, V_DIMMER);
    MyMessage light3Msg(3, V_LIGHT);
    void before()
      for (int sensorRel = 4, pin = RELAY_PIN; sensorRel <= NUMBER_OF_RELAYS; sensorRel++, pin++) {
        pinMode(pin, OUTPUT);
        digitalWrite(pin, loadState(sensorRel) ? RELAY_ON : RELAY_OFF);
      // LEDS
      // Pull the gateway's current dim level - restore light level upon sendor node power-up
      for (int sensor = 1; sensor <= noLEDs; sensor++) {
        request( sensor, V_DIMMER );
      sendSketchInfo("mysz0n", "4.0");
        present(sensorRel, S_BINARY);
        present(sensor, S_DIMMER);
        wait(2);
        // Change relay state
        digitalWrite(message.sensor - 1 + RELAY_PIN, message.getBool() ? RELAY_ON : RELAY_OFF);
        // Store state in eeprom
        // Write some debug info
        Serial.print(message.sensor);
      if (message.type == V_LIGHT || message.type == V_DIMMER) {
        if (message.sensor == 1) {
          int requestedLevel1 = atoi( message.data );
          requestedLevel1 *= ( message.type == V_LIGHT ? 100 : 1 );
          // Clip incoming level to valid range of 0 to 100
          requestedLevel1 = requestedLevel1 > 100 ? 100 : requestedLevel1;
          requestedLevel1 = requestedLevel1 < 0   ? 0   : requestedLevel1;
          fadeToLevel1( requestedLevel1, message.sensor );
          send(light1Msg.set(currentLevel1 > 0 ? 1 : 0));
          send(dimmer1Msg.set(currentLevel1) );
        if (message.sensor == 2) {
          int requestedLevel2 = atoi( message.data );
          requestedLevel2 *= ( message.type == V_LIGHT ? 100 : 1 );
          requestedLevel2 = requestedLevel2 > 100 ? 100 : requestedLevel2;
          requestedLevel2 = requestedLevel2 < 0   ? 0   : requestedLevel2;
          fadeToLevel2( requestedLevel2, message.sensor );
          send(light2Msg.set(currentLevel2 > 0 ? 1 : 0));
          send(dimmer2Msg.set(currentLevel2) );
        if (message.sensor == 3) {
          int requestedLevel3 = atoi( message.data );
          requestedLevel3 *= ( message.type == V_LIGHT ? 100 : 1 );
          requestedLevel3 = requestedLevel3 > 100 ? 100 : requestedLevel3;
          requestedLevel3 = requestedLevel3 < 0   ? 0   : requestedLevel3;
          fadeToLevel3( requestedLevel3, message.sensor );
          send(light3Msg.set(currentLevel3 > 0 ? 1 : 0));
          send(dimmer3Msg.set(currentLevel3) );
        This method provides a graceful fade up/down effect
    void fadeToLevel1( int toLevel1, int ledid1 ) {
      int delta1 = ( toLevel1 - currentLevel1 ) < 0 ? -1 : 1;
      while ( currentLevel1 != toLevel1 ) {
        currentLevel1 += delta1;
        analogWrite(LED_Pin[ledid1 - 1], (int)(currentLevel1 / 100. * 255) );
        wait( FADE_DELAY );
    void fadeToLevel2( int toLevel2, int ledid2 ) {
      int delta2 = ( toLevel2 - currentLevel2 ) < 0 ? -1 : 1;
      while ( currentLevel2 != toLevel2 ) {
        currentLevel2 += delta2;
        analogWrite(LED_Pin[ledid2 - 1], (int)(currentLevel2 / 100. * 255) );
        wait( FADE_DELAY );
    void fadeToLevel3( int toLevel3, int ledid3 ) {
      int delta3 = ( toLevel3 - currentLevel3 ) < 0 ? -1 : 1;
      while ( currentLevel3 != toLevel3 ) {
        currentLevel3 += delta3;
        analogWrite(LED_Pin[ledid3 - 1], (int)(currentLevel3 / 100. * 255) );
        wait( FADE_DELAY );
    • M mysz0n
      //relay
      int lastLightLevel;
      //dimmable led
      #define noLEDs 3
      void before()
        // LEDS
          wait(2);
          wait( FADE_DELAY );
          wait( FADE_DELAY );
          wait( FADE_DELAY );
      @mysz0n calling send() from within receive() will cause the current message to be overwritten which makes the logic match on the sent message instead of the received message.
      You’ll need to move the send() calls to loop() and use variables to let loop() know when it should send.
        mysz0n
        @mfalkvidd Basically the code above is a combination of 2 examples from mysensors library. Dimmable LED Actuator and Relay Actuator. I thought that since the individual scripts work properly, combining them should not change the logic of the whole script?
        • M mysz0n
          @mysz0n it is actually the combination that causes the problem.
          In the library examples, the message is never looked at after send() is called, so overwriting the message is not a problem.
          But still, it would be nice if someone could spend the time and effort required to change the examples to make them safe to combine.
