  3. RFM69HCW Feather M0 MQTT
23 Posts 3 Posters 4.3k Views 1 Watching
  • Andrew MaynardA Andrew Maynard
    @mfalkvidd I will try it on an esp8266 tomorrow and see if anything changes. When going back versions is there anything else i need to do besides deleting directory and going through ./configure again? I will try the 2.2 version first. I already went from 2.3.1 to 2.3.0.
    @andrew-maynard deleting and starting over is fine. If you're comfortable with git you can switch branch/tag instead of deleting.
    Andrew MaynardA 1 Reply Last reply
      Andrew MaynardA
      Andrew MaynardA
      Andrew Maynard
      @mfalkvidd I switched gateway to esp8266
      451843 GWT:TPS:TOPIC=domoticz/out/MyMQTT/100/1/1/0/0,MSG SENT
      452390 TSF:MSG:READ,100-100-0,s=0,c=1,t=1,pt=7,l=5,sg=0:45.7
      452454 GWT:TPS:TOPIC=domoticz/out/MyMQTT/100/0/1/0/1,MSG SENT
      453679 TSF:MSG:READ,100-100-0,s=1,c=1,t=0,pt=7,l=5,sg=0:77.5
      453743 GWT:TPS:TOPIC=domoticz/out/MyMQTT/100/1/1/0/0,MSG SENT
      Im still not seeing it on the domoticz log
      2018-08-05 18:37:30.458 Error: Esp8266 MQTT Gateway hardware (5) nothing received for more than 5 Minutes!....
      2018-08-05 18:37:31.459 Error: Restarting: Esp8266 MQTT Gateway
      2018-08-05 18:37:32.293 Status: MQTT: Worker stopped...
      2018-08-05 18:37:33.295 Status: MQTT: Connecting to 192.168.1.110:1883
      2018-08-05 18:37:33.396 Status: MQTT: connected to: 192.168.1.110:1883
      2018-08-05 18:37:33.396 Status: MySensorsMQTT: connected to: 192.168.1.110:1883
      2018-08-05 18:37:33.497 Status: MQTT: Subscribed
      When i try to test it using
      pi@raspberrypi3:~ $ mosquitto_sub -v -t 'domoticz/out/MyMQTT'
      nothing happens and freezes cmd prompt. it does publish though
      pi@raspberrypi3:~ $ mosquitto_pub -t 'domoticz/in/MyMQTT' -m '0,29'
      I have to be missing something stupid!
      • Andrew MaynardA
        Andrew MaynardA
        Andrew Maynard
        Would it be wise to close this and move it to Domoticz MySensors forum? It looks like its an issue with mqtt or domoticz.
