  3. MySensor Request Function
8 Posts 3 Posters 2.1k Views 3 Watching
  • sghazaghS
    sghazaghS
    sghazagh
    wrote on last edited by sghazagh
    All,
    I used to had a sketch to grab the V_TEXT values from Domoticz controller and show on LCD.
    All was good except, recently I wanted to change some of the text on LCD.
    I only changed the text and when I tried to compile the sketch I get some error.
    It does not like this line anymore:
    void request(uint8_t childSensorId, uint8_t variableType, uint8_t destination);
    And I receive this set of errors in compiler (Arduino IDE):
    LCD_Sketch:113: error: new declaration 'void request(uint8_t, uint8_t, uint8_t)'
    In file included from C:\Users\Saeid\Documents\Arduino\libraries\MySensors/MySensors.h:412:0,
                     from D:\WemosD1MiniPro-NodeMCU-LCD_Sketch\WemosD1MiniPro-NodeMCU-LCD_Sketch.ino:35:
    C:\Users\Saeid\Documents\Arduino\libraries\MySensors/core/MySensorsCore.cpp:392:6: error: ambiguates old declaration 'bool request(uint8_t, uint8_t, uint8_t)'
     bool request(const uint8_t childSensorId, const uint8_t variableType, const uint8_t destination)
    exit status 1
    I commented the "void request" line and sketch compile just fine but I feel something is not right.
    • Would you please explain why my code does not compile the code?
    • Is alright to not having the Request line at all?
    • What is your suggestion to get this code improved/fixed as I see the device get restarted after a while on and off!!!
    Here is the full code for my sketch:
    //Fixed NodeID in Domoticz
    #define MY_NODE_ID 2
    #define MY_REPEATER_FEATURE
    #include <Wire.h>
    // Set the LCD address to 0x27 for a 16 chars and 2 line display
    LiquidCrystal_I2C lcd(0x3F, 20, 4);
    //const byte nodeId = 66 ;                   // MySensors fixed node id
    const byte LCD1_CHILD = 8 ;                  // LCD line 1
    const byte LCD2_CHILD = 9 ;                  // LCD line 2
    const byte LCD3_CHILD = 10 ;                 // LCD line 3
    const byte LCD4_CHILD = 11 ;                 // LCD line 4
    char lastLCD1[21] = "Line1 - first   ";     // define & init before first receive
    char lastLCD2[21] = "Line2 - second  ";
    char lastLCD3[21] = "Line3 - third   ";
    char lastLCD4[21] = "Line4 - forth   ";
    // Initialize messages for sensor network
    MyMessage textMsg( 0, V_TEXT );
    void setup(){
      //WiFi.persistent(false);
      //ESP.flashEraseSector(0x3fe);
      Wire.begin(D3, D4);
      lcd.begin();
      lcd.backlight(); // finish with backlight on
    //-------- Write characters on the display ----------------
    // NOTE: Cursor Position: CHAR, LINE) start at 0
      lcd.setCursor(0,0); //Start at character 4 on line 0
      lcd.print("Welcome to :");
      delay(1000);
      lcd.setCursor(4,1);
      lcd.print("LCD Panel");
      delay(2000);
      lcd.setCursor(0,3);
      lcd.print("Weather Station");
      delay(2000);
      lcd.clear();
      // Initialize the serial port at a speed of 9600 baud
      Serial.begin(115200);
      sendSketchInfo("LCD", "2.0");
      present(LCD1_CHILD, S_INFO, "LCD_line1");        // new S_type 20150905 (not know by domoticz)
      present(LCD2_CHILD, S_INFO, "LCD_line2");
      present(LCD3_CHILD, S_INFO, "LCD_line3");
      present(LCD4_CHILD, S_INFO, "LCD_line4");
      send(textMsg.setSensor(LCD1_CHILD).set("-"));    // initialize the V_TEXT at controller for sensor to none (trick for Domoticz)
      send(textMsg.setSensor(LCD2_CHILD).set("-"));
      send(textMsg.setSensor(LCD3_CHILD).set("-"));
      send(textMsg.setSensor(LCD4_CHILD).set("-"));
      //requestTime();
        lcd.clear();
        lcd.setCursor(0, 0);
        lcd.print("Inside  (T):");
        lcd.setCursor(0, 1);
        lcd.print("Outside (T):");
        lcd.setCursor(0, 2);
        lcd.print("Bedroom (T):");
        lcd.setCursor(0, 3);
        lcd.print("Bedroom (H):");
    void requestTime();
    void loop(){
      Serial.println(".");
      //requestTime();
      request(8,V_TEXT,0);
      wait(50);
      request(9,V_TEXT,0);
      wait(50);
      request(10,V_TEXT,0);
      wait(50);
      request(11,V_TEXT,0);
      wait(50);
      sleep(60000);
      // If characters arrived over the serial port...
      if (Serial.available()) {
        // Wait a bit for the entire message to arrive
        delay(100);
        // Clear the screen
        lcd.clear();
        // Write all characters received with the serial port to the LCD.
        while (Serial.available() > 0) {
          lcd.write(Serial.read());
    // This is called only if new time value was received by calling requestTime();
    void receiveTime(unsigned long controllerTime) {
        Serial.print("Time value received: ");
        Serial.println(controllerTime);
        //Hours = controllerTime / (1000*60*60)
        //Minutes = (controllerTime % (1000*60*60)) / (1000*60)
        //Seconds = ((controllerTime % (1000*60*60)) % (1000*60)) / 1000
        lcd.clear();
        lcd.print("Current Time");
        lcd.setCursor(0,1);
        lcd.print(controllerTime);  //seconds format ex. 45681238785
    // This is called when a message is received
       // Write some debug info
       Serial.print("Message: ");
       Serial.print(message.sensor);
       Serial.print(", Message: ");
       Serial.println(message.getString());
      if (message.type==V_TEXT) {
        if (message.sensor == LCD1_CHILD ) {
          //snprintf(lastLCD1, sizeof(lastLCD1), "%20s", message.getString());  // load text into LCD string
          //lcd.setCursor(17, 1);
          //lcd.print(lastLCD1);
          lcd.setCursor(13, 0);
          lcd.print(message.getString());
          lcd.print((char)223);
          lcd.print("C");
       if (message.sensor == LCD2_CHILD ) {
          //lcd.print(lastLCD2);
            lcd.setCursor(13, 1);
            lcd.print("C");
       if (message.sensor == LCD3_CHILD ) {
          //lcd.print(lastLCD3);
            lcd.setCursor(13, 2);
            lcd.print("C");
      if (message.sensor == LCD4_CHILD ) {
          //lcd.print(lastLCD4);
            lcd.setCursor(13, 3);
            lcd.print("%");
    P.S: I am using MySensor Library 2.3.0 hwever, by reverting it back to 2.2.0, problem still persist.
    I am also using NodeMCU v1.0 for my microprocessor connected to LCD and NRF24 Radio.
    • sghazaghS sghazagh
      All,
      exit status 1
      #include <Wire.h>
      void setup(){
        Wire.begin(D3, D4);
        lcd.begin();
        delay(1000);
        lcd.setCursor(4,1);
        delay(2000);
        lcd.setCursor(0,3);
        delay(2000);
        lcd.clear();
        //requestTime();
          lcd.clear();
      void requestTime();
      void loop(){
        //requestTime();
        wait(50);
        wait(50);
        wait(50);
        wait(50);
        sleep(60000);
          delay(100);
          // Clear the screen
          lcd.clear();
          lcd.clear();
          lcd.setCursor(0,1);
            lcd.print("C");
              lcd.print("C");
              lcd.print("C");
              lcd.print("%");
      @sghazagh remove void
      By adding void, you've changed the statement from calling the function to declaring it.
      sghazaghS 1 Reply Last reply
        sghazaghS
        sghazaghS
        sghazagh
        @mfalkvidd So what should I do then?
        It was with void before and compiler didn't get any error.
        Isn't it the way to declare it? like other functions?
        ex. void setup(), void presentation(),.... ?????????
          @sghazagh I don't think the c programming language has changed how functions are declared in the last 50 years, so I doubt having void there was working before. MySensors can't influence how the programming language works.
          What are you trying to do with the request function?
          • electrikE
            electrikE
            electrik
            You can remove these lines, the declaration is already done in the MySensors framework. For presentation() it is needed because you write code there, that is in the function. Now you only call the function, and the code is already in the framework.
            • electrikE electrik
              sghazaghS
              sghazaghS
              sghazagh
              @electrik Thanks electrik.
              It is absolutely right, I removed the line for declaring the function and all is working as expected.
              Actually the other problem which made me nut was that I was seeing the device restarts continuously so I thought not declaring the request function is causing that.
              That has fixed as well. The issue was that I had enabled the REPEATER option, however, I didn't add any WIFI library or correct setting for that so the system was crashing and was resetting .
              Now that I disabled that REPEATER option and also did not declaring the request function, all is working fine again.
              @mfalkvidd: I am not sure but believe me it was there and it was compiling just fine before.
              Perhaps used to we had to declare it, and now as "electrik" explained, it already declares in MySensor call.
              Thank you both anyway.
              I think I get it working now.
              Cheers,
              • sghazaghS
                sghazaghS
                sghazagh
                All,
                I leave the code here as it's a working code for getting the Domoticz Virtual Sensor V_TEXT and showing on LCD.
                Just don't forget to:
                disable REPEATER option:
                // #define MY_REPEATER_FEATURE
                and remove this line:
                Thanks.
                • electrikE
                  electrikE
                  electrik
                  You should do the same for requestTime();
