  3. ESP8266 CH340 Error on gateway
4 Posts 4 Posters 1.1k Views 4 Watching
  • S
    SAm85
    I use a esp8266 de type CH340 NodeMcu V3 .
    here is my code:
    #define MY_BAUD_RATE 9600
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_ESP8266
    #define MY_WIFI_SSID "yyyyyyy"
    #define MY_WIFI_PASSWORD "xxxxxx"
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
    //#define MY_HOSTNAME "sensor-gateway"
    //#define MY_IP_ADDRESS 192,168,1,102
    //#define MY_IP_GATEWAY_ADDRESS 192,168,1,254
    #define MY_PORT 5003
    // Enable inclusion mode
    //#define MY_INCLUSION_MODE_BUTTON_PIN D1
    // Set blinking period
    //#define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Flash leds on rx/tx/err
    // Led pins used if blinking feature is enabled above
    #if defined(MY_USE_UDP)
    #include <WiFiUdp.h>
    #include <ESP8266WiFi.h>
    #define CHILD_ID 30
    volatile uint32_t watt = 10;
    MyMessage msgContacteur(CHILD_ID, V_TRIPPED);
    //uint32_t SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't want to spam the gateway.
      MyMessage wattMsg(CHILD_ID,V_WATT);
      MyMessage kWhMsg(CHILD_ID,V_KWH);
    	sendSketchInfo("MySensors Watt", "1.0");
        present(CHILD_ID, S_POWER);
      send(wattMsg.set(watt));  // Send watt value to gw
                  Serial.print("Watt:");
                Serial.println(watt);
    here are the errors:
    90 TSF:LRT:OK
    105 TSM:INIT
    119 TSF:WUR:MS=0
    142 !TSM:INIT:TSP FAIL
    166 TSM:FAIL:CNT=1
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 3
    cnt
    connected with yyyyyyyyyy, channel 1
    dhcp client start...
    334 TSM:FAIL:DIS
    352 TSF:TDI:TSL
    ip:192.168.1.102,mask:255.255.255.0,gw:192.168.1.254
    10370 TSM:FAIL:RE-INIT
    10394 TSM:INIT
    10415 !TSM:INIT:TSP FAIL
    10441 TSM:FAIL:CNT=2
    10463 TSM:FAIL:DIS
    10483 TSF:TDI:TSL
    do you have an idea about the problem?
    cordially
    YveauxY J 2 Replies Last reply
    • S SAm85
      here is my code:
      #define CHILD_ID 30
      90 TSF:LRT:OK
      105 TSM:INIT
      119 TSF:WUR:MS=0
      166 TSM:FAIL:CNT=1
      scandone
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      aid 3
      cnt
      334 TSM:FAIL:DIS
      352 TSF:TDI:TSL
      10394 TSM:INIT
      10463 TSM:FAIL:DIS
      10483 TSF:TDI:TSL
      cordially
      YveauxY
      YveauxY
      @sam85 said in ESP8266 CH340 Error on gateway:
      Hi and welcome to the forum!
      TSP FAIL indicates a problem with the radio communication. Triple check your wiring or try with a different radio.
        or add // before #define MY_RADIO_NRF24 if you don't plan to use a radio.
        • S SAm85
          here is my code:
          #define CHILD_ID 30
          90 TSF:LRT:OK
          105 TSM:INIT
          119 TSF:WUR:MS=0
          166 TSM:FAIL:CNT=1
          scandone
          state: 0 -> 2 (b0)
          state: 2 -> 3 (0)
          state: 3 -> 5 (10)
          add 0
          aid 3
          cnt
          334 TSM:FAIL:DIS
          352 TSF:TDI:TSL
          10394 TSM:INIT
          10463 TSM:FAIL:DIS
          10483 TSF:TDI:TSL
          cordially
          J
          J
          JPe4619
          @sam85 #if defined(MY_USE_UDP) // is it defined somewhere?
