  3. Problem with dimmable LED actuator with encoder
17 Posts 7 Posters 5.0k Views 7 Watching
  • vladimirV
    vladimirV
    vladimir
    Hi all!
    I'm using OpenHAB 2, and I have some problems with the sketch code "DimmableLightWithRotaryEncoderButton".
    When the encoder button is pressed, the switch in OpenHAB does not respond.
    When turn the encoder knob one step, the value changes in two steps.
    Maybe you have encountered such a problem? Or maybe you can share a more modern sketch?
     * Version 1.0 - Developed by Bruce Lacey and GizMoCuz (Domoticz)
     * Version 1.1 - Modified by hek to incorporate a rotary encode to adjust
     *                                light level locally at node
     * This sketch provides an example how to implement a dimmable led light node with a rotary
     * encoder connected for adjusting light level.
     * The encoder has a click button which turns on/off the light (and remembers last dim-level)
     * The sketch fades the light (non-blocking) to the desired level.
     * Default MOSFET pin is 3
     *  Arduino      Encoder module
     *  5V           5V (+)
     *  GND          GND (-)
     *  4            CLK (or putput 1)
     *  5            DT  (or output 1)
     *  6            SW (Switch/Click)
    // Enable debug prints
    #include <Bounce2.h>
    #include <Encoder.h>
    #define LED_PIN 3           // Arduino pin attached to MOSFET Gate pin
    #define KNOB_ENC_PIN_1 4    // Rotary encoder input pin 1
    #define KNOB_ENC_PIN_2 5    // Rotary encoder input pin 2
    #define KNOB_BUTTON_PIN 6   // Rotary encoder button pin
    #define FADE_DELAY 10       // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
    #define SEND_THROTTLE_DELAY 400 // Number of milliseconds before sending after user stops turning knob
    #define SN "DimmableLED /w button"
    #define SV "1.2"
    #define CHILD_ID_LIGHT 1
    #define EEPROM_DIM_LEVEL_LAST 1
    #define EEPROM_DIM_LEVEL_SAVE 2
    #define LIGHT_OFF 0
    #define LIGHT_ON 1
    int dimValue;
    int fadeTo;
    int fadeDelta;
    byte oldButtonVal;
    bool changedByKnob=false;
    bool sendDimValue=false;
    unsigned long lastFadeStep;
    unsigned long sendDimTimeout;
    char convBuffer[10];
    MyMessage dimmerMsg(CHILD_ID_LIGHT, V_DIMMER);
    Encoder knob(KNOB_ENC_PIN_1, KNOB_ENC_PIN_2);
    Bounce debouncer = Bounce();
      // Set knob button pin as input (with debounce)
      pinMode(KNOB_BUTTON_PIN, INPUT);
      digitalWrite(KNOB_BUTTON_PIN, HIGH);
      debouncer.attach(KNOB_BUTTON_PIN);
      debouncer.interval(5);
      oldButtonVal = debouncer.read();
      // Set analog led pin to off
      analogWrite( LED_PIN, 0);
      // Retreive our last dim levels from the eprom
      fadeTo = dimValue = 0;
      byte oldLevel = loadLevelState(EEPROM_DIM_LEVEL_LAST);
      Serial.print("Sending in last known light level to controller: ");
      Serial.println(oldLevel);
      send(dimmerMsg.set(oldLevel), true);
      Serial.println("Ready to receive messages...");
    void presentation() {
      present(CHILD_ID_LIGHT, S_DIMMER);
      sendSketchInfo(SN, SV);
      // Check if someone turned the rotary encode
      checkRotaryEncoder();
      // Check if someone has pressed the knob button
      checkButtonClick();
      // Fade light to new dim value
      fadeStep();
        // Incoming on/off command sent from controller ("1" or "0")
        int lightState = message.getString()[0] == '1';
        int newLevel = 0;
        if (lightState==LIGHT_ON) {
          // Pick up last saved dimmer level from the eeprom
          newLevel = loadLevelState(EEPROM_DIM_LEVEL_SAVE);
        // Send dimmer level back to controller with ack enabled
        send(dimmerMsg.set(newLevel), true);
        // We do not change any levels here until ack comes back from gateway
        return;
      } else if (message.type == S_DIMMER) {
        // Incoming dim-level command sent from controller (or ack message)
        fadeTo = atoi(message.getString(convBuffer));
        // Save received dim value to eeprom (unless turned off). Will be
        // retreived when a on command comes in
        if (fadeTo != 0)
          saveLevelState(EEPROM_DIM_LEVEL_SAVE, fadeTo);
      saveLevelState(EEPROM_DIM_LEVEL_LAST, fadeTo);
      Serial.print("New light level received: ");
      Serial.println(fadeTo);
      if (!changedByKnob)
        knob.write(fadeTo);
      // Cancel send if user turns knob while message comes in
      changedByKnob = false;
      sendDimValue = false;
      // Stard fading to new light level
      startFade();
    void checkRotaryEncoder() {
      long encoderValue = knob.read();
      if (encoderValue > 100) {
        encoderValue = 100;
        knob.write(100);
      } else if (encoderValue < 0) {
        encoderValue = 0;
        knob.write(0);
      if (encoderValue != fadeTo) {
        fadeTo = encoderValue;
        changedByKnob = true;
        startFade();
    void checkButtonClick() {
      debouncer.update();
      byte buttonVal = debouncer.read();
      byte newLevel = 0;
      if (buttonVal != oldButtonVal && buttonVal == LOW) {
        if (dimValue==0) {
          // Turn on light. Set the level to last saved dim value
          int saved = loadLevelState(EEPROM_DIM_LEVEL_SAVE);
          newLevel = saved > 0 ? saved : 100;
        send(dimmerMsg.set(newLevel),true);
      oldButtonVal = buttonVal;
    void startFade() {
      fadeDelta = ( fadeTo - dimValue ) < 0 ? -1 : 1;
      lastFadeStep = millis();
    // This method provides a graceful none-blocking fade up/down effect
    void fadeStep() {
      unsigned long currentTime  = millis();
      if ( dimValue != fadeTo && currentTime > lastFadeStep + FADE_DELAY) {
        dimValue += fadeDelta;
        analogWrite( LED_PIN, (int)(dimValue / 100. * 255) );
        lastFadeStep = currentTime;
        Serial.print("Fading level: ");
        Serial.println(dimValue);
        if (fadeTo == dimValue && changedByKnob) {
          sendDimValue = true;
          sendDimTimeout = currentTime;
      // Wait a few millisecs before sending in new value (if user still turns the knob)
      if (sendDimValue && currentTime > sendDimTimeout + SEND_THROTTLE_DELAY)  {
         // We're done fading.. send in new dim-value to controller.
         // Send in new dim value with ack (will be picked up in incomingMessage)
        send(dimmerMsg.set(dimValue), true); // Send new dimmer value and request ack back
    // Make sure only to store/fetch values in the range 0-100 from eeprom
    int loadLevelState(byte pos) {
      return min(max(loadState(pos),0),100);
    void saveLevelState(byte pos, byte data) {
      saveState(pos,min(max(data,0),100));
    H 1 Reply Last reply
    • I
      I
      itbeyond
      wrote on last edited by itbeyond
      @vladimir I really think you need to look at this in the serial monitor and add some serial.print lines in the associated places in the code to see what is going on.
      vladimirV 1 Reply Last reply
      • I itbeyond
        vladimirV
        vladimirV
        vladimir
        @itbeyond said in Problem with dimmable LED actuator with encoder:
        Can you tell me where exactly to add?
        • vladimirV vladimir
          Hi all!
           *  5V           5V (+)
           *  GND          GND (-)
          #define SV "1.2"
          #define LIGHT_OFF 0
          #define LIGHT_ON 1
          int dimValue;
          int fadeTo;
          int fadeDelta;
          byte oldButtonVal;
            checkButtonClick();
            fadeStep();
              int newLevel = 0;
              return;
              if (fadeTo != 0)
            if (!changedByKnob)
              knob.write(fadeTo);
            startFade();
              encoderValue = 100;
              knob.write(100);
              encoderValue = 0;
              knob.write(0);
              startFade();
            debouncer.update();
            byte newLevel = 0;
              if (dimValue==0) {
          void startFade() {
          void fadeStep() {
          H
          H
          hard-shovel
          @vladimir
          To deal with the encoder giving two pulses per indent change the following two lines in checkRotaryEncoder:
            long encoderValue = knob.read()>>1 ;      //### Divide by 2 (using shift right)
              encoderValue = 100;
              knob.write(200);                        //### max value now 200 due to divide by 2
              encoderValue = 0;
              knob.write(0);
              startFade();
          and the receive function change one line
           if (!changedByKnob)
              knob.write(fadeTo<<1);             //### need to multiply by two (using Shift left)
          If you use a different encoder you may have to change back these settings to the original
          For the switch Pushbutton problem change the two lines in the receive function section
            if (message.type == V_STATUS) {  //## change from V_LIGHT
             } else if (message.type == V_PERCENTAGE) {    //## change from V_DIMMER
          • H hard-shovel
            @vladimir
                encoderValue = 100;
                encoderValue = 0;
                knob.write(0);
                startFade();
             if (!changedByKnob)
            vladimirV
            vladimirV
            vladimir
            @hard-shovel thanks for the answer!
            The encoder started working as it should! There was only a problem with the switch in OpenHAB. It does not switch when you press a button on the device. The feeling that OpenHAB does not get the status of this switch. The device works well.
            In this video, I clearly demonstrated the problem: https://cloud.mail.ru/public/4fee/HiVX5ZSxh
            Maybe you know what the problem is? I made all the changes you wrote to me in the previous message. Here is the updated device code:
             *  5V           5V (+)
             *  GND          GND (-)
            #define SV "1.2"
            #define LIGHT_OFF 0
            #define LIGHT_ON 1
            int dimValue;
            int fadeTo;
            int fadeDelta;
            byte oldButtonVal;
              checkButtonClick();
              fadeStep();
                int newLevel = 0;
                return;
                if (fadeTo != 0)
              if (!changedByKnob)
              startFade();
                encoderValue = 100;
                encoderValue = 0;
                knob.write(0);
                startFade();
              debouncer.update();
              byte newLevel = 0;
                if (dimValue==0) {
            void startFade() {
            void fadeStep() {
               *  5V           5V (+)
               *  GND          GND (-)
              #define SV "1.2"
              #define LIGHT_OFF 0
              #define LIGHT_ON 1
              int dimValue;
              int fadeTo;
              int fadeDelta;
              byte oldButtonVal;
                checkButtonClick();
                fadeStep();
                  int newLevel = 0;
                  return;
                  if (fadeTo != 0)
                if (!changedByKnob)
                startFade();
                  encoderValue = 100;
                  encoderValue = 0;
                  knob.write(0);
                  startFade();
                debouncer.update();
                byte newLevel = 0;
                  if (dimValue==0) {
              void startFade() {
              void fadeStep() {
              H
              H
              hard-shovel
              @vladimir
              I see the problem now
              When operating from Node, if you switch on or off the Switch indicator (Status) does not update.
              Try this method:
              Add the additional message line
              MyMessage statusMsg(CHILD_ID_LIGHT, V_STATUS);    // Addition for Status update to OpenHAB Controller
              and this in the check button function
                  send(statusMsg.set(newLevel>0 ? "1" : "0"),true); // Addition for Status update to OpenHAB Controller
              so complete code:
               *  5V           5V (+)
               *  GND          GND (-)
              #define SV "1.2"
              #define LIGHT_OFF 0
              #define LIGHT_ON 1
              int dimValue;
              int fadeTo;
              int fadeDelta;
              byte oldButtonVal;
                checkButtonClick();
                fadeStep();
                  int newLevel = 0;
                  return;
                  if (fadeTo != 0)
                if (!changedByKnob)
                startFade();
                  encoderValue = 100;
                  encoderValue = 0;
                  knob.write(0);
                  startFade();
                debouncer.update();
                byte newLevel = 0;
                  if (dimValue==0) {
              void startFade() {
              void fadeStep() {
              • H hard-shovel
                @vladimir
                Try this method:
                so complete code:
                 *  5V           5V (+)
                 *  GND          GND (-)
                #define SV "1.2"
                #define LIGHT_OFF 0
                #define LIGHT_ON 1
                int dimValue;
                int fadeTo;
                int fadeDelta;
                byte oldButtonVal;
                  checkButtonClick();
                  fadeStep();
                    int newLevel = 0;
                    return;
                    if (fadeTo != 0)
                  if (!changedByKnob)
                  startFade();
                    encoderValue = 100;
                    encoderValue = 0;
                    knob.write(0);
                    startFade();
                  debouncer.update();
                  byte newLevel = 0;
                    if (dimValue==0) {
                void startFade() {
                void fadeStep() {
                vladimirV
                vladimirV
                vladimir
                @hard-shovel at compilation produces an error of the following content:
                /Users/vladimirpetrov/Documents/Arduino/Dimmer/Dimmer.ino: In function 'void setup()':
                Dimmer:106: error: 'newLevel' was not declared in this scope
                   send(statusMsg.set(newLevel > 0 ? "1" : "0"),true); // Addition for Status update to OpenHAB Controller
                exit status 1
                  exit status 1
                  H
                  H
                  hard-shovel
                  @vladimir
                  Sorry about that it should be the following in the setup function
                    send(statusMsg.set(oldLevel>0 ? "1" : "0"),true); // Addition for Status update to OpenHAB Controller
                  This sends the status of the lamp ON or OFF on startup biased on the dimmer value stored in the eeprom, if you do not want this then just delete this line, or fix the value 1 or 0.
                  • H hard-shovel
                    @vladimir
                    vladimirV
                    vladimirV
                    vladimir
                    @hard-shovel switch is working, thanks! Only while he behaves a little unpredictably: video 1, video 2
                      H
                      H
                      hard-shovel
                      @vladimir
                      I am unsure what you problems is from the video clips.
                      However i do see that you have several NAKS due to radio problems.
                      try this code snippet
                        debouncer.update();
                        byte newLevel = 0;
                          if (dimValue==0) {
                            newLevel = saved > 1 ? saved : 100;           // newLevel = saved > 0 ? saved : 100;
                          send(statusMsg.set(newLevel>0 ? "1" : "0")); // Addition for Status update to OpenHAB Controller,   No Echo
                      • H hard-shovel
                        @vladimir
                          debouncer.update();
                          byte newLevel = 0;
                            if (dimValue==0) {
                        vladimirV
                        vladimirV
                        vladimir
                        wrote on last edited by vladimir
                        @hard-shovel thank you very much!:raised_hands: Now everything works!
                        I will give here a full sketch. I'm sure it will be useful to many.
                         *  5V           5V (+)
                         *  GND          GND (-)
                        #define SV "1.3"
                        #define LIGHT_OFF 0
                        #define LIGHT_ON 1
                        int dimValue;
                        int fadeTo;
                        int fadeDelta;
                        byte oldButtonVal;
                          checkButtonClick();
                          fadeStep();
                            int newLevel = 0;
                            return;
                            if (fadeTo != 0)
                          if (!changedByKnob)
                          startFade();
                            encoderValue = 100;
                            encoderValue = 0;
                            knob.write(0);
                            startFade();
                          debouncer.update();
                          byte newLevel = 0;
                            if (dimValue==0) {
                        void startFade() {
                        void fadeStep() {
                        • Y
                          Y
                          yoshida
                          Thanks Guys, finally a sketch which compiled for me :) I will try it in Domoticz later on.
                            mateos78
                            Does anybody use the corrected "Example with Rotary Encoder" sketch with DOMOTICZ? I'm trying to force the sketch to work, but for time being without any result:(
                            T 1 Reply Last reply
                            • M mateos78
                              tsjoender
                              @mateos78
                              What are the symptoms you're experiencing? When changing the dim value using the encoder. Does Domoticz pick up that change? When changing the dim value on the Domoticz end. Does the node change as well?
                              I have two of these dimmer nodes with rotary encoders based on the examples and working with Domoticz. What I did find out when building them is that the radio communication needs to be working well otherwise the dimmer seems (sometimes) unresponsive to the rotary encoder. After fixing radio communication (proper module and capacitors for powering it) these sketches worked like a charm. When using message signing the importance of good communication with the gateway becomes even more important as the messages become larger.
                                mateos78
                                hi tsjoender,
                                I've got connection between raspberry and arduino via USB.
                                Unfortunatelly phisical button dosn't work (no switch on / off) and there is no feedbeck from domoticz to Arduino to set level of dim.
                                I also find that when i change the led dimmer from the encoder the led changes quickly, but it take about ten seconds before the dormoticz web page updates to show each new slider position.
                                here https://www.mysensors.org/build/dimmer I've also described the problem.
                                • M mateos78
                                  hi tsjoender,
                                  tsjoender
                                  @mateos78 The Domoticz ui gets refreshed every 10 seconds or so. I too see that updates to sensors or switches can be a bit lagging. The logs update pretty much realtime, so you can use that to confirm that Domoticz picks up the differences instantly.
                                  • I
                                    I
                                    iguaan
                                    i have similar problem with domoticz and mysensors.
                                    Firstly, i can't get current dim level from domoticz on startup.
                                    Secondly if i start arduino and controll it over domoticz only, dimming and on/off works. If i turn the rotary knob, domoticz commands won't work.
                                    In serial monitor i see that new dim value has been received:
                                    but output doesn't change. If i turn knob on rotary, value in domoticz changes.
                                    I removed eeprom writes and rotary button. Only dims to off/on or domoticz commands off/on.
                                    Domoticz 4.10171, Mysensors 2.3.1, ide 1.8.10
                                    #define MY_RADIO_RF24
                                    #define MY_NODE_ID 10
                                    #define MY_REPEATER_FEATURE
                                    #define MY_TRANSPORT_WAIT_READY_MS 10      //ajaviide ms, kuni läheb tööle ilma serverita
                                    #define KNOB_ENC_PIN_1 5    // Rotary encoder input pin 1
                                    #define KNOB_ENC_PIN_2 4    // Rotary encoder input pin 2
                                    #define SEND_THROTTLE_DELAY 500 // Number of milliseconds before sending after user stops turning knob
                                    #define CHILD_ID_Light 1
                                    #define SN "DimmableLED"
                                    #define SV "1.1"
                                    int dimValue;
                                    int fadeTo;
                                    int fadeDelta;
                                    bool changedByKnob = false;
                                    bool sendDimValue = false;
                                    //char convBuffer[10];
                                    static int16_t currentLevel ;  // Current dim level...
                                    MyMessage dimmerMsg(CHILD_ID_Light, V_DIMMER);
                                    MyMessage lightMsg(CHILD_ID_Light, V_LIGHT);
                                       Dimmable LED initialization method
                                      // Pull the gateway's current dim level - restore light level upon node power-up
                                      request( CHILD_ID_Light, V_DIMMER);
                                      // wait(3000);
                                      present(CHILD_ID_Light, S_DIMMER );
                                        Dimmable LED main processing loop
                                      fadeStep();
                                      if (message.type == V_STATUS || message.type == V_PERCENTAGE) {
                                        fadeTo = atoi( message.data );
                                        fadeTo *= ( message.type == V_LIGHT ? 100 : 1 );
                                        // Clip incoming level to valid range of 0 to 100
                                        fadeTo = fadeTo > 100 ? 100 : fadeTo;
                                        fadeTo = fadeTo < 0   ? 0   : fadeTo;
                                        //startFade();
                                        if (!changedByKnob)
                                          knob.write(fadeTo << 1);           //### need to multiply by two (using Shift left)
                                        startFade();
                                        //		// Inform the gateway of the current DimmableLED's SwitchPower1 and LoadLevelStatus value...
                                        //		send(lightMsg.set(dimValue > 0));
                                        //		// hek comment: Is this really nessesary?
                                        //		send( dimmerMsg.set(dimValue) );
                                      long encoderValue = knob.read() >> 1 ;    //### Divide by 2 (using shift right)
                                        encoderValue = 100;
                                        encoderValue = 0;
                                        knob.write(0);
                                        startFade();
                                    void startFade() {
                                    void fadeStep() {
                                        analogWrite( LED_PIN, (int)(dimValue / 100. * 255 ) );
                                        send(dimmerMsg.set(dimValue)); // Send new dimmer value and request ack back
