  3. Node-RED
  4. NodeRed TCP Gateway
NodeRed TCP Gateway
Scheduled Pinned Locked Moved Node-RED
3 Posts 2 Posters 1.7k Views 3 Watching
  • SoloamS
    SoloamS
    Soloam
    Hello all, I'm using Nodered with a MQTT Gateway, and I'm planning on changing to a TCP Gateway, does the Mysensors node support TCP Gateway? I would like to remove MQTT from the mysensors equation to remove some complexity (on less service running and depending on), but On the Mysensors Node on NodeRed it seams that only supports MQTT!
    Thank You
    • D
      D
      David Muller
      Hi, I'm using a TCP gateway without any problems. Just place a TCP node in input instead of your MQTT node, I used this tutrial
      • SoloamS
        SoloamS
        Soloam
        Thank you @David-Muller
