  3. Combining DS18B20 and relay..
8 Posts 4 Posters 2.7k Views 7 Watching
    Mela
    Hi there,
    I am new to the world of domotica, but so far everything works fine....UNTIL..I tried to combine sensors to make me use as less nano's as possible.
    I tries to combine DS18B20 (2 pieces) and a relay, I searched on this forum, I did find some information wich helped me further in this project. The situation is now:
    1. Domoticz sees every child, so I see 1 relay an two DS18B20.
    2. but he puts the temperature value in the relay child.
    3. When I look in the device I see 2 temperature sensors and one relay, all three work fine
    the only thing is, that he present the values in the wrong child, see printscreen:
    https://drive.google.com/file/d/1p8q0QlZt-uMx12mS0Vxm8XHJBV40KrIK/view?usp=sharing
    this is the the code:
     * Version 1.0 - Henrik Ekblad
    #define MY_NODE_ID 12
    #define MY_REPEATER_FEATURE
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #include <OneWire.h>
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg(0,V_TEMP);
    #define RELAY_PIN 6  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    void before()
      for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
        pinMode(pin, OUTPUT);
      sensors.begin();
      sendSketchInfo("VloerverwarmingAansturing", "1.6");
         present(i+5, S_TEMP);
        present(sensor, S_BINARY);
      sleep(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
        #else
          send(msg.setSensor(i).set(temperature,1));
      //sleep(SLEEP_TIME);
      if (message.type==V_STATUS) {
        // Change relay state
        digitalWrite(message.sensor-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
        // Store state in eeprom
        // Write some debug info
        Serial.print(message.sensor);
    It is clear that I am doing something wrong, but I don't see it at this moment with the knowledge that I have (0,0) about debugging sketches. The hardware is ok, I tested everything seprately and works fine.
    mfalkviddM H 2 Replies Last reply
    • M Mela
      Hi there,
      int numSensors=0;
      bool metric = true;
      void before()
        sensors.begin();
          #else
      @mela you probably want to set numSensors to 2?
      M 1 Reply Last reply
      • M Mela
        Hi there,
        int numSensors=0;
        bool metric = true;
        void before()
          sensors.begin();
            #else
        H
        H
        hard-shovel
        @mela You are presenting the devices as Relay Child 1, and Temperature sensors as Child Ids 5 and 6.
        But when sending you are sending the temperatures as Child Ids 0 and 1
        Change the following send line
        to
              send(msg.setSensor(i+5).set(temperature,1));
        so the send function matches the presentation values.
        M 2 Replies Last reply
          Mela
          @mfalkvidd said in Combining DS18B20 and relay..:
          The sketches wich I have combined works with those values seprately without errors, thats why I didn't chage it, so maybe you have a point to set this value to 2 because I don't use more than 2 temp. sensors, thanks for your thinking.
          • H hard-shovel
            to
            Mela
            @hard-shovel said in Combining DS18B20 and relay..:
            to
            :) I think this is the problem, I will change it a soon as possible and wil give an update here. Thank you :)
            • H hard-shovel
              to
              Mela
              @hard-shovel problem solved thanks to you, great man....
              Now every child gives the correct value:
              https://drive.google.com/file/d/1juxdKk4ljZBUxzQWDp-3hGJC4PHqm1WQ/view?usp=sharing
              for people who need the working sketch:
              int numSensors=0;
              bool metric = true;
              void before()
                sensors.begin();
                sendSketchInfo("VloerverwarmingAansturing", "1.7");
                  #else
                sleep(SLEEP_TIME);
              • WoekaW
                WoekaW
                Woeka
                Hi, not long ago I did the same.
                Looking at your code I notice you got 16 DS18B20's. When using so many it is probably better to also fix the ID's otherwise when a DS18B20 is not responding the order of the sensors is shifted. See for code to get the ID's: https://forum.mysensors.org/topic/4143/about-ds18b20-onewire
                I also changed the pin assignment for the relay's a tiny bit.
                My sketch:
                const int PINS[] = {4, 5, 6, 7, 8, 14, 15}; // I/O pins 4, 5, 6, 7, 8, A0, A1 for the relays
                #define NUMBER_OF_RELAYS 7 // Total number of attached relays
                #define RELAY_ON 0  // GPIO value to write to turn on attached relay
                #define RELAY_OFF 1 // GPIO value to write to turn off attached relay
                #define COMPARE_TEMP 0 // Send temperature only if changed? 1 = Yes 0 = No
                #define MAX_ATTACHED_DS18B20 5
                // Generally, you should use "unsigned long" for variables that hold time
                // The value will quickly become too large for an int to store
                unsigned long previousMillis = 0;        // will store last time LED was updated
                byte D[5][8] = {
                { 0x28, 0xF2, 0xAB, 0x0F, 0x07, 0x00, 0x00, 0xA1 },
                { 0x28, 0x23, 0x29, 0xDB, 0x05, 0x00, 0x00, 0x5A },
                { 0x28, 0xAB, 0x2A, 0xDB, 0x05, 0x00, 0x00, 0x5F },
                { 0x28, 0x49, 0xAF, 0x0F, 0x07, 0x00, 0x00, 0x41 },
                { 0x28, 0x1D, 0x2F, 0x10, 0x07, 0x00, 0x00, 0xDA }
                int numSensors=0;
                bool metric = true;
                void before()
                    for (int sensor=1; sensor<=NUMBER_OF_RELAYS; sensor++) {
                        pinMode(PINS[sensor-1], OUTPUT);
                        digitalWrite(PINS[sensor-1], loadState(sensor)?RELAY_ON:RELAY_OFF);
                    sensors.begin();
                    sendSketchInfo("Relay and Temp", "1.0");
                    for (int sensor=1; sensor<=NUMBER_OF_RELAYS+MAX_ATTACHED_DS18B20; sensor++) {
                        if (sensor<=NUMBER_OF_RELAYS){
                        else {
                          present(sensor, S_TEMP);
                  if (currentMillis - previousMillis >= SLEEP_TIME) {
                    // save the last time you blinked the LED
                    previousMillis = currentMillis;
                    for (int i=0; i<MAX_ATTACHED_DS18B20; i++) {
                      // float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                      float temperature = sensors.getTempC(D[i]);
                      if (COMPARE_TEMP == 1) {
                            send(msg.setSensor(i+NUMBER_OF_RELAYS+1).set(temperature,1));
                      else {
                        digitalWrite(PINS[message.sensor-1], message.getBool()?RELAY_ON:RELAY_OFF);
                • WoekaW Woeka
                  My sketch:
                  byte D[5][8] = {
                  int numSensors=0;
                  bool metric = true;
                  void before()
                      sensors.begin();
                          else {
                        else {
                  Mela
                  @woeka Yeah you are right, i should change the code to 2 DS18B20's with eachone its own ID, thanks for the advise, also thanks for sharing your sketch.
