  3. Serial Data Sensor is there an example sketch? I need help!
4 Posts 2 Posters 1.6k Views 2 Watching
  • F Offline
    F Offline
    fosi
    I everyone! just started using mysensors to monitor my house air quality! but i don't know if its possible this thing: i have some air quality sensors that output data to serial uart, i see it on a terminal like this:
    Temperature:21.75 ,Humidity:60.66 ,Pressure:101254  ,IAQ:47 ,Gas:119387  ,Altitude:5  ,IAQ_accuracy:1
    is there some serial data read mysensor sensor sketch? i don't know much of developing, but i tried to modify the AirQualitySensor mysensors sketch
    this is the original working arduino sketch that asks and grabs data from the sensor and outputs it to terminal console:
    //GY_MCU680 air quality sensor ARDUINO
    #include <SoftwareSerial.h>
    SoftwareSerial mySerial(4, 5);
    uint16_t temp1=0;
    int16_t temp2=0;
    unsigned char Re_buf[30],counter=0;
    unsigned char sign=0;
    int led = 13;
      Serial.begin(9600);
       mySerial.begin(9600);
       mySerial.listen();
      delay(4000);
      mySerial.write(0XA5);
      mySerial.write(0X55);
      mySerial.write(0X3F);
      mySerial.write(0X39);
      delay(100);
      mySerial.write(0X56);
      mySerial.write(0X02);
      mySerial.write(0XFD);
      delay(100);
    void loop(){
      float Temperature ,Humidity;
      unsigned char i=0,sum=0;
      uint32_t Gas;
      uint32_t Pressure;
      uint16_t IAQ;
      int16_t  Altitude;
      uint8_t IAQ_accuracy;
      while (mySerial.available()) {
        Re_buf[counter]=(unsigned char)mySerial.read();
        if(counter==0&&Re_buf[0]!=0x5A) return;
        if(counter==1&&Re_buf[1]!=0x5A)
        counter=0;
         return;
        counter++;
        if(counter==20)
           counter=0;
           sign=1;
      if(sign)
         sign=0;
         if(Re_buf[0]==0x5A&&Re_buf[1]==0x5A )
                for(i=0;i<19;i++)
                   sum+=Re_buf[i];
                 if(sum==Re_buf[i] )
                         temp2=(Re_buf[4]<<8|Re_buf[5]);
                         Temperature=(float)temp2/100;
                         temp1=(Re_buf[6]<<8|Re_buf[7]);
                         Humidity=(float)temp1/100;
                         Pressure=((uint32_t)Re_buf[8]<<16)|((uint16_t)Re_buf[9]<<8)|Re_buf[10];
                         IAQ_accuracy= (Re_buf[11]&0xf0)>>4;
                         IAQ=((Re_buf[11]&0x0F)<<8)|Re_buf[12];
                         Gas=((uint32_t)Re_buf[13]<<24)|((uint32_t)Re_buf[14]<<16)|((uint16_t)Re_buf[15]<<8)|Re_buf[16];
                         Altitude=(Re_buf[17]<<8)|Re_buf[18];
                         Serial.print("Temperature:");
                         Serial.print(Temperature);
                         Serial.print(" ,Humidity:");
                         Serial.print(Humidity);
                         Serial.print(" ,Pressure:");
                         Serial.print(Pressure);
                         Serial.print("  ,IAQ:");
                         Serial.print(IAQ);
                         Serial.print(" ,Gas:");
                         Serial.print(Gas );
                         Serial.print("  ,Altitude:");
                         Serial.print(Altitude);
                         Serial.print("  ,IAQ_accuracy:");
                         Serial.println(IAQ_accuracy);
               delay(1000);
    this is me trying to figure out how to modify the AirQualitySensor mysensors sketch to work with my own sensor:
    //GY_MCU680  ARDUINO  modified to work on mysensors platform
    uint16_t temp1=0;
    int16_t temp2=0;
    int led = 13;
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #define   CHILD_ID_MQ                   0
    MyMessage msg(CHILD_ID_MQ, V_LEVEL);
      Serial.begin(9600);
       mySerial.listen();
      delay(5000);
      delay(200);
      delay(200);
      sendSketchInfo("Air Quality Sensor", "1.0");
      present(CHILD_ID_MQ, S_AIR_QUALITY);
    void loop(){
      uint32_t Gas;
      uint32_t Pressure;
      uint16_t IAQ;
      int16_t  Altitude;
        counter=0;
         return;
       };      // 检查帧头
        counter++;
        if(counter==20)
           counter=0;
           sign=1;
      if(sign)
         sign=0;
                for(i=0;i<19;i++)
                   sum+=Re_buf[i];
                 if(sum==Re_buf[i] )
                         Serial.print(IAQ);
                         Serial.print(Gas );
               delay(1000);
    but i dont know what to put in the loop! can someone please helpme?
    • F fosi
      uint16_t temp1=0;
      int16_t temp2=0;
      int led = 13;
        Serial.begin(9600);
         mySerial.listen();
        delay(4000);
        delay(100);
        delay(100);
      void loop(){
        uint32_t Gas;
        uint32_t Pressure;
        uint16_t IAQ;
        int16_t  Altitude;
          counter=0;
           return;
          counter++;
          if(counter==20)
             counter=0;
             sign=1;
        if(sign)
           sign=0;
                  for(i=0;i<19;i++)
                     sum+=Re_buf[i];
                   if(sum==Re_buf[i] )
                           Serial.print(IAQ);
                           Serial.print(Gas );
                 delay(1000);
      uint16_t temp1=0;
      int16_t temp2=0;
      int led = 13;
        Serial.begin(9600);
         mySerial.listen();
        delay(5000);
        delay(200);
        delay(200);
      void loop(){
        uint32_t Gas;
        uint32_t Pressure;
        uint16_t IAQ;
        int16_t  Altitude;
          counter=0;
           return;
         };      // 检查帧头
          counter++;
          if(counter==20)
             counter=0;
             sign=1;
        if(sign)
           sign=0;
                  for(i=0;i<19;i++)
                     sum+=Re_buf[i];
                   if(sum==Re_buf[i] )
                           Serial.print(IAQ);
                           Serial.print(Gas );
                 delay(1000);
      Hi @fosi, welcome to the MySensors community!
      I think the sketch below should get you going. This is what I've done:
      • Renamed setup() from the MCU680 sketch to setupMCU680()
      • Renamed loop() from the MCU680 sketch to getMCU680()
      • Moved the print stuff to a separate function, so it can be easily turned off
      • Moved the data variables to global variables for simplicity
      • Added the code from the Air temperature + humidity example
      To also send Gas, Pressure and Altitude, you can probably reuse code from the following examples:
      https://www.mysensors.org/build/gas
      https://www.mysensors.org/build/pressure
      https://www.mysensors.org/build/gps
      I don't know what IAQ is, sorry.
      Since I don't have a MCU680 sensor I can't test the sketch but it compiles for a Pro Mini so I think it will be fine.
      // Enable debug prints
      //#define MY_RS485
      uint16_t temp1 = 0;
      int16_t temp2 = 0;
      unsigned char Re_buf[30], counter = 0;
      unsigned char sign = 0;
      int led = 13;
      float Temperature , Humidity;
      uint32_t Gas;
      uint32_t Pressure;
      uint16_t IAQ;
      int16_t  Altitude;
      #define UPDATE_INTERVAL 1000
      #define CHILD_ID_HUM 0
      #define CHILD_ID_TEMP 1
      void setupMCU680()
        Serial.begin(9600);
        mySerial.listen();
        delay(4000);
        delay(100);
        delay(100);
      void getMCU680() {
        unsigned char i = 0, sum = 0;
          Re_buf[counter] = (unsigned char)mySerial.read();
          if (counter == 0 && Re_buf[0] != 0x5A) return;
          if (counter == 1 && Re_buf[1] != 0x5A)
            counter = 0;
            return;
          counter++;
          if (counter == 20)
            counter = 0;
            sign = 1;
        if (sign)
          sign = 0;
          if (Re_buf[0] == 0x5A && Re_buf[1] == 0x5A )
            for (i = 0; i < 19; i++)
              sum += Re_buf[i];
            if (sum == Re_buf[i] )
              temp2 = (Re_buf[4] << 8 | Re_buf[5]);
              Temperature = (float)temp2 / 100;
              temp1 = (Re_buf[6] << 8 | Re_buf[7]);
              Humidity = (float)temp1 / 100;
              Pressure = ((uint32_t)Re_buf[8] << 16) | ((uint16_t)Re_buf[9] << 8) | Re_buf[10];
              IAQ_accuracy = (Re_buf[11] & 0xf0) >> 4;
              IAQ = ((Re_buf[11] & 0x0F) << 8) | Re_buf[12];
              Gas = ((uint32_t)Re_buf[13] << 24) | ((uint32_t)Re_buf[14] << 16) | ((uint16_t)Re_buf[15] << 8) | Re_buf[16];
              Altitude = (Re_buf[17] << 8) | Re_buf[18];
        sendSketchInfo("MCU680 temp+hum", "1.0");
        present(CHILD_ID_HUM, S_HUM);
        setupMCU680();
        getMCU680();
      #ifdef MY_DEBUG
        printMCU680();
        send(msgTemp.set(Temperature, 1));
        send(msgHum.set(Humidity, 1));
        sleep(UPDATE_INTERVAL);
      void printMCU680() {
        Serial.print(IAQ);
        Serial.print(Gas );
      • F Offline
        F Offline
        fosi
        wrote on last edited by fosi
        Hi @mfalkvidd ! thank you very much for the help,
        IAQ is the Index of air quality 0-500 level, its a BOSCH proprietary software that runs on a cortex arm mcu that calculates from all sensor values: temp, hum, press, gases, and some other stuff.
        i was trying to figure it out myself! so i did this:
         *  DESCRIPTION
         *  BME680 GY-MCU680 UART Air Quality Sensor
         *  This sensor measures Temperature (xx.xx cº), Humidity (xx.xx %), Pressure, Gas (ohm), IAQ (0-500)
        // if you uncomment this, you can get test and debug updates about the sensor' wireless connection by using the serial monitor tool.
        #define MY_RADIO_NRF24                            // A 2.4Ghz transmitter and receiver, often used with MySensors.
        #define MY_RF24_PA_LEVEL RF24_PA_MIN           // This sets a low-power mode for the radio. Useful if you use the verison with the bigger antenna, but don't want to power that from a separate power source. It can also fix problems with fake Chinese versions of the radio.
        // #define MY_RADIO_RFM69                         // 433Mhz transmitter and reveiver.
        // Libraries
        // Feel free to change this:
        unsigned long co2MeasurementInterval = 20000;     // Time to wait between reads (in milliseconds).
        SoftwareSerial mySerial(4, 5);                  // RX, TX . You can choose other pins if you prefer.
        uint16_t temp1=0;
        int16_t temp2=0;
        //int led = 13;
        // Mysensors settings
        #define CHILD_ID_BME680 1                            // The sensor' ID on this node.
        MyMessage msgBmeTemp(CHILD_ID_BME680, V_TEMP);
        MyMessage msgBmeHum(CHILD_ID_BME680, V_HUM);
        MyMessage msgBmePress(CHILD_ID_BME680, V_PRESSURE);
        MyMessage msgBmeIAQ(CHILD_ID_BME680, V_VAR1);
        MyMessage msgBmeGas(CHILD_ID_BME680, V_VAR2);
        MyMessage msgBmeIAQA(CHILD_ID_BME680, V_VAR3);
          sendSketchInfo("BOSCH Sensortec BME680 Air Quality Sensor", "1.0");
          // Register attached sensor(s) to gateway
            present(CHILD_ID_BME680, S_CUSTOM);
          delay(1000);
          Serial.begin(115200);
          delay(1000);
          delay(1000);
          mySerial.listen();
          delay(3000);
          delay(200);
          delay(500);
          uint32_t Gas;
          uint32_t Pressure;
          uint16_t IAQ;
          int16_t  Altitude;
          // You should not change these variables:
          static unsigned long previousCo2Millis = 0; // Used to remember the time of the last temperature measurement.
          unsigned long currentMillis = millis(); // The time since the sensor started, counted in milliseconds. This script tries to avoid using the Sleep function, so that it could at the same time be a MySensors repeater.
          if (currentMillis - previousCo2Millis >= co2MeasurementInterval) { // this only gets triggered when enough time has passed.
            counter=0;
             return;
            counter++;
            if(counter==20)
               counter=0;
               sign=1;
          if(sign)
             sign=0;
                    for(i=0;i<19;i++)
                       sum+=Re_buf[i];
                     if(sum==Re_buf[i] )
                             Serial.print(IAQ);
                             Serial.print(Gas );
                             delay(1000);
                            // return Humidity;
            Serial.println("BME680 - Sending data request to sensor.");
            previousCo2Millis = currentMillis;
            float temp = Temperature;
            float hum = Humidity;
            uint32_t pressu = Pressure;
            uint16_t iaq = IAQ;
            uint32_t gas = Gas;
            uint8_t iaqaccur = IAQ_accuracy;
            Serial.println("Temperature = " + String(temp));
            send(msgBmeTemp.set(Temperature, 2));
            Serial.println("Humidity = " + String(hum));
            send(msgBmeHum.set(Humidity, 2));
            Serial.println("Pressure = " + String(pressu));
            send(msgBmePress.set(Pressure, 0));
            Serial.println("IAQ = " + String(iaq));
            send(msgBmeIAQ.set(IAQ, 0));
            Serial.println("Gas = " + String(gas));
            send(msgBmeGas.set(Gas, 0));
            Serial.println("IAQ_accuracy = " + String(iaqaccur));
            send(msgBmeIAQA.set(IAQ_accuracy, 0));
            Serial.print("BME680 - zzzzZZZZzzzzZZZZzzzz\n");
        but your example seems cleaner than mine, i will try
        my example is working almost 100%, but this messages:
        i see that they are sending:
        BME680 UART - Sending data request to sensor.
        Temperature = 21.33
        901008 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:21.33
        Humidity = 59.43
        901019 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:59.43
        Pressure = 98988
        901027 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=4,pt=7,l=5,sg=0,ft=0,st=OK:98988
        IAQ = 29
        901036 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=24,pt=7,l=5,sg=0,ft=0,st=OK:29
        Gas = 127960
        901045 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=25,pt=7,l=5,sg=0,ft=0,st=OK:127960
        IAQ_accuracy = 3
        901053 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=26,pt=7,l=5,sg=0,ft=0,st=OK: 3
        but they are not showing up on the controller, maybe because its because this type : V_VAR* ?
        • F fosi
           *  DESCRIPTION
          // Libraries
          uint16_t temp1=0;
          int16_t temp2=0;
          //int led = 13;
            delay(1000);
            delay(1000);
            delay(1000);
            mySerial.listen();
            delay(3000);
            delay(200);
            delay(500);
            uint32_t Gas;
            uint32_t Pressure;
            uint16_t IAQ;
            int16_t  Altitude;
              counter=0;
               return;
              counter++;
              if(counter==20)
                 counter=0;
                 sign=1;
            if(sign)
               sign=0;
                      for(i=0;i<19;i++)
                         sum+=Re_buf[i];
                       if(sum==Re_buf[i] )
                               Serial.print(IAQ);
                               Serial.print(Gas );
                               delay(1000);
                              // return Humidity;
              uint16_t iaq = IAQ;
              uint32_t gas = Gas;
          Temperature = 21.33
          Humidity = 59.43
          Pressure = 98988
          IAQ = 29
          Gas = 127960
          IAQ_accuracy = 3
          @fosi Nice work. Each message needs to have a different child id.
          Do something similar to this:
          MyMessage msgBmeIAQ(CHILD_ID_AQ, V_VAR1);
          MyMessage msgBmeGas(CHILD_ID_GAS, V_VAR2);
          MyMessage msgBmeIAQA(CHILD_ID_AQA, V_VAR3);
          and define them as different numbers.
