  3. Raspberry gateway: small range
7 Posts 3 Posters 1.7k Views 3 Watching
  • narfN Offline
    narfN Offline
    narf
    Hello!
    i was finally able to set up the gateway and some Sensebender Micro. But as i moved the nodes to different rooms i noticed that the gateway has very poor coverage :(
    i used a Raspberry (1) with these components:
    https://it.gearbest.com/transmitters-receivers-module/pp_453011.html
    https://www.amazon.it/dp/B016BAPC0K/ref=pe_386201_41597321_TE_item
    The Sensebender Micro is equipped with only NRF24L01 Radio.
    What could i do to improve the gateways range? would NRF24L01 modules with antennas (f.e.: these) perform better or should i go with RFM69?
    cheers!
    Peter
    • alowhumA Offline
      alowhumA Offline
      alowhum
      Looks like you got the cheap 'fake' NRF24's.
      Indeed, get a PA LNA version. But get a shielded version.
      https://www.aliexpress.com/item/1-pc-Long-Range-E01-ML01DP5-Ebyte-20dBm-2100m-SPI-NRF24L01-PA-LNA-2-4GHz-RF/32783191387.html
      For your nodes, get the red eByte modules, for example. They are more expensive, but they work great.
      You may also want to check out the "Nano Wireless Board".
      Interesting stabiliser.
      • narfN Offline
        narfN Offline
        narf
        thanks @alowhum !
        so i'll just need 1 (one) like this for my gateway http://s.click.aliexpress.com/e/c4CU7enO ?
        could you post (pm) me an example for a "red eByte module" (your link for "nano wireless board" leads to searchpage for "nrf24l01 ebyte" - but they are all green...)? i usually have to wait ~60 days until i get my aliexpress orderer items, so i really would like to get the "right one" with my first order...
        and what's up with the nano wireless board?
        • alowhumA Offline
          alowhumA Offline
          alowhum
          Do a search on the forum and you'll find threads about the ebyte modules.
          the Nano Wireless Board does the same thing your stabiliser board does, but also makes it much easier to connect things together. I swear by them.
          • narfN Offline
            narfN Offline
            narf
            so i took a good look but mostly i found your recommendation for the ebyte modules.
            are we talking about this one? https://it.aliexpress.com/item/CDEBYTE-2PCS-Lot-E01-ML01D-Wireless-Transceiver-For-Arduino-nRF24L01-2-4GHz-Antenna-Module-For-Microcontroll/32803704874.html?aff_platform=aaf&cpt=1542663609771&sk=cMM8rUbm&aff_trace_key=1fc52e06d7a94d0096aabebefb8bb607-1542663609771-06798-cMM8rUbm&terminal_id=f538d8e92d1f481098e725b32d788ce6
            cd-ebyte?
            i won't need a stabiliser for the Sensebender Micro board, right? on every build i found a radio connected directly mounted on the board...
            Sorry for the bis confusion...
            • alowhumA Offline
              alowhumA Offline
              alowhum
              That's the correct module, yes.
              I don't know the answer to your question about the sensebender device.
              • TmasterT Offline
                TmasterT Offline
                Tmaster
                wrote on last edited by Tmaster
                I changed all my radios to rfm68 exactly because poor range.probably you are on middle of a 2.4ghz signal war. Take a look on your wifi neighborhood.probably there's a lot of 2.4 signal already ,masking you small nrf24 signal.... And then all ebay ones are fake... Just make a try with 2 rfm69w and you never touch an nrf24 again. 😎
                i'm a arduino fan .Even sometimes don't undestanding how to use it :P
                11.9k
                113.3k
