  3. NRF24L01+ SI24R1
NRF24L01+ SI24R1
11 Posts 4 Posters 4.7k Views 4 Watching
  • G
    G
    grumpazoid
    wrote on last edited by grumpazoid
    I have just received three of these modules from Banggood. https://www.banggood.com/3Pcs-NRF24L01-SI24R1-2_4G-Wireless-Power-Enhanced-Communication-Receiver-Module-p-1057155.html?rmmds=search&cur_warehouse=CN#jsReviewsWrap
    Have I made a mistake in buying these?
    I've tried to get them communicating using the following guide but no joy so far. https://maniacbug.wordpress.com/2011/11/02/getting-started-rf24/
    I'll have another try tonight.
    Raspberry Pi 3B - Domoticz + Node Red
    Arduino Pro Mini 3.3V - W5100 Ethernet, Nrf24
    Arduino Mega, RFLink 433Mhz
    Sonoff/ESP8266/Tasmota switches
    • electrikE
      electrikE
      electrik
      @grumpazoid Try this guide https://www.mysensors.org/build/connect_radio
      It looks like you miss one connection
      • G
        G
        grumpazoid
        After a bit of trial and error, it turned out that the clone uno board (made by geekcreit) needed a capacitor across the power lines to the radio.
        I used the code as provided on this tutorial https://www.youtube.com/watch?v=JSHJ-RLbNJk
        Next on this list is to try and make sense of this:
        Default mode output power of SI24R1 is 2 ~ 3dBm, if you want the output is 7dBm, you should write 1 (NRF24L01 + This bit is not used, the default is 0) into the lowest bit register address 0x06 (RF_SETUP) . For example, the 01register, 0x061111
        • G
          G
          grumpazoid
          Just a further update with these modules. I was having trouble with the modules not being able to communicate across the distance of my house.
          Since then I received a second order of this same SKU from BG. This time the radios came in nice individual geekcreit bags. I swapped out all the radios and now they communicate perfectly form one side of the house to the other.
          It's a shame that the BG website lists both my orders as the same part number , so there is no way of knowing what will turn up if I order again.
          • G
            G
            grumpazoid
            Latest update.
            Another 4 boards arrived from ebay. They looked like the bad batch I had in that the tracks on the PCB antenna are slightly thicker.
            Sure enough......terrible range.
            I have also received the NRF24L01+PA+LNA from the link on the Mysensors store.
            This refuses to work in MAX power mode - yes I am using separate 3.3V supply for it. Everything just locks up. Range in other power modes is no better. The printing on the PCB is different to that pictured. Pin 0 is not marked. Confusingly there is a dot next to pin 8 !!!
            so so far 3 good radios. 8 Bad ones.
            I have asked Banggood if they are still shipping the radios that worked.
            Anybody bought any recently that work ok? Maybe time to change to another band?
            YveauxY 1 Reply Last reply
            • G grumpazoid
              Latest update.
              YveauxY
              YveauxY
              @grumpazoid said in NRF24L01+ SI24R1:
              Check this thread : https://forum.mysensors.org/topic/9668/cdebyte-s-new-nrf24-modules-are-great-and-cheap
              IMHO all the hassle isn't worth the price difference.
              G 1 Reply Last reply
              • YveauxY Yveaux
                G
                G
                grumpazoid
                @yveaux Some useful info there. Thanks. Will keep an eye on those modules to see if the price drops a bit.
                • G
                  G
                  grumpazoid
                  Today I have conducted some experiments with the antenna on one of my "bad" modules.
                  First I extended the length of the antenna as detailed in the youtube video by @petewill . No improvement to speak of.
                  Having noted that the antenna tracks on all my bad modules are thicker than the ones that work, I cut the track to the on board antenna and soldered on a 125mm piece of cat5 wire.
                  The improvement was immediate. I can now reach from one end of my house to the other.
                  Interestingly there were still a couple of dead spots right at the far ends, but bending the wire at right angles, 2 or 3 cm form the end got everything working. :grin:
                  I have yet more modules on order from ebay so will see what they look like - CDEBYTE ones still at a high price :(
                  • G grumpazoid
                    G
                    G
                    Guillermo Schimmel
                    @grumpazoid I did the same but on the tip of the PCB antenna and can confirm that increases the range a lot!
                    • G Guillermo Schimmel
                      G
                      G
                      grumpazoid
                      @guillermo-schimmel It is interesting that the "tip" method did not work for me. Maybe the antenna tracks on my PCBs are not too good.
                      • G grumpazoid
                        G
                        G
                        Guillermo Schimmel
                        @grumpazoid It is not the same module. Is another with a simpler antenna.
