Irrigation Controller (up to 16 valves with Shift Registers)
    Great Work Guys!!
  • @Sparkman I like the sensors, I just built some and was dbating the way to make smaller, what kind of battery life do those moisture sensors have?
    @petewill Time to change my current 16 valve arduino sprinklers to a little smarter version like yours! I love this community.
    You have been coming on with some awesome videos and contributions!
    @DrJeff I agree this is a great community! So much fun!
    Thanks for the kind words! All credit for this project goes to @BulldogLowell though. I just made the video 🙂
  • @BulldogLowell Sorry For not giving the credit where it is due! Major Props @BulldogLowell !
    They've been running for about 9 months on the first set of batteries (2xAAA) so far and are still going strong.
    Al
    Thanks @DrJeff
    I just made an irrigation controller... @petewill made it for everyone!
    just for inspiration, here's another irrigation controller video (no, it's not mine.. but one of my friends that made it)
    Arduino controlled garden watering system – 01:04
    — Nikolaj Rahbek
  • Wow 48 channels thats awesome
    @tbowmo WOW! What did he use that for??
  • @tbowmo Time for a Shower, Can you say body sprays! 🙂
    @petewill
    He recently planted a lot of trees, so instead of walking around and watering each one manually he made this
    Its a arduino with a nrf24 module, but not using the mysensors library (yet...)
    @tbowmo said:
    @petewill
    I guess so 🙂
    Cool!
    @treb0r
    here is a stab at modification for no shift register... not much changes.
    Not tested but it compiles...
    Let me know if you see anything in testing.
    MySprinkler for MySensors
    Arduino Multi-Zone Sprinkler Control
    June 30, 2015
    *** Version 2.0nsr //MODIFIED FOR NO SHIFT REGISTER
    * LED status indicator
    PARTS LIST:
    * Relays (8 channel)
    * NRF24L01 Radio
    * Arduino (I used a Pro Mini)
    * Capacitors (10uf and .1uf)
    * 3.3v voltage regulator
    * Resistors (270 & 10K)
    * Female Dupont Cables
    * LED
    * Push button
    * Shift Register (SN74HC595)
    * 18 gauge wire (for relay)
    INSTRUCTIONS:
      on the serial monitor.
    #include <Time.h>
    #include <LiquidCrystal.h>
    #define NUMBER_OF_VALVES 4  // Change this to set your valve count up to 16.
    #define RADIO_ID AUTO  // Change this to fix your Radio ID or use Auto
    #define SKETCH_VERSION "2.0nsr"
    #define CHILD_ID_SPRINKLER 0
    #define ACTIVE_LOW // comment out this line if your relays are active high
    #ifdef ACTIVE_LOW
    #define ALL_VALVES_OFF 0xFFFF
    #define ALL_VALVES_OFF 0U
    #ifdef DEBUG_ON
    typedef enum {
    SprinklerStates;
    SprinklerStates lastState;
    const int relayPin[NUMBER_OF_VALVES] = {5,6,7,8};//<<<<<<<<<<<<<<<<<<< YOUR DIGITAL PINS HERE
    byte menuState = 0;
    unsigned long menuTimer;
    byte countDownTime = 10;
    int allZoneTime [NUMBER_OF_VALVES + 1];
    int valveSoloTime [NUMBER_OF_VALVES + 1];
    int valveNumber;
    int lastValve;
    unsigned long startMillis;
    const int ledPin = 4;//<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< CHANGED THIS TOO
    const int waterButtonPin = 3;
    boolean buttonPushed = false;
    boolean showTime = true;
    boolean clockUpdating = false;
    boolean recentUpdate = true;
    const char *dayOfWeek[] = {
    String valveNickName[17] = {
    time_t lastTimeRun = 0;
    /*Setup Shift Register...<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< COMMENTED OUT THIS BIT
    const int latchPin = 8;
    const int clockPin = 4;
    const int dataPin  = 7;
    LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
      SERIAL_START(115200);
      /*  <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< COMMENTED OUT THIS BLOCK
      pinMode(latchPin, OUTPUT);
      pinMode(clockPin, OUTPUT);
      pinMode(dataPin, OUTPUT);
      pinMode(ledPin, OUTPUT);
      attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
      digitalWrite (ledPin, HIGH);
      updateRelays(ALL_VALVES_OFF);
      //delay(5000);
      lcd.clear();
      lcd.backlight();
      lcd.createChar(0, clock);
      lcd.createChar(1, raindrop);
      delay(500);
      if (gw.loadState(0) == 0xFF); // EEPROM flag
        for (int i = 0; i < 4 ; i++)
          lastTimeRun = lastTimeRun | gw.loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
      gw.begin(getVariables, RADIO_ID, false); // Change 'false' to 'true' to create a Radio repeating node
        gw.present(i, S_LIGHT);
      digitalWrite (ledPin, LOW);
      DEBUG_PRINTLN(F("Ready..."));
      lcd.setCursor(0, 0);
      lcd.setCursor(15, 0);
      lcd.write(byte(0));
      lcd.setCursor(0, 1);
      int clockCounter = 0;
        gw.requestTime(receiveTime);
        delay(1000);
        lcd.print(".");
        clockCounter++;
        if (clockCounter > 16)
          lcd.clear();
          delay(2000);
      lcd.clear();
        pinMode(relayPin[i], OUTPUT);//<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< ADDED PINMODE HERE
        lcd.print(F(" Updating  "));
        lcd.print(i);
        boolean flashIcon = false;
        DEBUG_PRINT(i);
        DEBUG_PRINTLN(F(" Data..."));
        while (gw.process() == false)
          flashIcon = !flashIcon;
          gw.request(i, V_VAR1);
          delay(100);
          gw.request(i, V_VAR2);
          delay(100);
          gw.request(i, V_VAR3);
          delay(100);
      lcd.clear();
      updateClock();
      updateDisplay();
      goGetValveTimes();
      if (buttonPushed)
        menuTimer = millis();
          state = ZONE_SELECT_MENU;
          menuState = 0;
          menuState++;
            menuState = 0;
        slowToggleLED ();
        if (state != lastState)
            delay(50);
            gw.send(msg1valve.setSensor(i).set(false), false);
          lcd.clear();
          lcd.setCursor(0,0);
          lcd.setCursor(0,1);
          delay(2000);
          lastValve = -1;
        if (lastValve != valveNumber)
              gw.send(msg1valve.setSensor(i).set(true), false);
        lastValve = valveNumber;
        fastToggleLed();
          valveNumber = 1;
          startMillis = millis();
          valveNumber++;
            state = CYCLE_COMPLETE;
            lastValve = -1;
            lastTimeRun = now();
            DEBUG_PRINT(F("State = "));
            DEBUG_PRINTLN(state);
        fastToggleLed();
          DEBUG_PRINT(F("Zone: "));
          DEBUG_PRINTLN(valveNumber);
          fastToggleLed();
      else if (state = ZONE_SELECT_MENU)
        displayMenu();
      lastState = state;
    void displayMenu(void)
      static int lastSecond;
        lcd.clear();
        lcd.print(F("Starting"));
        lcd.print(F("."));
        Serial.print(".");
      lastSecond = thisSecond;
        if (menuState == 0)
          valveNumber = 1;
          state = RUN_ALL_ZONES;
          valveNumber = menuState;
          state = RUN_SINGLE_ZONE;
      lastMenuState = menuState;
    void updateRelays(int value)
      /*<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<  COMMENTED OUT THIS BLOCK BELOW
      digitalWrite(latchPin, LOW);
      digitalWrite(latchPin, HIGH);
      //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<   ADDED THIS BLOCK BELOW
      for (byte i = 0; i < NUMBER_OF_VALVES; i++)
        digitalWrite(relayPin[i], bitRead(value, i));
        buttonPushed = true;
    void fastToggleLed()
        fastLedTimer = millis ();
    void slowToggleLED ()
        slowLedTimer = millis ();
      boolean zoneTimeUpdate = false;
      if (message.isAck())
        if (message.sensor == i)
          if (message.type == V_LIGHT)
            if (switchState == 0)
              if (i == 0)
                valveNumber = 1;
                valveNumber = i;
                DEBUG_PRINTLN(i);
            DEBUG_PRINT(i);
            DEBUG_PRINT(F(" = "));
            DEBUG_PRINTLN(variable1);
              allZoneTime[i] = variable1;
              zoneTimeUpdate = true;
            DEBUG_PRINT(i);
            DEBUG_PRINTLN(variable2);
              valveSoloTime[i] = variable2;
            if (newMessage.length() == 0)
              DEBUG_PRINTLN(i);
            if (newMessage.length() > 16)
              newMessage.substring(0, 16);
            valveNickName[i] = "";
            DEBUG_PRINT(F("Recieved new name for zone "));
            DEBUG_PRINT(i);
            DEBUG_PRINT(F(" and it is now called: "));
      if (zoneTimeUpdate)
          if (i != 0)
            DEBUG_PRINT(F("Zone "));
            DEBUG_PRINT(i);
            DEBUG_PRINTLN(allZoneTime[i]);
        recentUpdate = false;
    void updateDisplay()
      static boolean displayToggle = false;
        switch (state) {
          case STAND_BY_ALL_OFF:
            fastClear();
            if (displayToggle)
              if (clockUpdating)
                lcd.write(byte(0));
              lcd.print(hourFormat12());
              lcd.print(minute());
              lcd.print(month());
              lcd.print(day());
              lcd.print(F("/"));
              lcd.print(year() % 100);
              if (clockUpdating)
                lcd.write(byte(0));
              lcd.setCursor(11, 1);
              lcd.print(day(lastTimeRun));
          case RUN_SINGLE_ZONE:
            fastClear();
            if (displayToggle)
              lcd.print(F(" Zone:"));
              lcd.print(valveNumber);
              lcd.print(F(" Active"));
                lcd.print("min");
                lcd.print("sec  ");
          case RUN_ALL_ZONES:
            fastClear();
            if (displayToggle)
              lcd.print(F(" Active "));
              lcd.print("min");
              lcd.print("sec  ");
          case CYCLE_COMPLETE:
            if (displayToggle)
              int totalTimeRan = 0;
              lcd.print(totalTimeRan);
              lcd.print(" Minutes   ");
        lastUpdateTime = millis();
      lastDisplayState = state;
      int lastSecond = second();
      int lastMinute = minute();
      int lastHour = hour();
      setTime(newTime);
        DEBUG_PRINT(hourFormat12());
        DEBUG_PRINT(minute());
        DEBUG_PRINT(month());
        DEBUG_PRINT(F("/"));
        DEBUG_PRINT(day());
        DEBUG_PRINTLN(year());
        showTime = false;
    void fastClear()
    void updateClock()
        lcd.write(byte(0));
        clockUpdating = true;
        lastVeraGetTime = millis();
      if (gw.loadState(0) != 0xFF)
        gw.saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
      for (int i = 1; i < 5; i++)
        gw.saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
    void goGetValveTimes()
      static byte valveIndex = 1;
      if (millis() - valveUpdateTime >= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
        DEBUG_PRINTLN(F("Calling for Valve Data..."));
        lcd.write(byte(1)); //lcd.write(1);
        gw.request(valveIndex, V_VAR1);
        gw.request(valveIndex, V_VAR2);
        gw.request(valveIndex, V_VAR3);
        valveUpdateTime = millis();
        valveIndex++;
        if (valveIndex > NUMBER_OF_VALVES + 1)
          valveIndex = 1;
  • thank you for this modification. I will test it today. Shall it be working withou any problems with Domoticz on Raspberry Pi?
    I assume so. It is using S_LIGHT, one of the most used device types. I am unsure however if Domoticz supports V_VAR1 & V_VAR2 for that device type, so you may have to check with other forum members who use Domoticz.
    Do you think I I could use that kind of design in parallel of a static watering controller, so I could have the basic program with the controller, and manage extras with the arduino/mysensors ?
    Inspired by @BulldogLowell's controller, I've been working on a MySensors irrigation controller that works in parallel with my RainBird Controller. I'm using a double set of relays (one 5VDC set that's controlled by the Arduino and a 24VAC set that's controlled by the 5VDC relays and the RainBird). This way I can also sense in my HA system when the valves have been opened by the RainBird controller. I have the base functionality finished and working on some additional bells and whistles. Will post some details in a separate thread later today.
    Al
  • Regarding the Video presenting this irrigation project: is the 15 min time, which is counting down after starting the valve via pressing the button, programed somewhere in the arduino code? Or it is taken from timer set in the Vera (or Domoticz) controller?
    Well, it is not working. Domoticz finds 5 switches, but on LCD there is Message: Failed Clock Synchronisation, and the Updating Valves but still 0 😕 Is the problems with V_VAR1 & V_VAR2 variables?
    On my Vera controller (as demonstrated by @petewill ) you would edit the times under Variable1 and Variable2, which corresponds to V_VAR1 and V_VAR2 in the program.
    The video shows how to modify the values in the arduino by changing the values. I am not sure if Domoticz supports such dataflow. Does Domoticz support V_VAR1 and V_VAR2?
    does Domoticz support MySensors time function? That I do not know.
  • @BulldogLowell
    I am afraid that Domoticz doesn't have such advanced options of configuration of devices. Or maybe I am wrong? Is there any chance to bypass the V_VAR1 variables?
    @treb0r This thread seems to imply that V_VAR1 etc are supported. I guess @AWI can say more about that.
    thanks for your help, @Moshe-Livne
    Do you know if Domoticz supports returning Unix timestamp using requestTime()?
    @BulldogLowell Sorry, I don't know.
    thanks @Moshe-Livne
    @treb0r said:
    @BulldogLowell
    @treb0r,
    If you can find out if V_VAR1 & V_VAR2 can work you can try that. Otherwise we can hard code the watering times by zone into the programming.
    If requestTime() isn't supported, we can attach a Real Time Clock (RTC) device to gain back the clock functionality.
    You can then use the Domoticz devices to start the ALL_ZONE sequence or individual zones...
    Let me know what you would like to do and I can modify the program for you.
  • @BulldogLowell
    requestTime() seems not be supported. A have rtc ds3231 or ds1307. They can use the same commands and libraries. If you would change the code that would perfect 🙂 As you proposed you would also include in the code the timers for zones, instead of requesting them from Domoticz. As I understand these timers are only for manuals starts (via button) right?
    @treb0r said:
    @BulldogLowell
    Well, those times will be used when you activate the device using the Domoticz on/off controls (or activate using 'scene' in Domotocz.
    Give me a day or so and I will try to code for you.
    @treb0r
    Would you like to try this, untested.
    Just to see if the RTC is working...
    June 30, 2015
    PARTS LIST:
    * NRF24L01 Radio
    * LED
    * Push button
    INSTRUCTIONS:
    #include <DS1307RTC.h>
    #include <Time.h>
    #ifdef ACTIVE_LOW
    #ifdef DEBUG_ON
    typedef enum {
    SprinklerStates;
    const int relayPin[NUMBER_OF_VALVES] = {5, 6, 7, 8}; //<<<<<<<<<<<<<<<<<<< YOUR DIGITAL PINS HERE
    byte menuState = 0;
    int allZoneTime [NUMBER_OF_VALVES + 1] = {0, 1, 1, 1, 1}; //minutes
    int valveSoloTime [NUMBER_OF_VALVES + 1] = {0, 2, 2, 2, 2};
    int valveNumber;
    int lastValve;
    const char *verboseDayOfWeek[] = {
      /*"Null",*/ "Sunday ", "Monday ", "Tuesday ", "Wednesday ", "Thursday ", "Friday ", "Saturday "
      //delay(5000);
      lcd.clear();
      lcd.backlight();
      // RTC setup
      setSyncProvider(RTC.get);   // the function to get the time from the RTC
      if(timeStatus()!= timeSet)
         Serial.println("Unable to sync with the RTC");
         Serial.println("RTC has set the system time");
      delay(500);
      lcd.clear();
        lcd.print(i);
        DEBUG_PRINT(i);
          delay(100);
          delay(100);
          delay(100);
      lcd.clear();
      updateDisplay();
      goGetValveTimes();
      if (buttonPushed)
          menuState = 0;
          menuState++;
            menuState = 0;
        slowToggleLED ();
            delay(50);
          lcd.clear();
          delay(2000);
          lastValve = -1;
        fastToggleLed();
          valveNumber = 1;
          valveNumber++;
            lastValve = -1;
        fastToggleLed();
          fastToggleLed();
        displayMenu();
      lastState = state;
        lcd.clear();
        lcd.print(F("."));
        Serial.print(".");
        if (menuState == 0)
          valveNumber = 1;
              if (i == 0)
                valveNumber = 1;
                valveNumber = i;
                DEBUG_PRINTLN(i);
            DEBUG_PRINT(i);
            DEBUG_PRINT(i);
              DEBUG_PRINTLN(i);
            DEBUG_PRINT(i);
      if (zoneTimeUpdate)
          if (i != 0)
            DEBUG_PRINT(i);
        switch (state) {
            fastClear();
            if (displayToggle)
              if (clockUpdating)
                lcd.write(byte(0));
              lcd.print(month());
              lcd.print(day());
              lcd.print(F("/"));
              if (clockUpdating)
                lcd.write(byte(0));
              lcd.print(verboseDayOfWeek[weekday(lastTimeRun)]);
            fastClear();
            if (displayToggle)
                lcd.print("min");
                lcd.print("sec  ");
          case RUN_ALL_ZONES:
            fastClear();
            if (displayToggle)
              lcd.print("min");
              lcd.print("sec  ");
            if (displayToggle)
    void fastClear()
        valveIndex++;
          valveIndex = 1;
  • @BulldogLowell
    HI
    Thanks for the post. On LCD there is no info about Time Synchronisation fail. It stops, as previously on info: Updating Valve : 0
    So I cant check if the RTC is working
    treb0r
    @treb0r
    did you get your RTC connected and tested?
  • @BulldogLowell
    Yes, RTC is connected and tested with different sketches (just to check if RTC work correctly). Works ok.
    With your correctes projects, as above mentioned: On LCD there is no info neither about Time Synchronisation, nor about Time Synchronisation fail. It stops, as previously on info: Updating Valve : 0
    treb0r
    Yes, since clock no longer needs to call server for time, synchronizing is not necessary.
    You should post serial output or show a video.
    Did you find out if Domoticz supports V_VAR1?
  • @BulldogLowell
    OK, I will post the video. If I will manage I will also post serial output
    treb0r
    @treb0r @BulldogLowel I had a chance to play a little bit with VAR1 this weekend. I verified that if you declare MyMessage var(CHILD_ID, V_VAR1); you can set it with gw.send(var.set("hello")); and request its value from the gateway using gw.request(CHILD_ID, V_VAR1);. you will get the answer in the incoming message handler under the V_VAR1 message
       if (message.type==V_VAR1) {
       	 Serial.println("got var1 answer");
    However I still didn't manage to find how to access or show these values on the domoticz. their site crashed so couldn't ask this in the forum
    @Moshe-Livne Domoticz (as of today) doesn't support V_VARx ...
    @epierre it does but in a strange way. The vars are not display vars. They are stored in the db and can be fetched and set only by the sensor. Tried it, it works....
    @Moshe-Livne this is not what @GizMoCuz said in a post... strange...
    @epierre can you please link to the post?
    @epierre He meant in the sense that it does not display or use it for anything. he said there "it is used to store/retrieve variables". The thread was about the option to show the vars as part of the sensor output. for storing and retrieving, it works.... verified.... I might get annoyed enough to add to the code that the lua script can also retrieve these vars and then it would be sweet.....
    ok good although it was not explicit... now I'll have to go back to him about water meter that heavily use V_VARs but is recognized.... as a power meter...
  • Hello
    And thx for a nice forum, I did build the irrigation controller and tried to connect it to Domoticz. Everything just seems fine, LCD works, push button works and I can turn on the irrigation from Domoticz and it shows in the LCD.
    But the problem is that it doesn't switch the relays on, it just says "no valve time" and then go watering cycle complete.
    Any suggestions on what the problem might be...... Domoticz?
    Regards
    @moffen666
    I don't have Domoticz but I suspect that the callback isn't functioning.
    try populating the array with the desired times for each sequence. replace this:
    with something like this:
    int allZoneTime [NUMBER_OF_VALVES + 1] = {0, 10, 10, 10, 5,<... how many valves you have with zero in the first position>} ;
    int valveSoloTime [NUMBER_OF_VALVES + 1] = {0, 5, 5, 5, 5,<... how many valves you have with zero in the first position>};
    This will load in the times that the program uses as your 'default' values. Then, you can check with Domoticz experts on getting the V_VAR variables working.
  • Thx Bulldog
    I will check asap and get back with the result.
    Regards
  • Hi
    I tried the code but it didn't compile, and I'm not good enough to be sure whats wrong.
    I did try change the code and I did get it to compile, but I don't know if I got it right. You can see the lame attempt below the colored line.
    upload-956d60c8-6d6d-44b7-abdb-015f701c65dc
    @moffen666
    Clearly you understand that you are to put the times for each of the valve zones, led by a zero into the array, and not copy my verbatim instructions...
    How many valves do you have? You need that many (plus one) integer numbers separated by commas...
    Example 8 valves:
    ...= {0,5,5,5,5,5,5,5,5};
    You've commented out the wrong lines.
  • Thx for the quick answer
    I use 4 valves atm, I tried your suggestion but it seems it wont work for me.
    upload-edb305b1-3dc3-4afd-ae02-e2e779452d18
    Regards
  • The inserted values in the array works from start, but it looks like the irrigation controller immediately starts to request valve data from the controller for variable1 and 2. As we cant set variable1 and 2 in Domoticz I guess it returns 0 and overwrite the inserted values in the arrays...or is it anything else happening?
    Initialising...
    send: 7-7-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
    send: 7-7-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    read: 0-0-7 s=255,c=3,t=6,pt=0,l=1,sg=0:M
    sensor started, id=7, parent=0, distance=1
    send: 7-7-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,st=ok:MySprinkler
    send: 7-7-0-0 s=255,c=3,t=12,pt=0,l=6,sg=0,st=ok:2.0nsr
    send: 7-7-0-0 s=0,c=0,t=3,pt=0,l=0,sg=0,st=ok:
    send: 7-7-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
    send: 7-7-0-0 s=2,c=0,t=3,pt=0,l=0,sg=0,st=ok:
    send: 7-7-0-0 s=3,c=0,t=3,pt=0,l=0,sg=0,st=ok:
    send: 7-7-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,st=ok:
    Ready...
    Calling for Valve 0 Data...
    send: 7-7-0-0 s=0,c=2,t=24,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=0,c=2,t=24,pt=0,l=0,sg=0:
    Recieved variable1 valve:0 = 0
    send: 7-7-0-0 s=0,c=2,t=25,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=0,c=2,t=25,pt=0,l=0,sg=0:
    Recieved variable2 valve:0 = 0
    send: 7-7-0-0 s=0,c=2,t=26,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=0,c=2,t=26,pt=0,l=0,sg=0:
    No Name Recieved for zone 0
    Calling for Valve 1 Data...
    send: 7-7-0-0 s=1,c=2,t=24,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=1,c=2,t=24,pt=0,l=0,sg=0:
    Recieved variable1 valve:1 = 0
    Zone 1 individual time: 1 group time: 0
    Zone 2 individual time: 1 group time: 1
    Zone 3 individual time: 1 group time: 1
    Zone 4 individual time: 1 group time: 1
    send: 7-7-0-0 s=1,c=2,t=25,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=1,c=2,t=25,pt=0,l=0,sg=0:
    Recieved variable2 valve:1 = 0
    Zone 1 individual time: 0 group time: 0
    send: 7-7-0-0 s=1,c=2,t=26,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=1,c=2,t=26,pt=0,l=0,sg=0:
    No Name Recieved for zone 1
    Calling for Valve 2 Data...
    send: 7-7-0-0 s=2,c=2,t=24,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=2,c=2,t=24,pt=0,l=0,sg=0:
    Recieved variable1 valve:2 = 0
    Zone 2 individual time: 1 group time: 0
    send: 7-7-0-0 s=2,c=2,t=25,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=2,c=2,t=25,pt=0,l=0,sg=0:
    Recieved variable2 valve:2 = 0
    Zone 2 individual time: 0 group time: 0
    send: 7-7-0-0 s=2,c=2,t=26,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=2,c=2,t=26,pt=0,l=0,sg=0:
    No Name Recieved for zone 2
    Calling for Valve 3 Data...
    send: 7-7-0-0 s=3,c=2,t=24,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=3,c=2,t=24,pt=0,l=0,sg=0:
    Recieved variable1 valve:3 = 0
    Zone 3 individual time: 1 group time: 0
    send: 7-7-0-0 s=3,c=2,t=25,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=3,c=2,t=25,pt=0,l=0,sg=0:
    Recieved variable2 valve:3 = 0
    Zone 3 individual time: 0 group time: 0
    send: 7-7-0-0 s=3,c=2,t=26,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=3,c=2,t=26,pt=0,l=0,sg=0:
    No Name Recieved for zone 3
    Calling for Valve 4 Data...
    send: 7-7-0-0 s=4,c=2,t=24,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=4,c=2,t=24,pt=0,l=0,sg=0:
    Recieved variable1 valve:4 = 0
    Zone 4 individual time: 1 group time: 0
    send: 7-7-0-0 s=4,c=2,t=25,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=4,c=2,t=25,pt=0,l=0,sg=0:
    Recieved variable2 valve:4 = 0
    Zone 4 individual time: 0 group time: 0
    send: 7-7-0-0 s=4,c=2,t=26,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=4,c=2,t=26,pt=0,l=0,sg=0:
    No Name Recieved for zone 4
    @moffen666
    try commenting out this in setup():
        lcd.print(i);
        DEBUG_PRINT(i);
          delay(100);
          delay(100);
          delay(100);
    and this in loop():
    //goGetValveTimes();
    That will disable those callbacks and you should be OK with a HardCoded time table for the valves and valve names.
  • Thx Bulldog for all the help, everything seems to be working as it should now.
    Keep up the good work 👍
    Updated code for Domoticz.
    May 31, 2015
    *** Version 2.0
    PARTS LIST:
    * NRF24L01 Radio
    * LED
    * Push button
    INSTRUCTIONS:
    #include <Time.h>
    #define SKETCH_NAME "MySprinkler Domoticz"
    #define SKETCH_VERSION "2.0"
    //#define ACTIVE_LOW // comment out this line if your relays are active high
    #ifdef ACTIVE_LOW
    #ifdef DEBUG_ON
    typedef enum {
    SprinklerStates;
    byte menuState = 0;
    int allZoneTime [NUMBER_OF_VALVES + 1]= {0, 1, 1, 1, 1};     // Insert values in min, 0 = all zone (always 0) this is a 4 chan relay
    int valveSoloTime [NUMBER_OF_VALVES + 1]= {0, 1, 1, 1, 1};   // Insert values in min, 0 = all zone (always 0) this is a 4 chan relay
    int valveNumber;
    int lastValve;
    const int ledPin = 5;
    //Setup Shift Register...
      //delay(5000);
      lcd.clear();
      lcd.backlight();
      delay(500);
      lcd.write(byte(0));
        delay(1000);
        lcd.print(".");
        clockCounter++;
          lcd.clear();
          delay(2000);
      lcd.clear();
        lcd.print(i);
        DEBUG_PRINT(i);
          delay(100);
          delay(100);
          delay(100);
      lcd.clear();
      updateClock();
      updateDisplay();
      if (buttonPushed)
          menuState = 0;
          menuState++;
            menuState = 0;
        slowToggleLED ();
            delay(50);
          lcd.clear();
          lcd.setCursor(0,0);
          lcd.setCursor(0,1);
          delay(2000);
          lastValve = -1;
        fastToggleLed();
          valveNumber = 1;
          valveNumber++;
            lastValve = -1;
        fastToggleLed();
          fastToggleLed();
        displayMenu();
      lastState = state;
        lcd.clear();
        lcd.print(F("."));
        Serial.print(".");
        if (menuState == 0)
          valveNumber = 1;
              if (i == 0)
                valveNumber = 1;
                valveNumber = i;
                DEBUG_PRINTLN(i);
            DEBUG_PRINT(i);
            DEBUG_PRINT(i);
              DEBUG_PRINTLN(i);
            DEBUG_PRINT(i);
      if (zoneTimeUpdate)
          if (i != 0)
            DEBUG_PRINT(i);
        switch (state) {
            fastClear();
            if (displayToggle)
              if (clockUpdating)
                lcd.write(byte(0));
              lcd.print(month());
              lcd.print(day());
              lcd.print(F("/"));
              if (clockUpdating)
                lcd.write(byte(0));
            fastClear();
            if (displayToggle)
                lcd.print("min");
                lcd.print("sec  ");
          case RUN_ALL_ZONES:
            fastClear();
            if (displayToggle)
              lcd.print("min");
              lcd.print("sec  ");
            if (displayToggle)
      setTime(newTime);
        DEBUG_PRINT(day());
        showTime = false;
    void fastClear()
    void updateClock()
        lcd.write(byte(0));
        valveIndex++;
          valveIndex = 1;
    Hey Everyone,
    I just made a follow up video to this irrigation controller that shows my logic I'm using to save water. It's pretty specific to my environment but hopefully you can use some of the ideas to save water in your environment. I have attached the logic I used in my PLEG device.
    Pete
    PLEG Irrigation.pdf
    Automation to Adjust Irrigation Watering Time Based on Weather – 25:17
    — Pete B
    looking at the project, I'm wondering why you propose 3.3V only, is this for the shift register and the screen ? Why not stay in 5V ?
    @epierre Where did you see that I don't remember? Perhaps for the NRF radio?
    @petewill it is here: http://www.mysensors.org/build/irrigation
    it is hard to know the BOM from the page, so I was wondering why you would neeed the powering adaptation if you input 5V
    @epierre
    If you watch the video, you can see he's using the voltage regulator to supply power to the radio.
    Are you getting ready to build?
    @epierre
    I've ordered the 8 switch, I have soil moisture, leaf moisture, ground humidity, rain gauge and found some evapotranspiration algorithm so I have all inputs and now need to have outputs in parallel of my rainbird scheduler (too dumb...)
    So I'm ready to build as you say 😉
  • @hek said:
    Added your project to the main site togeter with @petewill excellent new video.
    https://youtu.be/l4GPRTsuHkI
    Excellent project.
    Can you help me with the android code, to send instrucctions from my cell phone to Arduino? like on-off light , bomb, etc.
    thanks for your time!
    best regards.
  • Excellent work. I need help with android code. Anybody can help me with this?
    thanks
    I made the circuit, but later i realize it required vera controller to sync all the data. Is there other way or idea to send data to the built system.
    @shemmozhipandian Sorry for the delayed reply. It does require a controller (like Vera) but there are free ones out there. Take a look here: http://www.mysensors.org/controller/
    I know Domoticz is free and seems to be fairly popular here. There are others as well. If you find one you like you may want to write a quick post to check compatibility. I personally use Vera so I'm not sure how the others work.
  • Hello Pete, thanks for your hard work on this. Superb!
    I want to build a irrigation controller like your project but can't figure out hows the wiring. On the wiki an image is shown but I can't see what the connections are in this "virtual proto board"
    Is there something clearer or like a pinout to pin list?
    I'm using an Arduino Nano, so things will be something different.
    Thank you very much.
    @Sergio Jim (@BulldogLowell) posted some more details above but here is my fritzing project as well. Hopefully you can zoom in where you need to see more.
    Fritzing Irrigation Controller Wiring.fzz
  • Mmm... I finally assembled the device. But I'm having problems with it. It doesn't activate/deactivates the relays. I'm getting the power for the relay board from the nano itself. Could that be the problem?
    Also, my domoticz doesn't receive the off signal from the controller. (doens't turn the light off) and sometimes throws some error telling that can't contact the node.
    BTW I tried to contac Bulldogloweel without success 😭
    Yes, that is most likely the problem. Most of the relays I have used need more power than what the arduino can supply. Try feeding it more power (like from a phone charger).
    Check the serial monitor with debug enabled. Does this happen every time? It could be radio issues. Do you have a 4.7uf cap on the radio? Is it close enough to your gateway?
  • @BulldogLowell
    I need to add a relay for a master valve. This will open when any zone valves open. I think it could be mapped to All On 0(1) but I am not sure how to accomplish this. I don't know the code for that or electrical connection. I also noticed we are about maxed out of data (99%) using ProMini. Any ideas?
    If you are worried about Program Space you can turn off Serial debug to rid yourself of a bunch of overhead in the sketch. I am not using String class so there is PLENTY of RAM and I've been using this for a while with no stack corruption issues:
    #define DEBUG_ON   // comment out to surpress serial monitor output
    if you propose to turn ON the master valve when each valve is cycled on, then I believe all you need to do is add that valve to the bitmask (logical OR) each time you updateRelays().
      if(value)
        value |= 0b0000000010000000;  // master is the eighth relay, there are 7 controlled in this example (active HIGH in this example)
    not tested
  • @BulldogLowell
    By commenting out the DEBUG, it went from 99% to 63% used memory.
    The modification to void updateRelays worked very nicely. I only wish the master control valve would remain ON during cycling through each valve (subjected to VALVE_RESET_TIME) as I am using it to control a chemical feed pump to prevent hydrogen proxide (30%) from entering my irrigation system.
    Awesome job and I am very pleased with your design.
    The only problem I had when building the controller was getting the LCD to communicate.
    I added this comment to my program under Instructions.
  • @BulldogLowell
    I ended up going a different approach. I modified the program so I could use Arduino digital pin6 as an output powering my master valve relay. I then added digitalWrite (masterValvePin, HIGH) where you have updateRelays(BITSHIFT_VALVE_NUMBER) to turn ON the valve. To turn off the valve I added a delay then digitalWrite (masterValvePin, LOW) to if (state == STAND_BY_ALL_OFF). This has tested perfectly for my situation.
    The only thing missing from the Controller is the ability to add the RainBird rain sensor to the board. I think the way of achieving this is an input to my Vera controller.
    @fusion_man
    maybe we can add a rain sensor this season. It is a good idea to include it.
  • @BulldogLowell
    I already did and it is up and running. I used A0 as the input for the rain sensor. I can see the rain sensor in Vera as a motion sensor. I didn't post the code as I didn't want to offend the designer. Being a newbie, I didn't know how to handle this update.
    @fusion_man
    why not just post your code? I'm sure the guy who wrote the original code won't mind, if you include his original notes and credits.
  • Quick question, semi also referenced on the openhab binding.
    Looking to use this with Openhab, I have managed to get it to work with the serial gateway, however i don't see a way i can pass out any configuration of a valve time, i can however trigger valves with a runtime of 0 seconds.
    Any ideas how i can amend this to either use a fixed runtime in the project (happy to run it in 1min increments trigged from openhab hydro sensor results)
    @Mark-Jefford
    In that case, I would just treat each zone as a separate relay/lamp and use Openhab to control the individual ON times... I think.
  • can I use pin D6 instead ok pin D8 to control the shift register. I am making the controller on the easy/newbie pc board and there is nothing connected to pin D8 on this board.
    @johnecy
    I think you should be OK to try that
  • @BulldogLowell thanks for the reply i will post pictures when i get it finished
  • @BulldogLowell
    Gave up with using openhab now using domoticz which is a lot nicer, forced it to hard coded run times by doing this:
    int variable1 = 5; // atoi(message.data);// RUN_ALL_ZONES time
    DEBUG_PRINT(i);
        int variable2 = 5; //atoi(message.data);// RUN_SINGLE_ZONE time
        DEBUG_PRINT(i);
    one thing to note the shift register 0b0000000010000000 does not seem to work, will work out a plan around this as i need to run a 12 pump off the relay bank to draw water from the water butt.
    Can you explain more? is there a bug?
  • @BulldogLowell
    Hi! 🙂
    Rather than using valve 8, i am using only a block of 4, but currently have a 2 channel for testing.
    My reading into shift registers showed 0b0000000010000000 is 2x 8 bit outputs, B0-B7
    tried configuing B0 and B7 to try and activate relay 1, was still seeing 5V on all pins apart from the output pin for the zone in use (EG zone 2 expecting Zone1 to alway be on)
    or am i doing this completely wrong? 🙂
    @Mark-Jefford
    hmmm... are your relays ACTIVE HIGH (actuate wiht a 5V signal) or ACTIVE LOW (actuate when brought to ground) type?
  • @BulldogLowell
    Oh, well this is strange, if i disconnect the pin to the relay, it does not activate when unpowered.
    but from the shift register it is +5 when the zone is not active, and 0V when active, so i assume its an active low not active high by your example... surely removing the 5V feed to the relay pin should make it activate.. not sure whats going on there, some sort of black magic 😛
    My reading of shift registers has made my brain hurt.. do i need to reverse the 0000000010000000 for 1111111101111111?
  • Dear all,
    i have trying to make the irrigation controller to start all zones in same time and run for the specified. I'm using version for domoticz. Can you please help me out with hint of what i can change in the code ?
    Another thing is that from domoticsz when i start a zone that zone start and previous is stopped but that status is not updated.
    Thank you in advance.
    P.S. I will post some pictures of the hardware build soon.
    @rechin304
    have you tried changing the eight to one?
    #define NUMBER_OF_VALVES 8  // Change this to set your valve count up to 16.
    trigger all your relays with the same output.
  • Well, that's not the point.
    I will have 4 zones that need different type of water needs. For example one zone will be with micro irrigation watering, another one with lawn sprinkler. i do not understand why not to start all zones at once and they will finish according to the time set and not to start one after other. Another thing is why to wait for a zone to finish when you trigger another one.
    To start all valve at once when is trigger all zones i did change:
        fastToggleLed();
          valveNumber = 1;
    with
              gw.send(msg1valve.setSensor(i).set(true), false); //to update domoticz
        fastToggleLed();
          valveNumber = 1;
          updateRelays(0); //all outputs will be on
    I will have 4 zones that need different type of water needs. For example one zone will be with micro irrigation watering, another one with lawn sprinkler. i do not understand why not to start all zones at once and they wi finish according to the time set and not to start one after other. Another thing is why to wait for a zone to finish when you trigger another one.
    I see your point an understand your questions. The purpose of zone cycling is to be able to have enough pressure in each zone independently while also having pressure for household use. Drawing water to every zone (in my case 9) makes the pressure so low, there may not be enough to open the individual pop-up valves, much less fill the washing machine.
    The wait period (which you may set) is there to allow the time for hydraulic actuation of solenoid valves. These types of valves close slowly, and since they are in a manifold, the next valve to start opens faster if the water pressure at the manifold is allowed time to reach normal static pressure.
    The beauty of open source is that you get to do it your way. If you have the pressure to run all your valves at the same time, with enough to spare to take a shower, then you are fortunate!
    So, did you add another 'switch' to your controller to send the all zone command?
    I did this so all relays on is ok now.
    What i miss is to start individual zones more than once at a time :).
  • Pictures of the case project and how is arranged inside. Not yet on the final location, still testing.
    5_1461396298101_IMG_3866.JPG 4_1461396298101_IMG_3865.JPG 3_1461396298101_IMG_3863.JPG 1_1461396298101_IMG_3861.JPG 0_1461396298101_IMG_3860.JPG
  • Hi I just finished building my first project in arduino ( this one) but the code is too large now for the arduino memory its 32748 bytes could you please share with me the older version of the code / libraries to run it in code bender ?
    @David-Mora's question was double-posted. See https://forum.mysensors.org/topic/3921/code-grew-larger-dan-promini/ for the other thread.
    @David-Mora I responded to your comment on the YouTube video but I'll respond here as well just in case people are reading this thread instead.
    This is probably because debug is enabled in the MyConfig.h file. Please comment out this line: #define DEBUG
    Make sure to save the .h file then recompile the Arduino code. It should be around 25,342 bytes.
  • Hi Pete thank you very much, I am using mysensors online editor , not sure if I should edit that code?0_1463751590886_mysensors.jpg
    It's not possible to disable this from codebender. You'll need to install the Arduino IDE onto your computer.
  • @hek in computer I get this:
    C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\I2CIO.cpp:35:26: fatal error: ../Wire/Wire.h: No such file or directory
    #include <../Wire/Wire.h>
    compilation terminated.
    exit status 1
    Error compilación en tarjeta Arduino Pro or Pro Mini.
  • thank you for your help ! I just reinstaled arduino and now I getthis ( I just downloaded the I.5 and copy and paste all libraries in the libraries folder:
    TENCIÓN: Categoría '' en librería UIPEthernet no es válida. Configurando a 'Uncategorized'
    C:\Users\David\Desktop\IrrigationController\IrrigationController.ino:92:31: fatal error: LiquidCrystal_I2C.h: No such file or directory
    exit status 1
    Error compilación en tarjeta Arduino Pro or Pro Mini.0_1463753883896_liquid.jpg
  • @David-Mora quite sad I´ve spent two days now installing and uninstalling arduino and libraries and no luck
    @David-Mora Did you close all instances of Arduino and open again after you added the LiquidCrystal library? It looks like it can't find it.
  • @petewill Yes Pete it doesnt work at all
  • @David-Mora hope this is the right way to post the code finally the only mistake is
    Arduino:1.6.9 (Windows 7), Tarjeta:"Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
    El Sketch usa 30,808 bytes (100%) del espacio de almacenamiento de programa. El máximo es 30,720 bytes.
    Las variables Globales usan 1,329 bytes (64%) de la memoria dinámica, dejando 719 bytes para las variables locales. El máximo es 2,048 bytes.
    processing.app.debug.RunnerException: Programa muy grando: visite http://www.arduino.cc/en/Guide/Troubleshooting#size para ver cómo reducirlo.
    at cc.arduino.Compiler.size(Compiler.java:315)
    at cc.arduino.Compiler.build(Compiler.java:156)
    at processing.app.Sketch.build(Sketch.java:1111)
    at processing.app.Sketch.build(Sketch.java:1081)
    at processing.app.Editor$BuildHandler.run(Editor.java:1988)
    at java.lang.Thread.run(Thread.java:745)
    Tarjeta en COM4 no disponible
    Este reporte podría tener más información con
    "Mostrar salida detallada durante la compilación"
    opción habilitada en Archivo -> Preferencias.
    @David-Mora Looks like you are almost there!
    Did you disable debug? The sketch looks too big. To disable go to the MySensors library and open the MyConfig.h file in Notepad and change this line:
    #define DEBUG
    to
    //#define DEBUG
    Also, it looks like the Arduino IDE programmer isn't finding your Pro Mini. Did you select the correct Board and Port from the Tools menu? I don't have an Arduino next to me so my port isn't available to select but it should look similar to this (except you would choose your Port the Arduino is connected to):
    0_1463835965285_upload-1dd27cba-b4e4-4543-980b-5ac59cc5da52
  • 90
