    Works like a charm!
    This is the NodeMcu board used (Called NodeMcu Devkit v1.0 by the NodeMcu Team. Schematics and layout can be found here)
    Radio connection (using MySensors default coloring scheme. IRQ is unused and can be left unconnected):
    The standard ESP8266 Gateway sketch can be used without modification (except for SSID & password).
    • Install CP2102 drivers from here.
    • Connect NodeMCU board.
    • Load the Esp8266Gateway.ino sketch (See Compiling the gateway in the top post)
    • Download the sketch. This NodeMcu board can be flashed automaticlly and doesn't need botload/reset buttons to be pressed.
    • Open the serial console and watch the board connecting to yout WiFi network.
    • Note the IP address assigned to it.
    • Now any application capable of communicating with the regular MySensors Ethernet gateway should be able to communicate with the ESP Gateway.
    • Enjoy!
    Optional step: If you want to use the onboard red LED (GPIO16) to blink when radio activity/error takes place, then change the following:
    MyConfig.h
    #define WITH_LEDS_BLINKING
    Esp8266Gateway.ino
    #ifdef WITH_LEDS_BLINKING
    #define RADIO_ERROR_LED_PIN 16  // Error led pin
    #define RADIO_RX_LED_PIN    16  // Receive led pin
    #define RADIO_TX_LED_PIN    16  // the PCB, on board LED
    Thanks @Yveaux,
    I'll probably copy (most) of the previous post to the main site.
    Yeah, no probs. I already thought you would.
    Maybe you should 'MySensor' the devkit pinout a little to have it fit in.
  • Hi
    Excellent build and exactly what I have been looking for. I just got my ESP-12 this week and I am about to build this. I just have one question, what is the "Inclusion mode" for? I tried to figure it out by look at the sketch and it's not quite clear.
    Thank you for everything you have done to get this to where it's at.
    Mike
    @Mike-Cayouette I copied the implementation from the Ethernet gateway.
    I thought it was meant as a function to allow clients to join the network within a certain timeframe after pressing the button.
    When looking at the code I'm not sure it does anything at all...
    Maybe @hek can shed some light on the issue?
    It doesn't do much on the gateway side. As @Yveaux says it allows you to have a physical button in the gateway to enable inclusion mode. After some (configurable) time it disables inclusion mode. The enabled/disabled status is sent to controller side. But no filtering of presentation messages occurs on the gateway.
    So it is really up to the controller to respect the inclusion mode status (whether or not to create new devices).
    @Yveaux
    Please PM me any updates needed on this:
    http://www.mysensors.org/build/esp8266_gateway
  • Hi @Yveaux ,
    I finally received my NodeMCU (but from http://doit.am/) did you had to flash any firmware (like the NodeMCU one) in order to be able to use it from Arduino IDE or it is just flash the .ino and it's ready to go?
    Regards
    @Daniel-Oliveira by downloading from the Arduino ide you will overwrite any firmware already in the flash. No manual steps are required. Just connect and download from Arduino ide.
  • Thank you for the quick response @Yveaux & @hek
    I started working on the gateway today but I seem to be having a problem. I already had IDE version 1.6.5 installed with the board manager enabled. I've been creating some sensors on some ESP-01 for a few weeks without a problem. I replaced the MySensors folder I had in my library folder with the most recent one. My old sketches still compile but when I try to compile the ESP8266Gateway sketch I get the following error.
    Esp8266Gateway.cpp.o: In function `incomingMessage(MyMessage const&)':
    Esp8266Gateway.cpp:(.text+0x74): undefined reference to `vsnprintf_P'
    Esp8266Gateway.cpp.o: In function `output(char const*, ...)':
    Esp8266Gateway.cpp:(.text+0xb6): undefined reference to `vsnprintf_P'
    MySensors/MyHwESP8266.cpp.o: In function `hw_writeConfig(int, unsigned char)':
    MyHwESP8266.cpp:(.text+0x138): undefined reference to `snprintf_P'
    MySensors/MyHwESP8266.cpp.o: In function `MyHwESP8266::MyHwESP8266()':
    MyHwESP8266.cpp:(.text+0x16f): undefined reference to `snprintf_P'
    MySensors/MyHwESP8266.cpp.o: In function `MyHwESP8266::debugPrint(bool, char const*, ...)':
    MyHwESP8266.cpp:(.text+0x19a): undefined reference to `vsnprintf_P'
    MyHwESP8266.cpp:(.text+0x1b3): undefined reference to `vsnprintf_P'
    collect2: error: ld returned 1 exit status
    Error compiling.
    All I changed in the ESP8266Gateway example sketch was the SSID and Password.
    Regards,
    Mike
    Can you check the boardmanager which version of ESP Arduino you have installed?
    Mine's like this:
    upload-fbb1d613-848e-4c2d-8076-8eb684d07141
    I use the 'stable' version, located at http://arduino.esp8266.com/stable/package_esp8266com_index.json
    Maybe your installation is inclomplete; you could try removing & reinstalling Arduino for ESP.
    That was the problem, I was running an older version, I upgraded it and now it show's the same as your version.
    Thanks again,
    Mike
  • Just wanted to say thank you! It works great after hooking it up on my breadboard, now I can finally include MySensors in my sensor network 8-)
    @jvandenbroek Great to hear it's working fine! Have fun!
  • Great work. Just starting out with mysensors and looking forward to implementing this. Waiting for my hardware to arrive 🙂
    @gmccarthy said:
    Great work.
    Your icon suggests differently 😆
  • I'm having problems compiling this - I must be missing something but can't figured out what.
    Error:
    Esp8266Gateway.ino:77:25: fatal error: ESP8266WiFi.h: No such file or directory
    I've downloaded the mysensor library and unzipped it.
    My sketchbook location is: C:\Users\xxxxx\Documents\Arduino
    Under C:\Users\xxxxx\Documents\Arduino\libraries\MySensors\examples\Esp8266Gateway
    Ads
    The esp8266gateway.ino file is present.
    Update: Pffft....try selecting the generic ESP8266 module 🙂
  • Built Mine 😃 works great the only problem I had was uploading the code from a Mac OSX Mavericks so I opened a Win7 VM I keep for these type of problems and all is good. Thanks! @Yveaux 👏
    @DrJeff said:
    Built Mine
    Great to hear you got things running!
    @hek is also on Mac and he managed to download directly. Maybe you can discuss your issues with him so we can update the install instructions if something special is required for Mac.
    My Gateway has shrunk...!
    Sure did, and it's wireless now 😆
    @DrJeff
    I managed to upload on mac, but had to fiddle around before I got it working.
    Added this text after my experience.
    "This NodeMCU board normally can be flashed automatically and shouldn't need bootload/reset buttons to be pressed. If you see error, try changing baudrate from from 9600 to 57600. Still problems? Hold flash and press reset. Start upload in IDE while keeping flash-button pressed until upload starts."
  • @hek Yes I tried those but it's probably the driver install it was acting a little finicky so it was quicker to flip over to the VM. 🙂
  • @DrJeff
    I remember that there was an error in the boardmanager-package for MacOS. You need to change the file-permissions to executable:
    sudo chmod +x ~/Library/Arduino15/packages/esp8266/tools/esptool/0.4.4/esptool
    I followed the steps above, and I'm even able to upload sketches, however I only get this in serial monitor:
    Bad module maybe?
    EDIT: After choosing the right board (v.1.0) and applying the fix above from @fleinze, it seems it is working now...
    I'm having problems running ESP8266 gateway. When I reset my nodes or trying send command from controller to node (dimmer, realy etc.) my gateway reset itself. I try using different ESP-s (I'm using ESP-12), power supplys and radio modules.
    On serial monitor I get this error:
    @krajcl What catches my eye is the client command echoed by the gateway: "Client 0: 44;255;3;0;6;"
    The 0 at the end seems to be missing -- This could be a gateway issue (are you using the standard ESP gateway sketch, or did you make any modifications?) which causes e.g. the command parser to crash.
    Could you give a more detailed description of your setup? Which controller are you using, what does the network look like (nr. of sensors, repeaters etc.).
  • @Yveaux I'm using standard ESP gateway sketch (I reinstalled Arduino IDE, download latest mysensors library). At the moment I'm using MYSController as controler (for testing), I only have one node active (standard humidity sketch - only changed node id).
    @krajcl The last command from the controller seems to be a response to the sensor to indicate metric or imperial units are used (internal command 6). The payload should be either 'M' or 'I'.
    I'm not familiar with MYSController, but is there some setting influencing the unit system? Can you check if it has a valid value?
    I can't replay the situation right now, so anything you can do yourself to track the problem would really help.
  • @Yveaux This is result with Domoticz as controller and new node (relay), same result:
    I'm definitely not a expert at all on the topic, but could it be that a ftdi-usb adapter doesn't provide enough power to ESP, and it eventually hangs when wi-fi transmissions drawn too much power? (according to the specs, ~150mA when transmitting) .
    Just trying to help with some (probably dumb) brainstorming. 😉
  • Do you need to the NodeMCU to implement this?
    I have an arduino uno and ESP-01. How do I wire these up?
    After doing some more reading looks like the esp-01 does not have enough pins. Dont think I can use it 😞
  • @Yveaux I tried function (clear routing table) in MYSConroller. This is result:
    Client 0: 0;0;3;0;10;C
    Client 0: 6;0;3;0;10;C
    ctx: cont
    sp: 3ffeabe0 end: 3ffeaf20 offset: 01b0
    When I try this function for gateway, evrything works fine, but for other nodes - gateway resets
    @krajcl When this message is addressed to the gateway (0;0;3;0;10;C) it does not get sent over the air by the radio.
    When you send it to node 6 (6;0;3;0;10;C), it will send the message to the node, using the radio.
    Can you please answer this: Will it crash with just any message sent to the nodes using the radio, or only when sending internal messages to nodes (internal messages to nodes have the first value unequal to 0 and the third value set to 3, like 6;x;3;x;x;x) ?
  • @Yveaux it doesn't matter, what I send, resets every time
    @krajcl Ah, ok! That helps!
    For me, and a lot of other people on this forum, sending messages just works with the ESP.
    Maybe @rvendrame is pointing in the right direction? How are you powering the ESP?
  • Is it possible to set a fixed IP adress and bypass DHCP? My router sometimes messes up his DHCP-table and reassigns all adresses. Then I would have to correct the IP in my controller which I want to avoid.
    @Anduril The ESP8266 Arduino port uses the same API as the standard Arduino WiFi library.
    This means you should be able to use WiFi.config() to set a fixed IP address.
    Change the following line in Esp8266Gateway.ino
      (void)WiFi.begin(ssid, pass);
    into something like (untested!):
      IPAddress ip(192, 168, 0, 123);  /* Set to whatever IP address you'd like the gateway to have */
      WiFi.config(ip);
    Please report back your experience!
  • I got this working on an 0.9 version of the nodeMCU ( the Yellow board ). It has some code upload issues, which are slightly worse on OS X than Linux, but usually a couple of tries with holding down the button as @hek mentioned usually does the trick. I do not have any TCP/IP clients pointed at it currently, but I also get lots of watch dog timer resets, which seem somewhat random, as it will run and log messages for somewhere between 15 mins and 10 hours.
    It is just being powered by USB and I have not swapped NRF modules yet, so one of those may likely be the culprit, but just wanted to chime in with a (mostly) successful setup.
    thanx
  • Hello all,
    is there anybody setup MQTT gateway and it's working fine? how many node wifi gateway can handle?
    Could you please share me Wifi MQTT Gateway code.
    Thank you all and have a nice day
    Currently there is no MQTT WiFi gateway, but it shouldn't be very hard to create one by combining the WiFi Gateway with the MQTT gateway.
    The same as any other MySensors gateway (around 250).
  • I will report a successful first experience with MySensors using the esp8266 WiFi Gateway and a digital switch nRF24L01+ MySensors node.
    Thank you Yveaux and hek! nRF24L01+ nodes are the only way to go for battery power!
    I look forward to learning more about the MySensors architecture.
    I am currently using openHAB as my controller.
    For the MQTT library, I will vote for the https://github.com/Imroy/pubsubclient library if you decide to create a MQTT version of the WiFi Gateway. I have this library installed on 8 esp8266 nodes operating for over two months without any problems.
    The knolleary version has had some recent updates since I installed the lmroy version, so it may work fine with Mosquitto MQTT 3.1.1 instead of MQTT 3.1 only.
  • Hi Friends
    I am having an issue with my NRF24L01+. If I change gw.begin() to anything like below,
    I get an error "radio init fail"
    And I am now trying ESP-8266 12E module along with nrf24L01+ (genuine) transceiver to built wifi gateway, which I'll later use as gateway for openhab. I am having a similar issue, Here is the log I get through serial monitor.
    **Connecting to Ahmed
    ...........Connected!
    IP: 192.168.0.31
    0;0;3;0;9;radio init fail
    ctx: cont
    sp: 3ffebdf0 end: 3ffec010 offset: 01b0
    stack>>>
    3ffebfa0: 0000007f 3ffec03c 40201cac 3ffeaff0
    3ffebfb0: 40202320 00000001 00000000 40201d4f
    3ffebfc0: 1f00a8c0 00ffffff 0100a8c0 3ffec03c
    3ffebfd0: 3ffe9328 3ffead34 3ffec070 402026ef
    3ffebfe0: 3ffe98a8 1f00a8c0 00000000 00000000
    3ffebff0: 3fffdc20 00000000 3ffec034 40201d1f
    3ffec000: 00000000 00000000 3ffeaff0 40100398
    <<<stack<<<
    ets Jan 8 2013,rst cause:1, boot mode:(3,3)
    tail 0
    chksum 0x42
    csum 0x42
    ~ld**
    This information runs in a loop again and again. I am using latest library from https://github.com/mysensors/Arduino/tree/master without editing the sample Esp8266Gateway sktech except user name and password. I have followed the connection instruction specified in sample sketch and sketch was successfully uploaded. I am using 101nf capacitors and 10K resistances as specified by https://www.youtube.com/watch?v=JA-0hs5rpMY.
    Everything is working fine except that error. May anyone help me out?
    @vickey the resets you're experiencing are caused by the failure to init the radio. This will cause the MySensors library to enter an endless loop. This will cause the watchdog to trigger and reset the ESP.
    Please try connecting the radio exactly as stated on the MySensors build page (when using NodeMcu hardware) or connect the same way as I did (see first post in this topic).
    Double check your radio connections.
  • I have checked all the wires and every thing is according to as par advised. I am using 2 separate 3.3 v voltage regulator to power up ESP-8266 12E and nrf24L01+ having common ground, using ESP-8266 breakout board without voltage regulator and nrf24l01+ breakout board with 3.3 v regulator powered by 5v supply.
    GPIO15 connected via 10K pulldown resistor to GND and also connected with CSN of nrf24l016, is this connection correct?
    Moreover, I am using USB to TTL adapter in place of FTDI and TX of ESP-8266 is connected with RX of TTL serial adapter and vice versa, GND of TTL serial adapter is also connected common GND. It's all the difference from your mentioned procedure.
    @vickey could the nrf24 be defective?
    Did you obtain the gateway & MySensors code from my github repository or from MySensors repository?
  • Sorry When I investigate the wiring throughly, MOSI and MISO was interchanged. Now it has started working but error has changed
    ESP8266 MySensors Gateway
    Connecting to Ahmed
    .......Connected!
    IP: 192.168.0.31
    0;0;3;0;9;read: 0-0-0 s=0,c=0,t=0,pt=0,l=0,sg=0:
    0;0;3;0;9;ver mismatch
    I obtained the code for gateway & MySensors from MySensors repository on github.
    what would be the problem now?
  • I would like to use this tutorial for MySensors in the openHAB program:
    http://forum.mysensors.org/topic/1194/tutorial-openhab-with-serial-gateway
    I have the ESP8266 WiFi gateway working over a telnet session in Putty.
    Is there a way to have openHAB communicate over telnet like a hardwired serial interface?
    Has anyone used this yet?
    https://github.com/openhab/openhab/pull/2832
    @ridge sorry, can't help with that. Everything's MQTT over here 🙂
  • Thanks! Are you using this gateway with a controller or is it a proof of concept?
    It is fun to watch the states respond in a telnet session. I am having trouble finding any mention on how to use this with a controller.
    @ridge its use should be no different then when using the Ethernet gateway (because it is an Ethernet gateway 🙂 )
    I'm using it with OpenHab through MQTT and NodeRed through MQTT.
  • Is your setup using this gateway like:
    MySensors network <=>Gateway <=> Format conversion program <=> MQTT broker <=> openHAB
    For some reason, I had assumed that the results of the gateway could be used directly in openHAB.
  • Thanks hek, OpenHAB 1.7.1 is stable for me. I will probably wait for openHAB 2.0 to get closer to production status before wading in.
    I understand serial binding.
    I understand MQTT binding.
    I am missing something stupid easy in understanding ethernet binding.
    Do I include the http binding in the addons folder?
    A serial connected device is defined in an openHAB items file like:
    Switch HardwareButton "Bell" (Entrance) { serial="/dev/ttyS0" }
    I just cannot find an example of what an ethernet connected device would use in place of the "serial" definition.
    Yes. Production gateway is currently (cabled) ethernet gateway, "Format conversion program" is this perl script and MQTT broker is Mosquitto.
    Perl script, Mosquitto and OpenHab run on Ubuntu 12.04LTS server PC.
    @ridge
    You could always use ser2net to emulate a serial port connected to the ethernet gateway from you openhab box.
  • Thank you hek and Yveaux. I thought I had missed something obvious. For the present with openHAB 1.7.1, a small piece of the wireless sensor data super highway of the future is still under construction! In that case I will certainly study the MySensors gateway to MQTT broker examples closely.
  • Hello guys,
    I am having issues with this installation. I got everything up and running but it simply doesn't connect to my WiFi Netgear router at home.
    I just enabled my hotspot on my cell phone and the gateway did connect successfully and started the gateway master with IP, etc assigned.
    When I try to connect to my home WiFi it just keeps on printing dot dot dot in the serial console.
    My Netgear has two networks with 2.4Ghz and 5Ghz. I tried both and none of them worked. They are configured with WPA2-PSK [AES] encryption for the passphrase and the passphrase has one special character included. The SSID is 5 characters long and the passphrase is 22 characters long which shouldn't be an issue.
    I don't get any error messages in the serial console and my router doesn't show anything in the logs either like the ESP gateway doesn't even try to connect. I don't know how to troubleshoot this from here.
    I also have both 5/2.4Ghz on my router.
    When ESP connects is seems to prefer 2,4 GHz / n / WPA2 if that helps.
  • This is what I have. 2,4 GHz / n / WPA2 (no TKIP but AES instead so I can go beyond 54Mbit) and it doesn't connect. Just dots coming up.
    @Pseudomizer Esp8266 is 2.4ghz only.
    You could try adding the following line just after hw_init() in the sketch:
    Serial.setDebugOutput(true);
    It will dump a lot of ESP WiFi related data, please post the output here. Maybe some will give a hint of what goes wrong.
  • Thanks a lot for this. This helped me troubleshoot the problem and I am surprised why it didn't connect. It couldn't find my SSID name because in the router it is all UPPER case but when I write it on any other machine Windows, Linux, etc to connect to, I always write it lower case with the exception of the first character.
    In this case I modified the sketch to have the SSID name all in UPPER case and voila it connected.
    Thanks again for the help here. Much appreciated.
  • I was very happy when it connected but now it is resetting itself constantly with this error message:
    wdt reset
    tail 0
    chksum 0x42
    csum 0x42
    ~ld
    Any ideas why?
  • I missed one line of error code above:
  • I tried my Home Wifi and my Cell Hotspot. The crashes occur on both wifi networks. 😞
  • @Pseudomizer , Is the esp8266 on a breadboard or is it part of a commercial product like HUZZAH or nodemcu ? I ask because the esp devices can reset themselves from a brownout condition during the WiFi transmit if the power supply circuit is not up to handling the momentary 'high current draw' requirements of the radio. From reading www.esp8266.com, breadboard circuits have caused many hours of troubleshooting enjoyment with the esp8266 parts.
    I replace the battery packs on these with 2 Amp cell phone charger power supplies. I have 8 under power 24/7 for months with no problems. They are available from multiple vendors.
    http://www.aliexpress.com/item/Free-shipping-ESP8266-ESP-12-serial-WIFI-Industrial-stable-version-A-full-test-board-Full-IO/32260095422.html?spm=2114.01020208.3.49.0YGvDs&ws_ab_test=201556_7,201527_4_3_2_1_4_71_72_73_74_75,0_0
  • I followed the instructions exactly as shown here and I purchased that exact equipment.
    I even powered the NRF24L01+ from a different power source just to make sure that power fluctuation is not the issue but it didn't make any difference.
    I even tried transfer rates 115k, 57k and 9600 Baud but none of that made any difference either.
    I also downloaded the flash eeprom ino program to clear all the data but again, no difference.
  • I even reflashed the ESP8266 with those instructions and then loaded the mysensors ino but still the same outcome. 😞
    http://benlo.com/esp8266/esp8266QuickStart.html
    @Pseudomizer did you make any changes to the gateway sketch out the MySensors library/config?
    Could you post the output of the gateway just before the crash occurs (it might give an indication of where this crash occurs)
  • The only changes to the sketch are the SSID, the pass and the debug line
    as instructed. No other changes were made.
    Here the the debug output....you will see multiple resets in a row based on the internal watchdog timer.
    Connecting to MYWIFI
    scandone
    f 0, scandone
    .add 0
    aid 1
    pm open phy_2,type:2 0 0
    cnt
    connected with MYWIFI, channel 6
    dhcp client start...
    ......ip:192.168.1.222,mask:255.255.255.0,gw:192.168.1.1
    .Connected!
    IP: 192.168.1.222
    wdt reset
    tail 0
    chksum 0x42
    csum 0x42
    ~ld
    scandone
    f 0, scandone
    .add 0
    aid 1
    cnt
    .......ip:192.168.1.222,mask:255.255.255.0,gw:192.168.1.1
    .Connected!
    IP: 192.168.1.222
    wdt reset
    tail 0
    chksum 0x42
    csum 0x42
    ~ld
    scandone
    f 0, scandone
    .add 0
    aid 1
    cnt
    .Connected!
    IP: 192.168.1.222
    Triple-check your radio wiring.
    Or try with a different radio. The crash seems to happen in the radio init part.
  • I just replaced the NRF with a new NRF and then again as I have 4 total. With every single one the same error.
    The wiring matches exactly the picture from mysensors.
    This is driving me crazy...
  • Hi, I tried the bridge with a rfm69hw module. It starts all well but does not receive any information. Neither shows startup information module .
    Where to put the DIO0 . I tried on several pins ( changing IRQ number) but no thoughts about doing anything.
    @miguelingles I didn't test with a rfm69hw module and I'm not aware of anybody else testing with this setup.
    Probably you have to test step by step what work and what not.
    Start with the radio initialization to see if the communication is ok, and go on from there.
    @Pseudomizer past few days @hek and I have been working on better diagnosis for the ESP8266 regarding radio communication failures.
    Please try if the version of MySensors development helps in diagnosing your problems.
    Make sure to uncomment the line
    //#define MY_DEBUG_VERBOSE
    in MyConfig.h and make the same changes to ssid & password as you did before.
    This version will dump diagnostics of NRF communications and a full register dump when starting up.
    Good luck!
  • Thanks a lot. This version provides much more details but at this stage of my learning progress I am not able to understand all those registers where I have to rely on your help guys. I assume that my password is not being exposed here.
    Connecting to ZEUS
    scandone
    f 0, scandone
    .add 0
    aid 1
    cnt
    connected with ZEUS, channel 6
    .Connected!
    IP: 192.168.1.222
    write_register(0x04,0x5F)
    write_register(0x06,0x23)
    write_register(0x06,0x03)
    write_register(0x00,0x0E)
    write_register(0x07,0x70)
    write_register(0x05,0x4C)
    STATUS 0x0E RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
    RX_ADDR_P0-1 0x0E0E0E0E0E 0707070707
    RX_ADDR_P2-5 0xFF C4 C5 C6
    TX_ADDR 0x0E0E0E0E0E
    RX_PW_P0-6 0x00 00 20 00 00 00
    EN_AA 0x3B
    EN_RXADDR 0x07
    RF_CH 0x4C
    RF_SETUP 0x03
    CONFIG 0x0E
    DYNPD/FEATURE 0x3F 06
    Data Rate 1MBPS
    Model nRF24L01+
    CRC Length 16 bits
    PA Power PA_LOW
    write_register(0x01,0x3F)
    write_register(0x01,0x3B)
    write_register(0x1D,0x06)
    FEATURE=0x06
    write_register(0x1C,0x3F)
    ets Jan 8 2013,rst cause:4, boot mode:(3,7)
    wdt reset
    tail 0
    chksum 0x42
    csum 0x42
    ~ld
    Connecting to ZEUS
    scandone
    f 0, scandone
    .add 0
    aid 1
    cnt
    .Connected!
    IP: 192.168.1.222
    EN_AA 0x3B
    EN_RXADDR 0x07
    RF_CH 0x4C
    RF_SETUP 0x03
    CONFIG 0x0E
    Data Rate 1MBPS
    Model nRF24L01+
    CRC Length 16 bits
    PA Power PA_LOW
    FEATURE=0x06
    wdt reset
    tail 0
    chksum 0x42
    csum 0x42
    ~ld
    @Pseudomizer just had a quick look at your results. Radio config (and this communication) seem to be OK, but it restarts due to watchdog timeout.
    Hopefully tonight I can have a better look.
  • when I put the development package I can not compile anything (all gives me error). I tried it with a clean install and nothing.
    I think the problem is the IRQ pin DIØØ , if the ESP cpu does not recognize this interruption when the RF module receives data is unable to apply for the request .
    The irq pin from the nrf24 stays unconnected, like the build instructions clearly state!
  • but RF69 need irq.
    @miguelingles didn't know you were talking about rf69... Sorry but I cannot keep track of what everyone is using.
    For everyone wondering what serial output during startup of the ESP8266-NRF24 gateway should look like (all captures taken using link development branch from Oct 6, 2015 (hek just merged gateway-refactoring this morning, so output might have slightly changed)) .
    WiFi startup comes first after reset, followed by MySensors (nRF24) startup:
    • WiFi startup (not using Serial.setDebugOutput(true) )
    Connecting to YOUR_SSID
    IP: 192.168.1.101
    • WiFi startup (using Serial.setDebugOutput(true) )
    scandone
    f 0, ....scandone
    .add 0
    aid 10
    cnt
    connected with YOUR_SSID, channel 1
    .....ip:192.168.1.101,mask:255.255.255.0,gw:192.168.1.1
    .Connected!
    IP: 192.168.1.101
    • MySensors startup (not using DEBUG and MY_DEBUG_VERBOSE)
    • MySensors startup (using DEBUG and MY_DEBUG_VERBOSE)
    write_register(0x06,0x27)
    write_register(0x06,0x07)
    write_register(0x00,0x0C)
    RX_ADDR_P2-5	0xC3 C4 C5 C6
    EN_AA		0x3F
    EN_RXADDR	0x03
    RF_CH		0x4C
    RF_SETUP	0x07
    CONFIG		0x0E
    DYNPD/FEATURE	0x00 00
    Data Rate	1MBPS
    Model		nRF24L01+
    CRC Length	16 bits
    PA Power	PA_MAX
    FEATURE=0x06
    write_register(0x1C,0x03)
    FEATURE=0x06
    write_register(0x13,0x20)
    write_register(0x02,0x07)
    write_register(0x11,0x20)
    write_register(0x12,0x20)
    write_register(0x00,0x0F)
    write_register(0x02,0x06)
    @Pseudomizer Had a better look at your crashdump.
    Your ESP seems to crash with a watchdog timeout when MySensors is setting the datarate (or shortly after that) after nRF24 has been initialized.
    Default datarate is RF24_250KBPS.
    Some questions, trying to rule things out:
    • Do you use this default datarate?
    • Could it be that you have an nRF24L01+ clone, which in reality is a nRF24L01 (clone)?
    • Did you ever try and succeed to connect these radios to a regular Arduino?
    • Are all radio's from the same batch/order?
  • I tried multiple different data rates when I created the ethernet gateway from mysensors. It didn't work at all in terms of connecting the sensors to the gateway while the gateway was visible in Vera until I made them all the same data rate. If I recall correctly I got them working with both at 250kpbs or 1Mbps.
    Since I tried to build the wifi gateway I haven't checked the data rates. I am going to check this next.
    In regards to your other questions:
    I purchased 4 radios from Amazon:
    http://www.amazon.com/nRF24L01-Wireless-Transceiver-Arduino-Compatible/dp/B00E594ZX0/ref=cm_cr_pr_product_top?ie=UTF8
    Yes, those radios work totally fine with the ethernet gateway from mysensors and I had two sensors attached. My goal is to have a wireless gateway so I can place it anywhere in the house and your great work would enable me to do so. 😉
  • Thinking about the data rate... at the moment I don't have any other sensors powered on at all which means I am just installing the wifi gateway. There should be no mismatch in the data rates unless I would have at least one sensor with a different data rate causing the issue. The Wifi gateway should boot up successfully without any client sensor.
    Is my thinking correct?
  • @Yveaux said:
    y but I
    it,s works !!!!! you have to do is remove the DIO0 while Bots and put it quickly . If not removed DIO0 not start.
  • I have done EXTENSIVE testing and I got it working now but I don't understand why.
    It seems like my MyConfig.h is broken which is the one which I copied over from your development package. I used one of my MyConfig.h files and the module boot was successfull and it did not crash anymore. It is stable and fully integrated into Vera with sensors now.
    I also tested the different data rates. I tested 250KBPS and 1MBPS and both work fine as long as I configure the gateway and the sensor clients with the same data rate. If I use different data rates between client and gateway, the gateway does NOT crash but the sensor clients simply don't connect.
    Now I have a working MyConfig.h and a broken MyConfig.h. Here is the WORKING MyConfig.h file.
    #ifndef MyConfig_h
    #define MyConfig_h
    #include <stdint.h>
    //#define DEBUG
    // Disable this line, If you are using TX(1), RX(0) as normal I/O pin
    #define ENABLED_SERIAL
    #define BAUD_RATE 115200
    #define MY_OTA_FLASH_SS 8
    // Flash jdecid
    *  Information LEDs blinking
    // disabled in the gateway.
    // #define WITH_LEDS_BLINKING
    // off when blinking
    // The RX LED default pin
    #define DEFAULT_RX_LED_PIN 6
    // The TX LED default pin
    #define DEFAULT_TX_LED_PIN 5
    // The Error LED default pin
    #define DEFAULT_ERR_LED_PIN 4
    *  Message Signing Settings
    //#define MY_SIGNING_FEATURE
    #define MY_ATSHA204_PIN 17 // A3 - pin where ATSHA204 is attached
    *  NRF24L01 Driver Defaults
    #define RF24_CE_PIN		   9
    #define RF24_CS_PIN		   10
    #define RF24_CHANNEL	   76
    //#define RF24_DATARATE 	   RF24_1MBPS
    //#define SOFTSPI
    #ifdef SOFTSPI
    *  RFM69 Driver Defaults
    And here is the NON WORKING MyConfig.h file.
    #ifndef MyConfig_h
    #define MyConfig_h
    #include <stdint.h>
    #define DEBUG
    // Enable MY_DEBUG_VERBOSE flag for verbose debug prints. Requires DEBUG to be enabled.
    // Flash jdecid
    //#define SOFTSPI
    #ifdef SOFTSPI
    I don't understand why the second one makes the module reboot constantly. However, I am happy now that it is working but I wanted to share my experience and maybe it can help others to troubleshoot this and understand why this was happening as I am sure I will not be the only one having that issue in the future.
    I do appreciate all the help so far and I wouldn't have been able to solve it without your help Yveaux. THANK YOU!!!
    You cannot mix MyConfig.h between branches.
    In the development brach all MySensors related defines has the prefix "MY_".
  • Hi, if it possible to show a sketch with an ESP8266 WIFI => MQTT gateway? I figure out, that the received sensor data will automatic publish to my MQTT Server running on my Raspi. Then i can install this pice of wonderfull work in every room from my house 🙂
    I created a simple ESP-MQTT sketch a while ago. I've only done some simple tests using it. Feedback appreciated.
  • @hek Very nice! the code are magic 🙂 Very nice solution, i'll test this next days.
    #include <ESP8266WiFi.h>
    Testing the above sket from the development branch with a new sensbender micro I get:
    mygateway/255/255/3/0/3 (null) on MQTT
    This is an id request. I answer this request with
    mosquitto_pub -h ds -t "mygateway/255/255/3/0/4" -m 8
    which should set the ID 8 on the sensbender micro in my undestanding. I can see the message in the serial terminal on the ESP-8266 but the message doesn't arrive at the sensbender micro.
    Is my message to set the id correct?
    Yes, the response message looks ok. But I must confess that I haven't verified the MQTT gateway much yet. Probably something I've missed (=bug).
    Do you have the possibility to to see where the message ends up or being thrown away (debug-print-debugging is awesome, yes I know...) in the MQTT gateway?
    Or wait a few days until I've had time to look at it.
    There seems to be a bug in incomingMQTT:
    replace
    with
    for (str = strtok_r(topic, "/", &p); str && i <= 5;
    or it will never send a message.
    There seems to be another problem:
    0;0;3;0;9;send: 0-0-0-255 s=255,c=3,t=4,pt=0,l=1,sg=0,st=fail:8
    Why is the payload in st=fail?
    The messages sent to MQTT seem to make a merry go round and come back.... 🙂
    The payload (8) seems correct. Gateway just never received any ack from node... which is fine for broadcast messages (to node 255) such as this.
    Ok, like you suspected earlier? So we need to subscribe to something else than we publish to then...
    @hek
    Loaded the ethernet ESP-8266 gateway and entered with telnet:
    255;255;3;0;4;8
    It is working as it should. Now I have assigned the id 8.
    Tried to solve the merry go round but it didn't help. Now I let the stage to the pros.. 🙂
  • Do you think we can use this board with MySensors (with NRF24 or RFM69) ?
    https://github.com/hallard/NodeMCU-Gateway
    If I want to use the GatewayESP8266MQTTClient sketch located in the development branch do I also need to use the mysensors libraries in that branch?
    Thank you,
    Mike
  • @hek Thanks for the code. I have few questions in my mind. Firstly do I just have to upload this ESP8266MQTTClient.ino sketch on esp8266 12-E model? or does it needs anything to add in the sketch except SSID and password? I want to use ESP-8266-E and NRF24L01+ as gateway for openhab. If it is possible then, do I have to adopt the same procedure for configuring openhab as ethernet gateway? Secondly, Can I make two gateways using this sketch, is this possible? As I want to add sensors which are 500 meters away at my farmhouse.
