My Slim 2AA Battery Node
@Cliff-Karlsson I'm experimenting with several versions of Optiboot (various upload and upload combinations) for my board. Once that is done, I will add it to the documentation of my board. I'm extending the sketch found here:
@Cliff-Karlsson Let's continue your bootloader trouble discussion in it's own thread:
http://forum.mysensors.org/topic/2975/how-do-i-burn-a-bootloader-to-an-328p-with-uno-bootloader-preinstalled/8
OK, so finally I have received most of the parts I need to build a few of these sensors. I want to go with a temp sensor at first, the si7021. So I wanted to check what "other bits" I need (newb alert).
From there, do I need both 1 and 2? If so, what are these?
From here, what are 3 and 4? Do I need both?
Also, depending on the answers above, do I solder to exactly the same pins? Have I missed anything?
Ok, finaly succeded in burning the bootloader. Now comes next part. Fuses and lockbits, I have no idea what this means but is this what I need to do?
oh, yes! And you have to be carefully with them, because to set the fuses wrong, can destroy your ยตcontroller
if you look to message Nr 179 you will find my bootloader and the correct fuses for this. But its a 1MHz Bootloader and the fuses too.
Web-based fuse calculator
http://www.engbedded.com/fusecalcAt the bottom I inserted your fuses.
Translation:
Sorry for asking the same questions over and over but I have just used the files linked at the top of this thread.
############################################################## # Add the new board to boards.txt (normally located at "C:\Program Files\Arduino\hardware\arduino\avr" # The *.bootloader.* etries only matters if you want to program bootloader (and fuses) from Arduino IDE. # See http://www.engbedded.com/fusecalc (select Atmega328p) for interpretation of fuse values and how # extended fuses are written in different applications (07h in Arduino IDE = FFh in Atmel studio). ############################################################## apm96.name=APM Optiboot internal 1MHz noBOD 9600baud apm96.upload.tool=avrdude apm96.upload.protocol=arduino apm96.upload.maximum_size=32256 apm96.upload.speed=9600 apm96.bootloader.tool=avrdude apm96.bootloader.low_fuses=0x62 apm96.bootloader.high_fuses=0xde apm96.bootloader.extended_fuses=0x07 apm96.bootloader.path=optiboot_v50 apm96.bootloader.file=atmega328_1a.hex apm96.bootloader.unlock_bits=0x3F apm96.bootloader.lock_bits=0x2F apm96.build.mcu=atmega328p apm96.build.f_cpu=1000000L apm96.build.core=arduino apm96.build.variant=standard
@m26872 I am fairly sure that all methods work in normal cases but nothing worked for me fore some reason .
@Cliff-Karlsson
Hi all, I'm seeing replies, but I'm not sure if any are aimed at my question? I think not?
@rsachoc
it would be nice when a atsha204 a an a flash rom where placed to pcb for signing and ota
@m26872: slowly getting there: http://forum.mysensors.org/topic/3043/new-nrf24l01-smd/14
What i like on this node is the great idea with the casing. To use a cable duct is a great idea. We have wooden windows and i found in a diy market cable ducts in wooden look
like this:
oh, yes. You have right, the battery fits in it, but its a little bit too big so i cant close the cover. Damn i didnt try it before.
Soldered an 8 mHz resonator (a 'crystal' which does not need the capacitors) for a more stable clock.Soldered a 3.3v LDO (662k) under the radio to have it powered with a rechargeable Lipo (4.1V max) battery. And added a voltage divider to measure the actual battery voltage.
With a SMD version of the radio. Needs some creative soldering...Compared to an other favourite ( @GertSanders )
A couple of more questions. In one of the pictures at the top the electrulyte 4,.7 uf capacitator is placed closer to the atmel chip and the 0.1 uf (c5) is placed closest to the edge does it matter witch capacitator goes where?
@AWI said:
panelized design
@AWI Sorry, can't help you with that. All Eagle here
@Yveaux i remember once that i read that dirtypcbs does not allow for different designs in their panelized boards. Am i correct ?
@ahmedadelhosni apparently not
@Yveaux aha. I thought that this means multiple (same) design not different. Thanks
Just ordered my first set of boards; v2.0 in Red; can't wait to try these out!
Thanks @m26872
Hi
1 x PDB board
1 x ATMega328p 28pin PDIP
1 x NRF24L01+ radio module
2 x AA batteries
Battery connector
1 x senor of choice
I notice there seem to be an assortment of capacitors/regulators in most of the photos on this thread, but no definitive list of which are needed. (I am very new to all this so please excuse my ignorance)Extras needed
1 x FTDI USB to TTL Serial AdapterHave I missed anything of my list? Also I would be really grateful for links to some of the above components.
@Matt-Pitts You can find a BOM for the board here:
https://www.openhardware.io/view/10/My-Slim-2AA-Battery-Node
@Soloam
and a flash module for OTA Sketch Uploads
Thanks @GertSanders for showing me the BOM I hadn't realised it was there, but do I need everything listed there to get it working properly?
@Matt-Pitts
I'm assuming that if a designer goes through the trouble of listing items on a bom, they are needed.But you are right, that is not always the case. I'm not at my Mac (using a miniscreen now), so i can not multitask.
I have problems to upload the scatch to the bare Amtel. I use an USB-TTL FTL Adaper and connect, RX/TX and Reset Pin with 100n->DTR. But I got always errors on uploading.The bootloader I have successfull burned with an raspberry pi and gpio (http://www.lxccu.com/hb-raspberry-bootloader-update
avrdude: safemode: Fuses OKHow can I got it working?
Thank youThomas
Have you tried to upload a standard arduino bootloader?, are you using correct baud settings for uploading?
@bjacobse No, used the bootloader from here (http://forum.mysensors.org/uploads/files/1443392692398-atmega328_1a.hex). This is an bootloader for the internal clock.
@m26872 Sure, but not with an bootloader (optiboot with intenal clock) on an bare Atmega. Later I will try this: http://forum.mysensors.org/uploads/files/1454449901412-7.png
I build some MySensors with an Arduino Micro, but not with only an Atmega.Update: I don't know what's different, but this works. Perhaps I forget to connect Reset from FDL -> Pin 1.
I have not had success to upload a sketch via FTDI on an Arduino ProMini using Optiboot. When I flash an ordinary bootloader (Taken from the Arduino IDE), I can easily upload a sketch via FTDI.
@bjacobse Witch bootloader you have taken?
Hi I'm just about to start ording parts of the slim node. Looking through the thread I'm thinking based on my limited knowledge of arduino, I might be better off buying chips which already have a bootloader installed?
@Matt-Pitts - Not that hard if you read about it. Here are some good links:
@Tom71
@bjacobse I thought the USBtiny is only to upload the bootloader, not the mysensors software.
I did two things:- Burn the bootloader atmega328_1a.hex to an bare Atmega328p with an Arduino as ISP
- Upload an simple scetch to the Atmega with an RX/TX uploader (I used an USB to TTL with an FTDI and also an Ardunino Uno without the Atmega chip, like here http://forum.mysensors.org/uploads/files/1454449901412-7.png) Both are working.
@Tom71
@Matt-Pitts
@bjacobse I'm out of fucus. What was the problem? Can you burn the bootloader+sketch with an USBtiny on an bare Atmgea328p? Connected on MISO/MOSI/SCK/RESET/VCC/GND?
@Tom71
@bjacobse Which Optiboot loader did you exactly use? I can try it. I have an Arduino Pro Mini.
I have ordered these. Hopefully they can get here soon-ish. All my prototyping is done and the WAF is dropping steadily with all the wires and components lying around.
@m26872 Sounds good! Current status is "at board house." Getting twitchy waiting.
Hello, I ordered it too yesterday Can't wait to step forward from my breadboards with a lot wires to PCB without wires
@drock1985 Right. I waited until a week after Chinese new year to order. Let the hangovers end and the trainstations empty . I am looking forward to finalizing my sensor network with cases as well. I have several old plastic/wood boxes lying around waiting for a less rats-nest setup.
now I finally set up my first sensor board, and, as expected, I donยดt receive any data from it on my gateway :suspect:
The sketch should run, but it doesnยดt. Any ideas how to troubleshoot now?
The same sketch works on my UNO and I have no radio problem.Do I have to upload the sketch without the 16MHz Crystal to get it work proper?
- Since external crystal isn't this designs standard, I think you should describe your hardware a bit more.
- Uno fuses and bootloader?
- "radio init fail" means nRF wiring issue in 99% of all cases.
I just installed the NRF module at itยดs desired place as well as the two capacitors and the resistors as described above. The crystal is only used for uploading the sketch to the Atmega328 chip, described here: https://www.arduino.cc/en/Tutorial/ArduinoToBreadboard
edit: Iยดve re-read your first post and also this thread http://forum.mysensors.org/topic/3018/tutorial-how-to-burn-1mhz-8mhz-bootloader-using-arduino-ide-1-6-5-r5/2 ...
Do I have to burn the bootloader using 1MHz or 8 MHz? I donยดt get why this makes a difference, only that the batteries would drain faster the higher the MHz rate is.
Did anybody tested this board with an ATSHA204A on A2? The ATSHA204A works with 2.0 to 5.5 V.
@Tom71
ok guys, I finally set up my first sensor and itยดs communicating well. Iยดve attached two reed switch which work fine, only my temp snesor DHT11 doesnยดt work. Are there any known issues with this sensor?
// Simple binary switch example // Connect button or door/window reed switch between // digitial I/O pin 3 (BUTTON1_PIN below) and GND. #include <MySensor.h> #include <SPI.h> // Define Node ID #define MY_NODE_ID 1 //Kontaktschalter #include <Bounce2.h> #define CHILD1_ID 1 // Kontaktschalter 1 #define CHILD2_ID 2 // Kontaktschalter 1 #define BUTTON1_PIN 5 // Kontaktschalter 1 #define BUTTON2_PIN 6 // Kontaktschalter 2 //Tempsensor #include <DHT.h> #define CHILD_ID_HUM 3 #define CHILD_ID_TEMP 4 #define HUMIDITY_SENSOR_DIGITAL_PIN 4 unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds) MySensor gw; //Kontaktschalter Bounce debouncer1 = Bounce(); Bounce debouncer2 = Bounce(); int oldValueReed1=-1; int oldValueReed2=-1; //tempsensor DHT dht; float lastTemp; float lastHum; boolean metric = true; //Messages // Kontaktschalter MyMessage msgReed1(CHILD1_ID,V_TRIPPED); // Kontaktschalter 1 MyMessage msgReed2(CHILD2_ID,V_TRIPPED); // Kontaktschalter 2 //TempMessage MyMessage msgHum(CHILD_ID_HUM, V_HUM); MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP); void setup() { gw.begin(NULL, MY_NODE_ID, true); //Tempsensor dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN); // Setup Kontaktschalter 1 pinMode(BUTTON1_PIN,INPUT); // Activate internal pull-up digitalWrite(BUTTON1_PIN,HIGH); // Setup Kontaktschalter 2 pinMode(BUTTON2_PIN,INPUT); // Activate internal pull-up digitalWrite(BUTTON2_PIN,HIGH); // After setting up the button, setup debouncer debouncer1.attach(BUTTON1_PIN); debouncer2.attach(BUTTON2_PIN); debouncer1.interval(5); debouncer2.interval(5); // Register binary input sensor to gw (they will be created as child devices) // You can use S_DOOR, S_MOTION or S_LIGHT here depending on your usage. // If S_LIGHT is used, remember to update variable type you send in. See "msg" above. gw.present(CHILD1_ID, S_DOOR); gw.present(CHILD2_ID, S_DOOR); //Tempsensor gw.present(CHILD_ID_HUM, S_HUM); gw.present(CHILD_ID_TEMP, S_TEMP); metric = gw.getConfig().isMetric; } // Check if digital input has changed and send in new value void loop() { //Kontakstschalter 1 debouncer1.update(); // Get the update value int valueReed1 = debouncer1.read(); if (valueReed1 != oldValueReed1) { // Send in the new value gw.send(msgReed1.set(valueReed1==HIGH ? 1 : 0)); Serial.println("Button 1 geschaltet"); oldValueReed1 = valueReed1; } //Kontakstschalter 2 debouncer2.update(); // Get the update value int valueReed2 = debouncer2.read(); if (valueReed2 != oldValueReed2) { // Send in the new value gw.send(msgReed2.set(valueReed2==HIGH ? 1 : 0)); Serial.println("Button 2 geschaltet"); oldValueReed2 = valueReed2; } //Tempsensor delay(dht.getMinimumSamplingPeriod()); float temperature = dht.getTemperature(); if (isnan(temperature)) { Serial.println("Failed reading temperature from DHT"); } else if (temperature != lastTemp) { lastTemp = temperature; if (!metric) { temperature = dht.toFahrenheit(temperature); } gw.send(msgTemp.set(temperature, 1)); Serial.print("T: "); Serial.println(temperature); } float humidity = dht.getHumidity(); if (isnan(humidity)) { Serial.println("Failed reading humidity from DHT"); } else if (humidity != lastHum) { lastHum = humidity; gw.send(msgHum.set(humidity, 1)); Serial.print("H: "); Serial.println(humidity); } //gw.sleep(SLEEP_TIME); //sleep a bit }
@siod my understanding was that the voltage which is provided by the slim node wouldn't be suitable for the DHT11 and DHT22, as they require a minimum of 3.3v. There is some discussion here on the DHT22, which I understand has the same voltage requirements as the DHT11.
Oh man, one problem solved, next just comes up...
edit2: I measured 0,02 Ampere consumption, isnยดt that too much?
OK thx for the hint, I guess I will just add a third AA battery, that should solve my problem...
@siod
Greets Eddie
I really don't want to spam this thread...
Edit : ah ok, the arduino is going to regulate down to 3.3v... Then I cant use 3AAs
@siod I was in much the same position as you, but the simple suggestion is to use the SI7021, as per this thread. Otherwise, the links in the other thread are for the 5v builds.
I wasn't aware that the nrf24l01 is so sensitive to voltage higher than 1.9v. I would like to have a sensor design to which I can add different sensors, just for the purpose I need it right now. So most sensors need 3.3v or 5v and I have to decide if I use 3v cells, which are more expensive or use step up / step down regulators which will drain my batteries. I just want to keep the flexibility to add any sort of sensor to my board... What would you suppose to do, also I think I am not the only one who faces those problems. Of course I am a beginner and still have a lot to learn but I also just want to finish this project as I am working on it for a very long time now...
when you are gonna to use some power up/down converter, them will need more power, so your battery will be faster empty.
OK guys, thanks for the explanation. In this case I need to buy new temp sensors...
I just think the next time I encounter problems is, when I try to setup a new sensor node with attached pir motion sensor... I will read the data sheet of it first and look out for power consumption
Is there any motion sensor that work on 3.3 V ? I tried powering the below one with 3.3 but it was acting crazy and keeps reporting motions.
@m26872 yeah I know you have a topic but actually was concerned with door and window sensors that time and forgot to check it again when I needed it
I can't program my slim node through ISP, is there a reason it isn't working.
But it can't find the node.someone have a clue how to solve this.
it doesn't recognise the avr.
This is the error i get:
this check.avrdude done. Thank you.
When i use a ziff programming board, the avr is programmeble. so usbasp is working.
Finally got my v2 (red) boards in. Ended up with 30 of them. Will start wiring them up this week!
Below is my first sketch with this awsome 2aa battery powerd board.
i didn't measure the current. but i tryed to be as efficient with the power as possible.my avr is running on 8Mhz, this is becaus the DTH22 doesn't run on 1Mhz.
#include <SPI.h> #include <MySensor.h> #include <DHT.h> #include <Vcc.h> #define CHILD_ID_TEMP 1 // Child id for temperatur #define CHILD_ID_HUM 2 // Child id for humidity #define CHILD_ID_VOLT 3 // Child id for battery reading #define HUMIDITY_SENSOR_DIGITAL_PIN 3 // Where is my DHT22 data pin connected to int node_id=6; // What is my node id unsigned long SLEEP_TIME =30000UL; // Sleep time between reads (in milliseconds) int sleepcycle=1; // Counter to count the amout of time not sending data int humoffset=2; // only data is send if humidity is changed for this amout int tempoffset=0.5; // only data is if temperature is changed for this amout int gwsendtimout=20; // each 20*sleep_time (10 minutes) data will be send const float VccMin = 1.5; // Minimum expected Vcc level, in Volts. const float VccMax = 3.0; // Maximum expected Vcc level, in Volts. const float VccCorrection = 1.0/1.0; // Measured Vcc by multimeter divided by reported Vcc Vcc vcc(VccCorrection); MySensor gw; DHT dht; //Store last values float lastTemp = 0 ; float lastHum = 0 ; float batteryV=0; int oldBatteryPcnt = 0; boolean lastTripped = false ; boolean metric = true; boolean gwsend = true; // to determin if data has to be send MyMessage msgHum(CHILD_ID_HUM, V_HUM); MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP); MyMessage msgVolt(CHILD_ID_VOLT, V_VOLTAGE); void setup() { gw.begin(NULL,node_id,false); dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN); // Send the Sketch Version Information to the Gateway gw.sendSketchInfo("Humidity", "1.1",true); // Register all sensors to gw (they will be created as child devices) gw.present(CHILD_ID_HUM, S_HUM,"Humidity douche"); gw.present(CHILD_ID_TEMP, S_TEMP,"Temperatuur douche"); gw.present(CHILD_ID_VOLT, S_MULTIMETER,"Battery voltage"); metric = gw.getConfig().isMetric; } void loop() { // get the battery Voltage batteryV = vcc.Read_Volts(); int batteryPcnt = vcc.Read_Perc(VccMin, VccMax); if (oldBatteryPcnt != batteryPcnt) { // Power up radio after sleep gwsend=true; oldBatteryPcnt = batteryPcnt; } delay(dht.getMinimumSamplingPeriod()); float temp1 = dht.getTemperature(); float humidity = dht.getHumidity(); if (isnan(temp1)) { // Serial.println("Failed reading temperature from DHT"); } else if ((temp1 <= lastTemp-tempoffset)||(temp1 >= lastTemp+tempoffset)) { lastTemp = temp1; if (!metric) { temp1 = dht.toFahrenheit(temp1); } gwsend=true; } if (isnan(humidity)) { // Serial.println("Failed reading humidity from DHT"); } else if ((humidity <= lastHum-humoffset)||(humidity >= lastHum+humoffset)) { lastHum = humidity; gwsend=true; } if (sleepcycle>gwsendtimout){ gwsend=true; } if (gwsend){ gw.sendBatteryLevel(oldBatteryPcnt); gw.send(msgVolt.set(batteryV, 1)); gw.send(msgTemp.set(lastTemp, 1)); gw.send(msgHum.set(lastHum, 1)); gwsend=false; sleepcycle=1; } sleepcycle++; gw.sleep(SLEEP_TIME); }
Finally had time to solder it. Not my best job, I admit. One of the caps I tried to mount was not flush enough so I had to clip it off. Hopefully not a critical component! I made the radio removable using some header strips. Now to figure out what temp sensor to use. I have currently used just a thermister. Can DHT22 work down at ~1.9V?
@wergeld congratulations
For the temp sensor I suggest a si7021 board. Almost the same price as as dht22 but more accurate, reliable and versatile. It uses the I2C bus (pin A4, A5)@AWI I saw the si7021 on another forum. Ordered a couple of the low voltage ones as I want to make my nodes with as few components as possible. I could still use my thermistor while I wait. This is a fun build!
Thank you all
