My Slim 2AA Battery Node
  • @Soloam
    and a flash module for OTA Sketch Uploads πŸ™‚
    @Matt-Pitts
    avrdude: safemode: Fuses OK
    How can I got it working?
    Thank you
    Thomas
  • @Tom71
    I did two things:
  • @Tom71
  • @Matt-Pitts
  • @Tom71
  • @wergeld
  • Hello, I ordered it too yesterday πŸ™‚ Can't wait to step forward from my breadboards with a lot wires to PCB without wires πŸ˜„
  • now I finally set up my first sensor board, and, as expected, I donΒ΄t receive any data from it on my gateway :suspect:
    The sketch should run, but it doesnΒ΄t. Any ideas how to troubleshoot now?
    @siod
    • Uno fuses and bootloader?
  • I just installed the NRF module at itΒ΄s desired place as well as the two capacitors and the resistors as described above. The crystal is only used for uploading the sketch to the Atmega328 chip, described here: https://www.arduino.cc/en/Tutorial/ArduinoToBreadboard
    edit: IΒ΄ve re-read your first post and also this thread http://forum.mysensors.org/topic/3018/tutorial-how-to-burn-1mhz-8mhz-bootloader-using-arduino-ide-1-6-5-r5/2 ...
    Do I have to burn the bootloader using 1MHz or 8 MHz? I donΒ΄t get why this makes a difference, only that the batteries would drain faster the higher the MHz rate is.
  • @Tom71
  • ok guys, I finally set up my first sensor and itΒ΄s communicating well. IΒ΄ve attached two reed switch which work fine, only my temp snesor DHT11 doesnΒ΄t work. Are there any known issues with this sensor?
    // Define Node ID
    #define MY_NODE_ID 1
    //Kontaktschalter
    //Tempsensor
    #define CHILD_ID_HUM 3
    #define CHILD_ID_TEMP 4
    //Kontaktschalter
    Bounce debouncer1 = Bounce();
    Bounce debouncer2 = Bounce();
    int oldValueReed1=-1;
    int oldValueReed2=-1;
    //tempsensor
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    //Messages
    // Kontaktschalter
    //TempMessage
      //Tempsensor
    // Setup Kontaktschalter 1
      pinMode(BUTTON1_PIN,INPUT);
        // Activate internal pull-up
    // Setup Kontaktschalter 2
      pinMode(BUTTON2_PIN,INPUT);
      debouncer1.interval(5);
      debouncer2.interval(5);
      //Tempsensor
      //Kontakstschalter 1
      debouncer1.update();
      // Get the update value
         // Send in the new value
         oldValueReed1 = valueReed1;
      //Kontakstschalter 2
      debouncer2.update();
         oldValueReed2 = valueReed2;
     //Tempsensor
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
    edit2: I measured 0,02 Ampere consumption, isnΒ΄t that too much?
  • @siod
    Greets Eddie
    I just think the next time I encounter problems is, when I try to setup a new sensor node with attached pir motion sensor... I will read the data sheet of it first and look out for power consumption πŸ™‚
  • @m26872 yeah I know you have a topic but actually was concerned with door and window sensors that time and forgot to check it again when I needed it πŸ™‚
    But it can't find the node.
    it doesn't recognise the avr.
    This is the error i get:
    this check.
    avrdude done. Thank you.
    #include <Vcc.h>
    Vcc vcc(VccCorrection);
    DHT dht;
    //Store last values
    float lastTemp = 0 ;
    float lastHum = 0 ;
    float batteryV=0;
    int oldBatteryPcnt = 0;
    boolean lastTripped = false ;
      gw.begin(NULL,node_id,false);
      // get the battery Voltage
       batteryV  = vcc.Read_Volts();
         // Power up radio after sleep
         gwsend=true;
         oldBatteryPcnt = batteryPcnt;
      if (isnan(temp1)) {
        lastTemp = temp1;
        if (!metric) {
        gwsend=true;
          lastHum = humidity;
          gwsend=true;
      if (sleepcycle>gwsendtimout){
        gwsend=true;
    if (gwsend){
        gwsend=false;
        sleepcycle=1;
      sleepcycle++;
    @wergeld congratulations πŸ‘
    Thank you all
  • I ordered a proto pack on 15th of April and received it on 30th of April. Pretty fast, I think. πŸ™‚
    Greetings
    @m26872
    @rollercontainer
    @rollercontainer
    I use the 2.0 beta
    @rollercontainer
    @Bobcat
  • @GertSanders
    @Bobcat
  • Hello all
    IΒ΄m Henrik, first post here and sort of beginner at this ( use to do some embedded stuff some 15 years ago and picked it up again recently )
    I just did a shopping list for this project, Version 2.0 if I got it correct πŸ˜ƒ
    straight pins
    Only thing extra needed I think would be some additional cable and a arduino UNO or some other way to program the single chips. But I assume you already have a UNO if you read this πŸ™‚
    //Henrik
    I never ordered any pcbΒ΄s like this before so I donΒ΄t want to get it wrong =D.
    thanks for any help
    @badmannen
    I don't want to ruin them! πŸ™‚
  • Thanks, it worked!
    Thanks in advance,
    hugo
    • R1
    • C1
    • C2
    • C3
    • Atmega socket
    • NRF24 radio
    • 6 pin angled connector
  • C4 in your picture looks correct to me. You could put C4 up on the edge under where the radio would be as well. You have VCC up on the edge. I think the pins adjacent to that are ground too. EDIT: I think I replied before you edited your picture πŸ™‚
  • @siod
  • each one goes around a corner and so one wall is partly between the nodes and the gateway and itΒ΄s not even concrete. I have one node in my basement attached to an arduino nano and I have no range problems...
    edit:
    Node sktech:
    // Sensor Node Schlafzimmer mit HTU21D Temp/Hum Sensor, Fensterkontakte an Interrupt PINS Digital 5&6. Sleep Time 15 Minutwn, wake up wenn Fenster geΓΆffnet/geschlossen wird.
    // Define Node ID
    #define MY_NODE_ID 4
    //Batterysensor
    #define CHILD_ID_BATT 7
    //Kontaktschalter
    //#include <Bounce2.h>
    //Tempsensor
    #include <SparkFunHTU21D.h>
    //tempsensor
    HTU21D myHumidity;
    float lastTemp;
    float lastHum;
    //boolean metric = true;
    //Messages
    //Battery
    // Kontaktschalter
    //TempMessage
    void presentation(){
      sendSketchInfo("KΓΌche Messstation", "2.0", true);
      //Tempsensor
      //Battery
    //Setup
      //Serial.begin(9600);
      Serial.println("Hello!");
      //Batterysensor
       analogReference(INTERNAL1V1);
       analogReference(INTERNAL);
    //Tempsensor
      myHumidity.begin();
      Serial.println("...done!");
    //Starte den Loop
      //Batterysensor
      delay(1000);
       #ifdef DEBUG
       #ifdef DEBUG
       Serial.print(batteryV);
       Serial.println(" V");
       Serial.print(batteryPcnt);
       Serial.println(" %");
      sleep(10);
     //Tempsensor
      if (isnan(temp)) {
        lastTemp = temp;
        Serial.println(temp);
      if (isnan(humd)) {
      } else if (humd != lastHum) {
          lastHum = humd;
          Serial.println(humd);
     Serial.println("Sleep...");
    Gateway sketch:
    // Set MQTT client id
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
      #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
      #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
      #define MY_RF24_CS_PIN 6
    #define MY_PORT 1883
    // Flash leds on rx/tx/err
    // Set blinking period
    // Enable inclusion mode
    #include <Ethernet.h>
    MyConfig.h
     * @file MyConfig.h
    #ifndef MyConfig_h
    #define MyConfig_h
    #include <stdint.h>
    *  Serial and debug options
    // I_DEBUG requests are:
    // V: CPU voltage
    // F: CPU frequency
    // M: free memory
    //#define MY_SPECIAL_DEBUG
    //#define MY_DISABLED_SERIAL
    //#define MY_CORE_ONLY
    #ifdef MY_DISABLED_SERIAL
    #undef MY_DEBUG
     * @def MY_BAUD_RATE
    #ifndef MY_BAUD_RATE
    #define MY_BAUD_RATE 115200
    //#define MY_RADIO_NRF24
    //#define MY_RS485
     * @def MY_NODE_ID
    #ifndef MY_NODE_ID
    #define MY_NODE_ID AUTO
     * @def MY_PARENT_NODE_ID
    #ifndef MY_PARENT_NODE_ID
     * @def MY_OTA_FLASH_SS
    #ifndef MY_OTA_FLASH_SS
    #define MY_OTA_FLASH_SS 8
     * @def MY_OTA_FLASH_JDECID
     * @brief Flash jdecid.
    #ifndef MY_OTA_FLASH_JDECID
    *  Gateway config
     * @def MY_GATEWAY_MAX_CLIENTS
    *  Information LEDs blinking
    // disabled in the gateway.
    // off when blinking
    *  Message Signing Settings
     * @def MY_SIGNING_ATSHA204
    //#define MY_SIGNING_ATSHA204
     * @def MY_SIGNING_SOFT
    //#define MY_SIGNING_SOFT
    *  RS485 Driver Defaults
     * @def MY_RS485_BAUD_RATE
     * @brief The RS485 BAUD rate.
    #ifndef MY_RS485_BAUD_RATE
    *  NRF24L01P Driver Defaults
     * @def MY_DEBUG_VERBOSE_RF24
     * @def MY_RF24_SPI_MAX_SPEED
     * @def MY_RF24_CE_PIN
    		#define MY_RF24_CE_PIN 4
    		#define MY_RF24_CE_PIN 27
    		#define MY_RF24_CE_PIN 9
     * @def MY_RF24_CS_PIN
    		#define MY_RF24_CS_PIN 15
    		#define MY_RF24_CS_PIN 3
    		#define MY_RF24_CS_PIN 10
     * @def MY_RF24_PA_LEVEL
    #ifndef MY_RF24_PA_LEVEL
     * @def MY_RF24_CHANNEL
    #ifndef MY_RF24_CHANNEL
    #define MY_RF24_CHANNEL	76
     * @def MY_RF24_DATARATE
    #ifndef MY_RF24_DATARATE
     * @def MY_RF24_BASE_RADIO_ID
    #ifndef MY_RF24_BASE_RADIO_ID
     * @def MY_RF24_ADDR_WIDTH
     * @brief RF24 address width.
    #ifndef MY_RF24_ADDR_WIDTH
    #define MY_RF24_ADDR_WIDTH 5
     * @def MY_RF24_SANITY_CHECK
    #define MY_RF24_SANITY_CHECK
    //#define MY_SOFTSPI
     * @def MY_SOFT_SPI_SCK_PIN
     * @brief Soft SPI SCK pin.
    #ifndef MY_SOFT_SPI_SCK_PIN
     * @def MY_SOFT_SPI_MISO_PIN
     * @brief Soft SPI MISO pin.
    #ifndef MY_SOFT_SPI_MISO_PIN
     * @def MY_SOFT_SPI_MOSI_PIN
     * @brief Soft SPI MOSI pin.
    #ifndef MY_SOFT_SPI_MOSI_PIN
    *  RFM69 Driver Defaults
     * @def MY_RFM69_FREQUENCY
    #ifndef MY_RFM69_FREQUENCY
     * @def MY_IS_RFM69HW
    //#define MY_IS_RFM69HW
     * @def MY_RFM69HW
    #ifdef MY_IS_RFM69HW
    	#define MY_RFM69HW true
    	#define MY_RFM69HW false
     * @def MY_RFM69_NETWORKID
    #ifndef MY_RFM69_NETWORKID
     * @def MY_RF69_IRQ_PIN
     * @brief RF69 IRQ pin.
    #ifndef MY_RF69_IRQ_PIN
     * @def MY_RF69_SPI_CS
    #ifndef MY_RF69_SPI_CS
     * @def MY_RF69_IRQ_NUM
     * @brief RF69 IRQ pin number.
    #ifndef MY_RF69_IRQ_NUM
    //#define MY_GATEWAY_W5100
    //#define MY_GATEWAY_ENC28J60
    //#define MY_GATEWAY_ESP8266
     * @def MY_PORT
    #ifndef MY_PORT
    #define MY_PORT 5003
    //#define MY_USE_UDP
     * @def MY_IP_RENEWAL_INTERVAL
     * @def MY_MAC_ADDRESS
    #ifndef MY_MAC_ADDRESS
     * @ingroup internals
     * under some form of attack.
     * - LDB (Locked During Boot)
     * @def MY_NODE_LOCK_FEATURE
     * @def MY_NODE_UNLOCK_PIN
    #ifndef MY_NODE_UNLOCK_PIN
    #define MY_NODE_UNLOCK_PIN 14
    /** @}*/ // Node lock group
    #if DOXYGEN
    edit2:
    Now I get this this from the node on my gatewayΒ΄s serial monitor:
    0;255;3;0;9;TSP:MSG:BC
    0;255;3;0;9;TSP:CHKUPL:OK
    0;255;3;0;9;TSP:MSG:GWL OK
    0;255;3;0;9;TSP:SANCHK:OK
    and so on...
  • I have ordered the 2.0 boards, they are on their way to my home πŸ™‚
    I'm plannign to use them as :
    • temperature node
    • door sensor
    Am I right ?
    @carmelo42
  • @m26872 said:
    @carmelo42
    Thanks to you for providing us theses files πŸ™‚
    Ok, my mistake (I juste received my 10 MOhm resistor πŸ˜‰
    Perfect, I just have to wait now for the little yellow packet πŸ˜‰
  • I have received yesterday my little packet from DirtyPCB πŸ™‚
    11 PCBs, so 33 sensors πŸ™‚
  • @m26872 is it possible to send the sketch in the atmega on board ? using an FTDI serial/usb ?
  • 44
  • 90
