My Slim 2AA Battery Node
    like this:
    wooden look cable duct
    @AWI said:
    panelized design
    @AWI Sorry, can't help you with that. All Eagle here 😅
  • @Yveaux aha. I thought that this means multiple (same) design not different. Thanks 🙂
    Thanks @m26872
  • Hi
    1 x PDB board
    1 x ATMega328p 28pin PDIP
    1 x NRF24L01+ radio module
    2 x AA batteries
    Battery connector
    1 x senor of choice
    Extras needed
  • @Soloam
    and a flash module for OTA Sketch Uploads 🙂
    @Matt-Pitts
    avrdude: safemode: Fuses OK
    How can I got it working?
    Thank you
    Thomas
  • @Tom71
    I did two things:
  • @Tom71
  • @Matt-Pitts
  • @Tom71
  • @wergeld
  • Hello, I ordered it too yesterday 🙂 Can't wait to step forward from my breadboards with a lot wires to PCB without wires 😄
  • now I finally set up my first sensor board, and, as expected, I don´t receive any data from it on my gateway :suspect:
    The sketch should run, but it doesn´t. Any ideas how to troubleshoot now?
    @siod
    • Uno fuses and bootloader?
  • I just installed the NRF module at it´s desired place as well as the two capacitors and the resistors as described above. The crystal is only used for uploading the sketch to the Atmega328 chip, described here: https://www.arduino.cc/en/Tutorial/ArduinoToBreadboard
    edit: I´ve re-read your first post and also this thread http://forum.mysensors.org/topic/3018/tutorial-how-to-burn-1mhz-8mhz-bootloader-using-arduino-ide-1-6-5-r5/2 ...
    Do I have to burn the bootloader using 1MHz or 8 MHz? I don´t get why this makes a difference, only that the batteries would drain faster the higher the MHz rate is.
  • @Tom71
  • ok guys, I finally set up my first sensor and it´s communicating well. I´ve attached two reed switch which work fine, only my temp snesor DHT11 doesn´t work. Are there any known issues with this sensor?
    // Define Node ID
    #define MY_NODE_ID 1
    //Kontaktschalter
    //Tempsensor
    #define CHILD_ID_HUM 3
    #define CHILD_ID_TEMP 4
    //Kontaktschalter
    Bounce debouncer1 = Bounce();
    Bounce debouncer2 = Bounce();
    int oldValueReed1=-1;
    int oldValueReed2=-1;
    //tempsensor
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    //Messages
    // Kontaktschalter
    //TempMessage
      //Tempsensor
    // Setup Kontaktschalter 1
      pinMode(BUTTON1_PIN,INPUT);
        // Activate internal pull-up
    // Setup Kontaktschalter 2
      pinMode(BUTTON2_PIN,INPUT);
      debouncer1.interval(5);
      debouncer2.interval(5);
      //Tempsensor
      //Kontakstschalter 1
      debouncer1.update();
      // Get the update value
         // Send in the new value
         oldValueReed1 = valueReed1;
      //Kontakstschalter 2
      debouncer2.update();
         oldValueReed2 = valueReed2;
     //Tempsensor
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
    edit2: I measured 0,02 Ampere consumption, isn´t that too much?
  • @siod
    Greets Eddie
    I just think the next time I encounter problems is, when I try to setup a new sensor node with attached pir motion sensor... I will read the data sheet of it first and look out for power consumption 🙂
  • @m26872 yeah I know you have a topic but actually was concerned with door and window sensors that time and forgot to check it again when I needed it 🙂
    But it can't find the node.
    it doesn't recognise the avr.
    This is the error i get:
    this check.
    avrdude done. Thank you.
    #include <Vcc.h>
    Vcc vcc(VccCorrection);
    DHT dht;
    //Store last values
    float lastTemp = 0 ;
    float lastHum = 0 ;
    float batteryV=0;
    int oldBatteryPcnt = 0;
    boolean lastTripped = false ;
      gw.begin(NULL,node_id,false);
      // get the battery Voltage
       batteryV  = vcc.Read_Volts();
         // Power up radio after sleep
         gwsend=true;
         oldBatteryPcnt = batteryPcnt;
      if (isnan(temp1)) {
        lastTemp = temp1;
        if (!metric) {
        gwsend=true;
          lastHum = humidity;
          gwsend=true;
      if (sleepcycle>gwsendtimout){
        gwsend=true;
    if (gwsend){
        gwsend=false;
        sleepcycle=1;
      sleepcycle++;
    @wergeld congratulations 👍
    Thank you all
  • I ordered a proto pack on 15th of April and received it on 30th of April. Pretty fast, I think. 🙂
    Greetings
    @m26872
    @rollercontainer
    @rollercontainer
    I use the 2.0 beta
    @rollercontainer
    @Bobcat
  • @GertSanders
  • 90
  • 44
  • 29
20
