Irrigation Controller (up to 16 valves with Shift Registers)
  • Dear all,
    i have trying to make the irrigation controller to start all zones in same time and run for the specified. I'm using version for domoticz. Can you please help me out with hint of what i can change in the code ?
    Another thing is that from domoticsz when i start a zone that zone start and previous is stopped but that status is not updated.
    Thank you in advance.
    P.S. I will post some pictures of the hardware build soon.
    @rechin304
    have you tried changing the eight to one?
    #define NUMBER_OF_VALVES 8  // Change this to set your valve count up to 16.
    trigger all your relays with the same output.
  • Well, that's not the point.
    I will have 4 zones that need different type of water needs. For example one zone will be with micro irrigation watering, another one with lawn sprinkler. i do not understand why not to start all zones at once and they will finish according to the time set and not to start one after other. Another thing is why to wait for a zone to finish when you trigger another one.
    To start all valve at once when is trigger all zones i did change:
        if (lastValve != valveNumber)
              gw.send(msg1valve.setSensor(i).set(true), false);
              gw.send(msg1valve.setSensor(i).set(false), false);
        lastValve = valveNumber;
        fastToggleLed();
        if (state != lastState)
          valveNumber = 1;
          updateRelays(ALL_VALVES_OFF);
    with
              gw.send(msg1valve.setSensor(i).set(true), false); //to update domoticz
        fastToggleLed();
          valveNumber = 1;
          updateRelays(0); //all outputs will be on
    I will have 4 zones that need different type of water needs. For example one zone will be with micro irrigation watering, another one with lawn sprinkler. i do not understand why not to start all zones at once and they wi finish according to the time set and not to start one after other. Another thing is why to wait for a zone to finish when you trigger another one.
    I see your point an understand your questions. The purpose of zone cycling is to be able to have enough pressure in each zone independently while also having pressure for household use. Drawing water to every zone (in my case 9) makes the pressure so low, there may not be enough to open the individual pop-up valves, much less fill the washing machine.
    The wait period (which you may set) is there to allow the time for hydraulic actuation of solenoid valves. These types of valves close slowly, and since they are in a manifold, the next valve to start opens faster if the water pressure at the manifold is allowed time to reach normal static pressure.
    The beauty of open source is that you get to do it your way. If you have the pressure to run all your valves at the same time, with enough to spare to take a shower, then you are fortunate!
    So, did you add another 'switch' to your controller to send the all zone command?
    I did this so all relays on is ok now.
    What i miss is to start individual zones more than once at a time :).
  • Pictures of the case project and how is arranged inside. Not yet on the final location, still testing.
    5_1461396298101_IMG_3866.JPG 4_1461396298101_IMG_3865.JPG 3_1461396298101_IMG_3863.JPG 1_1461396298101_IMG_3861.JPG 0_1461396298101_IMG_3860.JPG
  • Hi I just finished building my first project in arduino ( this one) but the code is too large now for the arduino memory its 32748 bytes could you please share with me the older version of the code / libraries to run it in code bender ?
    @David-Mora's question was double-posted. See https://forum.mysensors.org/topic/3921/code-grew-larger-dan-promini/ for the other thread.
    @David-Mora I responded to your comment on the YouTube video but I'll respond here as well just in case people are reading this thread instead.
    This is probably because debug is enabled in the MyConfig.h file. Please comment out this line: #define DEBUG
    Make sure to save the .h file then recompile the Arduino code. It should be around 25,342 bytes.
  • Hi Pete thank you very much, I am using mysensors online editor , not sure if I should edit that code?0_1463751590886_mysensors.jpg
    It's not possible to disable this from codebender. You'll need to install the Arduino IDE onto your computer.
  • @hek in computer I get this:
    C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\I2CIO.cpp:35:26: fatal error: ../Wire/Wire.h: No such file or directory
    #include <../Wire/Wire.h>
    compilation terminated.
    exit status 1
    Error compilación en tarjeta Arduino Pro or Pro Mini.
  • thank you for your help ! I just reinstaled arduino and now I getthis ( I just downloaded the I.5 and copy and paste all libraries in the libraries folder:
    TENCIÓN: Categoría '' en librería UIPEthernet no es válida. Configurando a 'Uncategorized'
    C:\Users\David\Desktop\IrrigationController\IrrigationController.ino:92:31: fatal error: LiquidCrystal_I2C.h: No such file or directory
    exit status 1
    Error compilación en tarjeta Arduino Pro or Pro Mini.0_1463753883896_liquid.jpg
  • @David-Mora quite sad I´ve spent two days now installing and uninstalling arduino and libraries and no luck
    @David-Mora Did you close all instances of Arduino and open again after you added the LiquidCrystal library? It looks like it can't find it.
  • @petewill Yes Pete it doesnt work at all
  • @David-Mora hope this is the right way to post the code finally the only mistake is
    Arduino:1.6.9 (Windows 7), Tarjeta:"Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
    El Sketch usa 30,808 bytes (100%) del espacio de almacenamiento de programa. El máximo es 30,720 bytes.
    Las variables Globales usan 1,329 bytes (64%) de la memoria dinámica, dejando 719 bytes para las variables locales. El máximo es 2,048 bytes.
    processing.app.debug.RunnerException: Programa muy grando: visite http://www.arduino.cc/en/Guide/Troubleshooting#size para ver cómo reducirlo.
    at cc.arduino.Compiler.size(Compiler.java:315)
    at cc.arduino.Compiler.build(Compiler.java:156)
    at processing.app.Sketch.build(Sketch.java:1111)
    at processing.app.Sketch.build(Sketch.java:1081)
    at processing.app.Editor$BuildHandler.run(Editor.java:1988)
    at java.lang.Thread.run(Thread.java:745)
    Tarjeta en COM4 no disponible
    Este reporte podría tener más información con
    "Mostrar salida detallada durante la compilación"
    opción habilitada en Archivo -> Preferencias.
    @David-Mora Looks like you are almost there!
    Did you disable debug? The sketch looks too big. To disable go to the MySensors library and open the MyConfig.h file in Notepad and change this line:
    #define DEBUG
    to
    //#define DEBUG
    Also, it looks like the Arduino IDE programmer isn't finding your Pro Mini. Did you select the correct Board and Port from the Tools menu? I don't have an Arduino next to me so my port isn't available to select but it should look similar to this (except you would choose your Port the Arduino is connected to):
    0_1463835965285_upload-1dd27cba-b4e4-4543-980b-5ac59cc5da52
  • On my controller i use diffren LCD library and i was commented out this line
    //#include <LiquidCrystal_I2C.h>
    and
    //LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
    Sketch uses 27,916 bytes (90%) of program storage space. Maximum is 30,720 bytes.
    Global variables use 1,295 bytes (63%) of dynamic memory, leaving 753 bytes for local variables. Maximum is 2,048 bytes.
  • Is there a way to use domoticz to connect with it and on/off this irrigation system? How to achive this?
    My domoticz is running on raspberry pi 0.
  • @Huczas
    Yes, i've had to manually set the valve runtimes on the ardunio code, because its not possible to pass the runtime variable etc, this is from the one i''ve got built. runtime is 1min, but you can edit as required.
            int variable1 = 60000; // atoi(message.data);// RUN_ALL_ZONES time
            DEBUG_PRINT(i);
            DEBUG_PRINT(F(" = "));
            DEBUG_PRINTLN(variable1);
              allZoneTime[i] = variable1;
              zoneTimeUpdate = true;
            int variable2 = 60000; //atoi(message.data);// RUN_SINGLE_ZONE time
            DEBUG_PRINT(i);
            DEBUG_PRINTLN(variable2);
              valveSoloTime[i] = variable2;
  • Thanks for posting, Mark. I was getting nuts figuring out what was the problem with my controller that was only activating 1sec each phase. I didn't implement it because that problem.
  • @Sergio-Rius no problem, i had plenty of issues trying to get this to work with openhab before i changed controller 🙂
  • So I have been thinking of building one of these. I have just ordered an 8 channel relay board from ebay. http://www.ebay.com/itm/5V-8-Channel-Relay-Board-Module-for-Arduino-Raspberry-Pi-ARM-AVR-DSP-PIC-MUC-/262472832393?hash=item3d1c999589:g:sDEAAOSwnFZXVj2p . I have been trying to sift through this thread and am not seeing what I am looking for. Does this project take into account a pump start relay? If not, I am wondering the best way to handle this. I only have 4 zones in my irrigation setup, so I could certainly use one of the relay channels for that if it is written into the sketch. One thought I had to save extra processing on the sketch in dealing with the shift register would be to put a diode on each output that would funnel to a single point, so whenever any relay is turned on the pump start connection point would go active. I would assume that something has already been calculated in for this, but I din't see anything.
    Thanks for the great project. The Youtube video for this is actually what got me started with MySensors in the first place.
  • I'm going down the diodes route... another channel to trigger it is tricky to deal with unless you use normally off relays and use the code earlier in this thread. I tried to use it but use normally on relays so going for diodes.
    K.I.S.S - keep it simple stupid 😉 no point making it harder for you if you have a workaround on the table 🙂
  • @Mark Jefford I can go that route, I just didn't know if someone already had that factored in to the project already. After thinking about it since I posted this, I could also go the route of using another single digital channel and wire it to one of the relays. Going that route would give me a couple things:
    • One I could turn on the pump independent of a zone because I have a faucet connected to the setup that I can use. Currently I have to turn on a zone to use the faucet.
    • Two, I could poll the state of the pump by checking the state of the one channel.
  • @Mark-Jefford I have the same issue. My system can't pass verifications for clock and valve data when I first plugged in because I don't know how to use this programs (Openhab, domoticz, etc.). Thank you!
  • Is it anybody who has this skecht in 24 hour format, instead of AM, PM?
    @Lars65 Take a look at lines 663-667. I haven't tested this but it should be something similar to this:
              lcd.print(hour() < 10 ? F(" ") : F(""));
              lcd.print(hour());
              lcd.print(minute());
              //lcd.print(isAM() ? F("am") : F("pm"));
  • Does anyone already made a pcb for this? My board keeps loosing it's "bridging" wires. They rot and fall near the solder.
  • @petewill I did try this, and it worked just fine. Thank you!
    @Sergio-Rius Where do you have your controller located? I have had mine running for over a year now and haven't had any issues. Maybe you need to put it into a waterproof case?
    To answer your question though, no, I don't believe anyone has created a PCB for this.
  • I will have mine in the greenhouse. Boxes is made of waxed oak,and it will be 3 modules, each one seald with a sillicone gasket.
    I have some trash wood in the garage, so I thought I could use it to something. 🙂
  • Have anyone compiled it with the 2.0.0?
  • Hello Gentlemen, new to this board as well as new to micro electrics. Started this Irrigation Controller about a two weeks ago, after finding Pete B’s U tube video on this project. Got all the parts and have started building by following Pete B’s video. Have a few part questions and am not very literal with the nomenclature.
    1. This 4.7uF 50V 20% Axial-Lead Electrolytic Capacitor goes on which end or pins on the
    2. Have a FT232RL FTDI USB 3.3V 5.5V to TTL Serial Adapter Module for Mini Port that is different than Pete’s.
      Not sure how to post JPEG's so this is the problem I am having.
      0_1468546122072_7-14-16 Hello Gentlemen help.docx
      The Pins on the ftdi are different than on Pete’s board, in that I cannot find the info for the double GND on the Arduino Pro Mini.
    Any guidance of will be appreciated.
    Respectfully RJ Myers
    @Lars65 No, not yet. It's on the list but it will probably be a little while before I get to it.
    @Ngwpower To add pictures you just have to drag and drop into the edit window. They will automatically upload.
    1. Can you provide more info here? I'm not sure what you're asking.
    2. Both of my FTDI adapters connect into the Pro Mini straight across (the wires don't get crossed when connecting. The key thing is TX on one side should go to RX on the other (and vice versa) then the other 4 wires line up from there. So, you almost have it correct in your picture but the TX and RX are switched. Just start from the DTR and go straight across.
  • Thank You, petewill I adjusted the wiring!
    0_1468603030032_upload-e9f66bab-6c30-42eb-80b2-da87857849e7
    This is the picture for the 4.7 UF that has me baffled of where to insert into the radio. Being color blind really hurts with wiring. And rather ask than fry another project....
    RJ
  • @Ngwpower
    EDIT: My condenser is 10uF / 63v
  • Does this sketch still work with the current Mysensors libraries?
    I lost my working environment so I had to build a new one. I downloaded the MySensors libraries and the sketch throws me an error not finding MySensor.h. The file is not at the libraries folder, but MySensorS.h
    If adding this later (used at the samples) the compilation throws an error:
    W:\....\MySensors_Arduino\arduino-1.6.9\portable\sketchbook\libraries\MySensors/MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
    exit status 1
    Error compilación en tarjeta Arduino Nano.```
    Does make sense for anyone?
  • @Sergio-Rius
    Than You for the clarfication & picture worth thousands of words.
    RJ
    @Sergio-Rius Hmm. Are you using the 2.0 release? If so then it's not compatible yet. It still needs to be upgraded.
  • Got the controller all ready to test like petewill shows in his presentation. Get this error
    MySensors-1.5.4 loaded it onto my board Arduino Pro Mini and get this error -*** F:\Arduino Programs\My sensors downloads\upload-9cc672c5-a5a3-4711-9e38-8f3f7da898a5\upload-9cc672c5-a5a3-4711-9e38-8f3f7da898a5.ino:33:19: fatal error: Relay.h: No such file or directory***
    Can I see this operate on my screen, without all the advanced technology? Found the Domoticz site and no sure if this is for me anymore than the Vera that is being used by petewill. Way out of my knowledge base with this project, just to stubborn to quit or give up.
  • @Ngwpower which sketch are you using?
  • @Lars65 Thanks
    June 2, 2014 12:00 Version 1.0 Arduino Multi-Zone Sprinkler Control
  • @Ngwpower I use this one which is earlier in this thread, an it works with my domoticz.
    MySprinkler for MySensors
    May 31, 2015
    *** Version 2.0
    * LED status indicator
    PARTS LIST:
    * Relays (8 channel)
    * NRF24L01 Radio
    * Arduino (I used a Pro Mini)
    * Capacitors (10uf and .1uf)
    * 3.3v voltage regulator
    * Resistors (270 & 10K)
    * Female Dupont Cables
    * LED
    * Push button
    * Shift Register (SN74HC595)
    * 18 gauge wire (for relay)
    INSTRUCTIONS:
      on the serial monitor.
    #include <Time.h>
    #include <LiquidCrystal.h>
    #define NUMBER_OF_VALVES 4  // Change this to set your valve count up to 16.
    #define RADIO_ID AUTO  // Change this to fix your Radio ID or use Auto
    #define SKETCH_NAME "MySprinkler Domoticz"
    #define SKETCH_VERSION "2.0"
    #define CHILD_ID_SPRINKLER 0
    //#define ACTIVE_LOW // comment out this line if your relays are active high
    #ifdef ACTIVE_LOW
    #define ALL_VALVES_OFF 0xFFFF
    #define ALL_VALVES_OFF 0U
    #ifdef DEBUG_ON
    typedef enum {
    SprinklerStates;
    SprinklerStates lastState;
    byte menuState = 0;
    unsigned long menuTimer;
    byte countDownTime = 10;
    int allZoneTime [NUMBER_OF_VALVES + 1]= {0, 1, 1, 1, 1};     // Insert values in min, 0 = all zone (always 0) this is a 4 chan relay
    int valveSoloTime [NUMBER_OF_VALVES + 1]= {0, 1, 1, 1, 1};   // Insert values in min, 0 = all zone (always 0) this is a 4 chan relay
    int valveNumber;
    int lastValve;
    unsigned long startMillis;
    const int ledPin = 5;
    const int waterButtonPin = 3;
    boolean buttonPushed = false;
    boolean showTime = true;
    boolean clockUpdating = false;
    boolean recentUpdate = true;
    const char *dayOfWeek[] = {
    String valveNickName[17] = {
    time_t lastTimeRun = 0;
    //Setup Shift Register...
    const int latchPin = 8;
    const int clockPin = 4;
    const int dataPin  = 7;
      SERIAL_START(115200);
      pinMode(latchPin, OUTPUT);
      pinMode(clockPin, OUTPUT);
      pinMode(dataPin, OUTPUT);
      pinMode(ledPin, OUTPUT);
      attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
      digitalWrite (ledPin, HIGH);
      //delay(5000);
      lcd.clear();
      lcd.backlight();
      lcd.createChar(0, clock);
      lcd.createChar(1, raindrop);
      delay(500);
      if (gw.loadState(0) == 0xFF); // EEPROM flag
        for (int i = 0; i < 4 ; i++)
          lastTimeRun = lastTimeRun | gw.loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
      gw.begin(getVariables, RADIO_ID, false); // Change 'false' to 'true' to create a Radio repeating node
        gw.present(i, S_LIGHT);
      digitalWrite (ledPin, LOW);
      DEBUG_PRINTLN(F("Ready..."));
      lcd.setCursor(0, 0);
      lcd.setCursor(15, 0);
      lcd.write(byte(0));
      lcd.setCursor(0, 1);
      int clockCounter = 0;
        gw.requestTime(receiveTime);
        delay(1000);
        lcd.print(".");
        clockCounter++;
        if (clockCounter > 16)
          lcd.clear();
          delay(2000);
      lcd.clear();
        lcd.print(F(" Updating  "));
        lcd.print(i);
        boolean flashIcon = false;
        DEBUG_PRINT(i);
        DEBUG_PRINTLN(F(" Data..."));
        while (gw.process() == false)
          flashIcon = !flashIcon;
          gw.request(i, V_VAR1);
          delay(100);
          gw.request(i, V_VAR2);
          delay(100);
          gw.request(i, V_VAR3);
          delay(100);
      lcd.clear();
      updateClock();
      updateDisplay();
      //goGetValveTimes();
      if (buttonPushed)
        menuTimer = millis();
          state = ZONE_SELECT_MENU;
          menuState = 0;
          menuState++;
            menuState = 0;
        slowToggleLED ();
            delay(50);
          lcd.clear();
          lcd.setCursor(0,0);
          lcd.setCursor(0,1);
          delay(2000);
          lastValve = -1;
        fastToggleLed();
          valveNumber = 1;
          startMillis = millis();
          valveNumber++;
            state = CYCLE_COMPLETE;
            lastValve = -1;
            lastTimeRun = now();
            DEBUG_PRINT(F("State = "));
            DEBUG_PRINTLN(state);
        fastToggleLed();
          DEBUG_PRINT(F("Zone: "));
          DEBUG_PRINTLN(valveNumber);
          fastToggleLed();
      else if (state = ZONE_SELECT_MENU)
        displayMenu();
      lastState = state;
    void displayMenu(void)
      static int lastSecond;
        lcd.clear();
        lcd.print(F("Starting"));
        lcd.print(F("."));
        Serial.print(".");
      lastSecond = thisSecond;
        if (menuState == 0)
          valveNumber = 1;
          state = RUN_ALL_ZONES;
          valveNumber = menuState;
          state = RUN_SINGLE_ZONE;
      lastMenuState = menuState;
    void updateRelays(int value)
      digitalWrite(latchPin, LOW);
      digitalWrite(latchPin, HIGH);
        buttonPushed = true;
    void fastToggleLed()
        fastLedTimer = millis ();
    void slowToggleLED ()
        slowLedTimer = millis ();
      boolean zoneTimeUpdate = false;
      if (message.isAck())
        if (message.sensor == i)
          if (message.type == V_LIGHT)
            if (switchState == 0)
              if (i == 0)
                valveNumber = 1;
                valveNumber = i;
                DEBUG_PRINTLN(i);
            DEBUG_PRINT(i);
            DEBUG_PRINT(i);
            if (newMessage.length() == 0)
              DEBUG_PRINTLN(i);
            if (newMessage.length() > 16)
              newMessage.substring(0, 16);
            valveNickName[i] = "";
            DEBUG_PRINT(F("Recieved new name for zone "));
            DEBUG_PRINT(i);
            DEBUG_PRINT(F(" and it is now called: "));
      if (zoneTimeUpdate)
          if (i != 0)
            DEBUG_PRINT(F("Zone "));
            DEBUG_PRINT(i);
            DEBUG_PRINTLN(allZoneTime[i]);
        recentUpdate = false;
    void updateDisplay()
      static boolean displayToggle = false;
        switch (state) {
          case STAND_BY_ALL_OFF:
            fastClear();
            if (displayToggle)
              if (clockUpdating)
                lcd.write(byte(0));
              lcd.print(hourFormat12());
              lcd.print(month());
              lcd.print(day());
              lcd.print(F("/"));
              lcd.print(year() % 100);
              if (clockUpdating)
                lcd.write(byte(0));
              lcd.setCursor(11, 1);
              lcd.print(day(lastTimeRun));
          case RUN_SINGLE_ZONE:
            fastClear();
            if (displayToggle)
              lcd.print(F(" Zone:"));
              lcd.print(valveNumber);
              lcd.print(F(" Active"));
                lcd.print("min");
                lcd.print("sec  ");
          case RUN_ALL_ZONES:
            fastClear();
            if (displayToggle)
              lcd.print(F(" Active "));
              lcd.print("min");
              lcd.print("sec  ");
          case CYCLE_COMPLETE:
            if (displayToggle)
              int totalTimeRan = 0;
              lcd.print(totalTimeRan);
              lcd.print(" Minutes   ");
        lastUpdateTime = millis();
      lastDisplayState = state;
      int lastSecond = second();
      int lastMinute = minute();
      int lastHour = hour();
      setTime(newTime);
        DEBUG_PRINT(hourFormat12());
        DEBUG_PRINT(minute());
        DEBUG_PRINT(month());
        DEBUG_PRINT(F("/"));
        DEBUG_PRINT(day());
        DEBUG_PRINTLN(year());
        showTime = false;
    void fastClear()
    void updateClock()
        lcd.write(byte(0));
        clockUpdating = true;
        lastVeraGetTime = millis();
      if (gw.loadState(0) != 0xFF)
        gw.saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
      for (int i = 1; i < 5; i++)
        gw.saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
    void goGetValveTimes()
      static byte valveIndex = 1;
      if (millis() - valveUpdateTime >= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
        DEBUG_PRINTLN(F("Calling for Valve Data..."));
        lcd.write(byte(1)); //lcd.write(1);
        gw.request(valveIndex, V_VAR1);
        gw.request(valveIndex, V_VAR2);
        gw.request(valveIndex, V_VAR3);
        valveUpdateTime = millis();
        valveIndex++;
        if (valveIndex > NUMBER_OF_VALVES + 1)
          valveIndex = 1;
     Take away the three dots in the bottom.
  • Does anyone have a working portable Arduino IDE for that sketch that would want to share with me? I lost my installation and so many things changed in the built in scripts when you do a new installation. I can compile the project even using 1.4.5 mysensors libraries.
    Thanks a lot.
    @Ngwpower Don't give up! It is a learning curve for sure but totally worth it when you finally get it. Try the irrigation controller sketch from the MySensors 1.5 library example. All the required stuff should be there.
    @Sergio-Rius I'm not sure what you're looking for. Do you need the 1.5 version?
  • Thanks, I envy you young people at 67 just opening the wide world of tech - do't have to do this sitting on a motor grader or Bull Dozer in the high desert. I have tried from 1.3 to 2.0 and thought I saw a flicker of LED in the string of switches, as in your example. Had my 5V on the wrong pin, so back to square one.
    I am having fun attempting to learn the terminology as well as the application!
  • @Ngwpower I am 55 and still learning. I don't know anything about programming. But I spend a lot of time on forums, and reading.
    I would love to learn programming, but I have a slow learning curve now.
    I work as a processengineer,so I guess I can understand some logic.
    But this is really fun stuff.
    Started up a couple of years ago, reading about a home made CNC mill.
    Now I have my own, and it got pretty big can mill surfaces about 1100x800mm.
    And I use it most to mill PCB boards. Hahaha.
  • @petewill
    The problem are the new libraries that come with newer arduino ide. My attempts fail about the wire.h library location or a wrong "positive" variable at liquiddisplay.
    I think it's not compatible with newer libraries.
    I was just thinking the other day I can't wait until I retire so I'll have more time to work on this stuff 😉
    I'm glad you're not giving up. It took me a while to get it too but eventually it all started to make a little sense. Unfortunately you're starting at a harder time because we are all still getting comfortable with 2.0
    @Sergio-Rius Ok, I haven't updated my libraries for a while so hopefully these will work for you. 0_1468884836658_Libraries.zip
  • @petewill
    Thank you very much. Unfortunately those are not the libraries I've problems with. The problem are the built-in ones. The ones that come with the Arduino IDE.
    What version of the IDE are you running? I guess you use the Mysensors 1.4.2 libs.
    I installed Arduino IDE 1.6.9 and using your libraries, those are the errors shown:
    W:\Domotica\MySensors_Arduino\arduino-1.6.9\portable\sketchbook\libraries\LiquidCrystal\I2CIO.cpp:35:26: fatal error: ../Wire/Wire.h: No such file or directory
    Multiple libraries were found for "Wire.h"
     Used: W:\Domotica\MySensors_Arduino\arduino-1.6.9\portable\sketchbook\libraries\Wire
     Not used: W:\Domotica\MySensors_Arduino\arduino-1.6.9\hardware\arduino\avr\libraries\Wire
    Multiple libraries were found for "LiquidCrystal.h"
     Used: W:\Domotica\MySensors_Arduino\arduino-1.6.9\portable\sketchbook\libraries\LiquidCrystal
     Not used: W:\Domotica\MySensors_Arduino\arduino-1.6.9\libraries\LiquidCrystal
    exit status 1
    As you can appreciate, the Wire library is at the ../Wire path, so that error is meaningless.
    I told you that I hate java environments? I still haven't found one that works out of the developer computer without issues. X)
    EDIT: So the problem is that the Wire library has been updated, but we are still using an old version of the LiquidCrystal. This last one expects the .h files been on the root library folder but this has been changed in newer versions. Built-in libraries have their code in "src" subfolder.
    I moved it to parent folder and it compiles, but I don't know what will happen with other dependencies.
    Better would be updating the sketch.
  • @Lars65
    As you also use it from Domoticz, your controller notices the changes in valves? I mean, when the IC is cycling through zones, Domoticz correctly changes states or you must refresh the page for it to show?
  • @Sergio-Rius yes, I can turn them on/off, and the switch is also shifting from on/off.
  • @Sergio-Rius Those can you download from internet. About Liquidcrystal is there a newer version called NewLiquidCrystal, that is also possible to download.
    That one worked for me.
    I deleted all my duplicates, it is anoying when you get those messeges in the arduino ide.
    Also the fatal error you get is ../wire/wire.h.
    seems like you have #include <../Wire/Wire.h
    What happens if you just write #include Wire.h
  • @Lars65
    Thanks. No, I finally made it work.
    I only have to find why my Domoticz don't update the switch status.
    @Sergio-Rius you can change the reference in the display library files. Just remove the path to the wire.h library.
  • @Lars65
    Tried your sketch as well as a few of my own adjustments, still getting
    Yard_Sprinklers_revised_7-20.ino:85:18: fatal error: Time.h: No such file or directory.
    At a loss of where I missed this in the library!
    Rather be riding my scooter! got to get it done!
  • @AWI
    I'll try it.
    @Ngwpower
    Don't drop the towel. Just install the library from the libraries manager.
  • @Sergio-Rius Really confused found these in AVR libraries on my computer. 0_1469044384924_upload-b0e77311-082b-4d33-9473-c59ef1302d37
    Am I looking in the wrong place?
    Thank You for the help!
  • @Ngwpower
    ArduinoIDE Menu->Program->Include Library->Library manager
    0_1469044814353_upload-bdb3d59c-30bb-4c2e-8345-9aa060d3d67e
    I'm currently looking at converting the sketch to v2.0
  • Hello, is there anyone who can explain to me step by step how to deal with these libraries ? I received this error when compiling :
    "C:\Users\witkowski.med\Downloads\IrrigationController\IrrigationController\IrrigationController.ino:85:22: fatal error: MySensor.h: No such file or directory
    exit status 1"
    I have installed the various library and it doesnt help. My IDE version is 1.6.10.
  • @PaweMed
    If you've done a new installation, perhaps you installed Mysensors libraries from the IDE lib manager. In that case you could have installed v2.0.
    In the newer version the library has changed to Mysensors.h, please read the documentation carefully as this is not a minor upgrade:
    https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x
  • @rechin304 - that's a great case/box. Where did you purchase it?
  • I am in the process of building this controller and in reading the comments here where some were asking about a master valve and how to control it. This is the concept that I am going to try with my setup.
    I only have 4 zones to control, so with the 8 channel relay board that I have, I am going to use channel 8 as my pump start relay control. The idea is that when any one channel is on, the diodes will activate the master valve, but keep the signal from back-feeding into another relay channel.
    Hope that helps some people out there.
  • So I figured I would share my progress with my version of this project. The majority of the build was done to the schematic from the build section of the site. The only changes I am making are eliminating the use of Q0 on the shift register, and wiring in diodes like I mentioned in my previous post to control my pump start relay using relay channel 8 when any zone is turned on. I may even add a connection for one more digital line for a pump only startup, but will have to see about the code mods to do that.
    One of my hurdles that I wanted to overcome was what kind of case I would be building this in. I searched on ebay a bit, but couldn't find what I wanted. I was digging through some old stuff one day and found an old composite video A/V switcher that I no longer use.
    A/V switcher front
    A/V switcher back
    Rather than recycling it, I figured, why not up-cycle it. The case was the perfect size for the 8 channel relay board. I even kept the back portion of the original circuit board to re-use the old DC in jack and build my regulator circuit on using an AMS1117 3.3v regulator. The output of the power board is Ground (black), +5V (red) and +3.3V (yellow).
    relay/power boards
    AMS1117 regulator
    I cut a slot in the front of the case to allow access to the relay connections.
    front cutout
    The connections came out just enough to allow access to the screw terminals. You can also see the mouning of the LCD, push button and status LED.
    screw terminals
    main board
    I designed the circuit board so that it could plug directly on top of the 8 channel relay board. Notice the header connector strip between the pro mini and the shift register. There is just enough room above the blue 3 input power connector to attach the FTDI cable for programming the pro mini. The last thing I need to add to the board is the 8 diodes to control the pump start relay which will be channel 8 on the relay board. Currently the code uses outputs Q0 thru Q7 of the shift register to control relays 1 thru 8. I will need to make a slight change to the code to use Q1 thru Q7 as the first 7 relays as it was easier to connect it that way to the header connector. I am eliminating the use of Q0 in the circuit.
    I am having a few issues with compiling the code to upload to the pro mini. It is telling me that it can't find the LiquidCrystal.h file, and I have the library in my arduino library folder. The folder has both the LiquidCrystal.h and LiquidCrystal_I2C.h files, so I am not sure what is up there. I hope to have it figured out soon so I can test the assembly.
    Thanks for reviewing.
  • I am trying to use this controller with Domoticz and I am wondering how to set the valve times. Is there anyone that is using this controller with Domoticz that can help?
  • Hi, in original code is written to work with Vera - this is similar to Domoticz. But I same like you have Domoticz on my RPi0. Some time ago I changed some lines in this code that it is working now with Domoticz.
    May 31, 2015
    *** Version 2.0
    PARTS LIST:
    * NRF24L01 Radio
    * LED
    * Push button
    INSTRUCTIONS:
    #include <Time.h>
    #ifdef ACTIVE_LOW
    #ifdef DEBUG_ON
    typedef enum {
    SprinklerStates;
    byte menuState = 0;
    int allZoneTime [NUMBER_OF_VALVES + 1];
    int valveSoloTime [NUMBER_OF_VALVES + 1];
    int valveNumber;
    int lastValve;
      "All Zones", "Zone 1", "Podlewanie 1", "Podlewanie 2", "Podlewanie 3", "Podlewanie 4", "Zone 6", "Zone 7", "Zone 8", "Zone 9", "Zone 10", "Zone 11", "Zone 12", "Zone 13", "Zone 14", "Zone 15", "Zone 16"
      //delay(5000);
      lcd.clear();
      lcd.backlight();
      delay(500);
      lcd.write(byte(0));
        delay(1000);
        lcd.print(".");
        clockCounter++;
          lcd.clear();
          delay(2000);
      lcd.clear();
        lcd.print(i);
        DEBUG_PRINT(i);
          delay(100);
          delay(100);
          delay(100);
      lcd.clear();
      updateClock();
      updateDisplay();
      goGetValveTimes();
      if (buttonPushed)
          menuState = 0;
          menuState++;
            menuState = 0;
        slowToggleLED ();
            delay(50);
          lcd.clear();
          lcd.setCursor(0,0);
          lcd.setCursor(0,1);
          delay(2000);
          lastValve = -1;
        fastToggleLed();
          valveNumber = 1;
          valveNumber++;
            lastValve = -1;
        fastToggleLed();
          fastToggleLed();
        displayMenu();
      lastState = state;
        lcd.clear();
        lcd.print(F("."));
        Serial.print(".");
        if (menuState == 0)
          valveNumber = 1;
              if (i == 0)
                valveNumber = 1;
                valveNumber = i;
                DEBUG_PRINTLN(i);
            int variable1 = 15; // atoi(message.data);// RUN_ALL_ZONES time
            DEBUG_PRINT(i);
            int variable2 = 10; //atoi(message.data);// RUN_SINGLE_ZONE time
            DEBUG_PRINT(i);
              DEBUG_PRINTLN(i);
            DEBUG_PRINT(i);
      if (zoneTimeUpdate)
          if (i != 0)
            DEBUG_PRINT(i);
        switch (state) {
            fastClear();
            if (displayToggle)
              if (clockUpdating)
                lcd.write(byte(0));
              lcd.print(hour());
              lcd.setCursor(7, 1);
              lcd.print(day() < 10 ? F(" 0") : F(" "));
              lcd.print(day());
              lcd.print(month() < 10 ? F("/0") : F("/"));
              lcd.print(month());
              lcd.print(F("/"));
              if (clockUpdating)
                lcd.write(byte(0));
              lcd.setCursor(10, 1);
              lcd.print(day(lastTimeRun) < 10 ? F(" 0") : F(""));
              lcd.print(month(lastTimeRun) < 10 ? F("/0") : F("/"));
            fastClear();
            if (displayToggle)
                lcd.print("min");
                lcd.print("sec  ");
          case RUN_ALL_ZONES:
            fastClear();
            if (displayToggle)
              lcd.print("min");
              lcd.print("sec  ");
            if (displayToggle)
      setTime(newTime);
        DEBUG_PRINT(day());
        showTime = false;
    void fastClear()
    void updateClock()
        lcd.write(byte(0));
        valveIndex++;
          valveIndex = 1;
    Ok, originally time - how long relay is triggered was downloaded from Vera, I commented out this two lines and specify time there. When you power on arduino - program is trying to connect to Vera and download all data but it obviously fail at it. After a while it's just get date and time from Domoticz. So no names of zones or how long water them. All is hard coded in Arduino.
    Now there is 15 minutes if you trigger all zones and 10 minutes if you choose specific single zone.
    If you want change it you need burn it again on Arduino - so it is not the best solution, but it works 🙂 And it is about 1 week with testing all with laptop and FTDI connected to this controller. After that - you can leave it forever.
    PS, also I changed date and time - it is 24h and DD/MM/YY - so more European friendly 🙂
  • @Huczas One of the main things I wanted with this project was the ability to change the watering times in the automation software using a script. If I have to reprogram the arduino every time I want to change a time it seems pointless . I am looking into a few ideas with this to make it work in Domoticz. If I come up with something, it is most likely going to be a hack workaround.
    I have a post also in the Domoticz forum on a more generalized solution that would cover this situation. Seems though that this is something that the Domoticz team will need to implement. Hopefully I can figure out some kind of workaround to get this going for now.
  • @dbemowsk Hmm if you set 1 hour or more and start watering in Domoticz, then you can manually (or by script) turn off wathering during that time - this is my simple solution to your problem 🙂
    But remember - RPi isn't that reliable for me, it can freeze and then you get swamp instead of nice grass.
  • @Huczas That is all the more reason to have it on the sprinkler controller node. I am trying what I think might be a workable solution. I need to do more testing with it tonight to see if it's going to work, but I think it will. Once I test it I will post my code.
  • @dbemowsk
    While domoticz devs implement a way of better managing variables, perhaps you can implement a text sensor in the sketch and use it like a "times array". You could then populate it from Domoticz and send to the node as it was some text to show on a display.
    I was porting this sketch to mysensors v2 but the changes on this version are so deep that I discarded it.
  • @Sergio-Rius That is the exact thing I am working on. In Domoticz it shows up as devices, but I can live with that for now until they can do something.
  • domoticz i don't think have plans to support this, they took out the ability to use free text variables.
    I plan on doing 1 minute cycles for irrigation and using a moisture sensor to evaluate how much longer the cycles need to run for.
    😞 that's unfortunate. Do they have any other way to store and retrieve variables? Has anyone reached out to them with this need?
    Can you elaborate a little more? What do you mean when you say free text variables?
  • Now that I read it twice... Just see that I writed "text sensor" not text or custom variables. That was what I first thought as a solution when I read about the the custom variable sending was dropped.
    And yes, it's so unfortunate that Domoticz doesn't foresees the need to have "intelligent" nodes. That's so limiting. I would like to build, for example, a garage door opener or a central heating controller. Those things must continue working even if domoticz loses connection. And they must have standalone routines that must be preconfigured without being a programmer.
    What if someone wants to sell an easy to use kit? In my language we say this is "andar con burreras", walking the path with those flaps horses and donkeys wear so they can't see sidewise.
    I agree. That's a big part of automation.
  • I am very close to having this working. The hardest part so far is sorting out all the text devices in Domoticz. I needed to use JSON calls to set the data for each of the text devices, but once they are set I shouldn't have to change them. But being JSON calls I should be able to easily change them with a script if needed.
    So I have the node present S_INFO devices for each of the 3 variables (all zones time, individual zone time, and zone name). I have 4 zones, so that presents 12 new devices to Domoticz. I have set zone names and they display correctly on the irrigation controller, I just need to figure out some of the zone time variables and what devices they are attached to.
    I should have this working in the next couple days and once I get it I will post the code with some notes on configuring it all.
  • Just an idea I was considering for my project, but haven't got around implementing yet so I don't know how viable it is.
    Wouldn't it be possible to use a S_Dimmer type of device instead of an S_Light?
    That way you can set the "dimmer" value in the UI between 0-100, and use this as the minutes in the sketch (I doubt I will water any part of my garden more than 100 mn). Granted it does not allow to have 2 different settings for manual and automatic, but I don't see this as a real limitation (actually, S_Dimmer also has a V_Watt variable, so theoretically you could also use that one).
  • So I think I have this figured out.One of the things that I had to contend with was running out of memory on my 5V Pro Mini 328. To fix this I had to comment out and shorten some of the DEBUG PRINTLN statements which didn't impede functionality.
    The key to making this work is presenting 3 new sensors for each zone. The sensors are S_INFO sensors that use V_TEXT variables. Because these are new to 2.0 and our sketch is for 1.5, we need to define them to be able to use them.
    const int V_TEXT = 47;
    // new S_INFO sensor type (development 20150905)
    const int S_INFO = 36 ;
    Here is how I present the new sensors. The S_LIGHT sensor is the valve control. The next 3 S_INFO sensors are the replacements for V_VAR1 - V_VAR3. They are defined as follows;
    All zones time
    Individual zone time
    Zone display name
        gw.present((i * 4), S_LIGHT);
        gw.present(((i * 4) + 1), S_INFO);
        gw.present(((i * 4) + 2), S_INFO);
        gw.present(((i * 4) + 3), S_INFO);
    The hardest part in this was figuring out the V_TEXT values on the Domoticz side. What I found was the easiest was to set each to a numeric value from 1 to whatever number of sensors are presented. To set the values type this into the address bar of your web browser:
    http://{your_domoticz_ip_address}:8080/json.htm?type=command&param=udevice&idx=41&nvalue=0&svalue=1
    Replace the 41 in idx=41 wit the idx value in the setup>devices list, and change the 1 in svalue=1 to the number next number. Once those are set, start all zones using the button on the controller. You will see one of the numbers on the display. Match that number with it's index (idx) value and re-run the above json command changing the idx to the matched index, and the svalue to the name of the zone:
    http://{your_domoticz_ip_address}:8080/json.htm?type=command&param=udevice&idx=36&nvalue=0&svalue=Run all zones
    Repeat this for all zone names. Then repeat the process by letting a zone start and matching a zone time to it's index. That is the reason for setting each V_TEXT variable to a unique number. When testing each zone on an "All Zones" run, it is best to find the first zone and set the time to 1 minute. Then run "All Zones" again and let the first zone run its 1 minute to hit the zone 2 time. Continue this through all zones changing the Domoticz names and values for each to identify them all.
    I have not been able to fully test this as my controller is set up slightly different than the one presented. I have done the steps above and have all of that set, but my zone 1 is my master valve, and zones 2 through 5 are my zones 1 through 4. Because of this I need to figure out the changes in my sketch. If someone can test this as I have it so far, that would help. Once I know this works, I will make my needed changes.
    Here is the complete modified sketch:
    May 31, 2015
    *** Version 2.0
    PARTS LIST:
    * NRF24L01 Radio
    * LED
    * Push button
    INSTRUCTIONS:
    #include <Time.h>
    #define CHILD_ID_SPRINKLER_ALL 1
    #define CHILD_ID_SPRINKLER_IND 2
    #ifdef ACTIVE_LOW
    #ifdef DEBUG_ON
    // new V_TEXT variable type (development 20150905)
    typedef enum {
    SprinklerStates;
    byte menuState = 0;
    int valveNumber;
    int lastValve;
    LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
    MyMessage var1valve(CHILD_ID_SPRINKLER_ALL, V_TEXT);
    MyMessage var2valve(CHILD_ID_SPRINKLER_IND, V_TEXT);
    bool receivedInitialValue = false;
      //delay(5000);
      lcd.clear();
      lcd.backlight();
      //DEBUG_PRINTLN(F("Checking EEPROM for stored date:"));
      delay(500);
        //``DEBUG_PRINTLN(F("Retreiving last run time from EEPROM..."));
      DEBUG_PRINTLN(F("Presentation Complete"));
      lcd.write(byte(0));
        DEBUG_PRINTLN(F("Requesting time:"));
        delay(1000);
        lcd.print(".");
        clockCounter++;
          DEBUG_PRINTLN(F("Failed synchronization!"));
          lcd.clear();
          delay(2000);
      lcd.clear();
        lcd.print(i);
        DEBUG_PRINT(i);
          gw.request((i * 4) + 1, V_TEXT);
          delay(100);
          gw.request((i * 4) + 2, V_TEXT);
          delay(100);
          gw.request((i * 4) + 3, V_TEXT);
          delay(100);
      lcd.clear();
      updateClock();
      updateDisplay();
      goGetValveTimes();
      if (buttonPushed)
          menuState = 0;
          menuState++;
            menuState = 0;
        slowToggleLED ();
          DEBUG_PRINTLN(F("State all Zones off"));
            delay(50);
            gw.send(msg1valve.setSensor(i * 4).set(false), false);
          lcd.clear();
          lcd.setCursor(0,0);
          lcd.setCursor(0,1);
          delay(2000);
          lastValve = -1;
              gw.send(msg1valve.setSensor(i * 4).set(true), false);
        fastToggleLed();
          valveNumber = 1;
          valveNumber++;
            lastValve = -1;
        fastToggleLed();
          fastToggleLed();
        displayMenu();
      lastState = state;
        lcd.clear();
        lcd.print(F("."));
        Serial.print(".");
        if (menuState == 0)
          valveNumber = 1;
        if (message.sensor == (i * 4))
              if (i == 0)
                valveNumber = 1;
                valveNumber = i;
                DEBUG_PRINTLN(i);
        if (message.sensor == ((i * 4) + 1))
          if (message.type == V_TEXT)
            DEBUG_PRINT(i);
        if (message.sensor == ((i * 4) + 2))
            DEBUG_PRINT(i);
        if (message.sensor == ((i * 4) + 3))
              DEBUG_PRINT(F("No Name for "));
              DEBUG_PRINTLN(i);
            DEBUG_PRINT(F("Recieved name "));
            DEBUG_PRINT(i);
            DEBUG_PRINT(F(" called: "));
          receivedInitialValue = true;
      if (zoneTimeUpdate)
        DEBUG_PRINTLN(F("New Zone Times..."));
          if (i != 0)
            DEBUG_PRINT(i);
        switch (state) {
            fastClear();
            if (displayToggle)
              if (clockUpdating)
                lcd.write(byte(0));
              lcd.print(month());
              lcd.print(day());
              lcd.print(F("/"));
              if (clockUpdating)
                lcd.write(byte(0));
            fastClear();
            if (displayToggle)
                lcd.print("min");
                lcd.print("sec  ");
          case RUN_ALL_ZONES:
            fastClear();
            if (displayToggle)
              lcd.print("min");
              lcd.print("sec  ");
            if (displayToggle)
              for (int i = 1; i <= NUMBER_OF_VALVES + 1; i++)
      setTime(newTime);
        DEBUG_PRINT(day());
        showTime = false;
    void fastClear()
    void updateClock()
        lcd.write(byte(0));
        gw.request((valveIndex * 4) + 1, V_TEXT);
        gw.request((valveIndex * 4) + 2, V_TEXT);
        gw.request((valveIndex * 4) + 3, V_TEXT);
        valveIndex++;
          valveIndex = 1;
    Curious to see how this works for people.
  • @dbemowsk
    Just a hint on memory: Why creating three sensors for each valve? Why not creating a unique sensor with array contents for all valves? 😉
  • @Sergio-Rius I hadn't thought of the array. I've never dealt with a S_INFO/V_TEXT as an array. Do you have an example of this? It does sound like an easier approach.
    @dbemowsk I would suggest to take @PierreSt advice and go for a V_PERCENTAGE device. From my perspective you wil mostly deal with "a scale of fixed values' for more or less intensive irrigation. As you are working with Domoticz you can use a "Selector switch" to select the diiferent options.
    I am currently using this for selecting patterns in my Wall mounted mood light and it works like a charm.
    If anyone is intrested I will publish a "how-to" (in the Domoticz section)
  • @AWI
    While that would be a logical approach, the the dimmer control in Domoticz it's complex and sometimes requires more than one click to activate. In other interfaces (Android, etc) that could be worse, and should change in the future.
    @dbemowsk
    I did not use S_INFO in my sketch, but I managed to use an array for valves configuration and may be pretty interesting if we mix the two of them.
    Note that this is a version 2.0 sketch, and that I removed all the remote management stuff. Due to the flow change in v2, the display menu was so difficult to do.
    Perhaps you can adapt it back and get back to the original idea.
    ///// Mysensors options /////
    #define MY_NODE_ID 1 // Having some problems with auto Id on my installation.
    #include <Time.h>
    #define SKETCH_NAME "GardenController"
    #define SKETCH_VERSION "1.0"
    /////// Display output options /////
    //#define USING_DISPLAY
    //boolean showTime = true;
    //#ifdef USING_DISPLAY
    //	LiquidCrystal_I2C lcd(0x27, 16, 2);
    //	//#define LCDINIT (DEBUG_PRINTLN("Setting up LCD..."); lcd.init(); lcd.clear(); lcd.backlight();)
    //#else
    //	#define LCDINIT
    //#endif
    unsigned char bitStatus;
    #ifdef ACTIVE_LOW
    	#define ALL_ELEMENTS_OFF 0xFFFF
    	#define myShiftOut (shiftOut(dataPin, clockPin, MSBFIRST, ~bitStatus))
    	#define ALL_ELEMENTS_OFF 0U
    	#define myShiftOut (shiftOut(dataPin, clockPin, MSBFIRST, bitStatus))
    boolean clockSetup = false;
    ///// Serial interface options /////
    #ifdef DEBUG_ON
    ///// Control elements /////
    class myElement {
    public:
    	myElement(char* name, int runningTime, unsigned long Started);
    	char* Name;
    	int RunningTime;
    	unsigned long Started;
    myElement::myElement(char* Name, int RunningTime, unsigned long Started = 0)
    	this->Name = Name;
    	this->RunningTime = RunningTime;
    	this->Started = Started;
    myElement myElements[] =
    	{ "Irrigation Zone 1", 1 },
    	{ "Irrigation Zone 2", 1 },
    	{ "Pond Pump", 0 },
    	{ "Pond Lights", 0 },
    	{ "Front way lights", 0 },
    	{ "Acc1", 0 },
    	{ "Acc2", 0 },
    	{ "Acc3", 0 },
    int NUMBER_OF_ELEMENTS = sizeof(myElements) / sizeof(*myElements);
    MyMessage msg1valve(0, V_STATUS);
    	SERIAL_START(9600);
    	DEBUG_PRINTLN("Initialising...");
    	//LCDINIT;
    	//DEBUG_PRINTLN("Setting up LCD..."); lcd.init(); lcd.clear(); lcd.backlight();
    	//DEBUG_PRINTLN("Requesting time from Gateway");
    	//requestTime();
    	//DEBUG_PRINTLN("Ready!");
    	for (int i = 0; i < NUMBER_OF_ELEMENTS; i++) {
    		myElement Elm = myElements[i];
    		present(i, S_BINARY, Elm.Name);
    		wait(50);
    		DEBUG_PRINT("Presented element (id/name/preset time): "); DEBUG_PRINT(i); DEBUG_PRINT("/");  DEBUG_PRINT(Elm.Name); DEBUG_PRINT("/"); DEBUG_PRINTLN(Elm.RunningTime);
    		request(i, V_STATUS);
    		wait(50);
    	//Check if there are some timer lights to shutdown
    		//DEBUG_PRINT(myElements[i].Name); DEBUG_PRINT("/"); DEBUG_PRINT(myElements[i].RunningTime); DEBUG_PRINT("/"); DEBUG_PRINTLN(myElements[i].Started);
    		if (myElements[i].Started > 0) {
    			DEBUG_PRINT("Running element ("); DEBUG_PRINT(i); DEBUG_PRINTLN(")");
    			if ((millis() - myElements[i].Started) >= (myElements[i].RunningTime * 60000)){
    				DEBUG_PRINT("ELEMENT TIMEOUT! ("); DEBUG_PRINT(i); DEBUG_PRINTLN(")");
    				updateRelay(i, 0);
    		wait(500);
    //void receiveTime(time_t newTime)
    //	DEBUG_PRINTLN("Received time value, updating...");
    //	int lastSecond = second();
    //	int lastMinute = minute();
    //	int lastHour = hour();
    //	setTime(newTime);
    //	if (((second() != lastSecond) || (minute() != lastMinute) || (hour() != lastHour)) )|| showTime)
    //		DEBUG_PRINT("Node's time currently set to: ");
    //		DEBUG_PRINT(day());
    //		DEBUG_PRINT("/");
    //		DEBUG_PRINT(month());
    //		DEBUG_PRINT(F("/"));
    //		DEBUG_PRINT(year());
    //		DEBUG_PRINT(hour() < 10 ? F(" 0") : F(" "));
    //		DEBUG_PRINT(hour());
    //		DEBUG_PRINT(minute() < 10 ? F(":0") : F(":"));
    //		DEBUG_PRINTLN(minute());
    //		showTime = false;
    //	else
    //		DEBUG_PRINTLN("Node's time did NOT need adjustment greater than 1 second.");
    //	clockSetup = true;
    	switch (message.type)
    	case V_STATUS:
    		DEBUG_PRINT("Received: Position "); DEBUG_PRINT(message.sensor); DEBUG_PRINT(" Value "); DEBUG_PRINTLN(message.getBool());
    		//DEBUG_PRINT("Before status: "); DEBUG_PRINTLN(bitStatus);
    		updateRelay(message.sensor, message.getBool());
    	default:
    //void RESET() {
    //	digitalWrite(latchPin, LOW);
    //	shiftOut(dataPin, clockPin, MSBFIRST, ALL_ELEMENTS_OFF);
    //	digitalWrite(latchPin, HIGH);
    void updateRelay(int whichPin, byte whichState) {
    	if (myElements[whichPin].RunningTime > 0){
    		if (whichState == 1){
    			myElements[whichPin].Started = millis();
    			DEBUG_PRINT("Stored start time ("); DEBUG_PRINT(myElements[whichPin].Started); DEBUG_PRINT(") for "); DEBUG_PRINTLN(whichPin);
    			myElements[whichPin].Started = 0;
    			DEBUG_PRINT("Reset start time for "); DEBUG_PRINTLN(whichPin);
    	bitWrite(bitStatus, whichPin, whichState);
    	//DEBUG_PRINT("updateRelay: bitStatus -> "); DEBUG_PRINTLN(bitStatus);
    	myShiftOut;
    As you may noticed, it can control up to 32 valves and you only have to populate the array. It'll be nice to request this data to domoticz and after a timer or received it, store in eeprom and populate the sub-nodes. Then in subsequent starts, boot with the info on eeprom and ask for changes.
    The sensor shuts itself the "valves" and if time is set to zero runs them without limit.
    That's not my irrigation controller, but my whole garden controller. (thaks the op for the idea)
  • @Sergio-Rius Just a few things. I am assuming that the array you are talking about is "myElement". I am fairly new to MySensors and Domoticz. How do you use this array with Domoticz to send the zone times to the controller? It looks like you are setting the valve names and times within the sketch as if they are permanently set on the controller. I am a little confused about the presentation of the S_BINARY, Elm.Name:
    My understanding is that S_BINARY is just for on/off which I am guessing is the on/off control for the zone. What does the Elm.Name do though? Do yoy have a way to set valve times from within Domoticz?
    I also noticed that you removed the time sync with the receiveTime() function. This tells me that you are not sending the current time to the controller. Any reason for this?
    As for my sketch, I am thinking of another route to go with this where I can send the valve times and names using a single S_INFO sensor. I plan to use some of the information from this forum post: Splitting a string. The idea is to use a separator character such as ":" or "|" to create a pseudo array using a single string. Doing this will eliminate 2 S_INFO sensors for each zone, and also make it easier to configure. I am going to work on this tonight and see where I get with it.
  • @AWI I am still not a big fan of the V_PERCENTAGE route. I like the flexibility of the all zones time as well as the individual zone times. I suppose from a scripting sense it wouldn't matter too much, but I still think it's easier and more flexible the other way.
  • OK, so I've modified my sketch making the change to only use a single S_INFO sensor. The idea is to send a pipe delimited string of all the config data for a zone in the following format:
    {all zone time}|{individual time}|{zone name}
    45|60|Garden/pond
    So all zones call uses 45 minutes, individual zone time is 60 minutes, and the zone name is "Garden/pond"
    Well without further adieu, here is the sketch.
    May 31, 2015
    *** Version 2.0
    PARTS LIST:
    * NRF24L01 Radio
    * LED
    * Push button
    INSTRUCTIONS:
    #include <Time.h>
    #ifdef ACTIVE_LOW
    #ifdef DEBUG_ON
    typedef enum {
    SprinklerStates;
    byte menuState = 0;
    int valveNumber;
    int lastValve;
      updateRelays(ALL_VALVES_OFF);
      //delay(5000);
      lcd.clear();
      lcd.backlight();
      delay(500);
        gw.present((i * 2), S_LIGHT);
        gw.present(((i * 2) + 1), S_INFO);
        delay(100);
      lcd.write(byte(0));
        delay(1000);
        lcd.print(".");
        clockCounter++;
          lcd.clear();
          delay(2000);
      lcd.clear();
        lcd.print(i);
        DEBUG_PRINT(i);
          gw.request((i * 2) + 1, V_TEXT);
          delay(100);
      lcd.clear();
      updateClock();
      updateDisplay();
      goGetValveTimes();
      if (buttonPushed)
          menuState = 0;
          menuState++;
            menuState = 0;
        slowToggleLED ();
        if (state != lastState)
            delay(50);
            gw.send(msg1valve.setSensor(i * 2).set(false), false);
          lcd.clear();
          lcd.setCursor(0,0);
          lcd.setCursor(0,1);
          delay(2000);
          lastValve = -1;
        if (lastValve != valveNumber)
              gw.send(msg1valve.setSensor(i * 2).set(true), false);
        lastValve = valveNumber;
        fastToggleLed();
          valveNumber = 1;
          valveNumber++;
            lastValve = -1;
        fastToggleLed();
          fastToggleLed();
        displayMenu();
      lastState = state;
        lcd.clear();
        lcd.print(F("."));
        Serial.print(".");
        if (menuState == 0)
          valveNumber = 1;
    //void getVariables(const MyMessage &message)
        if (message.sensor == (i * 2))
              if (i == 0)
                valveNumber = 1;
                valveNumber = i;
                DEBUG_PRINTLN(i);
        if (message.sensor == ((i * 2) + 1))
            String valveMessage = String(message.data);
            char* valveData = &valveMessage[0]; //.c_str();
            DEBUG_PRINT(F("Recieved valve data:"));
            DEBUG_PRINT(i);
            DEBUG_PRINTLN(valveMessage);
            char* var = strtok(valveData, "|");
            int variable1 = atoi(var); // RUN_ALL_ZONES time
            var = strtok(NULL, "|");
            int variable2 = atoi(var);// RUN_SINGLE_ZONE time
            String newMessage = String(var);
              DEBUG_PRINTLN(i);
            DEBUG_PRINT(i);
      if (zoneTimeUpdate)
          if (i != 0)
            DEBUG_PRINT(i);
        switch (state) {
            fastClear();
            if (displayToggle)
              if (clockUpdating)
                lcd.write(byte(0));
              lcd.print(month());
              lcd.print(day());
              lcd.print(F("/"));
              if (clockUpdating)
                lcd.write(byte(0));
            fastClear();
            if (displayToggle)
                lcd.print("min");
                lcd.print("sec  ");
          case RUN_ALL_ZONES:
            fastClear();
            if (displayToggle)
              lcd.print("min");
              lcd.print("sec  ");
            if (displayToggle)
      setTime(newTime);
        DEBUG_PRINT(day());
        showTime = false;
    void fastClear()
    void updateClock()
        lcd.write(byte(0));
        valveIndex++;
          valveIndex = 1;
    Can you elaborate on this? In my setup the Dimmer is as reliable as any other control. Main limitation is that the standard dimmer can only assume 16 "states"/ values.
    While introducing the V_TEXT/S_INFO type we were aware that this would be a would open up the route to many "non standard" applications. I personally try to keep everything in the standard types or to have a standard defined for it. (like in the V_ORIENTATION suggestion in the Orientation actuator ).
    Sometimes the choice is limited as with the V_PERCENTAGE/ DIMMER implementation in Domoticz as there is no "generic" type to represent just a value (int/float) or date/time (y/m/d hⓂs).
    Yes, that was the part where we supposedly had to join our sketches. Just getting all the array contents from an S_INFO. Perhaps using some Json to array conversion. Should be some library for conversions there.
    Elm.Name assigns a name to the valve. And presents to Domoticz. Still doesn't exists a way to get from domoticz.
    Again, still doesn't....
    Yes. as I said it was so complicated for me to integrate the "stand-alone functions" that use loop cycles for running the menu. I planned to make dedicated functions for it, but didn't have time.
    And why not using this approach on a single S_INFO, that could feed the array I have in my sketch?
    The dimmer is reliable. I was talking of interface widget being complex. In Domoticz, to activate one zone you would have to first click, and when the popup appears, click again on the blue (sphere?) for it to start.
    In Imperihome, you would have up to 32 rgb dial indicators on your page and still don't get the current set value, and when you set it on, most of times it doesn't respect the current intensity value.
    And that doesn't solve the double timing setup nor the naming.
    I always like to apply the KISS rule to my developments and avoid to depend on other systems. Specially if they don't walk in the same direction. Imagine that in the future the dimmer system changes, for example, into a hue pallete.
    And it's true that mysensors and domoticz is lacking a sensors configuration system.
    @Sergio-Rius Think I understand 😉 and keep my systems as autonomous and simple as possible.
    The route with S_INFO/V_TEXT won't bring you any luck, regarding the customization to be done in Domoticz to get values in V_TEXT (LUA / JSON).
    btw. Like your sketch 👍
  • @AWI
    You'r right, that's not the best route. But until we have sensors configuration routines... 😉
    Will we have? 😬
    @Sergio-Rius Don't expect too much in either MySensors/ Domoticz unless you know of a "industry standard" approach which can be implemented with reasonable efforts by the community..
